Linux BSP User Guide for AOM-3821 Series-Debian12
Contents
- 1Linux BSP Version
- 2Build Environment on Host
- 3Run Docker example
- 4Getting Linux Source Code
- 5Build Choose Project 5.1Build Choose Project A0M-3821
- 6Build U-boot
- 7Build Kernel
- 8Build Recovery
- 9Build Debian 12.x
- 10Push all image to rockdev folder
- 11Make update.img
Linux BSP Version
Debian 12.x
Kernel 6.1.75
Currently, we adopt Docker as build environment.
You can get the latest version of advrisc/u20.04-rklbv1 Docker image for developing Rockchip RK3588 projects.
Docker command:
$ sudo apt-get update
$ sudo apt-get install -y qemu-user-static
$ sudo apt-get install -y live-build
$ sudo docker pull advrisc/u20.04-rklbv1
Run Docker example
Step1 Run docker container (example)
$ sudo docker run -it --name rk3588_linux_risc -v /home/bsp/myLinux:/home/adv/BSP:rw --privileged advrisc/u20.04-rklbv1:latest /bin/bash
Step2 In container, change the user. (example)
$ adv@7cc0fa834366:~$ sudo chown adv:adv -R BSP
Debian 12.x
Please contact PM to get BSP.
If you have BSP tarball (eg. ASRA501A2EG90AIM38DBV110051_2025-03-04.bsp.tgz), then you have to copy it into container.
Follow the steps below:
1.Exit container and back to local machine
$ exit
2.Copy BSP tarball to ${WORKSPACE} , and change owner
$ cp ASRA501A2EG90AIM38DBV110051_2025-03-04.bsp.tgz ${WORKSPACE}
$ sudo chown adv:adv ${WORKSPACE}/ASRA501A2EG90AIM38DBV110051_2025-03-04.bsp.tgz
3.Back to container
$ docker start ${CONTAINER_NAME}
$ docker attach ${CONTAINER_NAME}
4.Unpack BSP tarball
$ tar zxvf ASRA501A2EG90AIM38DBV110051_2025-03-04.bsp.tgz
CAUTION
BSP tarball is for fast developping uboot and kernel .
And it ONLY supports to build uboot and kernel .
$ export TOP=`pwd`
$ cd $TOP
$ ./build.sh adv_rk3588_aom3821a1_defconfig
Build U-boot
$ cd $TOP
$ ./build.sh uboot
Build Kernel
$ cd $TOP
$ ./build.sh kernel
Build Recovery
$ cd $TOP
$ rm buildroot/output/rockchip_rk3588_recovery -rf
$ ./build.sh recovery
CAUTION
BSP tarball DONOT support to build recovery .
Build Debian 12.x
$ cd $TOP
$ sudo dpkg -i debian/ubuntu-build-service/packages/*
$ sudo apt-get install -f -y
$ ./build.sh debian
CAUTION
BSP tarball DONOT support to build debian .
SDK V110 and after:
$ cd $TOP
$ ./build.sh firmware
The common image files are listed below:
# boot.img
# misc.img
# oem.img
# recovery.img
# rootfs.img
# uboot.img
# userdata.img
# MiniLoaderAll.bin
# parameter.txt
Make update.img
$ cd $TOP
$ sudo apt-get install bsdmainutils
$ ./build.sh updateimg
You can get update.img in rockdev/
CAUTION
BSP tarball DONOT support to build updateimg .
