RSB-3710_Android_User_Guide
產品介紹(Product introduction )
產品特性(Product Features)
  • Rockchip Arm® Cortex®-A72 RK3399 up to 1.8 GHz
  • Onboard LPDDR4 2GB
  • HDMI 1920x1080 at 60Hz, 1 Dual Channel 24 bit LVDS
  • 1 2-wire RS-232, 1 USB3.0, 1 USB2.0, 1 Micro SD, 1 Mic. in / Line out
  • 1 mini-PCIe for 3G/4G
  • UIO expansion 3 USB2.0, 8 GPIO, 2 RS232 2/2-wires UART, 1 I2C
  • Supports Debian9/10 and Android7.1/10.0
  • Support I/O Expansions by UIO40-Express I/O boards, please refer to page #3 for more information
產品官網連結(Product Features)
RSB-3710
硬件接口說明(Hardware interface introduction)
接口布局和尺寸(Layout and Sizes)
接口布局圖 Board Dimension Layout
RTENOTITLE
RTENOTITLE
RTENOTITLE
Connector List
RTENOTITLE
BATRTC Battery Connector
HDMIHDMI1 CONN
BLLVDS BKL CONN
LVDSLVDS CONN
LAN1LAN
LAN2LAN
MINIPCIEMINI PCIE 52P
SIMNano SIM Card
AUDIOAudio PIN Header
USB1USB CONN
COM2/DebugCOM2
SDSD Slot
OTGUSB
BTNPower BTN pin header
RSTReset Button
DCIN112V DC Jack
LEDLED
CN11UIO1
CN12UIO2
接口引脚定義 (Pin definitions)
  • [BAT](./RSB-3710_Android_User_Guide_wiki_data/BAT "BAT".md)
  • [HDMI1](./RSB-3710_Android_User_Guide_wiki_data/HDMI1 "HDMI1".md)
  • [BL](./RSB-3710_Android_User_Guide_wiki_data/BL "BL".md)
  • [LVDS](./RSB-3710_Android_User_Guide_wiki_data/LVDS "LVDS".md)
  • [LAN1, LAN2](./RSB-3710_Android_User_Guide_wiki_data/LAN1,_LAN2 "LAN1, LAN2".md)
  • [MINIPCIE](./RSB-3710_Android_User_Guide_wiki_data/MINIPCIE "MINIPCIE".md)
  • [SIM](./RSB-3710_Android_User_Guide_wiki_data/SIM "SIM".md)
  • [Audio](./RSB-3710_Android_User_Guide_wiki_data/Audio "Audio".md)
  • [USB1](./RSB-3710_Android_User_Guide_wiki_data/USB1 "USB1".md)
  • [COM2/Debug](./RSB-3710_Android_User_Guide_wiki_data/COM2/Debug "COM2/Debug".md)
  • [SD](./RSB-3710_Android_User_Guide_wiki_data/SD "SD".md)
  • [OTG](./RSB-3710_Android_User_Guide_wiki_data/OTG "OTG".md)
  • [BTN](./RSB-3710_Android_User_Guide_wiki_data/BTN "BTN".md)
  • [RST](./RSB-3710_Android_User_Guide_wiki_data/RST "RST".md)
  • [DCIN1](./RSB-3710_Android_User_Guide_wiki_data/DCIN1 "DCIN1".md)
  • [LED](./RSB-3710_Android_User_Guide_wiki_data/LED "LED".md)
  • [CN11](./RSB-3710_Android_User_Guide_wiki_data/CN11 "CN11".md)
  • [CN12](./RSB-3710_Android_User_Guide_wiki_data/CN12 "CN12".md)
  • [RSB-3710_Jumper List](./RSB-3710_Android_User_Guide_wiki_data/RSB-3710_Jumper_List "RSB-3710 Jumper List".md)
**机械尺寸  (**Mechanical Characteristics)
RTENOTITLE
快速入门 (Quick Start)
系统下载 ( OS Download)
Note:  LIV=Yocto Linux, UIV=Ubuntu, DIV=Debian, AIV=Android
             LBV=BSP, LIV=Image
PlatformProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagComment
RK3399RSB-3710V11932021/04/20RTMNABaidu  Password:a887 DropboxRK3399_N7_AIV1193.xml
  • Alpha:  Basic I/O function bring up by RD;
  • Beta:  Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
  • GA:  Beta version by QE verification;
  • RTM:  Beta version by SI/Power/QE verification and pre-loaded;
Android 燒錄方法 (Flash Android image into eMMC Method)
1. Prepare a mirco USB Cable and Debug Cable
mirco USB
RTENOTITLE
Debug Cable
RTENOTITLE
  1. Plug the OTG Cable into RSB-3720
RTENOTITLE
Connect Debug cable
RTENOTITLE
2. 設定終端機(Set Debug Terminal)
Debug 串口調試 (Debug port Setting)
 Tera Term setting
   Baud Rate:115200
Data :8
Parity :none
Stop :1
Flow Control:none
Tera Term Tool
RTENOTITLE
RTENOTITLE
Note:
Check the Sriel port in Device Manager :
if you can not identify the Serial device , please check your serial driver.
3.Open the flash tool
RTENOTITLE
  1. Turn on the power
  2. When you see the debug message in Terminal , then press "Ctrl+C" , then log into Uboot stage
RTENOTITLE
  1. In Uboot , please type  "loader"  , then the device will transfer to "Flash mode" , Android tool also will show  "Found One MASKROM Device "
RTENOTITLE
  1. In RKDevTool pressed  "Run"  , and it will flash image into eMMC.
RTENOTITLE
  1. The flash process  was finishded
RTENOTITLE
  1. Reboot the device , and connect with HDMI , it will show the Android Desktop.
RTENOTITLE
Debian 燒錄方法 ( Flash Debian image into eMMC Method)
1. Prepare a  mirco USB cable and Debug Cable
mirco USB
RTENOTITLE
Debug Cable
RTENOTITLE
  1. plugmirco USB cable into the  RSB-3710 OTG port.
RTENOTITLE
Connect  Debug cable
RTENOTITLE
3. 設定終端機(Set Debug Terminal)
   Baud Rate:115200
Data :8
Parity :none
Stop :1
Flow Control:none
Tera Term Tool
RTENOTITLE
RTENOTITLE
Note:
查看PC端的串口号(Check the Sriel port in Device Manager) :
如果沒有找到 請先確認是否有安裝驅動(if you can not identify the Serial device , please check your serial driver.)
  1. Execute the Flash tool
RTENOTITLE
  1. Turn on the power.
  2. Press "Ctrl + C", log into u-boot
RTENOTITLE
  1. In Uboot , please type "rbrom " , the device will transfer to**"Flash mode"** , Android tool also will show "Found One MASKROM Device "
RTENOTITLE
 7. In RKDevTool , Press "Run" , it will flash the image into eMMC.
RTENOTITLE
8.  The flash process  was finishded
RTENOTITLE
  1. Reboot the device , and connect with HDMI , it will show the Debian Desktop.
RTENOTITLE
系统的基本使用(Linux System Basic Operating Method)
Display Setting (RSB-3710)
lvdslvds-g070vw01; lvds-g150xgel05; lvds-g215hvn01
hdmihdmi-default
dpdp-default
IN ubootIn Debian/Android
setenv prmry_screen hdmi-defaultfw_setenv prmry_screen hdmi-default
setenv extend_screen edp-1920x1080fw_setenv extend_screen edp-1920x1080
saveenv
resetreboot
In u-boot:
=> setenv prmry_screen lvds-g070vw01
=> setenv extend_screen hdmi-default
=> saveenv
=> reset
In Linux:
~# fw_setenv prmry_screen lvds-g070vw01
~# reboot
Modify LVDS backlight PWM: (Defaul is 20KHz, New version BSP support to modify the PWM clock in u-boot from 200~20KHz)
In u-boot:
=> setenv lvds_pwm_clock 10000 (Set PWM clock to 10KHz)
In Linux:
~# fw_setenv lvds_pwm_clock 10000 (Set PWM clock to 10KHz)
~# reboot
Check PWM duty sysle in Linux:
~# cat /sys/kernel/debug/pwm
RTENOTITLE
乙太網路使用方法(Ethernent Testing Method)
Command : ifconfig
Command: Ping 8.8.8.8
WiFi使用方法(WIFI Testing Method)
# killall wpa_supplicant
# ifconfig wlan0 up
# wpa_passphrase "SSID" "PASSWORD" > /tmp/wpa.conf
# cat /tmp/wpa.conf
# wpa_supplicant -BDwext -iwlan0 -c/tmp/wpa.conf
# udhcpc -b -i wlan0
# ifconfig
# ping 8.8.8.8
Add DNS to /etc/resolv.conf
# cat /etc/resolv.conf
# Generated by Connection Manager
nameserver 8.8.8.8
nameserver 8.8.4.4
Now can ping google.com
# ping google.com
4G使用方法(4G Testing Method)
Ubuntu - 4G 模塊(EC-25J) 設定 ( 4G module (EC-25J) in Ubuntu system)
Ubuntu - 4G 模塊(EC-20) 設定( 4G module (EC-20) in Ubuntu system)
GPIO使用方法(GPIO Operating Method)
RTENOTITLE
RTENOTITLE
RTENOTITLE
蓝牙使用方法(BlueTooth Operating Method)
# hciattach /dev/ttymxc0 bcm43xx 115200 flow
# hciconfig hci0 up
# hcitool scan# bluetoothctl
# discoverable on
#pairable on
# scan on
# scan off
# pair 84:C5:A6:D3:AF:E4
# connect 84:C5:A6:D3:AF:E4
Check BT connect info
# info 84:C5:A6:D3:AF:E4
音訊使用方法(BlueTooth Operating Method)
Line-in , Line-out, MIC
1.Line-out
Command : gplay-1.0
2.MIC
Command : arecord
Check audio codec:
# cat /proc/asound/cards
0 [sgtl5000 ]: sgtl5000 - sgtl5000
sgtl5000
1 [audiohdmi ]: audio-hdmi - audio-hdmi
audio-hdmi
root@imx8mprsb3720a1:~#
Set Mic/audio volume
# amixer set Mic 100%
# amixer set Lineout 100%
# amixer set PCM 100%
Record and playback
Example command:
# arecord –t wav –c 1 –r 44100 –d 5 /tmp/mic.wav
# aplay /tmp/mic.wav
Record from MIC:
# arecord -D plughw:0,0 -r 16000 -f S16_LE ./f-16000.wav
Recording WAVE './f-16000.wav' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
# aplay f-16000.wav
Playing WAVE 'f-16000.wav' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
Play wav file from codec:
# aplay -D plughw:0,0 file_example_WAV_10MG.wav
Playing WAVE 'file_example_WAV_10MG.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
Play wav file from HDMI:
# aplay -D plughw:1,0 file_exam
ple_WAV_10MG.wav
看門狗測試 (Watch Dog Test method)
System will reboot after 1 sec
# /unit_tests/Watchdog/wdt_driver_test.out 1 2 0
遠程訪問及文件傳輸(Remote Access and File Transimmion)
**查看主板IP位址 ( Chech IP Address ):**​
        Command : ifconfig
RTENOTITLE
Windows下SSH访问及文件传输
SSH Remote Log into Device
  • SSH远程登录,以putty选择putty.exe(或者使用Xshell、SecureCRT等类似软件)
  • 需要设置远程设备的IP、通讯端口(默认22)、通讯方式,登录后验证用户名密码
RTENOTITLE
RTENOTITLE
RTENOTITLE
通用方法(General Method)
查看CPU温度(Check CPU Temperature)
root@linaro-alip:~# cat /sys/devices/virtual/thermal/thermal_zone0/temp
40000
# 或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]°
>> 40°
查看CPU频率(Check CPU Frequency)
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
>> 1200000
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
>> 1800000
查看内存容量(Check Memory Capacity)
root@linaro-alip:~# busybox free -m
              total        used        free      shared  buff/cache   available
Mem:           1961         303        1096          97         561        1575
Swap:             0           0           0
root@linaro-alip:~#
查看存储容量(Check Storage Capacity)
root@linaro-alip:~# busybox df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root                 7.8G      2.8G      4.6G  37% /
devtmpfs                972.3M      8.0K    972.3M   0% /dev
tmpfs                   980.8M         0    980.8M   0% /dev/shm
tmpfs                   980.8M     16.8M    964.0M   2% /run
tmpfs                     5.0M      4.0K      5.0M   0% /run/lock
tmpfs                   980.8M         0    980.8M   0% /sys/fs/cgroup
/dev/mmcblk1p10           6.4G      3.8M      6.4G   0% /userdata
/dev/mmcblk1p7           62.6M     12.0M     47.3M  20% /oem
tmpfs                   196.2M         0    196.2M   0% /run/user/0
tmpfs                   196.2M      8.0K    196.1M   0% /run/user/1000
root@linaro-alip:~#
網路Ping測試(Ping Network Testing)
ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
設置RTC (RTC Setting)
Set system time to current, then write to RTC
root@linaro-alip:# date 01282022
Fri Jan 28 20:22:00 UTC 2022
root@linaro-alip:
Restart the RTC time to system time
hwclock -s && date
root@linaro-alip:# hwclock -s && date
Thu Jan 20 06:18:26 UTC 2022
root@linaro-alip:
如果有驗證上的錯誤 請使用以下的方法(If you got " Server certificate verification failed " message ,please follow the solution as below)
**### repo sync failed with Server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
export GIT_SSL_NO_VERIFY=1
#or
git config --global http.sslverify false
