RSB-4810_Debian_User_Guide
产品介绍(product presentation)
产品特性(product feature)
  • Rockchip RK3568 Arm Quad Cortex-A55, up to 2.0GHz
  • Built-in NPU with processing performance of up to 0.8 TOPS
  • Onboard 2/4GB LPDDR4 memory and 16/32GB eMMC
  • Supports 1 x HDMI 2.0 4K, 1 x LVDS/MIPI-DSI, and 1 x eDP
  • Supports 4K H.264/H.265 video decoder
  • Provides 2 x GbE, 1 x SATA 3.0, 6 x UART, 2 x USB 3.0, 2 x USB 2.0, 1 x USB OTG, and 2 x CAN FD
  • Provides a M.2 E Key with PCIE 3.0/USB 2.0/SDIO/UART signal for Wi-Fi 5/6 Modules, and a MINI-PCIE with PCIE 3.0/USB 2.0 signal for LTE/5G Modules
  • Supports Linux and Android OS
RSB-4810 - Rockchip Arm Cortex-A55 RK3568 3.5" SBC - Advantech
硬件接口说明
接口布局圖 Board Layout
RTENOTITLE
接口尺寸 Board Dimension
RTENOTITLE
接口引脚定義 (Pin definitions)
Jumper List
[J1](./RSB-4810_Debian_User_Guide_wiki_data/J1_RSB-4810 "J1 RSB-4810".md)MASKROM mode select Short pin 12 and power on the RSB-4810 to enter MASKROM mode. Change back to pin 23 before click "Run" to flash image
[J2](./RSB-4810_Debian_User_Guide_wiki_data/J2_RSB-4810 "J2 RSB-4810".md)CAN impedance matching
[J3](./RSB-4810_Debian_User_Guide_wiki_data/J3_RSB-4810 "J3 RSB-4810".md)CAN impedance matching
[J4](./RSB-4810_Debian_User_Guide_wiki_data/J4_RSB-4810 "J4 RSB-4810".md)OTG Mode selection, default USB3.0 host
[SW1](./RSB-4810_Debian_User_Guide_wiki_data/SW1_RSB-4810 "SW1 RSB-4810".md)AT & ATX Mode Switch, default AT mode
[BLP1](./RSB-4810_Debian_User_Guide_wiki_data/BLP1_RSB-4810 "BLP1 RSB-4810".md)LVDS BKL PWR 3.3V&5V level select, default 5V
[BLP2](./RSB-4810_Debian_User_Guide_wiki_data/BLP2_RSB-4810 "BLP2 RSB-4810".md)LVDS BKL PWR 12V select
[VDD1](./RSB-4810_Debian_User_Guide_wiki_data/VDD1_RSB-4810 "VDD1 RSB-4810".md)EDP VDD 3.3V &5V level select, default 3.3V
[VDD2](./RSB-4810_Debian_User_Guide_wiki_data/VDD2_RSB-4810 "VDD2 RSB-4810".md)LVDS VDD 3.3V & 5V level select, default 3.3V
[J5](./RSB-4810_Debian_User_Guide_wiki_data/J5_RSB-4810 "J5 RSB-4810".md)COM5,COM6 power 12/5V level select, default 5V
List
[AUDIO](./RSB-4810_Debian_User_Guide_wiki_data/AUDIO-4810 "AUDIO-4810".md)Audio pin header (Headphone, Mic in, Speaker)
[EDP](./RSB-4810_Debian_User_Guide_wiki_data/EDP-4810 "EDP-4810".md)eDP CONN
[LVDS](./RSB-4810_Debian_User_Guide_wiki_data/LVDS-4810 "LVDS-4810".md)LVDS CONN
[BL](./RSB-4810_Debian_User_Guide_wiki_data/BL-4810 "BL-4810".md)LVDS Back light Control
[SATA](./RSB-4810_Debian_User_Guide_wiki_data/SATA-4810 "SATA-4810".md)SATA3.0
[MINIPCIE](./RSB-4810_Debian_User_Guide_wiki_data/MINIPCIE-4810 "MINIPCIE-4810".md)MINI PCIe 52P
[SIM](./RSB-4810_Debian_User_Guide_wiki_data/SIM-4810 "SIM-4810".md)Nano SIM card
[M2](./RSB-4810_Debian_User_Guide_wiki_data/M2-4810 "M2-4810".md)M.2 E-Key CONN
[SD](./RSB-4810_Debian_User_Guide_wiki_data/SD-4810 "SD-4810".md)Micro SD slot
[PWRBTN](./RSB-4810_Debian_User_Guide_wiki_data/PWRBTN-4810 "PWRBTN-4810".md)Power button and LED
[DCIN1](./RSB-4810_Debian_User_Guide_wiki_data/DCIN1-4810 "DCIN1-4810".md)12V DC jack
[COM1](./RSB-4810_Debian_User_Guide_wiki_data/COM1-4810 "COM1-4810".md)RS-232 pin header
[COM2](./RSB-4810_Debian_User_Guide_wiki_data/COM2-4810 "COM2-4810".md)RS-232 DB9
[HDMI](./RSB-4810_Debian_User_Guide_wiki_data/HDMI-4810 "HDMI-4810".md)HDMI CONN
[CAN1/2](./RSB-4810_Debian_User_Guide_wiki_data/CAN1/2-4810 "CAN1/2-4810".md)CAN FD CONN
[USB1/2](./RSB-4810_Debian_User_Guide_wiki_data/USB1/2-4810 "USB1/2-4810".md)USB pin header
[USB3/4](./RSB-4810_Debian_User_Guide_wiki_data/USB3/4-4810 "USB3/4-4810".md)USB Type A ((2 x USB3.0, the lower Type A connector can be configured to OTG by jumper setting))
[SATAP](./RSB-4810_Debian_User_Guide_wiki_data/SATAP-4810 "SATAP-4810".md)SATA Power
[LAN1](./RSB-4810_Debian_User_Guide_wiki_data/LAN1-4810 "LAN1-4810".md)LAN1
[LAN2](./RSB-4810_Debian_User_Guide_wiki_data/LAN2-4810 "LAN2-4810".md)LAN2
[BAT](./RSB-4810_Debian_User_Guide_wiki_data/BAT-4810 "BAT-4810".md)RTC CONN
[COM3/4](./RSB-4810_Debian_User_Guide_wiki_data/COM3/4-4810 "COM3/4-4810".md)COM3 and COM4 with RS-232 or RS-485
[COM5/6](./RSB-4810_Debian_User_Guide_wiki_data/COM5/6-4810 "COM5/6-4810".md)COM5 and COM6 with RS-232
[RST](./RSB-4810_Debian_User_Guide_wiki_data/RST-4810 "RST-4810".md)Reset button
[CN1](./RSB-4810_Debian_User_Guide_wiki_data/CN1-4810 "CN1-4810".md)GPIO CONN
[I2C1](./RSB-4810_Debian_User_Guide_wiki_data/I2C1-4810 "I2C1-4810".md)I2C pin header
[Debug port](./RSB-4810_Debian_User_Guide_wiki_data/RSB-4810_Debug_Port.png "RSB-4810 Debug Port.png".md)Debug connector
快速入门 (Quick Start)
系统下载 (OS Download)
Note:  LIV=Yocto Linux, UIV=Ubuntu, DIV=Debian, AIV=Android
             LBV=BSP, LIV=Image
PlatformProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagSDKCommentCAN2.0 Patch
RK3568RSB-4810DIV1303112024/03/15BetaRelease noteBaidu  Password:a887 DropboxRK3568_RISC_DIV130311.xmlBaidu Password:a887 DropboxTest Report **CAN2.0 Errata**提取码:a887Baidu Password:a887
  • Alpha:  Basic I/O function bring up by RD;
  • Beta:  Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
  • GA:  Beta version by QE verification;
  • RTM:  Beta version by SI/Power/QE verification and pre-loaded;
How to update images .
There are three ways to update images:
[Usering_RKTool.](./RSB-4810_Debian_User_Guide_wiki_data/1._Using_RKTool_RSB-4810_Debain "1. Using RKTool RSB-4810 Debain".md)
[SD_update image.](./RSB-4810_Debian_User_Guide_wiki_data/2._RSB-4810_Debian_SD_update_image "2. RSB-4810 Debian SD update image".md)
OS_update image.") (TBD)
U-boot update image.")(TBD)
Linux系统的基本使用(Linux System Basic Operating Method)
乙太網路使用方法(Ethernent Testing Method)
Command : ifconfig
RTENOTITLE
RTENOTITLE
WiFi使用方法(WIFI Testing Method)
RTENOTITLE
RTENOTITLE
4G使用方法(4G Testing Method)
RTENOTITLE
RTENOTITLE
RTENOTITLE
蓝牙使用方法(BlueTooth Operating Method)
RTENOTITLE
音訊使用方法(BlueTooth Operating Method)
RTENOTITLE
RTENOTITLE
CAN2.0 測試( CAN Test method)
Note:RK3568 CAN2.0 Errata;
**CAN2.0 Errata:CAN2.0 Errata**提取码:a887
CAN2.0 Patch:Baidu Password:a887
Short CAN1/2 Pin header ,Loopback test for example:
CAN0_D+->CAN1_D+
CAN0_D-->CAN1_D-
RTENOTITLE
输入指令:
# ip link set can0 down
# ip link set can0 type can bitrate 1000000
# ip link set can0 up
# ip -details link show can0
# candump can0 &
# ip link set can1 down
# ip link set can1 type can bitrate 1000000
# ip link set can1 up
# ip -details link show can1
# cansend can1 123#55
can0  123   [1]  55
RTENOTITLE
I2C 測試( I2C Test method)
RTENOTITLE
看門狗測試 (Watch Dog Test method)
RTENOTITLE
UART測試 (UART Test method)
RTENOTITLE
How to Configure RS-232/485 Mode Enter U-boot interrupt mode. Connect the device to the debug port and open the debug console. Press “ctrl + c” before powering on the device.
The following information should be displayed on the debug console:
Hit any key to stop autoboot: 0
Then input the following command to configure the UART mode.
RS-485 Mode:
setenv uart_mode 0x0c
saveenv
reset
RS-232 Mode:
setenv uart_mode 0x00
saveenv
reset
Note: The default value is RS-232. Cp210x supports four ports, but for RSB-4810 only ttyUSB2 and ttyUSB3 support RS-485 mode.
In the above command “setenv uart_mode 0x0c”, 0x0c means set bit2(ttyUSB2) and bit3(ttyUSB3) to 1 (0 means to RS-232; 1 means to RS-485). To configure just ttyUSB2 (or ttyUSB3) to RS-485 mode, change 0x0c to 0x04 (or 0x08).
GPIO測試(GPIO Test method)
RTENOTITLE
RTENOTITLE
Display測試(Display Test method)
RTENOTITLE
[How_to_Config_Multi-Display](./RSB-4810_Debian_User_Guide_wiki_data/How_to_Config_Multi-Display "How to Config Multi-Display".md)
RTENOTITLE
RTENOTITLE
RTENOTITLE
RTENOTITLE
遠程訪問及文件傳輸(Remote Access and File Transimmion)
查看主板IP位址 ( Chech IP Address ):
RTENOTITLE
RTENOTITLE
RTENOTITLE
ID: root password:123456
RTENOTITLE
通用方法(General Method)
QT Toolchain
查看CPU温度(Check CPU Temperature)
cat /sys/devices/virtual/thermal/thermal_zone0/temp   40000
或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 40°
查看CPU频率(Check CPU Frequency)
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
 >> 1200000
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
 >> 1800000
查看内存容量(Check Memory Capacity)
busybox free -m
查看存储容量(Check Storage Capacity)
busybox df -h
調整亮度(Change the backlight)
Note: connect with LVDS Panel  , default value is 200
root@linaro-alip:# echo 100 > /sys/class/backlight/backlight/brightness
root@linaro-alip:
# echo 200 > /sys/class/backlight/backlight/brightness
root@linaro-alip:~#
 root@linaro-alip:# cat /sys/class/backlight/backlight/max_brightness
255
root@linaro-alip:
# cat /sys/class/backlight/backlight/brightness
200
How to build Debian 11 BSP (Debian 11 BSP 編譯)
[Linux BSP User Guide for RSB-4810 series Debian11](./RSB-4810_Debian_User_Guide_wiki_data/Linux_BSP_User_Guide_for_RSB-4810_series_Debian11 "Linux BSP User Guide for RSB-4810 series Debian11".md)
