Linux BSP User Guide for RK3288 Series Debian9
This document provides comprehensive instructions for building and deploying Linux BSP for RK3288 series platforms running Debian 9. The guide covers environment setup, source code acquisition, building processes, and deployment methods.
Linux BSP Version
We have two versions available for RK3288 series:
V2.1
  • OS: Debian 9 stretch
  • Kernel: Linux version 4.4.143
V230
  • OS: Debian 10 buster
  • Kernel: Linux version 4.4.194
Get Docker Image
If you don't have docker in your system, then you can follow the below steps to install docker and run it first.
To Install Docker Engine on Your Platform
Please refer to Docker Installation Guide for details.
To Pull Ubuntu 16.04 Image from Docker Hub
sudo docker pull advrisc/u16.04-rk3288lbv1
Install Additional Dependencies
$ sudo apt-get update
$ sudo apt-get install binfmt-support qemu-user-static
Config Docker
Initial Docker Setup
$ mkdir -p ~/work/code/rk3288_debian
$ sudo docker run -it --name rk3288_linux --privileged -v ~/work/code/rk3288_debian:/home/adv/code:rw advrisc/u16.04-rk3288lbv1:latest /bin/bash
$ exit # This command runs in docker workspace. It means exit docker workspace to host workspace.
Note: The above commands only need to be run the first time.
Start Docker
$ sudo docker start rk3288_linux
$ sudo docker attach rk3288_linux
Note: After running the above two commands, you will work in docker workspace. You can get debian source code and build them in docker workspace.
Getting Debian Source Code
V2.1 Version
$ cd ~/code
$ sudo git clone https://github.com/ADVANTECH-Rockchip/repo.git
$ mkdir rk3288_debian
$ cd rk3288_debian
$ git config --global user.name "Your Name"
$ git config --global user.email you@example.com
$ ../repo/repo init -u https://github.com/ADVANTECH-Rockchip/linux-manifest.git -b rk3288_linux_v2.0 -m default.xml
$ ../repo/repo sync
$ ../repo/repo forall -c git checkout -b local --track advantech-github/rk3288_linux_v2.0
$ sudo dpkg -i rootfs/ubuntu-build-service/packages/*
$ sudo apt-get install -f
V230 Version
$ cd ~/code
$ cd rk3288_debian
$ ../repo/repo init -u https://github.com/ADVANTECH-Rockchip/linux-manifest.git -b rk3288_linux_v230_risc -m default.xml
$ ../repo/repo sync
$ ../repo/repo forall -c git checkout -b local --track advantech-github/rk3288_linux_v230_risc
Build U-boot
Build RSB-4680 U-boot
V2.1 Version
$ export TOP=`pwd`
$ cd $TOP
$ cd u-boot/
$ ./make.sh rsb4680a3-2G-rk3288
V230 Version
$ export TOP=`pwd`
$ cd $TOP
$ cd u-boot/
$ ./make.sh rk3288_rsb4680a3_2G
Build Kernel
Build RSB-4680 Kernel
$ cd $TOP
$ cd kernel/
$ make ARCH=arm rk3288_adv_defconfig
$ make ARCH=arm rk3288-rsb4680-a3.img -j12
Build Recovery
$ cd $TOP
$ rm buildroot/output/rockchip_rk3288_recovery -rf
$ source envsetup.sh rockchip_rk3288_recovery
$ ./build.sh recovery
NOTE: For recovery.img includes kernel and recovery tools, kernel MUST be built before recovery.
Build Rootfs
V2.1 Version
$ cd $TOP
$ cd rootfs/
$ sudo ARCH=armhf ./mk-rootfs.sh
$ sudo ARCH=armhf ./mk-adv.sh
$ sudo ./mk-image.sh
V230 Version
$ cd $TOP
$ sudo BUILD_IN_DOCKER=TRUE ./mk-debian.sh
Creating the ext4 Image
$ cd $TOP
$ sudo ./mkfirmware.sh
NOTE: If there is no error, the following ten files will be found in $TOP/rockdev/:
  • boot.img
  • MiniLoaderAll.bin
  • misc.img
  • oem.img
  • parameter.txt
  • recovery.img
  • rootfs.img
  • trust.img
  • uboot.img
  • userdata.img
How to Update RK3288 Platform
There are two ways to update images:
1. Android Tool
Update image through AndroidTool
2. SD Card
Update image through SD-Card
NOTE: This method only supports:
  • Linux (Debian9) upgrade to Linux (Debian9)
  • Android 6.0 upgrade to Android 6.0
  • Android 8.1 upgrade to Android 8.1
If the device is running Android and you want to upgrade to Linux (Debian9), please use Android Tool.
Default User and Password
Here are the default user credentials:
UsernamePassword
linaro123456
root123456
Build Toolchain
To Build a Toolchain
$ cd ~/RSB4680_CODEBASE/
$ source buildroot/build/envsetup.sh rockchip_rk3288
$ make
The toolchain will be generated in:
~/RSB4680_CODEBASE/buildroot/output/rockchip_rk3288/host/arm-buildroot-linux-gnueabihf/
Initramfs
Method 1: Using Cpio Format
1. Get a Sample Initramfs Rootfs
$ git clone https://github.com/TeeFirefly/initrd.git
2. Make a Cpio Format Gzipped File
$ cd initrd
$ find . | cpio -o -H newc | gzip > ../initramfs_data.cpio.gz
3. Copy to Kernel Source
Copy initramfs_data.cpio.gz to ~/KERNEL_SRC/usr/
4. Add Configuration
Add config CONFIG_INITRAMFS_SOURCE="usr/initramfs_data.cpio.gz" to rk3288_adv_defconfig
5. Rebuild Boot Image
Modify Initramfs Rootfs
To modify existing initramfs rootfs:
$ zcat initramfs_data.cpio.gz | cpio -i -d -H newc --no-absolute-filenames
Method 2: Direct Folder Reference
You can point CONFIG_INITRAMFS_SOURCE to a folder directly:
2. Set Configuration
Set CONFIG_INITRAMFS_SOURCE="../../initrd/"
3. Rebuild Boot Image
Important Notes
  1. The init found in the initramfs has nothing to do with kernel cmdline root=
  2. The init inside the initrd.git will be triggered and boot the system completely. You may add anything you want to this rootfs
Supported Hardware Platforms
  • RSB-4680: Industrial Single Board Computer with RK3288 processor
Build Workflow Summary
  1. Environment Setup → Docker + Ubuntu 16.04
  2. Source Download → Git repo sync from Advantech Rockchip repositories
  3. Component Build → U-boot → Kernel → Recovery → Rootfs
  4. Image Creation → Create ext4 images and firmware
  5. Deployment → Android Tool or SD Card flashing
  • Docker environment with advrisc/u16.04-rk3288lbv1 image
  • Ubuntu 16.04 base system
  • Git and repo tools
  • Build tools and cross-compilation toolchain
  • Sufficient disk space for source code and build artifacts
  • Internet connection for source code download
  • Target processors (RSB-4680)
This guide provides comprehensive instructions for building and deploying Linux BSP on RK3288 series platforms.
