RSB-4411 Yocto 2.5 User Guide
產品介紹(Product introduction )
產品特性(Product Features)
  • NXP ARM® Cortex®-A9 i.MX6 Dual/Quad up to 1 GHz
  • Onboard 1GB DDR3 memory and 4GB eMMC
  • HDMI and VGA 1920x1080 at 60Hz, Dual Channel 18/24 bit LVDS
  • 3 UART, 1 GbE, 5 USB 2.0, 20 GPIO, 2 I2C, 1 SPI
  • M.2 for WIFI/BT support , mini-PCIe for WIFI/3G support
  • Low power consumption, fanless design
  • Supports Linux and Android
RSB-4411
硬件接口說明(Hardware interface introduction)
接口布局和尺寸(Layout and Sizes)
RSB-4411 接口布局圖 Board Dimension Layout
RTENOTITLE
Rear I/O
RTENOTITLE
Jumper Settings
SW2
RTENOTITLE
SW3
RTENOTITLE
**机械尺寸  (**Mechanical Characteristics)
RSB-4411
RTENOTITLE
RTENOTITLE
RTENOTITLE
快速入门 (Quick Start)
Linux 燒錄方法 (Linux Flash eMMC Method)
使用Flash tool 燒錄鏡像到eMMC (Flash image into eMMC by Flash Tools)
Step0: 檢查SD卡在Linux 環境的代號 (check SD card symbol in Linux system)
RTENOTITLE
RTENOTITLE
Step1: 創造一張可開機的SD 卡 (Create a bootable SD card)
RTENOTITLE
Step2: 將可開機的SD 卡插入底板SD卡卡槽(Plug the SD card into Carrier board 's SD card slot)
Step4: 確認開機選擇指撥開關
           SD 卡開機模式:
Step3:打開電源 和 終端機 (Turn on the Power & Terminal)
Step4: 解壓縮flash tools 檔案,並複製到U盤中(Unzip the flash tools file , then copy to USB Disk)
    解壓縮(Unzip the file )
RTENOTITLE
 複製檔案到U盤中 (Copy the flash file to USB Disk)
  1. 插入U盤到你的Ubuntu 電腦上 (Plug the USB Disk into you Linux PC
  2. 檢視U盤在Ubuntu 系統代號 (Check the USB Disk's symbol in Ubuntu System)
RTENOTITLE
RTENOTITLE
 3. 掛載U盤在Ubuntu 系統中
Debug 串口調試 (Debug port Setting)
以 Tera Term  为例介绍如何使用串口调试功能
   Baud Rate波特率:115200
Data 数据位:8
Parity 奇偶校验:无
  Stop 停止位:1
Flow Control流控:无
Tera Term Tool
RTENOTITLE
RTENOTITLE
Check the Sriel port in Device Manager (查看PC端的串口号):
if you can not identify the Serial device , please check your serial driver.
RTENOTITLE
Debug port connection (串口連接)
Log into Terminal  Tool (进入串口调试终端):
Linux系统的基本使用(Linux System Basic Operating Method)
乙太網路使用方法(Ethernent Testing Method)
Command : ifconfig
RTENOTITLE
Command: Ping - I eth1 8.8.8.8  or Ping - I eth0 8.8.8.8
RTENOTITLE
WiFi使用方法(WIFI Testing Method)
Command :
# killall wpa_supplicant
# ifconfig wlan0 up
# wpa_passphrase "SSID" "PASSWORD" > /tmp/wpa.conf
# wpa_supplicant -BDwext -iwlan0 -c/tmp/wpa.conf
# udhcpc -b -i wlan0'''
ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
RTENOTITLE
4G使用方法(4G Testing Method)
Command:
Test 4G: (EWM-C117FL06E - USB)
Step 1: Connect EWM-C117FL06E to Mini PCIE slot on 9680015491 and connect
the card to CN6 PCIe_D slot on ROM-DB5901.
Step 2: Connect the antenna 1750007990-01 to the SMA (F) connector on
9680015491
and connect the IPEX connector to MT1 on EWM-C117FL06E module.
Step 3: Connect the Mini USB cable from 9680015491 to USB 2.0 Type A port on
ROM-DB5901.
Step 4: Power on and execute the pppd command to connect to the network.
RTENOTITLE
GPIO使用方法(GPIO Operating Method)
GPIO PinGPIO Pin defineGPIO Number[32*(Bank-1)+ IO]
GPIO_01ENET_RXD/GPIO1_IO2727 [32*(1-1) + 27]
GPIO_02ENET_TXD1/GPIO1_IO2929 [32*(1-1) + 29]
GPIO_03ENET_CRS_DV/GPIO1_IO2525 [32*(1-1) + 25]
GPIO_04ENET_TXD0/GPIO1_IO3030 [32*(1-1) + 30]
GPIO_05EIM_BCLK__GPIO6_IO31191 [32*(6-1) + 31]
GPIO_06EIM_D30/GPIO3_IO3094 [32*(3-1) + 30]
GPIO_07EIM_D31/GPIO3_IO3195 [32*(3-1) + 31]
GPIO_08EIM_D21/GPIO3_IO2185 [32*(3-1) + 21]
GPIO_09EIM_A25__GPIO5_IO02130 [32*(5-1) + 2]
GPIO_10EIM_D20/GPIO3_IO2084 [32*(3-1) + 20]
GPIO_11EIM_D23/GPIO3_IO2387 [32*(3-1) + 23]
GPIO_12NANDF_CS0/GPIO6_IO11171 [32*(6-1) + 11]
GPIO_13NANDF_D2/GPIO2_IO0234 [32*(2-1) + 2]
GPIO_14NANDF_WP_B/GPIO6_IO09169 [32*(6-1) + 9]
GPIO_15NANDF_D3/GPIO2_IO0335 [32*(2-1) + 3]
GPIO_16NANDF_CS3/GPIO6_IO16176 [32*(6-1) + 16]
GPIO_17NANDF_CLE/GPIO6_IO07181 [32*(6-1) + 21]
GPIO_18NANDF_D4/GPIO2_IO0436 [32*(2-1) + 4]
GPIO_19NANDF_D0/GPIO2_IO0032 [32*(2-1) + 0]
GPIO_20NANDF_ALE/GPIO6_IO08168 [32*(6-1) + 8]
Loop-back Test (Take GPIO4 and GPIO5 as examples)
Step 1: Connect GPIO4 and GPIO5
Step 2: Export GPIO interface
root@imx8qxprom5620a1 : ~# echo 30 > /sys/class/gpio/export
root@imx8qxprom5620a1 : ~# echo 191 > /sys/class/gpio/export
Step 3: Set direction
root@imx8qxprom5620a1 : ~# echo out > /sys/class/gpio/gpio1/direction
root@imx8qxprom5620a1 : ~# echo in > /sys/class/gpio/gpio2/direction
Step 4: Read value and set output value then check
root@imx8qxprom5620a1 : ~# cat /sys/class/gpio/gpio2/value
0r
oot@imx8qxprom5620a1 : ~# echo 1 > /sys/class/gpio/gpio1/value
1
串口使用方法(Serial Port Operating Method)
RS-232 Test
RTENOTITLE
SW3 Setting (SW3設置)
RTENOTITLE
RS-485
Download Test Tool : Test485
RS 485 test (系統預設minincom)
  1. Switch : 2 ->1 , others   off
  2. ./test485 /dev/ttymxc1 tx
RTENOTITLE
 3. minicom -D /dev/ttymxc1
      RTENOTITLE
  1. Open two terminal tool
RTENOTITLE
藍芽使用方法(BlueTooth Operating Method)
Command :
$ hciconfig hci0 up
$ bluetoothctl
$ discoverable on
$ pairable on
$ scan on
[NEW] FC:18:3C:8D:75:F4 myphone
$ scan off
$ pair FC:18:3C:8D:75:F4
$ connect FC:18:3C:8D:75:F4
RTENOTITLE
CAN使用方法 (CAN Test)
Connect device with CAN0 (CN8A)
ip link set can0 up type can bitrate 125000
RTENOTITLE
遠程訪問及文件傳輸(Remote Access and File Transimmion)
**查看主板IP位址 ( Chech IP Address ):**​
        Command : ifconfig
Windows下SSH访问及文件传输
SSH Remote Log into Device
  • SSH远程登录,以putty选择putty.exe(或者使用Xshell、SecureCRT等类似软件)
  • 需要设置远程设备的IP、通讯端口(默认22)、通讯方式,登录后验证用户名密码
RTENOTITLE
RTENOTITLE
RTENOTITLE
RTENOTITLE
通用方法(General Method)
查看CPU温度(Check CPU Temperature)
    root@imx8qxprom5620a1:/# cat /sys/devices/virtual/thermal/thermal_zone0/temp 44600
# 或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 45°
查看CPU频率(Check CPU Frequency)
           cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
>> 900000
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
>> 1200000
查看内存容量(Check Memory Capacity)
root@imx8qxprom5620a1:/# busybox free -m
total used free shared buffers cached
Mem: 1794920 516080 1278840 17252 9852 80292
-/+ buffers/cache: 425936 1368984
Swap: 0 0 0
查看存储容量(Check Storage Capacity)
root@imx8qxprom5620a1:/# busybox df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 13.4G 1.7G 11.1G 13% /
devtmpfs 395.8M 4.0K 395.8M 0% /dev
tmpfs 876.4M 0 876.4M 0% /dev/shm
tmpfs 876.4M 16.5M 859.9M 2% /run
tmpfs 876.4M 0 876.4M 0% /sys/fs/cgroup
tmpfs 876.4M 4.0K 876.4M 0% /tmp
tmpfs 876.4M 280.0K 876.2M 0% /var/volatile
/dev/mmcblk0p2 13.6G 1.7G 11.3G 13% /run/media/mmcblk0p2
/dev/mmcblk0p1 63.9M 23.4M 40.5M 37% /run/media/mmcblk0p1
/dev/mmcblk1p1 63.9M 23.4M 40.5M 37% /run/media/mmcblk1p1
tmpfs 175.3M 88.0K 175.2M 0% /run/user/0
網路Ping測試(Ping Network Testing)
     ping 8.8.8.8
設置RTC (RTC Setting)
     root@imx8qxprom5620a1:/# systemctl stop ntpdate.service
root@imx8qxprom5620a1:/# date 090816072021 && hwclock -w && date
Wed Sep 8 16:07:00 UTC 2021
Wed Sep 8 16:07:06 UTC 2021
root@imx8qxprom5620a1:/#'''
Android BSP編譯方法(Linux BSP Compile Method)
Android 6.0
Linux BSP編譯方法(Linux BSP Compile Method)
Yocto 4.2
Yocto 2.5
Yocto 2.1
