ROM-5720 User Guide
Contents
- 1 產品介紹 (Product introduction)
- 1.1 產品特性 (Product Features)
- 1.2 產品官網連結 (Product official website link)
- 2 硬件接口說明 (Hardware interface introduction)
- 2.1 接口布局和尺寸 (Layout and Sizes)
- 2.2 ROM-5720 接口布局圖 Board Dimension Layout
- 2.3 ROM-DB5901 接口布局圖 Board Dimension Layout
- 2.4 主板内置插针式引脚排序方式 (Pin Header defination)
- 2.5 Internal I/O
- 2.6 Rear I/O
- 2.7 接口引脚定義 (Pin definitions)
- 2.8 机械尺寸 (Mechanical Characteristics)
- 3 快速入门 (Quick Start)
- 3.1 系统下载 (OS Download)
- 3.2 Linux 燒錄方法 (Linux Flash eMMC Method)
- 3.3 Debug 串口調試 (Debug port Setting)
- 4 Linux系统的基本使用 (Linux System Basic Operating Method)
- 4.1 UUU 使用方法 (USB Connection (OTG port))
- 4.2 Display Setting (ROM-5720)
- 4.3 乙太網路使用方法 (Ethernent Testing Method)
- 4.4 4G使用方法 (4G Testing Method)
- 4.5 GPIO使用方法 (GPIO Operating Method)
- 4.6 串口使用方法 (Serial Port Operating Method)
- 4.7 遠程訪問及文件傳輸 (Remote Access and File Transimmion)
- 4.7.1 Windows下SSH访问及文件传输
- 5 通用方法 (General Method)
- 5.1 Mic錄音 (Mic record)
- 5.2 PCIe裝置移除與rescan
- 6 Linux BSP編譯方法 (Linux BSP Compile Method)
- 6.1 Yocto 4.2
- 6.2 Yocto 3.0
- 7 Build known issue
產品介紹(Product introduction)
產品特性(Product Features)
- NXP i.MX 8M processor with dual or quad Arm Cortex A53 cores
- 1 x Arm Cortex-M4 core
- Onboard 2GB LPDDR4 memory and eMMC 16GB
- 1 x HDMI2.0 up to 4096 x 2160, 1 x 4-Lane MIPI DSI
- 2 x USB3.0, 4 x USB2.0, 4 x UART, 4 x I2C, 12 x GPIO, 1 x PCIe2.0, 1 x 4-lane MIPI CSI camera input, 1 x 2-lane MIPI CSI camera input and 2 x Gigabit LAN
- Supports OpenGL ES 3.1/3.0/2.0/1.1, Open CL 1.2, and Vulkan hardware accelerators
- Supports 4Kp60 HEVC/H.265 decoding with HDR
- Cable pack & panel included
- Evaluative image & test utility built-in
產品官網連結(Product official website link)
硬件接口說明(Hardware interface introduction)
接口布局和尺寸(Layout and Sizes)
Internal I/O
| Position | Description | Connector Type |
| BAT1 | PIN Header for Battery | WAFER 8P 2.54mm 180D(M) DIP A2543WV2-8P |
| BH1 | RTC Battery Holder | BATTERY HOLDER 24.923.48.9 CR2032 BH800.4GG |
| CAN1 | CANBus Port 1 | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| CAN2 | CANBus Port 2 | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| COM1 | COM Port 1 | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| COM3 | COM Port 3 (Debug Port) | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| CN4 | PCIex1 Connector 1 | PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF |
| CN5 | PCIex1 Connector 2 | PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF |
| CN6 | PCIex1 Connector 3 | PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF |
| CN11 | SATA Connector | Serial ATA 7P 1.27mm 180D(M) DIP WATM-07DBN4A3B8 |
| CN12 | SATA Power Connector | WAFER 4P 2.5mm 180D(M) DIP 24W1161-04S10-01T |
| CN22 | GPIOx8 sets | PIN HEADER 10x2P 2.0mm 180D(M) DIP 21N22050 |
| CN25 | MXM 3.0 Connector | MXM Conn. 314P 90D(F) SMD AS0B821-S78B-7H |
| CN26 | M.2 Key E Slots | NGFF 75P 0.5mm 90D(F) H=4.2mm SMD AS0BC21-S40BE |
| CN38 | FAN (Reserved) | WTB Con. 3P 2.54mm 180D(M) DIP A2543WV0-3P-6T-5e |
| CN39 | MIPI-CSI1 (FPC, 4-Lane) | FPC 39P, 0.6mm, H0.9mm |
| CN40 | MIPI-CSI0 (FPC, 2-Lane) | FPC 39P, 0.6mm, H0.9mm |
| CN41 | MIPI-CSI0 (Mini-SAS, 2-Lane) | Mini SAS 36P/0.8mm/(M)/LCP/VA/G15u/S/BK/W |
| CN42 | MIPI-CSI1 (Mini-SAS, 4-Lane) | Mini SAS 36P/0.8mm/(M)/LCP/VA/G15u/S/BK/W |
| ESPI_CN1 | ESPI | PIN HEADER 6x2P 2.0mm 180D(M) SMD 21N22050-12M00B |
| I2C_GP_1 | I2C Pin Header | WAFER BOX 4P 2.00mm 180D(M) DIP 721-81-04TW00 |
| I2C_CN3 | Audio Codec Board | PIN HEADER 2x10P 2.54mm 180D(M) DIP 21N22564 |
| LVDS0 | LVDS0 | Wafer 2x20P/1.25mm/(M)/NY9T/VA/GFL/S/WH/W |
| LVDS_BK_PWR | LVDS0 Back Light | WAFER BOX 5P 2.0mm 180D(M) DIP A2001WV2-5P |
| LVDS1 | LVDS1 | Wafer 2x20P/1.25mm/(M)/NY9T/VA/GFL/S/WH/W |
| LVDS1_BK_PWR | LVDS1 Back Light | WAFER BOX 5P 2.0mm 180D(M) DIP A2001WV2-5P |
| SD1 | SD Card Slot | SD CARD 9P 90D(F) SMD WK2192CS3D-7H |
| SPI_CN1 | SPI Pin Header | PIN HEADER 4x2P 2.54mm 180D(M) SMD 21N22564 |
| SW2 | Reset Button | TACT SW STS-091 SMD 4P H=3.8mm |
| SW4 | SLP Button | TACT SW STS-091 SMD 4P H=3.8mm |
| SW5 | Power Button | TACT SW STS-091 SMD 4P H=3.8mm |
| USB0_OTG1 | USB OTG | Micro USB 5P/0.65mm/(F)/NY9T/GFL/RA/S/BK/B |
| USB-4-5 | USB Port 4, Port 5 | PIN HEADER 2x5P 2.0mm 180D(M) SMD 21N22050 |
Rear I/O
- 電池(BAT1) & 電池扣(BH1)
- CAN(CAN1,CAN2)
- 串口(COM_DB(COM3)、COM1、UART0、UART2)
- 显示接口(LVDS、LVDS Backlight、HDMI、DP)
- LAN接口(LAN)
- USB接口(USB1-2、USB-4-5、USB Type C、USB OTG)
- 音频接口(Audio Output & Audio Codec)
- 电源及指示灯和开关机复位按钮(Power、LED、Power Button、Reset Button、Sleep Button)
- GPIO接口
- MINI_PCIE接口_M.2接口_SPI、I2C_接口
ROM-5720
Dimensions: SMARC form factor size, 82mm (D) x 50mm (W) Height on Top: Under 3.0 mm base on SPEC definition (without heat sink) Height on Bottom: Under 1.3 mm base on SPEC definition
快速入门 (Quick Start)
系统下载 (OS Download)
使用Flash tool 燒錄鏡像到eMMC (Flash image into eMMC by Flash Tools)
Step0: 檢查SD卡在Linux 環境的代號 (check SD card symbol in Linux system)
Step1: 創造一張可開機的SD 卡 (Create a bootable SD card)
Step2: 將可開機的SD 卡插入底板SD卡卡槽 (Plug the SD card into Carrier board's SD card slot)
Step4: 確認開機選擇指撥開關
SD 卡開機模式:
Step3: 打開電源 和 終端機 (Turn on the Power & Terminal)
Step4: 壓縮flash tools 檔案,並複製到U盤中 (the flash tools file, then copy to USB Disk)
Step 5: Yocto 系統會自動掛載 U盤 在 /run/media/sda1 下
並拷貝 5720A1AIM30LIVA0271_iMX8M_2G_flash_tool.tgz 到根目錄 (copy the file into Yocto system)
cp -a 5720A1AIM30LIVA0271_iMX8M_2G_flash_tool.tgz /
在Yocto 系統中解壓縮 (Unzip the file in Yocto system on ROM-5720)
Step 6. 燒錄eMMC 鏡像 (flash image into eMMC flash by flash tool file)
./mksd-linux.sh /dev/mmcblk0
Step 7. 結束燒錄後, 請改變撥碼開關至 1 on, 其他 off (eMMC開機模式) (Finish the flash process, please change the switch (SW1) to 1 on, others off)
移除SD卡, 拔除電源, 改變撥碼開關 (unplug the SD card, turn off power, change the SW1 switch to eMMC mode)
eMMC mode: 1 on, others off
Step 8. 重新上電開機 (Turn on the power, then check the Debug message)
以 Tera Term 为例介绍如何使用串口调试功能
Baud Rate波特率:115200
Data 数据位:8
Parity 奇偶校验:无
Stop 停止位:1
Flow Control流控:无
Tera Term Tool
Check the Serial port in Device Manager (查看PC端的串口号):
if you can not identify the Serial device, please check your serial driver.
Debug port connection (串口連接)
Log into Terminal Tool (进入串口调试终端):
Linux系统的基本使用(Linux System Basic Operating Method)
UUU 使用方法(USB Connection (OTG port))
U-boot Command:
setenv fdt_file imx8mq-rom5720-a1-dcss-adv7535.dtb
env save
boot
Yocto 2.5
| Display | DTB File |
| DSI to HDMI | adv-imx8mq-rom5720-a1-dcss-adv7535-b3.dtb |
| DSI to HDMI (lcdif) | adv-imx8mq-rom5720-a1-lcdif-adv7535.dtb |
| DSI auog101uan02 | adv-imx8mq-rom5720-a1-dcss-auog101uan02.dtb |
| Dual Display (DSI to HDMI + HDMI) | adv-imx8mq-rom5720-a1-dual-display.dtb |
| M.2 SDIO | adv-imx8mq-rom5720-a1-m2-sdio.dtb |
| M.2 I2S | adv-imx8mq-rom5720-a1-m2-i2s.dtb |
Yocto 3.0
| Display | DTB File | Note |
| DSI to HDMI | imx8mq-rom5720-a1-dcss-adv7535.dtb | weston.ini: drm-device=card2 |
| DSI to HDMI (lcdif) | imx8mq-rom5720-a1-lcdif-adv7535.dtb | |
| DSI auog101uan02 | imx8mq-rom5720-a1-dcss-auog101uan02.dtb | |
| Dual Display (DSI to HDMI + HDMI) | imx8mq-rom5720-a1-dual-display.dtb | weston.ini: drm-device=card1 |
| M.2 SDIO | imx8mq-rom5720-a1-m2-sdio.dtb |
乙太網路使用方法(Ethernent Testing Method)
Command: ifconfig
Command: ping -I eth1 8.8.8.8
WiFi使用方法(WIFI Testing Method)
killall wpa_supplicant
ifconfig wlan0 up
wpa_passphrase "SSID" "PASSWORD" > /tmp/wpa.conf
wpa_supplicant -BDwext -iwlan0 -c/tmp/wpa.conf
udhcpc -b -i wlan0
ping 8.8.8.8
# PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
# 64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms
4G使用方法(4G Testing Method)
Command:
Test 4G: (EWM-C117FL06E - USB)
Step 1: Connect EWM-C117FL06E to Mini PCIE slot on 9680015491 and connect
the card to CN6 PCIe_D slot on ROM-DB5901.
Step 2: Connect the antenna 1750007990-01 to the SMA (F) connector on
9680015491 and connect the IPEX connector to MT1 on EWM-C117FL06E module.
Step 3: Connect the Mini USB cable from 9680015491 to USB 2.0 Type A port on
ROM-DB5901.
Step 4: Power on and execute the pppd command to connect to the network.
GPIO使用方法(GPIO Operating Method)
# Loop-back Test (Take GPIO4 and GPIO5 as examples)
# Step 1: Connect GPIO4 and GPIO5
# Step 2: Export GPIO interface
echo 0 > /sys/class/gpio/export
echo 132 > /sys/class/gpio/export
# Step 3: Set direction
echo out > /sys/class/gpio/gpio1/direction
echo in > /sys/class/gpio/gpio2/direction
# Step 4: Read value and set output value then check
cat /sys/class/gpio/gpio2/value
# 1
echo 0 > /sys/class/gpio/gpio1/value
# 0
串口使用方法(Serial Port Operating Method)
RS-232 Test
- COM0: CN15A 上 (SER0/UART3):
/dev/ttymxc2 - COM2: CN15B 下 (SER2/UART2):
/dev/ttymxc1 - COM3: (A53 debug/SER3/UART1):
/dev/ttymxc0 - COM1: (M4 debug/SER1/UART4):
/dev/ttymxc3
Loopback test (eg. ttymxc1) — Before loopback test, connect tx and rx:
stty -F /dev/ttymxc1 115200
stty -F /dev/ttymxc1 -echo
cat /dev/ttymxc1 &
echo test > /dev/ttymxc1
蓝牙使用方法(BlueTooth Operating Method)
$ hciconfig hci0 up
$ bluetoothctl
$ discoverable on
$ pairable on
$ scan on
[NEW] FC:18:3C:8D:75:F4 myphone
$ scan off
$ pair FC:18:3C:8D:75:F4
$ connect FC:18:3C:8D:75:F4
遠程訪問及文件傳輸(Remote Access and File Transimmion)
查看主板IP位址 (Check IP Address):
ifconfig
Windows下SSH访问及文件传输
SSH Remote Log into Device
- SSH远程登录,以putty选择putty.exe(或者使用Xshell、SecureCRT等类似软件)
- 需要设置远程设备的IP、通讯端口(默认22)、通讯方式,登录后验证用户名密码
通用方法(General Method)
查看CPU温度(Check CPU Temperature)
cat /sys/devices/virtual/thermal/thermal_zone0/temp
# 44600
# 或者直接以度爲單位顯示
echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]°
# >>> 45°
查看CPU频率(Check CPU Frequency)
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
# >> 900000
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
# >> 1200000
查看内存容量(Check Memory Capacity)
busybox free -m
# total used free shared buffers cached
# Mem: 1794920 516080 1278840 17252 9852 80292
# -/+ buffers/cache: 425936 1368984
# Swap: 0 0 0
查看存储容量(Check Storage Capacity)
busybox df -h
網路Ping測試(Ping Network Testing)
ping 8.8.8.8
# 64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
設置RTC (RTC Setting)
systemctl stop ntpdate.service
date 090816072021 && hwclock -w && date
# Wed Sep 8 16:07:00 UTC 2021
date
# Wed Sep 8 16:07:06 UTC 2021
Mic錄音 (Mic record)
amixer set Mic 20%
arecord -D plughw:0,0 -r 16000 -f S16_LE ./f-16000.wav
aplay ./f-16000.wav
PCIe裝置移除與rescan
# 移除 eth1
echo "1" > /sys/bus/pci/devices/0000\:01\:00.0/remove
# rescan 恢復 eth1
echo "1" > /sys/bus/pci/rescan
Linux BSP編譯方法(Linux BSP Compile Method)
Yocto 4.2
Yocto 3.0
Build known issue
如果有驗證上的錯誤 請使用以下的方法
repo sync failed — Server certificate verification failed
export GIT_SSL_NO_VERIFY=1
# or
git config --global http.sslverify false
nnshark error
https://community.nxp.com/t5/i-MX-Processors/Yocto-3-3-5-10-72-BSP-Build-Fail/m-p/1487902
