EPC-R4710_Debian_User_Guide
產品介紹(Product introduction )
產品特性(Product Features)
  • Rockchip RK3399 ARM Dual Cortex-A72 and Quad Cortex-A53 1.8 GHz
  • Onboard 2GB LPDDR4 memory and 16GB eMMC
  • Dual HDMI(4K 60fps + 1080P)
  • Support 4K H.264/H.265 Video decoder
  • 6 serial, 1 USB3.0, 4 USB2.0 ,1 USB OTG, 2 GbE, 1 SPI, 1 I2C, 5 GPIO
  • M.2 for WIFI/BT support, mini-PCIe for 3G/4G support
  • Support Linux and Android
產品官網連結(Product Features)
EPC-R4710
Packing List
Part NumberDescription
EPC-R4710EPC-R4710 Box computer
1960083394N001VESA MOUNT BKT 2U2X EPC-R4710
接口布局和尺寸(Layout and Sizes)
External I/O
RTENOTITLE
接口布局圖 Board Dimension Layout
RTENOTITLE
RTENOTITLE
RTENOTITLE RTENOTITLE
Connector List
AUDIOAudio pin header
EDPEDP CONN
LVDSLVDS CONN
BLLVDS BKL CONN
CSICSI CONN
MINIPCIEMINI PCIe 52P
SIMNano SIM card
M2M.2 CONN
SDSD slot
BTNPower button and LED
DCIN112V DC jack
COM1COM1
COM2/DebugCOM2
HDMI1HDMI1 CONN
HDMI2HDMI2 CONN
USB1USB Type A (USB 3.0 and 2.0)
USB2USB pin header
USB3USB pin header
LAN1LAN1
LAN2LAN2
BATRTC CONN
COM56COM5 and COM6 with RS-232 or RS-485
COM34COM3 and COM4 with RS-232
OTGUSB
RSTReset button
CN3GPIO CONN
CN1SPI
CN2I2C
接口引脚定義 (Pin definitions)
  • [电池扣(RTC)](./EPC-R4710_Debian_User_Guide_wiki_data/电池扣(RTC) "电池扣(RTC)".md)
  • 串口(RS-232 (COM1),RS-232/Debug Port (COM2/DEBUG),RS-232/485 (COM56),Internal RS-232 (COM34))
  • [显示接口(LVDS,LVDS_BL,EDP,HDMI)](./EPC-R4710_Debian_User_Guide_wiki_data/显示接口(LVDS,LVDS_BL,EDP,HDMI) "显示接口(LVDS,LVDS BL,EDP,HDMI)".md)
  • [LAN接口(LAN1,LAN2)](./EPC-R4710_Debian_User_Guide_wiki_data/LAN接口(LAN1,LAN2) "LAN接口(LAN1,LAN2)".md)
  • [USB接口(USB1,Pin Header,OTG)](./EPC-R4710_Debian_User_Guide_wiki_data/USB接口(USB1,Pin_Header,OTG) "USB接口(USB1,Pin Header,OTG)".md)
  • [音频接口(Audio)](./EPC-R4710_Debian_User_Guide_wiki_data/音频接口(Audio) "音频接口(Audio)".md)
  • [Micro SD & Nano SIM Card](./EPC-R4710_Debian_User_Guide_wiki_data/Micro_SD_&_Nano_SIM_Card "Micro SD & Nano SIM Card".md)
  • [电源及指示灯和开关机复位按钮(DC Power,Power Button and LED)](./EPC-R4710_Debian_User_Guide_wiki_data/电源及指示灯和开关机复位按钮(DC_Power,Power_Button_and_LED,Power_Button_and_LED) "电源及指示灯和开关机复位按钮(DC Power,Power Button and LED,Power Button and LED)".md)
  • [Mini PCIe & MIPI CSI 接口](./EPC-R4710_Debian_User_Guide_wiki_data/Mini_PCIe_&_MIPI_CSI_接口 "Mini PCIe & MIPI CSI 接口".md)
  • [M.2接口](./EPC-R4710_Debian_User_Guide_wiki_data/M.2接口 "M.2接口".md)
  • [GPIO接口](./EPC-R4710_Debian_User_Guide_wiki_data/GPIO接口 "GPIO接口".md)
  • [SPI ,I2C接口](./EPC-R4710_Debian_User_Guide_wiki_data/SPI_,I2C接口 "SPI ,I2C接口".md)
  • [RSB-4710 Jumper List](./EPC-R4710_Debian_User_Guide_wiki_data/RSB-4710_Jumper_List "RSB-4710 Jumper List".md)
**机械尺寸  (**Mechanical Characteristics)
RTENOTITLE
RTENOTITLE
快速入门 (Quick Start)
系统下载 (OS Download)
Debian 10:
Note:  LIV=Yocto Linux, UIV=Ubuntu, DIV=Debian, AIV=Android
             LBV=BSP, LIV=Image
PlatformProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagComment
RK3399RSB-4710DIV2510292022/03/15GARelease_NoteBaidu      Password:a887 DropboxRK3399_RISC_DIV251029.xmlMP Version
Android &Debian 燒錄方法 (Android Flash eMMC Method)
There are three ways to update images:
[1.Using_AndroidToool.](./EPC-R4710_Debian_User_Guide_wiki_data/1._Using_AndroidToool. "1. Using AndroidToool.".md)
There is no limitation by this way.
[2.Using_storage(such sd_or_USB_disk)with_update.zip_in_it.](./EPC-R4710_Debian_User_Guide_wiki_data/2._Using_storage(such_sd_or_USB_disk)with_update.zip_in_it. "2. Using storage(such sd or USB disk)with update.zip in it.".md)
There are some limitations:
(1)The device must be able to boot up to Android system.
(2)Only update images from the same os,  eg :
        Android6.0 upgrade to Android6.0 or Android7.1 upgrade to Android7.1.
(3)Using update.zip to upgrade. (see more detail in "Create OTA zip" on how to create update.zip)
[3.Using_bootup_sd_disk made_by SDDiskTool.](./EPC-R4710_Debian_User_Guide_wiki_data/3._Using_bootup_sd_disk_made_by_SDDiskTool. "3. Using bootup sd disk made by SDDiskTool.".md)
(1)Only update images from the same os,  eg :
(2)Using update.img to upgrade.
Linux系统的基本使用(Linux System Basic Operating Method)
User Guide
RISC series(RSB-3710/RSB-4710/ROM-5780)
  • Linux BSP User Guide for rk3399 series Debian9/Debian10.)
  • Getting Start.)
  • MAC_Address
DS-100
  • [Linux BSP User Guide for rk3399 series Debian9](./EPC-R4710_Debian_User_Guide_wiki_data/IoTGateway/BSP/Linux/Linux_BSP_User_Guide_Debian9_for_rk "IoTGateway/BSP/Linux/Linux BSP User Guide Debian9 for rk".md)
  • [Linux BSP User Guide for rk3399 series DeviceOn](./EPC-R4710_Debian_User_Guide_wiki_data/IoTGateway/BSP/Linux/Linux_BSP_User_Guide_DeviceOn "IoTGateway/BSP/Linux/Linux BSP User Guide DeviceOn".md)
  • [Linux BSP User Guide for SGI [DMS-SA53]](./EPC-R4710_Debian_User_Guide_wiki_data/IoTGateway/BSP/Linux/Linux_BSP_User_Guide_SGI "IoTGateway/BSP/Linux/Linux BSP User Guide SGI".md)
通用方法(General Method)
乙太網路使用方法(Ethernent Testing Method)
Command : ifconfig
root@linaro-alip:~# ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:83:27:77:c0  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.127.101  netmask 255.255.255.0  broadcast 192.168.127.255
        inet6 fe80::e405:b000:5963:d697  prefixlen 64  scopeid 0x20<link>
        ether c6:ff:6c:34:9d:7d  txqueuelen 1000  (Ethernet)
        RX packets 23  bytes 7566 (7.3 KiB)
        TX packets 45  bytes 5391 (5.2 KiB)
        device interrupt 24
eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 96:a4:98:8d:52:09  txqueuelen 1000  (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 484  bytes 32428 (31.6 KiB)
        TX packets 484  bytes 32428 (31.6 KiB)
Command : ping 192.168.127.101
root@linaro-alip:~# ping 192.168.127.101
PING 192.168.127.101 (192.168.127.101) 56(84) bytes of data.
64 bytes from 192.168.127.101: icmp_seq=1 ttl=64 time=0.221 ms
64 bytes from 192.168.127.101: icmp_seq=2 ttl=64 time=0.135 ms
64 bytes from 192.168.127.101: icmp_seq=3 ttl=64 time=0.134 ms
64 bytes from 192.168.127.101: icmp_seq=4 ttl=64 time=0.137 ms
64 bytes from 192.168.127.101: icmp_seq=5 ttl=64 time=0.137 ms
^C
--- 192.168.127.101 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 0.134/0.152/0.221/0.037 ms
root@linaro-alip:~#
查看CPU温度(Check CPU Temperature)
root@linaro-alip:~# cat /sys/devices/virtual/thermal/thermal_zone0/temp   34444
# 或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 37°
查看CPU频率(Check CPU Frequency)
root@linaro-alip:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
408000
root@linaro-alip:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
1416000
查看内存容量(Check Memory Capacity)
root@linaro-alip:~# busybox free -m
              total        used        free      shared  buff/cache   available
Mem:           1961         269        1454          18         237        1696
Swap:             0           0           0
查看存储容量(Check Storage Capacity)
root@linaro-alip:~# df -h
Filesystem       Size  Used Avail Use% Mounted on
/dev/root        7.9G  2.6G  4.9G  35% /
devtmpfs         973M  8.0K  973M   1% /dev
tmpfs            981M     0  981M   0% /dev/shm
tmpfs            981M  8.9M  972M   1% /run
tmpfs            5.0M  4.0K  5.0M   1% /run/lock
tmpfs            981M     0  981M   0% /sys/fs/cgroup
/dev/mmcblk1p10  6.4G  3.8M  6.4G   1% /userdata
/dev/mmcblk1p7    63M   13M   48M  21% /oem
tmpfs            197M  8.0K  197M   1% /run/user/1000
tmpfs            197M     0  197M   0% /run/user/0
root@linaro-alip:~#
設置RTC (RTC Setting)
root@linaro-alip:~# date
Wed May 11 01:12:06 UTC 2022
root@linaro-alip:~# date -s "2022-5-11 09:12:00"
Wed May 11 09:12:00 UTC 2022
Wed May 11 09:12:06 UTC 2022
root@linaro-alip:~# hwclock -w
2022-05-11 09:12:17.266424+00:00
WiFi使用方法(WIFI Testing Method)
1.Click Settings
2.Turn on Wi-Fi
3.Choose ESSID (for example, Advantech for guest)
4.Input the password
5.Wi-Fi connected
4G使用方法(4G Testing Method)
蓝牙使用方法(BlueTooth Operating Method)
音訊使用方法(BlueTooth Operating Method)
I2C 測試( I2C Test method)
看門狗測試 (Watch Dog Test method)
攝像頭測試(Camera Test method)
**遠程訪問及文件傳輸(Remote Access and File Transimmion)**​
QT 安装步骤
[Qt5Creator_toolchain_Qt_5.11.3](./EPC-R4710_Debian_User_Guide_wiki_data/Qt5Creator_toolchain_Qt_5.11.3 "Qt5Creator toolchain Qt 5.11.3".md)
