RSB-4710_Debian_User_Guide
產品介紹(Product introduction )
產品特性(Product Features)
- Rockchip RK3399 ARM Dual Cortex-A72 and Quad Cortex-A53 1.8 GHz
- Onboard 2GB LPDDR4 memory and 16GB eMMC
- Dual HDMI(4K 60fps + 1080P), 1 x eDP, 1 x dual channel LVDS, 1 x MIPI CSI
- Supports 4K H.264/H.265 video decoder
- 6 x serial, 1 x USB3.0, 4 x USB2.0 ,1 x USB OTG, 2 x GbE, 1 x SPI, 1 x I2C, 5 x GPIOs
- M.2 for WIFI/BT support, mini-PCIe for 3G/4G support
- Supports Debian9/10 and Android7.1/10.0
產品官網連結(Product official website link)
硬件接口說明(Hardware interface introduction)
接口布局和尺寸(Layout and Sizes)
接口布局圖 Board Dimension Layout
Connector List
| AUDIO | Audio pin header |
| EDP | EDP CONN |
| LVDS | LVDS CONN |
| BL | LVDS BKL CONN |
| CSI | CSI CONN |
| MINIPCIE | MINI PCIe 52P |
| SIM | Nano SIM card |
| M2 | M.2 CONN |
| SD | SD slot |
| BTN | Power button and LED |
| DCIN1 | 12V DC jack |
| COM1 | COM1 |
| COM2/Debug | COM2 |
| HDMI1 | HDMI1 CONN |
| HDMI2 | HDMI2 CONN |
| USB1 | USB Type A (USB 3.0 and 2.0) |
| USB2 | USB pin header |
| USB3 | USB pin header |
| LAN1 | LAN1 |
| LAN2 | LAN2 |
| BAT | RTC CONN |
| COM56 | COM5 and COM6 with RS-232 or RS-485 |
| COM34 | COM3 and COM4 with RS-232 |
| OTG | USB |
| RST | Reset button |
| CN3 | GPIO CONN |
| CN1 | SPI |
| CN2 | I2C |
接口引脚定義 (Pin definitions)
- [电池扣(RTC)](./RSB-4710_Debian_User_Guide_wiki_data/电池扣(RTC) "电池扣(RTC)".md)
- 串口(RS-232 (COM1),RS-232/Debug Port (COM2/DEBUG),RS-232/485 (COM56),Internal RS-232 (COM34))
- [显示接口(LVDS,LVDS_BL,EDP,HDMI)](./RSB-4710_Debian_User_Guide_wiki_data/显示接口(LVDS,LVDS_BL,EDP,HDMI) "显示接口(LVDS,LVDS BL,EDP,HDMI)".md)
- [LAN接口(LAN1,LAN2)](./RSB-4710_Debian_User_Guide_wiki_data/LAN接口(LAN1,LAN2) "LAN接口(LAN1,LAN2)".md)
- [USB接口(USB1,Pin Header,OTG)](./RSB-4710_Debian_User_Guide_wiki_data/USB接口(USB1,Pin_Header,OTG) "USB接口(USB1,Pin Header,OTG)".md)
- [音频接口(Audio)](./RSB-4710_Debian_User_Guide_wiki_data/音频接口(Audio) "音频接口(Audio)".md)
- [Micro SD & Nano SIM Card](./RSB-4710_Debian_User_Guide_wiki_data/Micro_SD_&_Nano_SIM_Card "Micro SD & Nano SIM Card".md)
- [电源及指示灯和开关机复位按钮(DC Power,Power Button and LED)](./RSB-4710_Debian_User_Guide_wiki_data/电源及指示灯和开关机复位按钮(DC_Power,Power_Button_and_LED,Power_Button_and_LED) "电源及指示灯和开关机复位按钮(DC Power,Power Button and LED,Power Button and LED)".md)
- [Mini PCIe & MIPI CSI 接口](./RSB-4710_Debian_User_Guide_wiki_data/Mini_PCIe_&_MIPI_CSI_接口 "Mini PCIe & MIPI CSI 接口".md)
- [M.2接口](./RSB-4710_Debian_User_Guide_wiki_data/M.2接口 "M.2接口".md)
- [GPIO接口](./RSB-4710_Debian_User_Guide_wiki_data/GPIO接口 "GPIO接口".md)
- [SPI ,I2C接口](./RSB-4710_Debian_User_Guide_wiki_data/SPI_,I2C接口 "SPI ,I2C接口".md)
- [RSB-4710 Jumper List](./RSB-4710_Debian_User_Guide_wiki_data/RSB-4710_Jumper_List "RSB-4710 Jumper List".md)
**机械尺寸 (**Mechanical Characteristics)
快速入门 (Quick Start)
系统下载 (OS Download)
Note: LIV=Yocto Linux, UIV=Ubuntu, DIV=Debian, AIV=Android
LBV=BSP, LIV=Image
Debian 10:
| Platform | Product | Image Version | Release Date | Release Version | Release notes | Image Download | BSP Download Tag | Comment |
| RK3399 | RSB-4710 | DIV251029 | 2022/03/15 | GA | Release_Note | Baidu Password:a887 Dropbox | RK3399_RISC_DIV251029.xml | MP Version |
Debian 9 :
| RK3399 | RSB-4710 | DIV10030 | 2020/12/11 | Alpha | Release_Note | Baidu Password:a887 Dropbox | RK3399_RISC_DIV10030.xml |
Alpha: Basic I/O function bring up by RD;
Beta: Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
GA: Beta version by QE verification;
RTM: Beta version by SI/Power/QE verification and pre-loaded;
Using AndroidTool: AndroidTool
Debian 燒錄方法 (Android Flash eMMC Method)
There are three ways to update images:
[1._Using_AndroidToool.](./RSB-4710_Debian_User_Guide_wiki_data/1._Using_AndroidToool. "1. Using AndroidToool.".md)
There is no limitation by this way.
[2._Using_storage(such sd_or_USB_disk)with_update.zip_in_it.](./RSB-4710_Debian_User_Guide_wiki_data/2._Using_storage(such_sd_or_USB_disk)with_update.zip_in_it. "2. Using storage(such sd or USB disk)with update.zip in it.".md)
There are some limitations:
(1)The device must be able to boot up to Android system.
(2)Only update images from the same os, eg :
Android6.0 upgrade to Android6.0 or Android7.1 upgrade to Android7.1.
(3)Using update.zip to upgrade. (see more detail in "Create OTA zip" on how to create update.zip)
[3._Using_bootup_sd_disk made_by SDDiskTool.](./RSB-4710_Debian_User_Guide_wiki_data/3._Using_bootup_sd_disk_made_by_SDDiskTool. "3. Using bootup sd disk made by SDDiskTool.".md)
(1)Only update images from the same os, eg :
(2)Using update.img to upgrade.
Linux系统的基本使用(Linux System Basic Operating Method)
User Guide
RISC series(RSB-3710/RSB-4710/ROM-5780)
- Linux BSP User Guide for rk3399 series Debian9/Debian10.)
- Getting Start.)
- MAC_Address
DS-100
- [Linux BSP User Guide for rk3399 series Debian9](./RSB-4710_Debian_User_Guide_wiki_data/IoTGateway/BSP/Linux/Linux_BSP_User_Guide_Debian9_for_rk "IoTGateway/BSP/Linux/Linux BSP User Guide Debian9 for rk".md)
- [Linux BSP User Guide for rk3399 series DeviceOn](./RSB-4710_Debian_User_Guide_wiki_data/IoTGateway/BSP/Linux/Linux_BSP_User_Guide_DeviceOn "IoTGateway/BSP/Linux/Linux BSP User Guide DeviceOn".md)
- [Linux BSP User Guide for SGI [DMS-SA53]](./RSB-4710_Debian_User_Guide_wiki_data/IoTGateway/BSP/Linux/Linux_BSP_User_Guide_SGI "IoTGateway/BSP/Linux/Linux BSP User Guide SGI".md)
通用方法(General Method)
乙太網路使用方法(Ethernent Testing Method)
Command : ifconfig
root@linaro-alip:~# ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:83:27:77:c0 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.127.101 netmask 255.255.255.0 broadcast 192.168.127.255
inet6 fe80::e405:b000:5963:d697 prefixlen 64 scopeid 0x20<link>
ether c6:ff:6c:34:9d:7d txqueuelen 1000 (Ethernet)
RX packets 23 bytes 7566 (7.3 KiB)
TX packets 45 bytes 5391 (5.2 KiB)
device interrupt 24
eth1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 96:a4:98:8d:52:09 txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 484 bytes 32428 (31.6 KiB)
TX packets 484 bytes 32428 (31.6 KiB)
Command : ping 192.168.127.101
root@linaro-alip:~# ping 192.168.127.101
PING 192.168.127.101 (192.168.127.101) 56(84) bytes of data.
64 bytes from 192.168.127.101: icmp_seq=1 ttl=64 time=0.221 ms
64 bytes from 192.168.127.101: icmp_seq=2 ttl=64 time=0.135 ms
64 bytes from 192.168.127.101: icmp_seq=3 ttl=64 time=0.134 ms
64 bytes from 192.168.127.101: icmp_seq=4 ttl=64 time=0.137 ms
64 bytes from 192.168.127.101: icmp_seq=5 ttl=64 time=0.137 ms
^C
--- 192.168.127.101 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 0.134/0.152/0.221/0.037 ms
root@linaro-alip:~#
查看CPU温度(Check CPU Temperature)
root@linaro-alip:~# cat /sys/devices/virtual/thermal/thermal_zone0/temp 34444
# 或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 37°
查看CPU频率(Check CPU Frequency)
root@linaro-alip:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
408000
root@linaro-alip:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
1416000
查看内存容量(Check Memory Capacity)
root@linaro-alip:~# busybox free -m
total used free shared buff/cache available
Mem: 1961 269 1454 18 237 1696
Swap: 0 0 0
查看存储容量(Check Storage Capacity)
root@linaro-alip:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.9G 2.6G 4.9G 35% /
devtmpfs 973M 8.0K 973M 1% /dev
tmpfs 981M 0 981M 0% /dev/shm
tmpfs 981M 8.9M 972M 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 981M 0 981M 0% /sys/fs/cgroup
/dev/mmcblk1p10 6.4G 3.8M 6.4G 1% /userdata
/dev/mmcblk1p7 63M 13M 48M 21% /oem
tmpfs 197M 8.0K 197M 1% /run/user/1000
tmpfs 197M 0 197M 0% /run/user/0
root@linaro-alip:~#
設置RTC (RTC Setting)
root@linaro-alip:~# date
Wed May 11 01:12:06 UTC 2022
root@linaro-alip:~# date -s "2022-5-11 09:12:00"
Wed May 11 09:12:00 UTC 2022
Wed May 11 09:12:06 UTC 2022
root@linaro-alip:~# hwclock -w
2022-05-11 09:12:17.266424+00:00
WiFi使用方法(WIFI Testing Method)
1.Click Settings
2.Turn on Wi-Fi
3.Choose ESSID (for example, Advantech for guest)
4.Input the password
5.Wi-Fi connected
4G使用方法(4G Testing Method)
蓝牙使用方法(BlueTooth Operating Method)
音訊使用方法(BlueTooth Operating Method)
Record: record audio to 1.wav file
arecord -f cd -d 10 -t wav 1.wav
Play: play the 1.wav file
aplay -Dplughw:0,0 1.wav
Connect audio cable from PC to RSB-4710 Mic-in or Line-in
Play audio on the PC and ensure there is audio output.
Connect Lien-out with head phone to check if there is an audio output from the RSB-4710 Line-out:
Mic-in:
arecord -f cd -t wav | aplay -Dplughw:0,0 -t wav
Line-in:
Switch to line-in:
amixer -c0 cset name="RECMIXL BST3 Switch" 1
I2C 測試( I2C Test method)
看門狗測試 (Watch Dog Test method)
攝像頭測試(Camera Test method)
**遠程訪問及文件傳輸(Remote Access and File Transimmion)**
QT 安装步骤
[Qt5Creator_toolchain_Qt_5.11.3](./RSB-4710_Debian_User_Guide_wiki_data/Qt5Creator_toolchain_Qt_5.11.3 "Qt5Creator toolchain Qt 5.11.3".md)
How to build Debian 9 & 10 BSP (Debian 9 & 10 BSP 編譯)
<http://ess-wiki.advantech.com.tw/view/Debian_BSP_User_Guide_for_rk3399_risc_series>
