ROM-5880_Android_User_Guide
产品特性(Features)
  • Rockchip RK3568 Arm Quad Cortex-A55 up to 2.0GHz
  • Onboard 2/4GB LPDDR4 memory and 16/32GB eMMC
  • Support 1 x HDMI2.0 4K, 1 x signal LVDS or 1 x MIPI DSI
  • Support 4K H.264/H.265 Video decoder
  • 2 x USB3.0, 2 x USB2.0, 4 x UART, 14 x GPIO
  • 2 x PCIe3.0, 1 x SATA, 1 x MIPI CSI, 2 x Gigabit LAN
  • Support Linux & Android
ROM-5880 - 基于瑞芯微RK3568平台的SMARC2.1核心模块 - 研华 (advantech.com.cn)
接口布局和尺寸(Layout and Sizes)
ROM-5880接口布局图 Board Dimension Layout
RTENOTITLE
Connector List
Debug
PositionDescription
DEBUGDEBUG Port
Switch
PositionDescription
SW1AT&ATX mode selection
SW1:AT/ATX Mode Selection
SettingFunction
1 off  2 onAT Mode(Default)
1 on 2 offATX Mode
RTENOTITLE
SOM-DB2510 A1 Board Dimension Layout
The figures below indicate the main chips on SOM-DB2510 Development Board for  SMARC 2.1.
RTENOTITLE
SOM-DB2510 Connectors and Jumper Settings
Connector Locations
RTENOTITLE
RTENOTITLE
Switch Locations
RTENOTITLE
I/O Connctor Locations
RTENOTITLE
Button Locations
RTENOTITLE
LED Locations
RTENOTITLE
LabelFunctionLabelFunction
ATX1ATX ConnectorFAN1Smart Fan Connector
SMARC_IN1Wide Range Input Power Connector (3V~5.25V)FAN2System Fan Connector
DCIN1DCIN connectorCAN0_1CAN Bus Connector
DP0_HDMIDP & HDMI ConnectorUSB0USB OTG Connector
USB12USB 2.0 port1~2 & USB 3.0 port0 ConnectorCOM1_3COM Port Port1,3 Connector
TYPEC_DP1Type-C ConnectorCOM2_4COM Port Port2,4 Connector
LAN0_LAN1LAN0 & LAN1 ConnectorCN8I2C connector for I2C_PM
LOUT1Line Out ConnectorCN7I2C Connector for I2C_GP
MIC1MIC1 ConnectorCN10eSPI Pin Header
CN1_MXM1SMARC ConnectorSATAP1SATA Power Connector
PCIEA-X4PCIe x4 ConnectorCSI0_B2BMIPI B2B Connector for 2M Camera
SATA1SATA Port0 ConnectorCSI1_B2BMIPI B2B Connector for 8M & 13M Camera
PCIED-X1PCIe x1 ConnectorSPI_BIOS1Carrier Board BIOS Socket (SOIC)
M2M.2 Key-E ConnectorBAT1Coin battery holder
MPCIE_CMini PCIe ConnectorBAT2Smart battery Connector
SIMSIM card ConnectorLINEOUT_1I2S Headphone Connector
LVDS1LVDS1 ConnectorMIC_1I2S MIC In Connector
LVDS0LVDS0 ConnectorCSI1_FPCMIPI FPC Connector for 8M & 13M Camera
LVDS1_INVERTERLVDS1 Invertor ConnectorCSI0_FPCMIPI FPC Connector for 2M Camera
LVDS0_INVERTERLVDS0 Invertor ConnectorCN5I2S2 Connector
SPI_BIOS2Carrier Board BIOS Socket (QFN)CN17I2S0 Connector
SDSD Card Connector
Jumper Locations
RTENOTITLE
RTENOTITLE
LableFunctionLableFunction
BTN3Sleep ButtonJ14EDP1/LVDS1 Hot-Plug Detect Selection Header
BTN1Power ButtonJ56Standby Voltage Control Header
BTN2Reset ButtonJ44Module +3.3V/+5V Power Selection Header
SW4BOOT SELECT SwitchPSON1AT/ATX Selection Header
LID1LID SwitchSPI_CN1SPI Header
J30Enable Battery Low# HeaderCN14For CAN Bus port0 Terminal Resistor
M2E_DISABLE_N1M.2 Wireless DisableCN15For CAN Bus port1 Terminal Resistor
J29SMB Alert Enable HeaderJ3/J4DP0 EQ0 Selection
CN9Header For GPIO TestJ5/J6DP0 EQ1 Selection
J7/J8LVDS0 Power Selection HeaderJ58PCIE_B_CKREQ# Selection
J11/J12LVDS1 Power Selection HeaderJ59PCIE_A_CKREQ# Selection
J9LVDS0 Inverter Power Selection HeadeGPIO_0GPIO0/CAM0_PWR# Selection
J10EDP0/LVDS0 Hot-Plug Detect Selection HeaderGPIO_1GPIO1/CAM1_PWR# Selection
J26HDA/I2S Selection HeaderGPIO_2GPIO2/CAM0_RST# Selection
J1DP1/HDMI1 SelectGPIO_3GPIO3/CAM1_RST# Selection
J13LVDS1 Inverter Power Selection HeaderGPIO_4GPIO4/HDA_RST# Selection
J31Clear CMOS HeaderGPIO_5GPIO5/PWM_OUT Selection
J25SPI Power HeaderGPIO_6GPIO6/TACHIN Selection
SW1COM1 mode SelectSATA_ACT_PH1SATA act# Header
SW2COM3 mode SelectPWRBTN_PH1Power button Header
J41Core Power Voltage Control HeaderSYS_RESET_PH1Reset button Header
J2DDI1 AUX/DDC Selection
LED Function List
LocationFunction
MODULE_VIN_LED1WDT_TIME_OUT# Indicate
MODULE_5V_LEDModule 5V Indicate
MODULE_VIN_LEDModule +V_MOD_IN Indicate
RESET_OUT_LEDRESET_OUT Indicate
RESET_OUT_LEDCARRIER_STBY Indicate
CARRIER_PWR_ON_LEDCARRIER_PWR_ON Indicate
MODULE_3P3V_LEDModule 3.3V Indicate
3P3V_LEDCarrier Board +V3.3 Indicate
5V_LEDCarrier Board +V5 Indicate
5V_DUAL_LEDCarrier Board +V5SB Indicate
3P3V_DUAL_LEDCarrier Board +V3.3SB Indicate
5VA_LEDCarrier Board +V5D_MOD Indicate
SATA_LEDSATA Indicate
SOM_LEDSOM BOM Indicate
RISC_LEDRISC BOM Indicate
Switch Settings
  • [SW4](./ROM-5880_Android_User_Guide_wiki_data/SW4 "SW4".md) (Boot Select/Force Recovery/Test Switches)
  • [LID1](./ROM-5880_Android_User_Guide_wiki_data/LID1 "LID1".md) (LID Button Enable/Disable Switches)
  • [SW5](./ROM-5880_Android_User_Guide_wiki_data/SW5 "SW5".md) (LAN CONN LED Pull High Switches)
  • [SW1](./ROM-5880_Android_User_Guide_wiki_data/COM0_Settings "COM0 Settings".md)(COM0 Settings)
  • [SW2](./ROM-5880_Android_User_Guide_wiki_data/SW2 "SW2".md)(COM2 Settings)
  • [SW3](./ROM-5880_Android_User_Guide_wiki_data/I2S_Clock_Settings "I2S Clock Settings".md)(I2S Clock Settings)
  • [M2E_DISABLE_N1](./ROM-5880_Android_User_Guide_wiki_data/M2E_DISABLE_N1 "M2E DISABLE N1".md)(M.2 Wireless Disable Switch)
接口引脚定義 (Connector Pin definitions)
  • [ATX1 Pin Connector](./ROM-5880_Android_User_Guide_wiki_data/ATX1_Pin_Connector "ATX1 Pin Connector".md)
  • [SMARC_IN1 Pin Connectors](./ROM-5880_Android_User_Guide_wiki_data/SMARC_IN1_Pin_Connectors "SMARC IN1 Pin Connectors".md)
  • [BAT1 RTC Battery Connectors](./ROM-5880_Android_User_Guide_wiki_data/BAT1_RTC_Battery_Connectors "BAT1 RTC Battery Connectors".md)
  • [DCIN1 DC-IN Power Connectors](./ROM-5880_Android_User_Guide_wiki_data/DCIN1_DC-IN_Power_Connectors "DCIN1 DC-IN Power Connectors".md)
  • [CAN0_1 CAN Bus Connectors](./ROM-5880_Android_User_Guide_wiki_data/CAN0_1_CAN_Bus_Connectors "CAN0 1 CAN Bus Connectors".md)
  • [CN9 GPIO Headers](./ROM-5880_Android_User_Guide_wiki_data/CN9_GPIO_Headers "CN9 GPIO Headers".md)
  • [COM2_4 COM Port2&4 Connectors](./ROM-5880_Android_User_Guide_wiki_data/COM2_4_COM_Port2&4_Connectors "COM2 4 COM Port2&4 Connectors".md)
  • [COM1_3 COM Port1& 3 Connectors](./ROM-5880_Android_User_Guide_wiki_data/COM1_3_COM_Port1&_3_Connectors "COM1 3 COM Port1& 3 Connectors".md)
  • [CN10 ESPI Headers](./ROM-5880_Android_User_Guide_wiki_data/CN10_ESPI_Headers "CN10 ESPI Headers".md)
  • [LVDS0 LVDS Connectors](./ROM-5880_Android_User_Guide_wiki_data/LVDS0_LVDS_Connectors "LVDS0 LVDS Connectors".md)
  • [LVDS0_INVERTER LVDS INVERTER Connectors](./ROM-5880_Android_User_Guide_wiki_data/LVDS0_INVERTER_LVDS_INVERTER_Connectors "LVDS0 INVERTER LVDS INVERTER Connectors".md)
  • [LVDS1 LVDS Connectors](./ROM-5880_Android_User_Guide_wiki_data/LVDS1_LVDS_Connectors "LVDS1 LVDS Connectors".md)
  • [LVDS1_INVERTER LVDS INVERTER Connectors](./ROM-5880_Android_User_Guide_wiki_data/LVDS1_INVERTER_LVDS_INVERTER_Connectors "LVDS1 INVERTER LVDS INVERTER Connectors".md)
  • [CN7 I2C_GP Connectors](./ROM-5880_Android_User_Guide_wiki_data/CN7_I2C_GP_Connectors "CN7 I2C GP Connectors".md)
  • [SPI_CN1 SPI Connectors](./ROM-5880_Android_User_Guide_wiki_data/SPI_CN1_SPI_Connectors "SPI CN1 SPI Connectors".md)
  • [SATAP1 SATA PWR Connectors](./ROM-5880_Android_User_Guide_wiki_data/SATAP1_SATA_PWR_Connectors "SATAP1 SATA PWR Connectors".md)
  • [CSI0_FPC Connectors](./ROM-5880_Android_User_Guide_wiki_data/CSI0_FPC_Connectors "CSI0 FPC Connectors".md)
  • [CSI1_FPC Connectors](./ROM-5880_Android_User_Guide_wiki_data/CSI1_FPC_Connectors "CSI1 FPC Connectors".md)
  • [CN5 I2S2 Connectors](./ROM-5880_Android_User_Guide_wiki_data/CN5_I2S2_Connectors "CN5 I2S2 Connectors".md)
  • [CN17 I2S0 Connectors](./ROM-5880_Android_User_Guide_wiki_data/CN17_I2S0_Connectors "CN17 I2S0 Connectors".md)
  • [PWRBTN_PH1 PWRBTN Pin Headers](./ROM-5880_Android_User_Guide_wiki_data/PWRBTN_PH1_PWRBTN_Pin_Headers "PWRBTN PH1 PWRBTN Pin Headers".md)
  • [SYS_RESET_PH1 SYS RESET Pin Headers](./ROM-5880_Android_User_Guide_wiki_data/SYS_RESET_PH1_SYS_RESET_Pin_Headers "SYS RESET PH1 SYS RESET Pin Headers".md)
  • [SATA_ACT_PH1 SATA ACT# Pin Headers](./ROM-5880_Android_User_Guide_wiki_data/SATA_ACT_PH1_SATA_ACT "SATA ACT PH1 SATA ACT".md)
  • [J32 Power LED Pin Headers](./ROM-5880_Android_User_Guide_wiki_data/J32_Power_LED_Pin_Headers "J32 Power LED Pin Headers".md)
  • [J30 BATLOW Pin Headers](./ROM-5880_Android_User_Guide_wiki_data/J30_BATLOW_Pin_Headers "J30 BATLOW Pin Headers".md)
  • [J29 SMBUS Alert Pin Headers](./ROM-5880_Android_User_Guide_wiki_data/J29_SMBUS_Alert_Pin_Headers "J29 SMBUS Alert Pin Headers".md)
  • [J41 Core Power Controls](./ROM-5880_Android_User_Guide_wiki_data/J41_Core_Power_Controls "J41 Core Power Controls".md)
  • [PSON1 ATX/AT Mode Selection](./ROM-5880_Android_User_Guide_wiki_data/PSON1_ATX/AT_Mode_Selection "PSON1 ATX/AT Mode Selection".md)
  • [J56 Standby Power Controls](./ROM-5880_Android_User_Guide_wiki_data/J56_Standby_Power_Controls "J56 Standby Power Controls".md)
  • [J44 Module Power Settings](./ROM-5880_Android_User_Guide_wiki_data/J44_Module_Power_Settings "J44 Module Power Settings".md)
  • [J7,J8 LVDS0 Power Selection](./ROM-5880_Android_User_Guide_wiki_data/J7,J8_LVDS0_Power_Selection "J7,J8 LVDS0 Power Selection".md)
  • [J9 LVDS0 Inverter Power Selection](./ROM-5880_Android_User_Guide_wiki_data/J9_LVDS0_Inverter_Power_Selection "J9 LVDS0 Inverter Power Selection".md)
  • [J11,J12 LVDS1 Power Selection](./ROM-5880_Android_User_Guide_wiki_data/J11,J12_LVDS1_Power_Selection "J11,J12 LVDS1 Power Selection".md)
  • [LVDS1 Inverter Power Selection](./ROM-5880_Android_User_Guide_wiki_data/LVDS1_Inverter_Power_Selection "LVDS1 Inverter Power Selection".md)
  • [EDP0 /LVDS0 HPD Selection](./ROM-5880_Android_User_Guide_wiki_data/EDP0_/LVDS0_HPD_Selection "EDP0 /LVDS0 HPD Selection".md)
  • [J14 EDP1/LVDS1 HPD Selection](./ROM-5880_Android_User_Guide_wiki_data/J14_EDP1/LVDS1_HPD_Selection "J14 EDP1/LVDS1 HPD Selection".md)
  • [CN14 CAN0 Terminal Resistor Selection](./ROM-5880_Android_User_Guide_wiki_data/CN14_CAN0_Terminal_Resistor_Selection "CN14 CAN0 Terminal Resistor Selection".md)
  • [CN15 CAN1 Terminal Resistor Selection](./ROM-5880_Android_User_Guide_wiki_data/CN15_CAN1_Terminal_Resistor_Selection "CN15 CAN1 Terminal Resistor Selection".md)
  • [J2 DDI1 AUX/DDC Selection](./ROM-5880_Android_User_Guide_wiki_data/J2_DDI1_AUX/DDC_Selection "J2 DDI1 AUX/DDC Selection".md)
  • [J1 DP1/HDMI1 Selection](./ROM-5880_Android_User_Guide_wiki_data/J1_DP1/HDMI1_Selection "J1 DP1/HDMI1 Selection".md)
  • [J58 PCIE_B_CKREQ# Selection](./ROM-5880_Android_User_Guide_wiki_data/J58_PCIE_B_CKREQ "J58 PCIE B CKREQ".md)
  • [J59 PCIE_A_CKREQ# Selection](./ROM-5880_Android_User_Guide_wiki_data/J59_PCIE_A_CKREQ "J59 PCIE A CKREQ".md)
  • [J31 Clear CMOS](./ROM-5880_Android_User_Guide_wiki_data/J31_Clear_CMOS "J31 Clear CMOS".md)
  • [J25 +V1.8M_SPI Power Jumpers](./ROM-5880_Android_User_Guide_wiki_data/J25_+V1.8M_SPI_Power_Jumpers "J25 +V1.8M SPI Power Jumpers".md)
  • [GPIO_0 GPIO0 Settings](./ROM-5880_Android_User_Guide_wiki_data/GPIO_0_GPIO0_Settings "GPIO 0 GPIO0 Settings".md)
  • [GPIO_1 GPIO1 Settings](./ROM-5880_Android_User_Guide_wiki_data/GPIO_1_GPIO1_Settings "GPIO 1 GPIO1 Settings".md)
  • [GPIO_2 GPIO2 Settings](./ROM-5880_Android_User_Guide_wiki_data/GPIO_2_GPIO2_Settings "GPIO 2 GPIO2 Settings".md)
  • [GPIO_3 GPIO3 Settings](./ROM-5880_Android_User_Guide_wiki_data/GPIO_3_GPIO3_Settings "GPIO 3 GPIO3 Settings".md)
  • [GPIO_4 GPIO4 Settings](./ROM-5880_Android_User_Guide_wiki_data/GPIO_4_GPIO4_Settings "GPIO 4 GPIO4 Settings".md)
  • [GPIO_5 GPIO5 Settings](./ROM-5880_Android_User_Guide_wiki_data/GPIO_5_GPIO5_Settings "GPIO 5 GPIO5 Settings".md)
  • [GPIO_6 GPIO6 Settings](./ROM-5880_Android_User_Guide_wiki_data/GPIO_6_GPIO6_Settings "GPIO 6 GPIO6 Settings".md)
  • [J26 HDA/I2S Selection](./ROM-5880_Android_User_Guide_wiki_data/J26_HDA/I2S_Selection "J26 HDA/I2S Selection".md)
ROM-5880 机械尺寸(Mechanical Characteristics)
  • Dimension: SMARC form factor size: (D x W) 82 x 50 mm/3.22 x 1.9 in
RTENOTITLE
  • Height on top: Under 3.0 mm
  • Height on bottom: Under 2.0 mm
RTENOTITLE
**SOM-DB2510_A1 机械尺寸 (**Mechanical Characteristics)
For more details regarding our 2D/3D models, please visit the Advantech COM support  service website at: <http://com.advantech.com.
Board Mechanical Diagram -Front
RTENOTITLE
Board Mechanical Diagram -Side1
RTENOTITLE
Board Mechanical Diagram -Side2
RTENOTITLE
Assemblly Diagram
These figures demonstrate the order of assembly needed when attaching the thermal  module and COM module to the carrier board.
RTENOTITLE
快速入门 (Quick Start)
系统下载 (OS Download)
Note:LIV=Yocto Linux , UIV=Ubuntu,DIV=Debain,AIV=Android,  LBV=BSP,LIV=Image
PlatformProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagComment
RK3568ROM-5880V120152024/02/01GA[Release_Note](./ROM-5880_Android_User_Guide_wiki_data/ROM-5880_Android12-Release_Note "ROM-5880 Android12-Release Note".md)Baidu   Password:a887 DropboxRK3568_S12_AIV12015.xml
  • Alpha:  Basic I/O function bring up by RD;
  • Beta:  Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
  • GA:  Beta version by QE verification;
  • RTM:  Beta version by SI/Power/QE verification and pre-loaded;
Android 燒錄方法 (Android Flash eMMC Method)
1.  [Usering_RKTool.](./ROM-5880_Android_User_Guide_wiki_data/1.Usering_RKTool. "1.Usering RKTool.".md)
2.  [Usering bootup_sd_disk made_by SDDiskTool.](./ROM-5880_Android_User_Guide_wiki_data/Using_bootup_sd_disk_made_by_SDDiskTool_for_ROM-5880 "Using bootup sd disk made by SDDiskTool for ROM-5880".md)
基本使用方法
  • [Display_Setting](./ROM-5880_Android_User_Guide_wiki_data/Display_Setting(ROM-5880) "Display Setting(ROM-5880)".md)
  • [Audio](./ROM-5880_Android_User_Guide_wiki_data/Audio(ROM-5880) "Audio(ROM-5880)".md)
  • [UART](./ROM-5880_Android_User_Guide_wiki_data/UART(ROM-5880) "UART(ROM-5880)".md)
  • [GPIO](./ROM-5880_Android_User_Guide_wiki_data/GPIO(ROM-5880) "GPIO(ROM-5880)".md)
  • [RTC](./ROM-5880_Android_User_Guide_wiki_data/RTC(ROM-5880) "RTC(ROM-5880)".md)
  • [Watchdog](./ROM-5880_Android_User_Guide_wiki_data/Watchdog(ROM-5880) "Watchdog(ROM-5880)".md)
  • [CAN](./ROM-5880_Android_User_Guide_wiki_data/CAN(ROM-5880) "CAN(ROM-5880)".md)
  • Dualcamera
Android BSP编译方法(Android BSP Compile Method)
[Android BSP User Guide for ROM-5880 series 12](./ROM-5880_Android_User_Guide_wiki_data/Android_BSP_User_Guide_for_ROM-5880_series_12 "Android BSP User Guide for ROM-5880 series 12".md)
