AOM-5721 Yocto 4.0 User Guide
產品介紹(Product introduction)
產品特性(Product Features)
- Qualcomm® QCS6490/QCS5430 on 3.5" SBC, support extend operating temperature -20~70°C
- Powerful but Low Power with 8x Kryo 670 CPU from 1.9 up to 2.7 GHz + Adreno GPU 643 + up to 12.3 TOPs iNPU
- Rugged Design with On-board 8GB LPDDR5 and 128GB UFS or eMMC
- Flexible Displays with HDMI and LVDS or eDP & Rich I/Os: 2x GbE, 6x USB, 4x COM, 2x MIPI-CSI, 1x Audio
- 3x M.2 Expansions: M.2 E-Key 2230 for WiFi/BT, M.2 B-Key 3052 for 4G/LTE, M.2 B-Key 2280 for NVMe Storage
- Various OS Support: Yocto, Windows on Arm
產品官網連結(Product official website link)
AOM-5721+AOM-DB6700 LE SW User Manual | ESS-KMS
Yocto4.0 image: 2025-10-31 - Dropbox
硬件接口說明(Hardware interface introduction)
接口布局(Layout)
Connector Pin Definitions
DCIN_2 Connector
| Pin | Pin Name |
| 1 | PGND |
| 2 | DC_IN |
| 3 | DC_IN |
| 4 | PGND |
Switch/Jumper Settings
AOM-5721:
| SW1 | ON | OFF |
| 1 | eMMC boot | UFS boot |
| 2 | Enter Download/Recovery | Normal boot |
AOM-DB6700:
SW1
| Switch | 1 | 2 | 3 | 4 | 5 | 6 | Function |
| SW1 | ON | --- | --- | --- | --- | --- | Enable: GBE0_LINK_MID# pull high [Default] |
| OFF | --- | --- | --- | --- | --- | Disable: GBE0_LINK_MID# pull high | |
| --- | ON | --- | --- | --- | --- | Enable: GBE0_LINK_MAX# pull high [Default] | |
| --- | OFF | --- | --- | --- | --- | Disable: GBE0_LINK_MAX# pull high | |
| --- | --- | ON | --- | --- | --- | Enable: GBE1_LINK_MID# pull high [Default] | |
| --- | --- | OFF | --- | --- | --- | Disable: GBE1_LINK_MID# pull high | |
| --- | --- | --- | ON | --- | --- | Enable: GBE1_LINK_MAX# pull high [Default] | |
| --- | --- | --- | OFF | --- | --- | Disable: GBE1_LINK_MAX# pull high | |
| --- | --- | --- | --- | ON | --- | Enable: GBE1_LINK_ACT# pull high | |
| --- | --- | --- | --- | OFF | --- | Disable: GBE1_LINK_ACT# pull high [Default] | |
| --- | --- | --- | --- | --- | ON | Enable: GBE0_LINK_ACT# pull high | |
| --- | --- | --- | --- | --- | OFF | Disable: GBE0_LINK_ACT# pull high [Default] |
SW2
| Switch | 1 | 2 | 3 | 4 | 5 | 6 | Function [Baseon Module specific] |
| SW2 | ON | ON | ON | --- | --- | NC | Carrier SATA |
| OFF | ON | ON | --- | --- | NC | Carrier SD Card | |
| ON | OFF | ON | --- | --- | NC | Carrier eSPI(CS0#) | |
| OFF | OFF | ON | --- | --- | NC | Carrier SPI(CS0#) | |
| ON | ON | OFF | --- | --- | NC | Module Device (NAND, NOR) | |
| OFF | ON | OFF | --- | --- | NC | Remote Boot (GBE, Serial) | |
| ON | OFF | OFF | --- | --- | NC | Module eMMC Flash [Default] | |
| OFF | OFF | OFF | --- | --- | NC | Module SPI | |
| --- | --- | --- | ON | --- | NC | Force Recovery Enable | |
| --- | --- | --- | OFF | --- | NC | Force Recovery Disable [Default] | |
| --- | --- | --- | --- | ON | NC | Specific Test Function Enable | |
| --- | --- | --- | --- | OFF | NC | Specific Test Function Disable [Default] |
SW3
| SW3 | OFF | OFF | OFF | --- | --- | --- | RS232 Loopback Mode |
| ON | OFF | OFF | --- | --- | --- | RS232 Mode [Default] | |
| OFF | ON | OFF | --- | --- | --- | RS485 Half-Duplex Mode | |
| ON | ON | OFF | --- | --- | --- | RS485 Full-Duplex (RS422) Mode | |
| OFF | OFF | ON | --- | --- | --- | Reserved (Do Not Use) | |
| ON | OFF | ON | --- | --- | --- | Reserved (Do Not Use) | |
| OFF | ON | ON | --- | --- | --- | Reserved (Do Not Use) | |
| ON | ON | ON | --- | --- | --- | Reserved (Do Not Use) | |
| --- | --- | --- | ON | ON | --- | Termination Enable | |
| --- | --- | --- | OFF | OFF | --- | Termination Disable [Default] | |
| --- | --- | --- | --- | --- | ON | Specific Test Function Enable | |
| --- | --- | --- | --- | --- | OFF | Specific Test Function Disable [Default] |
SW4
| SW4 | OFF | OFF | OFF | --- | --- | --- | RS232 Loopback Mode |
SW5
| Switch SW5 | Function |
| 1-2 | I2S2_MCK from module [Default] |
| 2-3 | I2S2_MCK from 24MHz_Oscillator |
SD_WP
| Switch | Function |
| ON | WriteProtection Enable |
| OFF | Write Protection Disable[Default] |
J1 HDMI DP1 Function Select
| Pin | Function |
| 1-2 | HDMI0 [Default] |
| 2-3 | DP1 |
J5 LVDS0 VDD Power Select
| Pin | Function |
| 3-5 | +3V3 [Default] |
| 1-3 | +5V |
| 3-4 | +12V |
| Other | No Function (Do Not Use) |
J6 eDP0 & LVDS0 Hot-Plug Detect Select
| Pin | Function |
| 1-2 | LVDS0 & DSI0 |
| 2-3 | eDP0_HPD [Default] |
J7 LVDS0 Backlight Power Select
| Pin | Function |
| 1-2 | +5V [Default] |
| 2-3 | +12V |
J8 LVDS1 VDD Power Select
| Pin | Function |
| 1-3 | +5V |
| 3-4 | +12V |
J9 eDP1 & LVDS1 Hot-Plug Detect Select
| Pin | Function |
| 1-2 | LVDS1 & DSI1 [Default] |
| 2-3 | eDP1_HPD |
J10 LVDS1 Backlight Power Select
| Pin | Function |
| 2-3 | +12V |
J12 CAN BUS Port0 Terminal Resistor
| Pin | Function |
| 1-2 | Mount CAN0 Terminal Resistor [Default] |
| 1-X | NC for CAN0 Terminal Resistor |
J13 CAN BUS Port1 Terminal Resistor
| Pin | Function |
| 1-2 | Mount CAN1 Terminal Resistor [Default] |
| 1-X | NC for CAN1 Terminal Resistor |
J30 SD Card Connector Power Source Select
| Pin | Function |
| 1-2 | +3V3_SB |
| 2-3 | +3V3 [Default] |
J31 SDIO to M2_E or SD Card Connector Select
| Pin | Function |
| 1-2 | To SDConnector [Default] |
| 2-3 | To M.2 |
J32 PCIE_A_CKREQ# Select for PCIEX1_A
| Pin | Function |
| 1-2 | PCIE_A_CKREQ# |
| 1-X | NC for PCIE_A_CKREQ# [Default] |
J33 UART0 to M2_E or COM0/2 Connector Select
| Pin | Function |
| 1-2 | UART0 to M.2 E-Key |
| 2-3 | UART0 to COM Connector[Default] |
J34 PCIE_A_CKREQ# Select for M2_E
| Pin | Function |
| 1-2 | PCIE_A_CKREQ# [Default] |
| 1-X | NC for PCIE_A_CKREQ# |
J35 Clear CMOS Header
| Pin | Function |
| 1-2 | Normal Operation[Default] |
| 2-3 | Clear CMOS |
PJ3 AT & ATX Select
| Pin | Function |
| 1-2 | ATX Mode |
| 2-3 | AT Mode[Default] |
SPI0_Jumper SPI0_Jumper_Group
| Pin | Function |
| J15-J19:1-2, J14:1-2 | FLASH CS0 SPI[Default] |
| J15-J19:1-2, J14:2-3 | FLASH CS1 SPI |
| J15-J19:2-3 | PIN HEADER |
SPI1/ESPI/QSPI_Jumper SPI1/ESPI/QSPI_Jumper_Group
| Pin | Function |
| J23-J29:1-2, J21-J22:1-2, J20:1-2 | FLASH,CS0 SPI [Default] |
| J23-J29:1-2, J21-J22:1-2, J20:2-3 | FLASH,CS1 SPI |
| J23-J29:1-2, J21-J22:2-3, J20:1-2 | FLASH,CS0 QSPI |
| J23-J29:1-2, J21-J22:2-3, J20:2-3 | FLASH,CS1 QSPI |
| J23-J29:2-3 | PIN HEADER |
GPIO5 function Select
| Pin | Function |
| 1-2 | GPIO5[Default] |
| 2-3 | PWM_OUT (For FAN function) |
GPIO6 function Select
| Pin | Function |
| 1-2 | GPIO6[Default] |
| 2-3 | TACHIN (For FAN function) |
快速入門(Quick Start)
系统下载(OS Download)
Yocto 4.0 :
Login information: root/oelinux123
燒錄方法(Recovery & Rescue method)
Install flash tool: The version below has been tested.
- Qualcomm USB Driver v1.00.91.6
- Qualcomm Product Configuration Assistant Tool v2.42.2.165
- Qualcomm Unified Tools Services v1.85.2.5
- Qualcomm Software Center v1.22.1
- Download the Qualcomm Software Center
- Open the Qualcomm Software Center
- Search "PCAT" in the search bar
- Install Qualcomm® Product Configuration Assistant Tool
- Install Qualcomm® Unified Tools Services
- You will find the new application in your Windows system.
- Unzip the UFS File and eMMC File
- For example :
aom5721a1_yocto4.0.18-le1.1_v1.0.0_kernel-6.6.28_qcs6490_8g_emmc_2025-10-31.tgzaom5721a1_yocto4.0.18-le1.1_v1.0.0_kernel-6.6.28_qcs6490_8g_ufs_2025-10-31.tgz
- For example :
- Connect your device via Micro USB.
- Set up to Download/Recovery mode and power on the system. If your PC can not identify the USB, please download the "Qualcomm USB Driver."
- Search "Qualcomm USB Driver" in the search bar, then install the driver.
Flash UFS provision:
For confirmation, we will erase the partition before UFS installation.
Change the SW1 of the AOM-5721 and SW2 of the AOM-DB6700:
Flash UFS Switch config AOM-5721 SW1 1-off, 2-on AOM-DB6700 SW2 4-on -
Turn on the power
Open "PCATApp" Tool
Select "Qualcomm HS-USB QDLoader 9008" and click connect
When you connect successfully, it will show "green word" - Qualcomm HS-USB QDLoader 9008 (COM $X)
Select the UFS Folder in the PCAT Tool. The Tool will help load Files automatically and select "MEMORY_TYPE_UFS."
Select the provision button
Add the
prog_firehose_ddr.elfandprovision_ufs31.xmlin UFS folder. -
Then press "OK", it will start to do the USF Provision.
When the Provision is finished, you can see the result in the message window.
Click "Download."
When you finish the download process, please power off and power on to flash UFS.
Flash UFS
Change the SW1
Turn on the power
Make sure the device connection status.
If the device disconnects from the PCAT Tool, please connect it again.
Make sure the setting, then press the "Download" button.
UFS Download completed
When the UFS installation is finished. Close the PCAT tool,
Please remove the micro USB cable, turn off the power
UFS boot-up setting:
UFS boot Switch config AOM-5721 SW1 1-off, 2-off AOM-DB6700 SW2 1-on -
Connect the debug cable and open the terminal, turn on the power.
Flash eMMC
Change the SW1
Flash eMMC Switch config AOM-5721 SW1 1-on, 2-on AOM-DB6700 SW2 4-on -
Turn on the power
Select the EMMC Folder in the PCAT Tool. The Tool will help load Files automatically and select "MEMORY_TYPE_EMMC."
eMMC Download completed
When the eMMC installation is finished. Close the PCAT tool,
eMMC boot-up setting:
eMMC boot Switch config AOM-5721 SW1 1-on, 2-off AOM-DB6700 SW2 1-on -
基本功能測試(Basic Function test)
Display Setting
HDMI
| Item | Setting | Command |
| HDMI setting | AOM-DB6700: HDMI0_DP1 J1: (1-2) : HDMI0 (Default), (2-3) : DP1 | # /tools/cdt/emmcChangeToHDMI.shor # /tools/cdt/ufsChangeToHDMI.sh |
| HDMI resolution | 1920x1080 | # echo 1920 1080 60 > /sys/bus/i2c/drivers/lt9611uxc/1-002b/edid_mode# systemctl restart init_display.service |
| 1280x720 | # echo 1280 720 60 > /sys/bus/i2c/drivers/lt9611uxc/1-002b/edid_mode# systemctl restart init_display.service | |
| 720x480 | # echo 720 480 60 > /sys/bus/i2c/drivers/lt9611uxc/1-002b/edid_mode# systemctl restart init_display.service | |
| HDMI status | Status | # cat /sys/class/drm/card0-DSI-1/status |
eDP
| eDP setting | AOM-DB6700: LVDS0, LVDS0_BL J6: (1-2) : LVDS, (2-3) : EDP HPD | # /tools/cdt/ufsChangeToEDPwithSGTL5000.shor # /tools/cdt/emmcChangeToEDPwithSGTL5000.sh |
| eDP backlight | Backlight | # echo 0 > /sys/class/backlight/panel-backlight/brightness# echo 50 > /sys/class/backlight/panel-backlight/brightness# echo 100 > /sys/class/backlight/panel-backlight/brightness |
| eDP status | Status | # cat /sys/class/drm/card0-eDP-1/status |
DP
| DP Setting | AOM-DB6700: CSI -> AOM-EC-91 CN4 | # /tools/cdt/emmcChangeToHDMI.shor # /tools/cdt/ufsChangeToHDMI.sh |
| DP | 1920x1080 | # echo 1920 1080 60 0 > /sys/kernel/debug/drm_dp/edid_modes# echo 0 > /sys/kernel/debug/drm_dp/hpd# echo 1 > /sys/kernel/debug/drm_dp/hpd |
| DP status | Status | # cat /sys/class/drm/card0-DP-1/status |
Multi display
| Multi display | HDMI+DP | # /tools/cdt/emmcChangeToHDMI.shor # /tools/cdt/ufsChangeToHDMI.sh |
| DSI+DP | # /tools/cdt/ufsChangeToDSIwithWCD9385.shor # /tools/cdt/emmcChangeToDSIwithWCD9385.sh | |
| eDP+DP | # /tools/cdt/ufsChangeToEDPwithSGTL5000.shor # /tools/cdt/emmcChangeToEDPwithSGTL5000.sh |
乙太網路使用方法(Ethernet Testing Method)
| 1G LAN0 Down(GBE0) | enP1p5s0f0 | # ifconfig enP1p5s0f0# ping google.com |
| 1G LAN0 LED | AOM-DB6700: SW1 set all ON LAN0 Link: • # ethtool -s enP1p5s0f0 speed 1000 duplex full - Green light• # ethtool -s enP1p5s0f0 speed 100 duplex full - Orange light• # ethtool -s enP1p5s0f0 speed 10 duplex full - Always offLAN0 Active: Green light: flashing on | |
| 1G LAN1Up(GBE1) | enP1p5s0f1 | # ifconfig enP1p5s0f1# ping google.com |
| 1G LAN1 LED | AOM-DB6700: SW1 set all ON LAN1 Link: • # ethtool -s enP1p5s0f0 speed 1000 duplex full - Green light• # ethtool -s enP1p5s0f0 speed 100 duplex full - Orange light• # ethtool -s enP1p5s0f0 speed 10 duplex full - Always offLAN1 Active: Green light: flashing on |
WiFi使用方法(WiFi Testing Method): M.2 KeyE
| AIW-170BQ | Connect AIW-170BQ to M2_E_1 | Edit wpa_supplicant.conf file:vi /etc/wpa_supplicant.conf<br/>network={<br/> ssid="SSID"<br/> key_mgmt=WPA-PSK<br/> proto=WPA RSN<br/> auth_alg=OPEN<br/> pairwise=TKIP CCMP<br/> group=TKIP CCMP<br/> psk="PASSWORD"<br/>}# wpa_supplicant -i wlp1s0 -Dnl80211 -c /etc/wpa_supplicant.conf &# ping 8.8.8.8 -I wlp1s0# ping google.com -I wlp1s0 |
| AIW-170BQ status | AIW-170BQ 0000:01:00.0 Network controller: Qualcomm QCNFA765 Wireless Network Adapter (rev 01) | # lspci |
藍芽使用方法(Bluetooth Testing Method): M.2 KeyE
| AIW-170BQ | Connect AIW-170BQ to M2_E_1 | # hciconfig# hciconfig hci0 up# bluetoothctl# discoverable on# pairable on# scan onDevice D0:57:7E:FF:7B:A6 Name: NB140511# pair 84:C5:A6:D3:AF:E4# connect 84:C5:A6:D3:AF:E4 |
| AIW-170BQ status | AIW-170BQ Bus 001 Device 004: ID 0cf3:e600 Qualcomm Atheros Communications | # lsusb |
數據網路使用方法(Mobil Modem Testing Method): M.2 KeyB
| AIW-356 | Connect AIW-356 to M2_B (Test by MBIM mode) Change to the MBIM + MODEM + DIAG + AT mode (One-time Prerequisite) for the AIW-356. The default mode is DIAG + MODEM + AT + PIPE + RMNET. | # microcom -t 15000 -s 115200 /dev/ttyUSB2at+gtusbmode=30Use the MBIM to connect to the internet: chmod u+w /sys/bus/usb-serial/drivers/option1/new_id# echo "2cb7 0111" > /sys/bus/usb-serial/drivers/option1/new_id# mbimcli -d /dev/cdc-wdm0 -p --query-connection-state# mbimcli -d /dev/cdc-wdm0 -p --query-subscriber-ready-status# mbimcli -d /dev/cdc-wdm0 -p --set-radio-state=on//# mbimcli -d /dev/cdc-wdm0 -p --enter-pin=0000 (If needed)# mbim-network /dev/cdc-wdm0 start# mbimcli -d /dev/cdc-wdm0 -p --query-ip-configuration# /tools/modem/mbim-set-ip /dev/cdc-wdm0 wwan0# ping 8.8.8.8 -I wwan0 |
| AIW-356 status | AIW-356 Bus 003 Device 003: ID 2cb7:0111 Fibocom Fibocom FM160 Modem_SN:8AF6F50C | # lsusb |
NVMe使用方法(NVMe Testing Method): M.2 KeyM
| SQF-C8BV2-128GDEDC | Connect the module to M2_M | # lsblk |
| SQF-C8BV2-128GDEDC status | 0001:03:00.0 Non-Volatile memory controller: Phison Electronics Corporation PS5013 E13 NVMe Controller (rev 01) | # lspci |
GPIO使用方法(GPIO Operating Method)
GPIO pin
| SMARC PIN# | SMARC Carrier GPIO# | CPU | Kernel GPIO # |
| GPIO0/CAM0_PWR#(P108) | GPIO0_1V8 | GPIO_141 | 676 |
| GPIO1/CAM1_PWR#(P109) | GPIO1_1V8 | GPIO_142 | 677 |
| GPIO2/CAM0_RST#(P110) | GPIO2_1V8 | GPIO_20 | 555 |
| GPIO3/CAM1_RST#(P111) | GPIO3_1V8 | GPIO_21 | 556 |
| GPIO4/HDA_RST#(P112) | GPIO4_1V8 | GPIO_8 | 543 |
| GPIO5/PWM_OUT(P113) | GPIO5_1V8 | GPIO_11 | 546 |
| GPIO6/TACHIN(P114) | GPIO6_1V8 | GPIO_15 | 550 |
| GPIO7/SERDES0_INT#(P115) | GPIO7_1V8 | GPIO_16 | 551 |
| GPIO8/SERDES1_INT#(P116) | GPIO8_1V8 | GPIO_18 | 553 |
| GPIO9/CAM2_RST#(P117) | GPIO9_1V8 | GPIO_19 | 554 |
| GPIO10/CAM2_PWR#(P118) | GPIO10_1V8 | GPIO_35 | 570 |
| GPIO11/CAM2_MCK(P119) | GPIO11_1V8 | GPIO_44 | 579 |
| GPIO12(S142) | GPIO12_1V8 | GPIO_68 | 603 |
| GPIO13(S123) | GPIO13_1V8 | GPIO_104 | 639 |
| GPIO14/LID#(S148) | GPIO14_1V8 | GPIO_112 | 647 |
| GPIO15/CHARGING#(S151) | GPIO15_1V8 | NA | NA |
| GPIO16/CHARGER_PRSNT#(S152) | GPIO16_1V8 | GPIO_9 | 544 |
| GPIO17/BATLOW#(S156) | GPIO17_1V8 | GPIO_111 | 646 |
GPIO 控制命令:
echo 676 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio676/direction
echo 1 > /sys/class/gpio/gpio676/value
串口使用方法(Serial Port Operating Method)
Serial port
| Serial port | SMARC pin# | device node |
| COM0(4 wire) | SER0 | /dev/ttyHS1 |
| COM1(2 wire) | SER1 | /dev/ttyHS3 |
| COM2(4 wire) | SER2 | /dev/ttyHS2 |
| COM3(2 wire) | SER3 | Debug console(115200) |
RS-232
| RS-232 | Default RS-232 function | Loopback Test and Function after reboot |
| COM0 | Set AOM-DB6700 SW3 to 1-on, 2-off | # stty -F /dev/ttyHS1 -echo -onlcr 115200 raw# cat /dev/ttyHS1 &# echo "Serial Port Test" > /dev/ttyHS1 |
| COM2 | Set AOM-DB6700 SW4 to 1-on, 2-off | # stty -F /dev/ttyHS2 -echo -onlcr 115200 raw# cat /dev/ttyHS2 &# echo "Serial Port Test" > /dev/ttyHS2 |
| COM1 | # stty -F /dev/ttyHS3 -echo -onlcr 115200 raw# cat /dev/ttyHS3 &# echo "Serial Port Test" > /dev/ttyHS3 |
RS-422
| RS-422 | Set RS-422 function | Test with ADAM-4520I Teraterm: 115200 8 n 1 Xon/Xoff |
| COM0 | Set AOM-DB6700 SW3 to 1245-on | # stty -F /dev/ttyHS1 speed 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke# cat /dev/ttyHS1 &# echo "Serial Test" > /dev/ttyHS1# echo -e "123456789-123456789-123456789-123456789-123456789-\r" |
| COM2 | Set AOM-DB6700 SW4 to 1245-on | # stty -F /dev/ttyHS2 speed 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke# cat /dev/ttyHS2 &# echo "Serial Test" > /dev/ttyHS2# echo -e "123456789-123456789-123456789-123456789-123456789-\r" |
RS-485
| RS-485 | Set RS-485 function | Test with ADAM-4520I Teraterm: 115200 8 n 1 Xon/Xoff |
| COM0 | Set AOM-DB6700 SW3 to 245-on | # stty -F /dev/ttyHS1 speed 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke# cat /dev/ttyHS1 &# echo "Serial Test" > /dev/ttyHS1# echo -e "123456789-123456789-123456789-123456789-123456789-\r" |
| COM2 | Set AOM-DB6700 SW4 to 245-on | # stty -F /dev/ttyHS2 speed 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke# cat /dev/ttyHS2 &# echo "Serial Test" > /dev/ttyHS2# echo -e "123456789-123456789-123456789-123456789-123456789-\r" |
SPI Bus(SPI bus Operating Method)
| SPI0 | AOM-DB6700: SPI_CN SPI0 Default: U34 J14: (1-2): CS0 (Default), (2-3): CS1 J15~J19: (1-2): Flash (Default),(2-3): PIN HEADER | # hexdump -C /dev/mtdblock0 -n 64# echo -n $'\x06\x05\x04\x03\x02\x01' > test# dd if=test of=/dev/mtdblock0# hexdump -C /dev/mtdblock0 -n 64 |
| SPI1 | AOM-DB6700: ESPI_CN SPI1 Default: U35 J20: (1-2): CS0 (Default), (2-3): CS1 J21: (1-2): SPI1 (Default), (2-3): QSPI J22: (1-2): SPI1 (Default), (2-3): QSPI J23~J29: (1-2): Flash (Default), (2-3): PIN HEADER | # hexdump -C /dev/mtdblock1 -n 64# echo -n $'\x06\x05\x04\x03\x02\x01' > test# dd if=test of=/dev/mtdblock1# hexdump -C /dev/mtdblock1 -n 64 |
CAN Bus(CAN bus Operating Method)
| CAN FD | Connect CAN1 and CAN2 loop test | ip link set can0 up type can bitrate 1000000 dbitrate 8000000 fd on# ip link set can1 up type can bitrate 1000000 dbitrate 8000000 fd on# candump can0 && candump can1 &# cansend can0 123##300112233445566778899aabbccddeeff# cansend can1 123##300112233445566778899aabbccddeeff |
| Connect CAN1 and CAN2 loop test with the CANFD test script | # /tools/canbus/canfd_test.sh |
Audio(Audio Operating Method)
| HDMI Audio | Copy audio wav file to the system | # pactl set-sink-port 0 headset# pactl set-sink-port 1 headset# paplay LRMonoPhase4.wavor # pactl set-sink-port 0 headset# pactl set-sink-port 1 headset# source /opt/qcom/qirp-sdk/qirp-setup.sh# gst-launch-1.0 -e filesrc location=LRMonoPhase4.wav ! wavparse ! audioconvert ! pulsesink volume=5 |
| ROM-EG51(I2S0) | I2S0 AUDIO output is AUDIO0 Audio: Connect ROM-EG51 to I2S0 (DB6700 needs to rework) Run: # /tools/cdt/ufsChangeToEDPwithSGTL5000.shor # /tools/cdt/emmcChangeToEDPwithSGTL5000.shCheck model: # dmesg | grep model | # pactl set-sink-port 0 speaker# pactl set-sink-port 1 speaker# paplay LRMonoPhase4.wavor # pactl set-sink-port 0 speaker# pactl set-sink-port 1 speaker# source /opt/qcom/qirp-sdk/qirp-setup.sh# gst-launch-1.0 -e filesrc location=LRMonoPhase4.wav ! wavparse ! audioconvert ! pulsesink volume=1 |
| ROM-EG51(I2S0) Mic | Mic: Connect the Mic to the Audio output and play a WAV file that was recorded. Then play the recorded WAV file Run: # /tools/cdt/ufsChangeToEDPwithSGTL5000.shor # /tools/cdt/emmcChangeToEDPwithSGTL5000.shCheck model: # dmesg | grep model | tinymix set "Mic Volume" 3# pactl set-source-port regular2 speaker-mic# parec -v --rate=48000 --format=s16le --channels=1 --file-format=wav /tmp/audio_48k.wav --device=regular2or # tinymix set "Mic Volume" 3# pactl set-source-port regular2 speaker-mic# source /opt/qcom/qirp-sdk/qirp-setup.sh# gst-launch-1.0 -v pulsesrc volume=1 ! audioconvert ! wavenc ! filesink location=/tmp/audio_48k.wav |
CSI Camera(CSI Camera Testing Method)
| CSI camera | (AOM-DB6700: CSI -> AOM-EC-91 -> cam*) (Module need to connect to the AOM-EC-91 CN2/CN3) Machine model: Advantech Technologies, Inc. AOM-5721 + HDMI + HDMI Audio CAM0: ov9282: 2-lanes 1280x720@30: | # source /opt/qcom/qirp-sdk/qirp-setup.sh# export XDG_RUNTIME_DIR=/dev/socket/weston && export WAYLAND_DISPLAY=wayland-1 && gst-launch-1.0 -e qtiqmmfsrc camera=0 name=camsrc ! video/x-raw,format=NV12,width=1280,height=720,framerate=30/1 ! waylandsink fullscreen=true async=true sync=false |
| CAM1: imx577: 4-lanes 3840x2160@30: | # source /opt/qcom/qirp-sdk/qirp-setup.sh# export XDG_RUNTIME_DIR=/dev/socket/weston && export WAYLAND_DISPLAY=wayland-1 && gst-launch-1.0 -e qtiqmmfsrc camera=1 name=camsrc ! video/x-raw,format=NV12,width=3840,height=2160,framerate=30/1 ! waylandsink fullscreen=true async=true sync=false | |
| 1920x1080@30: | # source /opt/qcom/qirp-sdk/qirp-setup.sh# export XDG_RUNTIME_DIR=/dev/socket/weston && export WAYLAND_DISPLAY=wayland-1 && gst-launch-1.0 -e qtiqmmfsrc camera=1 name=camsrc ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! waylandsink fullscreen=true async=true sync=false | |
| CAM2: imx577: 4-lanes 3840x2160@30: | # source /opt/qcom/qirp-sdk/qirp-setup.sh# export XDG_RUNTIME_DIR=/dev/socket/weston && export WAYLAND_DISPLAY=wayland-1 && gst-launch-1.0 -e qtiqmmfsrc camera=2 name=camsrc ! video/x-raw,format=NV12,width=3840,height=2160,framerate=30/1 ! waylandsink fullscreen=true async=true sync=false | |
| 1920x1080@30: | # source /opt/qcom/qirp-sdk/qirp-setup.sh# export XDG_RUNTIME_DIR=/dev/socket/weston && export WAYLAND_DISPLAY=wayland-1 && gst-launch-1.0 -e qtiqmmfsrc camera=2 name=camsrc ! video/x-raw,format=NV12,width=1280,height=720,framerate=30/1 ! waylandsink fullscreen=true async=true sync=false | |
| CAM3: imx577: 4-lanes 3840x2160@30: | # source /opt/qcom/qirp-sdk/qirp-setup.sh# export XDG_RUNTIME_DIR=/dev/socket/weston && export WAYLAND_DISPLAY=wayland-1 && gst-launch-1.0 -e qtiqmmfsrc camera=3 name=camsrc ! video/x-raw,format=NV12,width=3840,height=2160,framerate=30/1 ! waylandsink fullscreen=true async=true sync=false | |
| 1920x1080@30: | # source /opt/qcom/qirp-sdk/qirp-setup.sh# export XDG_RUNTIME_DIR=/dev/socket/weston && export WAYLAND_DISPLAY=wayland-1 && gst-launch-1.0 -e qtiqmmfsrc camera=3 name=camsrc ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! waylandsink fullscreen=true async=true sync=false | |
| Multi-camera preview | 1280x800 and 1280x720 preview | source /opt/qcom/qirp-sdk/qirp-setup.sh# export XDG_RUNTIME_DIR=/dev/socket/weston# export WAYLAND_DISPLAY=wayland-1Set 0~7 CPU to performance: # echo "performance" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor# echo "performance" > /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor# echo "performance" > /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor# echo "performance" > /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor# echo "performance" > /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor# echo "performance" > /sys/devices/system/cpu/cpu5/cpufreq/scaling_governor# echo "performance" > /sys/devices/system/cpu/cpu6/cpufreq/scaling_governor# echo "performance" > /sys/devices/system/cpu/cpu7/cpufreq/scaling_governorLaunch 4 camera: # gst-launch-1.0 -e qtivcomposer name=mixer \sink_0::position="<0, 0>" sink_0::dimensions="<1280, 800>" \sink_1::position="<1280, 0>" sink_1::dimensions="<1280, 720>" \sink_2::position="<0, 720>" sink_2::dimensions="<1280, 720>" \sink_3::position="<1280, 720>" sink_3::dimensions="<1280, 720>" \mixer. ! queue ! waylandsink enable-last-sample=false fullscreen=true \qtiqmmfsrc video_0::type=preview name=camsrc_0 camera=0 ife-direct-stream=1 ! 'video/x-raw,format=NV12,width=1280,height=800,framerate=30/1' ! mixer. \qtiqmmfsrc name=camsrc_1 camera=1 ! video/x-raw, format=NV12, width=1280, height=720, framerate=30/1 ! mixer. \qtiqmmfsrc name=camsrc_2 camera=2 ! video/x-raw, format=NV12, width=1280, height=720, framerate=30/1 ! mixer. \qtiqmmfsrc name=camsrc_3 camera=3 ! video/x-raw, format=NV12, width=1280, height=720, framerate=30/1 ! mixer. |
通用方法(General Method)
Watchdog(Watchdog Testing)
| Item | Setting | Command | Result |
| Watchdog | Internal Watchdog | echo c > /proc/sysrq-trigger | System will reboot after 7 sec |
RTC(RTC testing)
| RTC | Disable RTC sync service | # systemctl stop systemd-timesyncd# systemctl disable systemd-timesyncd |
| Set system time to current, then write to RTC | # date 021710452022 && hwclock -w && date | |
| Set one incorrect time, then read time from RTC to verify | # date 010100002000 && hwclock -r && date | |
| Set the system time from the RTC | # hwclock -s && date | |
| Store into RTC and check RTC current status | # hwclock -w -f /dev/rtc0# hwclock -v -f /dev/rtc0 | |
| Enable RTC sync service | # systemctl enable systemd-timesyncd# systemctl start systemd-timesyncd |
TPM(TPM Testing)
| TPM | # dmesg | grep tpm# /tools/tpm/tpm_test.bin | [TPM Command]80010000000C000001440000[TPM Response]80010000000A00000100[TPM Command]80010000000B0000014301[TPM Response]80010000000A00000000[TPM Command]8001000000160000017A000000060000010500000001[TPM Response]80010000001B000000000100000006000000010000010553544D20[TPM Command]8001000000160000017A000000060000010B00000002[TPM Response]800100000023000000000100000006000000020000010B000901010000010C00000000 |
I2C(I2C Testing)
| I2C_PM | 0x27: TCA9555PWR GPIO Expandor 0x2B: LT9611UXC (DSI to HDMI bridge) 0x2E: TPM 0x32: RTC 0x50: EEPROM 0x53: EEPROM 0x6C: PCIe CLKGEN 0x71: ERP_MCU | # i2cdetect -y -r 1 |
| I2C_PM | 0x50: EEPROM test | # echo -n $'\x06\x05\x04\x03\x02\x01' > test# dd if=test of=/sys/bus/i2c/devices/1-0050/eeprom# hexdump -C /sys/bus/i2c/devices/1-0050/eeprom -n 64 |
AIM-Linux/BSP/Qualcomm/LE1.1 BSP User Guide - ESS-WIKI
Linux BSP編譯方法(Linux BSP Compile Method)
完整的 BSP 編譯步驟請參考對應 OS 版本的 README:
