← Back to EPC-R3220
EPC-R3220 Yocto 2.4 User Guide
資源特性(Features)​
  • TI Sitara™ AM3352 Cortex®-A8 800MHz processor
  • 1GB of DDR3-800 and 8 GB of eMMC NAND Flash onboard
  • 2 Gigabit Ethernet ports
  • 2 RS232/485, 1 USB OTG, 6 GPIO
  • WiFi/BT/LTE solution ready
  • Yocto Linux support
  • -20 ~ 70 °C operating temperature/ 12~24V DC power supply
  • Equipped with processors watchdog timer for system protection
產品官網連結(Product information Link)[edit]​
EPC-R3220
接口布局和尺寸(Layout and Sizes)
EPC-R3220  接口布局圖 Board Dimension Layout​
Front I/O
RTENOTITLE
Left-Side
RTENOTITLE
Right-Side
RTENOTITLE
RTENOTITLE
**机械尺寸  (**Mechanical Characteristics)​
EPC-R3220
RTENOTITLE
快速入门 (Quick Start)
系统下载 (OS Download)​
Note :LBV=BSP , LIV= Image , UIV=Ubuntu , DIV = Debian​
Git BSP Tag VersionProductCPUBSP/ImageDateAlpha ReleaseBeta ReleaseMP ReleaseRelease NoteSDKRelease Owner
am335xDBV20012EPC-R3220A1am33522021-07-292021-07-29Image:am335xDIV20012 BSP:am335xDBV20012Release Noteam335xDBV20012_SDKZhengguang.Yang
am335xUBV20012EPC-R3220A1am33522021-07-292021-07-29Image:am335xUIV20012 BSP:am335xUBV20012Release Noteam335xUBV20012_SDKZhengguang.Yang
am335xLBV20012EPC-R3220A1am33522021-07-292021-07-29Image:am335xLIV20012 BSP:am335xLBV20012Release Noteam335xLBV20012_SDKZhengguang.Yang
Linux 燒錄方法 (Linux Flash eMMC Method)​
使用Flash tool 燒錄鏡像到eMMC (Flash image into eMMC by Flash Tools)  [Use Ubuntu 18.04 to create SD card (Test the SD image can boot into Linux without problem that created on Ubuntu18.04 or 20.04)]
解壓縮檔案(Unzip the files)
RTENOTITLE
mkdir ti-sdk-XXX(XXX represents numbers, e.g. ti-sdk-001)
Command : phill@riscserver-Default-string:/home/RISC_BSP_Home/EPC-R3220/R3220A1AIM20LIV20012_am335x_2021-07-29$ mkdir ti-sdk-001
Unzip file to ti-sdk-001
Command : tar -xJf processor-sdk-linux-image-am335xepcr3220a1-20210729031957.tar.xz -C ti-sdk-001
RTENOTITLE
Step0: 檢查SD卡在Linux 環境的代號 (check SD card symbol in Linux system)
RTENOTITLE
RTENOTITLE
Step1: 創造一張可開機的SD 卡 (Create a bootable SD card)
 $ cd ti-sdk-XXX/bin
RTENOTITLE
$ sudo ./create-sdcard.sh
RTENOTITLE
Select SD card:
RTENOTITLE
Select number of partitions:
RTENOTITLE
RTENOTITLE
RTENOTITLE
Select Pre-built System image:
RTENOTITLE
Select tisdk-rootfs-image-XXX.tar.xz(XXX represents machine name, e.g. am335xepcr3220a1):
RTENOTITLE
RTENOTITLE
If you need to transfer whole system to on-board flash, please press y followed by Enter.
RTENOTITLE
RTENOTITLE
Step2: 將可開機的SD 卡插入底板SD卡卡槽(Plug the SD card into Carrier board 's SD card slot)
RTENOTITLE
Step3: 確認開機選擇指撥開關(Check the SW1 switch)
            SPL開機模式(SPL boot mode: boot from SD/MMC, SPI...)
            1--off  2---off
            eMMC開機模式(eMMC(SPI) boot mode): The R3220 can only support SPI and SD boot in HW design. So it needs to flash the MLO file to the SPI flash, and it can boot the SPI first and then boot the u-boot from the eMMC
            1--on  2--off
            Note: After change switch setting. Unplug and plug AC power for the change to take effect.
Step3:打開電源 和 終端機 (Turn on the Power & Terminal)
RTENOTITLE
RTENOTITLE
Step4: 利用mk-eMMC-boot.sh 安裝eMMC 鏡像(Flash image to eMMC Flash by mk-eMMC-boot.sh )
RTENOTITLE
RTENOTITLE
RTENOTITLE
RTENOTITLE
RTENOTITLE
RTENOTITLE
RTENOTITLE
Debug 串口調試 (Debug port Setting)​
以 Tera Term  为例介绍如何使用串口调试功能
   Baud Rate波特率:115200
Data 数据位:8
Parity 奇偶校验:无
  Stop 停止位:1
Flow Control流控:无
Tera Term Tool
RTENOTITLE
RTENOTITLE
Check the Sriel port in Device Manager (查看PC端的串口号):
if you can not identify the Serial device , please check your serial driver.
RTENOTITLE
Debug port connection (串口連接)
RTENOTITLE
Log into Terminal  Tool (进入串口调试终端):
RTENOTITLE
Linux系统的基本使用(Linux System Basic Operating Method)
乙太網路使用方法(Ethernent Testing Method)​
Command : ifconfig
RTENOTITLE
Command: Ping - I eth1 8.8.8.8  or Ping - I eth0 8.8.8.8
RTENOTITLE
WiFi使用方法(WIFI Testing Method)​
M.2 Mrvl. WIFI/BT Test
EPC-R3220 supports MarverllSD8897 wifi/bt modules throught M.2.
RTENOTITLE
GPIO使用方法(GPIO Operating Method)​
RTENOTITLE
RTENOTITLE
串口使用方法(Serial Port Operating Method)​
RS-232 Test
RTENOTITLE
蓝牙使用方法(BlueTooth Operating Method)​
Command :
$ hciconfig hci0 up
$ bluetoothctl
$ discoverable on
$ pairable on
$ scan on
[NEW] FC:18:3C:8D:75:F4 myphone
$ scan off
$ pair FC:18:3C:8D:75:F4
$ connect FC:18:3C:8D:75:F4
RTENOTITLE
遠程訪問及文件傳輸(Remote Access and File Transimmion)​
**查看主板IP位址 ( Chech IP Address ):**​
        Command : ifconfig
RTENOTITLE
Windows下SSH访问及文件传输​
SSH Remote Log into Device
  • SSH远程登录,以putty选择putty.exe(或者使用Xshell、SecureCRT等类似软件)
  • 需要设置远程设备的IP、通讯端口(默认22)、通讯方式,登录后验证用户名密码
RTENOTITLE
RTENOTITLE
RTENOTITLE
Account is “root” , no password.
RTENOTITLE
RS-485 測試方式 (RS-485 testing method)​
Test tool script :
Uart change mode
百度網盤(Baidu Disk): 链接:&nbsp https://pan.baidu.com/s/1HGJoW0jqp_GGK5VFvXAieg
提取码:luug
RTENOTITLE
RTENOTITLE
RTENOTITLE
RTENOTITLE
RTENOTITLE
通用方法(General Method)
**'**查看CPU频率(Check CPU Frequency)'​
           root@am335xepcr3220a1:/# cat /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq
>> 600000
root@am335xepcr3220a1:/# cat /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_max_freq
>> 800000
查看内存容量(Check Memory Capacity)​
root@am335xepcr3220a1:~# busybox free -m[  143.716190] NET: Registered protocol family 15
             total       used       free     shared    buffers     cached
Mem:          1002        152        849          9         23         88
-/+ buffers/cache:         40        961
Swap:            0          0          0
查看存储容量(Check Storage Capacity)​
root@am335xepcr3220a1:~# busybox df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root                 6.1G      2.2G      3.5G  39% /
devtmpfs                476.7M      4.0K    476.7M   0% /dev
tmpfs                   501.2M         0    501.2M   0% /dev/shm
tmpfs                   501.2M      9.6M    491.6M   2% /run
tmpfs                   501.2M         0    501.2M   0% /sys/fs/cgroup
tmpfs                   501.2M         0    501.2M   0% /tmp
tmpfs                    16.0M         0     16.0M   0% /media/ram
tmpfs                    50.0M    128.0K     49.9M   0% /var/volatile
/dev/mmcblk1p3           58.0M     31.1M     23.7M  57% /run/media/mmcblk1p3
/dev/mmcblk1p6          739.9M    796.0K    700.7M   0% /cache
/dev/mmcblk1p5            2.9M     34.0K      2.6M   1% /run/media/mmcblk1p5
/dev/mmcblk1p1           68.9M    472.5K     68.4M   1% /run/media/mmcblk1p1
tmpfs                   100.2M         0    100.2M   0% /run/user/0
網路Ping測試(Ping Network Testing)​
     ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
設置RTC (RTC Setting)​
root@am335xepcr3220a1:~# date 101212102021 && hwclock -w && date
Tue Oct 12 12:10:00 UTC 2021
Tue Oct 12 05:52:57 UTC 2021
Tue Oct 12 05:52:58 UTC 2021
