RSB-3710 Android7 User Guide
← Back to RSB-3710
產品介紹(Product introduction )​
產品特性(Product Features)​
  • Rockchip Arm® Cortex®-A72 RK3399 up to 1.8 GHz
  • Onboard LPDDR4 2GB
  • HDMI 1920x1080 at 60Hz, 1 Dual Channel 24 bit LVDS
  • 1 2-wire RS-232, 1 USB3.0, 1 USB2.0, 1 Micro SD, 1 Mic. in / Line out
  • 1 mini-PCIe for 3G/4G
  • UIO expansion 3 USB2.0, 8 GPIO, 2 RS232 2/2-wires UART, 1 I2C
  • Supports Debian9/10 and Android7.1/10.0
  • Support I/O Expansions by UIO40-Express I/O boards, please refer to page #3 for more information
產品官網連結(Product Features)​
RSB-3710
硬件接口說明(Hardware interface introduction)​
接口布局和尺寸(Layout and Sizes)​
接口布局圖 Board Dimension Layout​
RTENOTITLE
RTENOTITLE
RTENOTITLE
Connector List​
RTENOTITLE
BATRTC Battery Connector
HDMIHDMI1 CONN
BLLVDS BKL CONN
LVDSLVDS CONN
LAN1LAN
LAN2LAN
MINIPCIEMINI PCIE 52P
SIMNano SIM Card
AUDIOAudio PIN Header
USB1USB CONN
COM2/DebugCOM2
SDSD Slot
OTGUSB
BTNPower BTN pin header
RSTReset Button
DCIN112V DC Jack
LEDLED
CN11UIO1
CN12UIO2
接口引脚定義 (Pin definitions)​
  • BAT
  • HDMI1
  • BL
  • LVDS
  • LAN1, LAN2
  • MINIPCIE
  • SIM
  • Audio
  • USB1
  • COM2/Debug
  • SD
  • OTG
  • BTN
  • RST
  • DCIN1
  • LED
  • CN11
  • CN12
  • RSB-3710_Jumper List
**机械尺寸  (**Mechanical Characteristics)​
RTENOTITLE
快速入门 (Quick Start)​
系统下载 ( OS Download)​
Note:  LIV=Yocto Linux, UIV=Ubuntu, DIV=Debian, AIV=Android
             LBV=BSP, LIV=Image
PlatformProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagComment
RK3399RSB-3710V11932021/04/20RTMNABaidu  Password:a887 DropboxRK3399_N7_AIV1193.xml
  • Alpha:  Basic I/O function bring up by RD;
  • Beta:  Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
  • GA:  Beta version by QE verification;
  • RTM:  Beta version by SI/Power/QE verification and pre-loaded;
Android 燒錄方法 (Flash Android image into eMMC Method)​
1. Prepare a mirco USB Cable and Debug Cable
mirco USB
RTENOTITLE
Debug Cable
RTENOTITLE
  1. Plug the OTG Cable into RSB-3720
RTENOTITLE
Connect Debug cable
RTENOTITLE
2. 設定終端機(Set Debug Terminal)
Debug 串口調試 (Debug port Setting)
 Tera Term setting
   Baud Rate:115200
Data :8
Parity :none
Stop :1
Flow Control:none
Tera Term Tool
RTENOTITLE
RTENOTITLE
Note:
Check the Sriel port in Device Manager :
if you can not identify the Serial device , please check your serial driver.
3.Open the flash tool
RTENOTITLE
  1. Turn on the power
  2. When you see the debug message in Terminal , then press "Ctrl+C" , then log into Uboot stage
RTENOTITLE
  1. In Uboot , please type  "loader"  , then the device will transfer to "Flash mode" , Android tool also will show  "Found One MASKROM Device "
RTENOTITLE
  1. In RKDevTool pressed  "Run"  , and it will flash image into eMMC.
RTENOTITLE
  1. The flash process  was finishded
RTENOTITLE
  1. Reboot the device , and connect with HDMI , it will show the Android Desktop.
RTENOTITLE
系统的基本使用(Linux System Basic Operating Method)​
Display Setting (RSB-3710) "Display Setting (RSB-3710)")​
lvdslvds-g070vw01; lvds-g150xgel05; lvds-g215hvn01
hdmihdmi-default
dpdp-default
IN ubootIn Debian/Android
setenv prmry_screen hdmi-defaultfw_setenv prmry_screen hdmi-default
setenv extend_screen edp-1920x1080fw_setenv extend_screen edp-1920x1080
saveenv
resetreboot
In u-boot:
=> setenv prmry_screen lvds-g070vw01
=> setenv extend_screen hdmi-default
=> saveenv
=> reset
In Linux:
~# fw_setenv prmry_screen lvds-g070vw01
~# reboot
Modify LVDS backlight PWM: (Defaul is 20KHz, New version BSP support to modify the PWM clock in u-boot from 200~20KHz)
In u-boot:
=> setenv lvds_pwm_clock 10000 (Set PWM clock to 10KHz)
In Linux:
~# fw_setenv lvds_pwm_clock 10000 (Set PWM clock to 10KHz)
~# reboot
Check PWM duty sysle in Linux:
~# cat /sys/kernel/debug/pwm
RTENOTITLE
乙太網路使用方法(Ethernent Testing Method)​
Command : ifconfig
Command: Ping 8.8.8.8
WiFi使用方法(WIFI Testing Method)​
# killall wpa_supplicant
# ifconfig wlan0 up
# wpa_passphrase "SSID" "PASSWORD" > /tmp/wpa.conf
# cat /tmp/wpa.conf
# wpa_supplicant -BDwext -iwlan0 -c/tmp/wpa.conf
# udhcpc -b -i wlan0
# ifconfig
# ping 8.8.8.8
Add DNS to /etc/resolv.conf
# cat /etc/resolv.conf
# Generated by Connection Manager
nameserver 8.8.8.8
nameserver 8.8.4.4
Now can ping google.com
# ping google.com
4G使用方法(4G Testing Method)​
Ubuntu - 4G 模塊(EC-25J) 設定 ( 4G module (EC-25J) in Ubuntu system)%E8%A8%AD%E5%AE%9A(4G_module(EC-25J)_in_Ubuntu_system) "Ubuntu - 4G 模塊(EC-25J) 設定 ( 4G module (EC-25J) in Ubuntu system)")
Ubuntu - 4G 模塊(EC-20) 設定( 4G module (EC-20) in Ubuntu system)_%E8%A8%AD%E5%AE%9A(4G_module(EC-20)_in_Ubuntu_system) "Ubuntu - 4G 模塊(EC-20) 設定( 4G module (EC-20) in Ubuntu system)")
GPIO使用方法(GPIO Operating Method)​
RTENOTITLE
RTENOTITLE
RTENOTITLE
蓝牙使用方法(BlueTooth Operating Method)​
# hciattach /dev/ttymxc0 bcm43xx 115200 flow
# hciconfig hci0 up
# hcitool scan# bluetoothctl
# discoverable on
#pairable on
# scan on
# scan off
# pair 84:C5:A6:D3:AF:E4
# connect 84:C5:A6:D3:AF:E4
Check BT connect info
# info 84:C5:A6:D3:AF:E4
音訊使用方法(BlueTooth Operating Method)​
Line-in , Line-out, MIC
1.Line-out
Command : gplay-1.0
2.MIC
Command : arecord
Check audio codec:
# cat /proc/asound/cards
0 [sgtl5000 ]: sgtl5000 - sgtl5000
sgtl5000
1 [audiohdmi ]: audio-hdmi - audio-hdmi
audio-hdmi
root@imx8mprsb3720a1:~#
Set Mic/audio volume
# amixer set Mic 100%
# amixer set Lineout 100%
# amixer set PCM 100%
Record and playback
Example command:
# arecord –t wav –c 1 –r 44100 –d 5 /tmp/mic.wav
# aplay /tmp/mic.wav
Record from MIC:
# arecord -D plughw:0,0 -r 16000 -f S16_LE ./f-16000.wav
Recording WAVE './f-16000.wav' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
# aplay f-16000.wav
Playing WAVE 'f-16000.wav' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
Play wav file from codec:
# aplay -D plughw:0,0 file_example_WAV_10MG.wav
Playing WAVE 'file_example_WAV_10MG.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
Play wav file from HDMI:
# aplay -D plughw:1,0 file_exam
ple_WAV_10MG.wav
看門狗測試 (Watch Dog Test method)​
System will reboot after 1 sec
# /unit_tests/Watchdog/wdt_driver_test.out 1 2 0
遠程訪問及文件傳輸(Remote Access and File Transimmion)​
**查看主板IP位址 ( Chech IP Address ):**​
        Command : ifconfig
RTENOTITLE
Windows下SSH访问及文件传输​
SSH Remote Log into Device
  • SSH远程登录,以putty选择putty.exe(或者使用Xshell、SecureCRT等类似软件)
  • 需要设置远程设备的IP、通讯端口(默认22)、通讯方式,登录后验证用户名密码
RTENOTITLE
RTENOTITLE
RTENOTITLE
通用方法(General Method)​
查看CPU温度(Check CPU Temperature)​
root@linaro-alip:~# cat /sys/devices/virtual/thermal/thermal_zone0/temp
40000
# 或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]°
>> 40°
查看CPU频率(Check CPU Frequency)​
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
>> 1200000
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
>> 1800000
查看内存容量(Check Memory Capacity)​
root@linaro-alip:~# busybox free -m
              total        used        free      shared  buff/cache   available
Mem:           1961         303        1096          97         561        1575
Swap:             0           0           0
root@linaro-alip:~#
查看存储容量(Check Storage Capacity)​
root@linaro-alip:~# busybox df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root                 7.8G      2.8G      4.6G  37% /
devtmpfs                972.3M      8.0K    972.3M   0% /dev
tmpfs                   980.8M         0    980.8M   0% /dev/shm
tmpfs                   980.8M     16.8M    964.0M   2% /run
tmpfs                     5.0M      4.0K      5.0M   0% /run/lock
tmpfs                   980.8M         0    980.8M   0% /sys/fs/cgroup
/dev/mmcblk1p10           6.4G      3.8M      6.4G   0% /userdata
/dev/mmcblk1p7           62.6M     12.0M     47.3M  20% /oem
tmpfs                   196.2M         0    196.2M   0% /run/user/0
tmpfs                   196.2M      8.0K    196.1M   0% /run/user/1000
root@linaro-alip:~#
網路Ping測試(Ping Network Testing)​
ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
設置RTC (RTC Setting)​
Set system time to current, then write to RTC
root@linaro-alip:# date 01282022
Fri Jan 28 20:22:00 UTC 2022
root@linaro-alip:
Restart the RTC time to system time
hwclock -s && date
root@linaro-alip:# hwclock -s && date
Thu Jan 20 06:18:26 UTC 2022
root@linaro-alip:
如果有驗證上的錯誤 請使用以下的方法(If you got " Server certificate verification failed " message ,please follow the solution as below)​
**### repo sync failed with Server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
export GIT_SSL_NO_VERIFY=1
#or
git config --global http.sslverify false
