RSB-4710 Android User Guide
← Back to RSB-4710
產品介紹(Product introduction )​
產品特性(Product Features)​
  • Rockchip RK3399 ARM Dual Cortex-A72 and Quad Cortex-A53 1.8 GHz
    *Onboard 2GB LPDDR4 memory and 16GB eMMC
    *Dual HDMI(4K 60fps + 1080P), 1 x eDP, 1 x dual channel LVDS, 1 x MIPI CSI
    *Supports 4K H.264/H.265 video decoder
    *6 x serial, 1 x USB3.0, 4 x USB2.0 ,1 x USB OTG, 2 x GbE, 1 x SPI, 1 x I2C, 5 x GPIOs
    *M.2 for WIFI/BT support, mini-PCIe for 3G/4G support
    *Supports Debian9/10 and Android7.1/10.0
產品官網連結(Product Features)​
RSB-4710
硬件接口說明(Hardware interface introduction)​
接口布局和尺寸(Layout and Sizes)​
接口布局圖 Board Dimension Layout​
RTENOTITLE
RTENOTITLE
RTENOTITLE RTENOTITLE
Connector List​
接口引脚定義 (Pin definitions)​
  • 电池扣(RTC)
  • 串口(RS-232 (COM1),RS-232/Debug Port (COM2/DEBUG),RS-232/485 (COM56),Internal RS-232 (COM34))%EF%BC%8CRS-232/Debug_Port_(COM2/DEBUG)%EF%BC%8CRS-232/485_(COM56)%EF%BC%8CInternal_RS-232_(COM34)%EF%BC%89 "串口(RS-232 (COM1),RS-232/Debug Port (COM2/DEBUG),RS-232/485 (COM56),Internal RS-232 (COM34))")
  • 显示接口(LVDS,LVDS_BL,EDP,HDMI)
  • LAN接口(LAN1,LAN2)
  • USB接口(USB1,Pin Header,OTG)
  • 音频接口(Audio)
  • Micro SD & Nano SIM Card
  • 电源及指示灯和开关机复位按钮(DC Power,Power Button and LED)
  • Mini PCIe & MIPI CSI 接口
  • M.2接口
  • GPIO接口
  • SPI ,I2C接口
  • RSB-4710 Jumper List
**机械尺寸  (**Mechanical Characteristics)​
RTENOTITLE
快速入门 (Quick Start)​
系统下载 (OS Download)​
Android7.12
Note: AIV=Android image  ABV=BSP
ProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagComment
RSB-4710V11802020/08/27RTMRelease_NoteBaidu  Password:a887 DropboxRK3399_N7_AIV1180.xml
  • Alpha:  Basic I/O function bring up by RD;
  • Beta:  Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
  • GA:  Beta version by QE verification;
  • RTM:  Beta version by SI/Power/QE verification and pre-loaded;
Android 燒錄方法 (Android Flash eMMC Method)
There are three ways to update images:
1.Using_AndroidToool.​
There is no limitation by this way.
2.Using_storage(such sd_or_USB_disk)with_update.zip_in_it.​
There are some limitations:
(1)The device must be able to boot up to Android system.
(2)Only update images from the same os,  eg :
        Android6.0 upgrade to Android6.0 or Android7.1 upgrade to Android7.1.
(3)Using update.zip to upgrade. (see more detail in "Create OTA zip" on how to create update.zip)
3.Using_bootup_sd_disk made_by SDDiskTool.​
(1)Only update images from the same os,  eg :
(2)Using update.img to upgrade.
Linux系统的基本使用(Linux System Basic Operating Method)​
How to debug​
How to use GPIO​
How to use UART​
How to config Multi-Display​
How to use I2C Hub​
How to Config 4G-module​
MAC_Address​
Android signature​
Install Jave in Linux​
DS-100​
  • Linux BSP User Guide for rk3399 series Debian9
  • Linux BSP User Guide for rk3399 series DeviceOn
  • [Linux BSP User Guide for SGI [DMS-SA53]](./RSB-4710_Android_User_Guide_wiki_data/IoTGateway/BSP/Linux/Linux_BSP_User_Guide_SGI "IoTGateway/BSP/Linux/Linux BSP User Guide SGI".md)
乙太網路使用方法(Ethernent Testing Method)​
Command : ifconfig
root@linaro-alip:~# ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:83:27:77:c0  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.127.101  netmask 255.255.255.0  broadcast 192.168.127.255
        inet6 fe80::e405:b000:5963:d697  prefixlen 64  scopeid 0x20<link>
        ether c6:ff:6c:34:9d:7d  txqueuelen 1000  (Ethernet)
        RX packets 23  bytes 7566 (7.3 KiB)
        TX packets 45  bytes 5391 (5.2 KiB)
        device interrupt 24
eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 96:a4:98:8d:52:09  txqueuelen 1000  (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 484  bytes 32428 (31.6 KiB)
        TX packets 484  bytes 32428 (31.6 KiB)
Command : ping 192.168.127.101
root@linaro-alip:~# ping 192.168.127.101
PING 192.168.127.101 (192.168.127.101) 56(84) bytes of data.
64 bytes from 192.168.127.101: icmp_seq=1 ttl=64 time=0.221 ms
64 bytes from 192.168.127.101: icmp_seq=2 ttl=64 time=0.135 ms
64 bytes from 192.168.127.101: icmp_seq=3 ttl=64 time=0.134 ms
64 bytes from 192.168.127.101: icmp_seq=4 ttl=64 time=0.137 ms
64 bytes from 192.168.127.101: icmp_seq=5 ttl=64 time=0.137 ms
^C
--- 192.168.127.101 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 0.134/0.152/0.221/0.037 ms
root@linaro-alip:~#
查看CPU温度(Check CPU Temperature)​
root@linaro-alip:~# cat /sys/devices/virtual/thermal/thermal_zone0/temp   34444
# 或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 37°
查看CPU频率(Check CPU Frequency)​
root@linaro-alip:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
408000
root@linaro-alip:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
1416000
查看内存容量(Check Memory Capacity)​
root@linaro-alip:~# busybox free -m
              total        used        free      shared  buff/cache   available
Mem:           1961         269        1454          18         237        1696
Swap:             0           0           0
查看存储容量(Check Storage Capacity)​
root@linaro-alip:~# df -h
Filesystem       Size  Used Avail Use% Mounted on
/dev/root        7.9G  2.6G  4.9G  35% /
devtmpfs         973M  8.0K  973M   1% /dev
tmpfs            981M     0  981M   0% /dev/shm
tmpfs            981M  8.9M  972M   1% /run
tmpfs            5.0M  4.0K  5.0M   1% /run/lock
tmpfs            981M     0  981M   0% /sys/fs/cgroup
/dev/mmcblk1p10  6.4G  3.8M  6.4G   1% /userdata
/dev/mmcblk1p7    63M   13M   48M  21% /oem
tmpfs            197M  8.0K  197M   1% /run/user/1000
tmpfs            197M     0  197M   0% /run/user/0
root@linaro-alip:~#
設置RTC (RTC Setting)​
root@linaro-alip:~# date
Wed May 11 01:12:06 UTC 2022
root@linaro-alip:~# date -s "2022-5-11 09:12:00"
Wed May 11 09:12:00 UTC 2022
Wed May 11 09:12:06 UTC 2022
root@linaro-alip:~# hwclock -w
2022-05-11 09:12:17.266424+00:00​
QT 安装步骤​
Qt5Creator_toolchain_Qt_5.11.3
How to build Android 7 BSP (Android 7 BSP 編譯)​
<http://ess-wiki.advantech.com.tw/view/Android_BSP_User_Guide_for_rk3399_series_7.1.2>
