Linux BSP User Guide for RK3568 series Debian11
This guide provides comprehensive instructions for building and deploying Linux BSP for RK3568 series development boards running Debian 11.
Linux BSP Version
  • Operating System: Debian 11.x
  • Kernel Version: 5.10.160
Build Environment on Host
Currently, we adopt Docker as the build environment for consistent development experience.
You can get the latest version of advrisc/u20.04-rklbv1 Docker image for developing Rockchip RK3568 projects.
Docker Installation Commands
sudo apt-get install -y qemu-user-static
sudo apt-get install -y live-build
sudo docker pull advrisc/u20.04-rklbv1
Run Docker Example
Step 1: Run Docker Container
sudo docker run -it --name rk356x_linux5.10_v130_risc \
-v /home/bsp/myLinux:/home/adv/BSP:rw \
--privileged advrisc/u20.04-rklbv1:latest /bin/bash
Step 2: Change User Ownership in Container
adv@7cc0fa834366:~$ sudo chown adv:adv -R BSP
Getting Linux Source Code
cd ~/BSP
git clone https://github.com/ADVANTECH-Rockchip/repo.git
mkdir rk356x_linux5.10_v130_risc
cd rk356x_linux5.10_v130_risc
git config --global user.name "Your Name"
git config --global user.email you@example.com
../repo/repo init -u https://AIM-Linux@dev.azure.com/AIM-Linux/RISC-RK3568-Linux/_git/manifest \
-b rk356x_linux5.10_v130_risc -m default.xml
../repo/repo sync
../repo/repo forall -c git checkout -b local --track advantech-azure/rk356x_linux5.10_v130_risc
Build Choose Project
RSB-4810 Project Build
export TOP=`pwd`
cd $TOP
./build.sh adv_rk3568_rsb4810a2_defconfig
ROM-5880 Project Build
export TOP=`pwd`
cd $TOP
./build.sh adv_rk3568_rom5880a1_defconfig
AFE-E630 Project Build
export TOP=`pwd`
cd $TOP
./build.sh adv_rk3568_afee630a1_defconfig
EBC-RB07 Project Build
export TOP=`pwd`
cd $TOP
# Coming soon
Build Components
Build U-boot
cd $TOP
./build.sh uboot
Build Kernel
cd $TOP
./build.sh kernel
Build Recovery
cd $TOP
rm buildroot/output/rockchip_rk3568_recovery -rf
./build.sh recovery
Build Debian 11.x
cd $TOP
sudo dpkg -i debian/ubuntu-build-service/packages/*
sudo apt-get install -f -y
./build.sh debian
Generate Firmware Images
Push All Images to rockdev Folder
cd $TOP
./build.sh firmware
All images will be generated in the rockdev/ directory. The ./mkfirmware.sh script from the previous step will repack boot.img and rootfs.img, and copy other related image files to the rockdev/ directory.
Common Image Files
The following image files will be generated:
  • boot.img - Boot partition image
  • misc.img - Miscellaneous partition image
  • oem.img - OEM partition image
  • recovery.img - Recovery partition image
  • rootfs.img - Root filesystem image
  • uboot.img - U-Boot bootloader image
  • userdata.img - User data partition image
  • MiniLoaderAll.bin - Mini loader binary
  • parameter.txt - Partition parameter file
Make update.img
cd $TOP
sudo apt-get install bsdmainutils
./build.sh updateimg
You can get update.img in the rockdev/ directory.
How to Update Images
There are three methods to update images on your target device:
Method 1: Using AndroidTool
This method has no limitations and provides the most flexibility for flashing images.
Features:
  • No restrictions on update scenarios
  • Supports all partition updates
  • Works regardless of device boot state
Method 2: Using Storage Device (SD Card or USB Disk) with update.zip
This method has specific limitations that must be considered:
Requirements:
  • The target device must be able to boot up to Debian
  • Only supports updating images from the same OS (e.g., Debian upgrade to Debian)
  • Must use update.img for the upgrade process
Limitations:
  • Device must be functional and bootable
  • Cross-OS updates are not supported
Method 3: Using Bootup SD Disk Made by SDDiskTool
This method creates a bootable SD card for system updates:
Requirements:
Limitations:
  • Same-OS restriction applies
  • Requires SDDiskTool for SD card preparation
Troubleshooting
Common Issues
  1. Docker Permission Issues: Ensure proper user permissions are set using chown command
  2. Build Failures: Verify all dependencies are installed and Docker image is up to date
  3. Source Code Issues: Check network connectivity and Git credentials for repository access
  4. Update Failures: Ensure compatibility between source and target OS versions
Build Dependencies
Make sure the following packages are installed in your build environment:
  • qemu-user-static
  • live-build
  • bsdmainutils
Additional Notes
  • This documentation was last modified on 19 September 2024
  • Always verify your build configuration matches your target hardware
  • Maintain proper Git configuration for source code management
  • Regular backup of working configurations is recommended
This guide is part of the ESS-WIKI documentation system for Advantech embedded systems development.
