ROM-5721 user guide
Contents
  • 1產品介紹(Product introduction ) 1.1產品特性(Product Features) 1.2產品官網連結(Product Features)
  • 2硬件接口說明(Hardware interface introduction) 2.1接口布局和尺寸(Layout and Sizes) 2.2ROM-5721 接口布局圖 Board Dimension Layout 2.3主板内置插针式引脚排序方式 (Pin Header defination) 2.4Internal I/O 2.5Rear I/O 2.6接口引脚定義 (Pin definitions) 2.7机械尺寸  (Mechanical Characteristics)
  • 3快速入门 (Quick Start) 3.1系统下载 (OS Download) 3.2Linux 燒錄方法 (Linux Flash eMMC Method) 3.3Debug 串口調試 (Debug port Setting)
  • 4Linux系统的基本使用(Linux System Basic Operating Method) 4.1UUU 使用方法(USB Connection (OTG port)) 4.2Display Setting (ROM-5721) 4.3乙太網路使用方法(Ethernent Testing Method) 4.4WiFi使用方法(WIFI Testing Method) 4.5串口使用方法(Serial Port Operating Method) 4.6蓝牙使用方法(BlueTooth Operating Method) 4.7遠程訪問及文件傳輸(Remote Access and File Transimmion) 4.7.1Windows下SSH访问及文件传输
  • 5通用方法(General Method) 5.1查看CPU温度(Check CPU Temperature) 5.2查看CPU频率(Check CPU Frequency) 5.3查看内存容量(Check Memory Capacity) 5.4查看存储容量(Check Storage Capacity) 5.5網路Ping測試(Ping Network Testing) 5.6設置RTC (RTC Setting)
  • 6Linux BSP編譯方法(Linux BSP Compile Method) 6.1Yocto 4.2 6.2Yocto 4.0 6.3Yocto 3.0 6.4Yocto 2.5
  • 7Build known issue
  • NXP i.MX 8M Mini processor with up to 4 Arm Cortex A53 cores
  • 1 x Arm Cortex-M4 core
  • Onboard LPDDR4 memory and eMMC
  • 1 x 4 lane MIPI-CSI,1 x Dual channel LVDS or 1 x Display Port
  • 4 x USB2.0, 1 x USB 2.0 OTG, 4 x UART, 4 x I2C, 12 x GPIO, 1 x PCIe2.0, 1x Gigabit LAN
  • Support OpenGL ES 2.0/1.1 by hardware accelerators
  • Low power consumption design
  • Support Linux and Android BSP
ROM-5721
Internal I/O
PositionDescriptionConnector Type
BAT1PIN Header for BatteryWAFER 8P 2.54mm 180D(M) DIP A2543WV2-8P
BH1RTC Battery HolderBATTERY HOLDER 24.923.48.9 CR2032 BH800.4GG
CAN1CANBus Port 1BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
CAN2CANBus Port 2BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
COM1COM Port 1BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
COM3COM Port 3 (Debug Port)BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
CN4PCIex1 Connector 1PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF
CN5PCIex1 Connector 2PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF
CN6PCIex1 Connector 3PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF
CN11SATA ConnectorSerial ATA 7P 1.27mm 180D(M) DIP WATM-07DBN4A3B8
CN12SATA Power ConnectorWAFER 4P 2.5mm 180D(M) DIP 24W1161-04S10-01T
CN22GPIOx8 setsPIN HEADER 10x2P 2.0mm 180D(M) DIP 21N22050
CN25MXM 3.0 ConnectorMXM Conn. 314P 90D(F) SMD AS0B821-S78B-7H
CN26M.2 Key E SlotsNGFF 75P 0.5mm 90D(F) H=4.2mm SMD AS0BC21-S40BE
CN38FAN (Reserved)WTB Con. 3P 2.54mm 180D(M) DIP A2543WV0-3P-6T-5e
CN39MIPI-CSI1 (FPC, 4-LaneFPC 39P, 0.6mm, H0.9mm
CN40MIPI-CSI0 (FPC, 2-Lane)FPC 39P, 0.6mm, H0.9mm
CN41MIPI-CSI0 (Mini-SAS, 2-Lane)Mini SAS 36P/0.8mm/(M)/LCP/VA/G15u/ S/BK/W
CN42MIPI-CSI1 (Mini-SAS, 4-Lane)Mini SAS 36P/0.8mm/(M)/LCP/VA/G15u/ S/BK/W
ESPI_CN1ESPIPIN HEADER 6x2P 2.0mm180D(M) SMD 21N22050-12M00B
I2C_GP_1I2C Pin HeaderWAFER BOX 4P 2.00mm 180D(M) DIP 721-81-04TW00
I2C_CN3Audio Codec BoardPIN HEADER 2x10P 2.54mm 180D(M) DIP 21N22564
LVDS0LVDS0Wafer 2x20P/1.25mm/(M)/NY9T/VA/GFL/ S/WH/W
LVDS_BK_PWRLVDS0 Back LightWAFER BOX 5P 2.0mm 180D(M) DIP A2001WV2-5P
LVDS1LVDS1Wafer 2x20P/1.25mm/(M)/NY9T/VA/GFL/ S/WH/W
LVDS1_BK_PWRLVDS1 Back LightWAFER BOX 5P 2.0mm 180D(M) DIP A2001WV2-5P
SD1SD Card SlotSD CARD 9P 90D(F) SMD WK2192CS3D- 7H
SPI_CN1SPI Pin HeaderPIN HEADER 4x2P 2.54mm 180D(M) SMD 21N22564
SW2Reset ButtonTACT SW STS-091 SMD 4P H=3.8mm
SW4SLP ButtonTACT SW STS-091 SMD 4P H=3.8mm
SW5Power ButtonTACT SW STS-091 SMD 4P H=3.8mm
USB0_OTG1USB OTGMicro USB 5P/0.65mm/(F)/NY9T/GFL/ RA/S/BK/B
USB-4-5USB Port 4, Port 5PIN HEADER 2x5P 2.0mm 180D(M) SMD 21N22050
Rear I/O
PositionDescriptionName
DCINDC JackA
CN15AUART Port 0B
CN15BUART Port 2C
CN1ADP PortD
CN1BHDMI PortE
CN33Type C Controller Programming Header (Reserved Only)F
CN34USB Type CG
CN8GbE Ethernet Connector PortH
CN3USB Port 1/ 2I
Audio1MIC Input/ Audio OutputJ
机械尺寸  ( Mechanical Characteristics)
快速入门 (Quick Start)
系统下载 (OS Download)
  • Linux系统 (Linux OS)
​Yocto 2.5: IoTGateway/BSP/Linux/iMX8/OS Support List - ESS-WIKI (advantech.com.tw)
Yocto 3.0: IoTGateway/BSP/Linux/iMX8/OS Support List 3.0
使用Flash tool 燒錄鏡像到eMMC (Flash image into eMMC by Flash Tools)
Step0: 檢查SD卡在Linux 環境的代號 (check SD card symbol in Linux system)
Step1: 創造一張可開機的SD 卡 (Create a bootable SD card)
Step2: 將可開機的SD 卡插入底板SD卡卡槽(Plug the SD card into Carrier board 's SD card slot)
Step4: 確認開機選擇指撥開關 (Check the boot switch)
SD 卡開機模式(SD boot mode):
Step3:打開電源 和 終端機 (Turn on the Power & Terminal)
Step4: 解壓縮flash tools 檔案,並複製到U盤中(Unzip the flash tools file , then copy to USB Disk)
解壓縮(Unzip the file )
複製檔案到U盤中 (Copy the flash file to USB Disk)
  1. 插入U盤到你的Ubuntu 電腦上 (Plug the USB Disk into you Linux PC
  2. 檢視U盤在Ubuntu 系統代號 (Check the USB Disk's symbol in Ubuntu System)
  3. 掛載U盤在Ubuntu 系統中 (Mount the USB Disk's in Ubuntu System)
  4. 複製檔案到U盤(Copy the file to USB disk)
  5. 將U盤連接到ROM-5721系統, 進入flash tool下的mk_inand資料夾, 執行指令./mksd-linux.sh /dev/mmcblk2燒錄image到eMMC (Connect USB Disk to ROM-5721 system, browser to mk_inand folder and execute flash shell script "./mksd-linux.sh /dev/mmcblk2"
ROM-5721
SD card/dev/mmcblk1
eMMC/dev/mmcblk2
  1. 切換開機switch 1:on 2,3,4,5,6:off來設定成從eMMC開機(Change boot switch to "1:on 2,3,4,5,6:off" to boot from eMMC. Reboot system).
以 Tera Term  为例介绍如何使用串口调试功能
   Baud Rate波特率:115200
Data 数据位:8
Parity 奇偶校验:无
  Stop 停止位:1
Flow Control流控:无
Tera Term Tool
Check the Sriel port in Device Manager (查看PC端的串口号):
if you can not identify the Serial device , please check your serial driver.
Debug port connection (串口連接)
Log into Terminal  Tool (进入串口调试终端):
Download uuu tool from (Release [ ADV v20200619 · ADVANTECH-Corp/uuu · GitHub]) or in the folder.
The “imx-boot-imx8mmrom5721a1-sd.bin-flash_evk” file be included in 5721A1AIM20LIV90XXX_iMX8MM_misc.tgz. XXX is the version.
Connect USB cable to USB OTG port.
Change boot switch to "4:on 1,2,3,5,6:off" to boot from force recovery mode.
Type command below to flash eMMC:
U-boot Command :
setenv fdt_file xxxx.dtb env save boot
U-boot load fefault setting:
env default -a env save reset
  • Display: Default support g070vw01 LVDS panel on LVDS0
Yocto 2.5
  • DSI to LVDS g070vw01 adv-imx8mm-rom5721-a1.dtb g150xgel05 adv-imx8mm-rom5721-a1-dsi2lvds-g150xgel05.dtb g215hvn01 adv-imx8mm-rom5721-a1-dsi2lvds-g215hvn01.dtb DSI to DP adv-imx8mm-rom5721-a1-dsi2dp.dtb DSI to HDMI adv-imx8mm-rom5721-a1-adv7535.dtb DSI auog101uan02 adv-imx8mm-rom5721-a1-auog101uan02.dtb
  • M.2 SDIO Adjust CN43~CN48 adv-imx8mm-rom5721-a1-m2-sdio.dtb
  • M.2 I2S adv-imx8mm-rom5721-a1-m2-i2s.dtb
Yocto 3.0
  • DSI to LVDS g070vw01 imx8mm-rom5721-a1.dtb g150xgel05 imx8mm-rom5721-a1-dsi2lvds-g150xgel05.dtb g215hvn01 imx8mm-rom5721-a1-dsi2lvds-g215hvn01.dtb DSI to DP imx8mm-rom5721-a1-dsi2dp.dtb DSI to HDMI imx8mm-rom5721-a1-adv7535.dtb DSI auog101uan02 imx8mm-rom5721-a1-auog101uan02.dtb
  • M.2 SDIO Adjust CN43~CN48 imx8mm-rom5721-a1-m2-sdio.dtb
Command : ifconfig
Command: Ping - I eth1 8.8.8.8  or Ping - I eth0 8.8.8.8
Command :
preparatory work:将WIFI天线安装到ROM-5721上
举例:
root@imx8mmrom5721a1:~# ifconfig mlan0 up
root@imx8mmrom5721a1:~#iwlist mlan0 scan
备注:(ESSID:"SSID"—热点名称,密码:123456789)
Cell 41 - Address: E2:92:00:7C:81:95
ESSID:"SSID" [41]
Mode:Master
Frequency=5.785 GHz
Quality:5/5 Signal level:-46 dBm Noise level:-96 dBm
Encryption key:on
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
36 Mb/s; 48 Mb/s; 54 Mb/s
Extra:Beacon interval=200
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
IE: Unknown: DD180050F2020101810003A4000027A4000042435E0062322F00
Extra:band=a
root@imx8mmrom5721a1:~# wpa_passphrase "SSID" 123456789 > /tmp/wpa.conf
root@imx8mmrom5721a1:~# sync
root@imx8mmrom5721a1:~# cat /tmp/wpa.conf
network={
ssid="SSID"
#psk="123456789"
psk=63079f1c4891c9bb8a0496498d793993b5a0927e042358833eef89f1a90719a1
root@imx8mmrom5721a1:~# wpa_supplicant -BDwext -imlan0 -c/tmp/wpa.conf
Successfully initialized wpa_supplicant
rfkill: Cannot get wiphy information
[ 189.719149] wlan: SCAN COMPLETED: scanned AP count=41
ioctl[SIOCSIWESSID]: Bad address
root@imx8mmrom5721a1:~# [ 191.724260] EXT_SCAN: wlan_interpret_bss_desc_with_ie returned error
[ 197.337568] wlan: SCAN COMPLETED: scanned AP count=41
[ 197.370146] IPv6: ADDRCONF(NETDEV_CHANGE): mlan0: link becomes ready
^C
root@imx8mmrom5721a1:~# udhcpc -b -i mlan0
udhcpc: started, v1.31.0
udhcpc: sending discover
udhcpc: sending select for 192.168.43.132
udhcpc: lease of 192.168.43.132 obtained, lease time 3600
/etc/udhcpc.d/50default: Adding DNS 192.168.43.1
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:214 errors:0 dropped:0 overruns:0 frame:0
TX packets:214 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:15212 (14.8 KiB) TX bytes:15212 (14.8 KiB)
mlan0 Link encap:Ethernet HWaddr c0:e4:34:6d:fa:bf
inet addr:192.168.43.132 Bcast:192.168.43.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:9 errors:0 dropped:0 overruns:0 frame:0
TX packets:48 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1248 (1.2 KiB) TX bytes:7034 (6.8 KiB)
备注:以上步骤完成,就可以查看到mlan0 是否有连接到wifi或热点。
root@imx8mmrom5721a1:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=50 time=287 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=50 time=104 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=50 time=331 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=50 time=149 ms
^C
--- 8.8.8.8 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 104.162/217.722/331.103/93.911 ms
=== '''  GPIO使用方法(GPIO Operating Method)''' ===
[[File:Z17.jpg|RTENOTITLE]]
<pre>Loop-back Test (Take GPIO0 and GPIO2 as examples)
Step 1: Connect GPIO0 and GPIO2
Step 2: Export GPIO interface
root@imx8mmrom5721a1: ~# echo 496 > /sys/class/gpio/export
root@imx8mmrom5721a1: ~# echo 497 > /sys/class/gpio/export
Step 3: Set direction
root@imx8mmrom5721a1: ~# echo out > /sys/class/gpio/gpio1/direction
root@imx8mmrom5721a1: ~# echo in > /sys/class/gpio/gpio2/direction
Step 4: Read value and set output value then check
root@imx8mmrom5721a1: ~# cat /sys/class/gpio/gpio2/value
0
root@imx8mmrom5721a1: ~# echo 1 > /sys/class/gpio/gpio1/value
1
RS-232 Test
CN15上(SER0/UART3): /dev/ttymxc2
CN15 下(SER2/UART1): /dev/ttymxc0
COM 3 (A53 debug/SER3/UART2): /dev/ttymxc1
COM 1 (M4 debug/SER1/UART4): /dev/ttymxc3
SW7 Setting (SW7設置)
MODE1  MODE0 0            0            LOOPBACK 0            1            RS232 1            0            RS485 1            1            RS422
Loopback test (eg. ttymxc0) Connect loopback test tool
  1. stty ‐F /dev/ttymxc0 115200 # stty ‐F /dev/ttymxc0 ‐echo # cat /dev/ttymxc0 & # echo test > /dev/ttymxc0
Command :
$ hciconfig hci0 up
$ bluetoothctl
$ discoverable on
$ pairable on
$ scan on
[NEW] FC:18:3C:8D:75:F4 myphone
$ scan off
$ pair FC:18:3C:8D:75:F4
$ connect FC:18:3C:8D:75:F4
查看主板IP位址 ( Chech IP Address ):
        Command : ifconfig
Windows下SSH访问及文件传输
SSH Remote Log into Device
  • SSH远程登录,以putty选择putty.exe(或者使用Xshell、SecureCRT等类似软件)
  • 需要设置远程设备的IP、通讯端口(默认22)、通讯方式,登录后验证用户名密码
    root@imx8mmrom5721a1:/# cat /sys/devices/virtual/thermal/thermal_zone0/temp 44600
# 或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 45°
           cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
>> 900000
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
>> 1200000
root@imx8mmrom5721a1:/# busybox free -m
total used free shared buffers cached
Mem: 1794920 516080 1278840 17252 9852 80292
-/+ buffers/cache: 425936 1368984
Swap: 0 0 0
root@imx8mmrom5721a1:/# busybox df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 13.4G 1.7G 11.1G 13% /
devtmpfs 395.8M 4.0K 395.8M 0% /dev
tmpfs 876.4M 0 876.4M 0% /dev/shm
tmpfs 876.4M 16.5M 859.9M 2% /run
tmpfs 876.4M 0 876.4M 0% /sys/fs/cgroup
tmpfs 876.4M 4.0K 876.4M 0% /tmp
tmpfs 876.4M 280.0K 876.2M 0% /var/volatile
/dev/mmcblk0p2 13.6G 1.7G 11.3G 13% /run/media/mmcblk0p2
/dev/mmcblk0p1 63.9M 23.4M 40.5M 37% /run/media/mmcblk0p1
/dev/mmcblk1p1 63.9M 23.4M 40.5M 37% /run/media/mmcblk1p1
tmpfs 175.3M 88.0K 175.2M 0% /run/user/0
root@imx8qxprom5620a1:/#
     ping 8.8.8.8
64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
設置RTC (RTC Setting)
     root@imx8mmrom5721a1:/# systemctl stop ntpdate.service
root@imx8mmrom5721a1:/# date 090816072021 && hwclock -w && date
Wed Sep 8 16:07:00 UTC 2021
Wed Sep 8 16:07:06 UTC 2021
root@imx8mmrom5721a1:/#'''
Yocto 4.2
Yocto 4.0
Y octo 3.0
Yocto 2.5
Build known issue
  • 如果有驗證上的錯誤 請使用以下的方法
### repo sync failed with Server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none ERROR: gstreamer1.0-1.14.4.imx-r0 do_unpack: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/hom e/adv/adv-release-bsp/build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/usr/bin/py thon3-native:/home/adv/adv-release-bsp/sources/poky/scripts:/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-poky-l inux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/usr/bin/aarch64-poky-linux:/home/adv/adv-release-bsp/build_x11/tm p/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot/usr/bin/crossscripts:/home/adv/adv-release-bsp/buil d_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/usr/sbin:/home/adv/adv-release-bsp/b uild_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/usr/bin:/home/adv/adv-release-bsp /build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/sbin:/home/adv/adv-release-bsp/ build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/bin:/home/adv/adv-release-bsp/so urces/poky/bitbake/bin:/home/adv/adv-release-bsp/build_x11/tmp/hosttools"; export HOME="/home/adv"; git -c core.fsyncob jectfiles=0 submodule update --init --recursive failed with exit code 1, output:
Submodule 'common' (
https://anongit.freedesktop.org/git/gstreamer/common.git)) registered for path 'common'
Cloning into '/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/git/common'...
fatal: unable to access '
https://anongit.freedesktop.org/git/gstreamer/common.git/': server certificate verification fa iled. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
fatal: clone of '
https://anongit.freedesktop.org/git/gstreamer/common.git' into submodule path '/home/adv/adv-release-b sp/build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/git/common' failed
Failed to clone 'common'. Retry scheduled
fatal: clone of '
Failed to clone 'common' a second time, aborting
ERROR: gstreamer1.0-1.14.4.imx-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14. 4.imx-r0/temp/log.do_unpack.42631
ERROR: Task (/home/adv/adv-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer 1.0_1.14.imx.bb:do_unpack) failed with exit code '1'
ERROR: gstreamer1.0-plugins-base-1.14.4.imx-r0 do_unpack: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; expo rt PATH="/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/ recipe-sysroot-native/usr/bin/python3-native:/home/adv/adv-release-bsp/sources/poky/scripts:/home/adv/adv-release-bsp/b uild_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/recipe-sysroot-native/usr/bin/aarch6 4-poky-linux:/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx -r0/recipe-sysroot/usr/bin/crossscripts:/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer 1.0-plugins-base/1.14.4.imx-r0/recipe-sysroot-native/usr/sbin:/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8m m-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/recipe-sysroot-native/usr/bin:/home/adv/adv-release-bsp/build_x11/ tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/recipe-sysroot-native/sbin:/home/adv/adv-rele ase-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/recipe-sysroot-native/bin:/ home/adv/adv-release-bsp/sources/poky/bitbake/bin:/home/adv/adv-release-bsp/build_x11/tmp/hosttools"; export HOME="/hom e/adv"; git -c core.fsyncobjectfiles=0 submodule update --init --recursive failed with exit code 1, output:
Cloning into '/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.im x-r0/git/common'...
fatal: clone of '
https://anongit.freedesktop.org/git/gstreamer/common.git' into submodule path '/home/adv/adv-release-b sp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/git/common' failed
fatal: clone of '
ERROR: gstreamer1.0-plugins-base-1.14.4.imx-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0 -plugins-base/1.14.4.imx-r0/temp/log.do_unpack.51633
ERROR: Task (/home/adv/adv-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer 1.0-plugins-base_1.14.imx.bb:do_unpack) failed with exit code '1'
============================================================ export GIT_SSL_NO_VERIFY=1 #or git config --global http.sslverify false ============================================================
  • Build error with git protocal:
ERROR: ExpansionError during parsing /home/adv/adv-release-bsp/sources/meta-advantech/meta-tools/recipes-utils/mdio-tool/mdio-tool_1.0.bb
fatal: remote error: The unauthenticated git protocol on port 9418 is no longer supported. Please see https://github.blog/2021-09-01-improving-git-protocol-security-github/ for more information.
Modify: "/home/adv/adv-release-bsp/sources/meta-advantech/meta-tools/recipes-utils/mdio-tool/mdio-tool_1.0.bb" file to
SRC_URI = " git://github.com/PieVo/mdio-tool.git;protocol= https ;branch=master"
nnshark error
https://community.nxp.com/t5/i-MX-Processors/Yocto-3-3-5-10-72-BSP-Build-Fail/m-p/1487902
