ROM-5721 User Guide
Contents
- 1 產品介紹 (Product introduction)
- 1.1 產品特性 (Product Features)
- 1.2 產品官網連結
- 2 硬件接口說明 (Hardware interface introduction)
- 2.1 接口布局和尺寸 (Layout and Sizes)
- 2.2 ROM-5721 接口布局圖 Board Dimension Layout
- 2.3 主板内置插针式引脚排序方式 (Pin Header defination)
- 2.4 Internal I/O
- 2.5 Rear I/O
- 2.6 接口引脚定義 (Pin definitions)
- 2.7 机械尺寸 (Mechanical Characteristics)
- 3 快速入门 (Quick Start)
- 3.1 系统下载 (OS Download)
- 3.2 Linux 燒錄方法 (Linux Flash eMMC Method)
- 3.3 Debug 串口調試 (Debug port Setting)
- 4 Linux系统的基本使用 (Linux System Basic Operating Method)
- 4.1 UUU 使用方法 (USB Connection (OTG port))
- 4.2 Display Setting (ROM-5721)
- 4.3 乙太網路使用方法 (Ethernent Testing Method)
- 4.4 WiFi使用方法 (WIFI Testing Method)
- 4.5 串口使用方法 (Serial Port Operating Method)
- 4.6 蓝牙使用方法 (BlueTooth Operating Method)
- 4.7 遠程訪問及文件傳輸 (Remote Access and File Transimmion)
- 5 通用方法 (General Method)
- 6 Linux BSP編譯方法 (Linux BSP Compile Method)
- 7 Build known issue
產品介紹(Product introduction)
產品特性(Product Features)
- NXP i.MX 8M Mini processor with up to 4 Arm Cortex A53 cores
- 1 x Arm Cortex-M4 core
- Onboard LPDDR4 memory and eMMC
- 1 x 4 lane MIPI-CSI, 1 x Dual channel LVDS or 1 x Display Port
- 4 x USB2.0, 1 x USB 2.0 OTG, 4 x UART, 4 x I2C, 12 x GPIO, 1 x PCIe2.0, 1x Gigabit LAN
- Support OpenGL ES 2.0/1.1 by hardware accelerators
- Low power consumption design
- Support Linux and Android BSP
產品官網連結
硬件接口說明(Hardware interface introduction)
接口布局和尺寸(Layout and Sizes)
Internal I/O
| Position | Description | Connector Type |
| BAT1 | PIN Header for Battery | WAFER 8P 2.54mm 180D(M) DIP A2543WV2-8P |
| BH1 | RTC Battery Holder | BATTERY HOLDER 24.923.48.9 CR2032 BH800.4GG |
| CAN1 | CANBus Port 1 | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| CAN2 | CANBus Port 2 | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| COM1 | COM Port 1 | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| COM3 | COM Port 3 (Debug Port) | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| CN4 | PCIex1 Connector 1 | PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF |
| CN5 | PCIex1 Connector 2 | PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF |
| CN6 | PCIex1 Connector 3 | PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF |
| CN11 | SATA Connector | Serial ATA 7P 1.27mm 180D(M) DIP WATM-07DBN4A3B8 |
| CN12 | SATA Power Connector | WAFER 4P 2.5mm 180D(M) DIP 24W1161-04S10-01T |
| CN22 | GPIOx8 sets | PIN HEADER 10x2P 2.0mm 180D(M) DIP 21N22050 |
| CN25 | MXM 3.0 Connector | MXM Conn. 314P 90D(F) SMD AS0B821-S78B-7H |
| CN26 | M.2 Key E Slots | NGFF 75P 0.5mm 90D(F) H=4.2mm SMD AS0BC21-S40BE |
| CN38 | FAN (Reserved) | WTB Con. 3P 2.54mm 180D(M) DIP A2543WV0-3P-6T-5e |
| CN39 | MIPI-CSI1 (FPC, 4-Lane) | FPC 39P, 0.6mm, H0.9mm |
| CN40 | MIPI-CSI0 (FPC, 2-Lane) | FPC 39P, 0.6mm, H0.9mm |
| CN41 | MIPI-CSI0 (Mini-SAS, 2-Lane) | Mini SAS 36P/0.8mm/(M)/LCP/VA/G15u/S/BK/W |
| CN42 | MIPI-CSI1 (Mini-SAS, 4-Lane) | Mini SAS 36P/0.8mm/(M)/LCP/VA/G15u/S/BK/W |
| ESPI_CN1 | ESPI | PIN HEADER 6x2P 2.0mm 180D(M) SMD 21N22050-12M00B |
| I2C_GP_1 | I2C Pin Header | WAFER BOX 4P 2.00mm 180D(M) DIP 721-81-04TW00 |
| I2C_CN3 | Audio Codec Board | PIN HEADER 2x10P 2.54mm 180D(M) DIP 21N22564 |
| LVDS0 | LVDS0 | Wafer 2x20P/1.25mm/(M)/NY9T/VA/GFL/S/WH/W |
| LVDS_BK_PWR | LVDS0 Back Light | WAFER BOX 5P 2.0mm 180D(M) DIP A2001WV2-5P |
| LVDS1 | LVDS1 | Wafer 2x20P/1.25mm/(M)/NY9T/VA/GFL/S/WH/W |
| LVDS1_BK_PWR | LVDS1 Back Light | WAFER BOX 5P 2.0mm 180D(M) DIP A2001WV2-5P |
| SD1 | SD Card Slot | SD CARD 9P 90D(F) SMD WK2192CS3D-7H |
| SPI_CN1 | SPI Pin Header | PIN HEADER 4x2P 2.54mm 180D(M) SMD 21N22564 |
| SW2 | Reset Button | TACT SW STS-091 SMD 4P H=3.8mm |
| SW4 | SLP Button | TACT SW STS-091 SMD 4P H=3.8mm |
| SW5 | Power Button | TACT SW STS-091 SMD 4P H=3.8mm |
| USB0_OTG1 | USB OTG | Micro USB 5P/0.65mm/(F)/NY9T/GFL/RA/S/BK/B |
| USB-4-5 | USB Port 4, Port 5 | PIN HEADER 2x5P 2.0mm 180D(M) SMD 21N22050 |
Rear I/O
| Position | Description | Name |
| DCIN | DC Jack | A |
| CN15A | UART Port 0 | B |
| CN15B | UART Port 2 | C |
| CN1A | DP Port | D |
| CN1B | HDMI Port | E |
| CN33 | Type C Controller Programming Header (Reserved Only) | F |
| CN34 | USB Type C | G |
| CN8 | GbE Ethernet Connector Port | H |
| CN3 | USB Port 1/2 | I |
| Audio1 | MIC Input/Audio Output | J |
- 電池(BAT1) & 電池扣(BH1)
- CAN(CAN1,CAN2)
- 串口(COM_DB(COM3)、COM1、UART0、UART2)
- 显示接口(LVDS、LVDS Backlight、HDMI、DP)
- LAN接口(LAN)
- USB接口(USB1-2、USB-4-5、USB Type C、USB OTG)
- 音频接口(Audio Output & Audio Codec)
- GPIO接口
- MINI_PCIE接口、M.2接口、SPI、I2C接口
快速入门 (Quick Start)
系统下载 (OS Download)
- Linux系统 (Linux OS)
Yocto 2.5: IoTGateway/BSP/Linux/iMX8/OS Support List
Yocto 3.0: IoTGateway/BSP/Linux/iMX8/OS Support List 3.0
使用Flash tool 燒錄鏡像到eMMC (Flash image into eMMC by Flash Tools)
Step0: 檢查SD卡在Linux 環境的代號 (check SD card symbol in Linux system)
Step1: 創造一張可開機的SD 卡 (Create a bootable SD card)
Step2: 將可開機的SD 卡插入底板SD卡卡槽 (Plug the SD card into Carrier board's SD card slot)
Step4: 確認開機選擇指撥開關 (Check the boot switch)
SD 卡開機模式 (SD boot mode):
Step3: 打開電源 和 終端機 (Turn on the Power & Terminal)
Step4: 解壓縮flash tools 檔案,並複製到U盤中 (Unzip the flash tools file, then copy to USB Disk)
解壓縮 (Unzip the file)
複製檔案到U盤中 (Copy the flash file to USB Disk)
插入U盤到你的Ubuntu 電腦上 (Plug the USB Disk into your Linux PC)
檢視U盤在Ubuntu 系統代號 (Check the USB Disk's symbol in Ubuntu System)
- 掛載U盤在Ubuntu 系統中 (Mount the USB Disk in Ubuntu System)
- 複製檔案到U盤 (Copy the file to USB disk)
- 將U盤連接到ROM-5721系統, 進入flash tool下的mk_inand資料夾, 執行指令
./mksd-linux.sh /dev/mmcblk2燒錄image到eMMC
| ROM-5721 | |
| SD card | /dev/mmcblk1 |
| eMMC | /dev/mmcblk2 |
- 切換開機switch 1:on 2,3,4,5,6:off 來設定成從eMMC開機 (Change boot switch to "1:on 2,3,4,5,6:off" to boot from eMMC. Reboot system).
以 Tera Term 为例介绍如何使用串口调试功能
Baud Rate波特率:115200
Data 数据位:8
Parity 奇偶校验:无
Stop 停止位:1
Flow Control流控:无
Tera Term Tool
Check the Serial port in Device Manager (查看PC端的串口号):
if you can not identify the Serial device, please check your serial driver.
Debug port connection (串口連接)
Log into Terminal Tool (进入串口调试终端):
Linux系统的基本使用(Linux System Basic Operating Method)
UUU 使用方法(USB Connection (OTG port))
Download uuu tool from (ADV v20200619 · ADVANTECH-Corp/uuu · GitHub) or in the folder.
The "imx-boot-imx8mmrom5721a1-sd.bin-flash_evk" file be included in 5721A1AIM20LIV90XXX_iMX8MM_misc.tgz. XXX is the version.
Connect USB cable to USB OTG port.
Change boot switch to "4:on 1,2,3,5,6:off" to boot from force recovery mode.
Type command below to flash eMMC:
U-boot Command:
setenv fdt_file xxxx.dtb
env save
boot
U-boot load default setting:
env default -a
env save
reset
- Display: Default support g070vw01 LVDS panel on LVDS0
Yocto 2.5
| Display | DTB File |
| DSI to LVDS g070vw01 | adv-imx8mm-rom5721-a1.dtb |
| DSI to LVDS g150xgel05 | adv-imx8mm-rom5721-a1-dsi2lvds-g150xgel05.dtb |
| DSI to LVDS g215hvn01 | adv-imx8mm-rom5721-a1-dsi2lvds-g215hvn01.dtb |
| DSI to DP | adv-imx8mm-rom5721-a1-dsi2dp.dtb |
| DSI to HDMI | adv-imx8mm-rom5721-a1-adv7535.dtb |
| DSI auog101uan02 | adv-imx8mm-rom5721-a1-auog101uan02.dtb |
| M.2 SDIO | adv-imx8mm-rom5721-a1-m2-sdio.dtb |
| M.2 I2S | adv-imx8mm-rom5721-a1-m2-i2s.dtb |
Yocto 3.0
| DSI to LVDS g070vw01 | imx8mm-rom5721-a1.dtb |
| DSI to LVDS g150xgel05 | imx8mm-rom5721-a1-dsi2lvds-g150xgel05.dtb |
| DSI to LVDS g215hvn01 | imx8mm-rom5721-a1-dsi2lvds-g215hvn01.dtb |
| DSI to DP | imx8mm-rom5721-a1-dsi2dp.dtb |
| DSI to HDMI | imx8mm-rom5721-a1-adv7535.dtb |
| DSI auog101uan02 | imx8mm-rom5721-a1-auog101uan02.dtb |
| M.2 SDIO | imx8mm-rom5721-a1-m2-sdio.dtb |
乙太網路使用方法(Ethernent Testing Method)
Command: ifconfig
Command: ping -I eth1 8.8.8.8 or ping -I eth0 8.8.8.8
WiFi使用方法(WIFI Testing Method)
# 安裝WIFI天線到ROM-5721上
ifconfig mlan0 up
iwlist mlan0 scan
# WPA2 連線
wpa_passphrase "SSID" 123456789 > /tmp/wpa.conf
wpa_supplicant -BDwext -imlan0 -c/tmp/wpa.conf
udhcpc -b -i mlan0
ifconfig
ping 8.8.8.8
串口使用方法(Serial Port Operating Method)
RS-232 Test
- CN15上 (SER0/UART3):
/dev/ttymxc2 - CN15 下 (SER2/UART1):
/dev/ttymxc0 - COM 3 (A53 debug/SER3/UART2):
/dev/ttymxc1 - COM 1 (M4 debug/SER1/UART4):
/dev/ttymxc3
SW7 Setting (SW7設置)
MODE1 MODE0
0 0 LOOPBACK
0 1 RS232
1 0 RS485
1 1 RS422
Loopback test (eg. ttymxc0) — Connect loopback test tool:
stty -F /dev/ttymxc0 115200
stty -F /dev/ttymxc0 -echo
cat /dev/ttymxc0 &
echo test > /dev/ttymxc0
GPIO使用方法(GPIO Operating Method)
# Loop-back Test (Take GPIO0 and GPIO2 as examples)
# Step 1: Connect GPIO0 and GPIO2
# Step 2: Export GPIO interface
echo 496 > /sys/class/gpio/export
echo 497 > /sys/class/gpio/export
# Step 3: Set direction
echo out > /sys/class/gpio/gpio1/direction
echo in > /sys/class/gpio/gpio2/direction
# Step 4: Read value and set output value then check
cat /sys/class/gpio/gpio2/value
# 0
echo 1 > /sys/class/gpio/gpio1/value
# 1
蓝牙使用方法(BlueTooth Operating Method)
$ hciconfig hci0 up
$ bluetoothctl
$ discoverable on
$ pairable on
$ scan on
[NEW] FC:18:3C:8D:75:F4 myphone
$ scan off
$ pair FC:18:3C:8D:75:F4
$ connect FC:18:3C:8D:75:F4
遠程訪問及文件傳輸(Remote Access and File Transimmion)
查看主板IP位址 (Check IP Address):
ifconfig
Windows下SSH访问及文件传输
SSH Remote Log into Device
- SSH远程登录,以putty选择putty.exe(或者使用Xshell、SecureCRT等类似软件)
- 需要设置远程设备的IP、通讯端口(默认22)、通讯方式,登录后验证用户名密码
通用方法(General Method)
查看CPU温度(Check CPU Temperature)
cat /sys/devices/virtual/thermal/thermal_zone0/temp
# 44600
# 或者直接以度爲單位顯示
echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]°
# >>> 45°
查看CPU频率(Check CPU Frequency)
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
# >> 900000
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
# >> 1200000
查看内存容量(Check Memory Capacity)
busybox free -m
# total used free shared buffers cached
# Mem: 1794920 516080 1278840 17252 9852 80292
# -/+ buffers/cache: 425936 1368984
# Swap: 0 0 0
查看存储容量(Check Storage Capacity)
busybox df -h
網路Ping測試(Ping Network Testing)
ping 8.8.8.8
# PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
# 64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms
# 64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
設置RTC (RTC Setting)
systemctl stop ntpdate.service
date 090816072021 && hwclock -w && date
# Wed Sep 8 16:07:00 UTC 2021
date
# Wed Sep 8 16:07:06 UTC 2021
Linux BSP編譯方法(Linux BSP Compile Method)
Yocto 4.2
Yocto 4.0
Yocto 3.0
Yocto 2.5
Build known issue
如果有驗證上的錯誤 請使用以下的方法
repo sync failed — Server certificate verification failed
export GIT_SSL_NO_VERIFY=1
# or
git config --global http.sslverify false
Build error with git protocol
ERROR: ExpansionError during parsing .../mdio-tool_1.0.bb
fatal: remote error: The unauthenticated git protocol on port 9418 is no longer supported.
Modify mdio-tool_1.0.bb:
SRC_URI = "git://github.com/PieVo/mdio-tool.git;protocol=https;branch=master"
nnshark error
https://community.nxp.com/t5/i-MX-Processors/Yocto-3-3-5-10-72-BSP-Build-Fail/m-p/1487902
