Erase eMMC
RSB-3720 16G eMMC:
u-boot=> mmc list
FSL_SDHC: 1 (SD) FSL_SDHC: 2
u-boot=> mmc dev 2 0
switch to partitions #0, OK mmc2(part 0) is current device
u-boot=> mmc part
Partition Map for MMC device 2 -- Partition Type: DOS
Part Start Sector Num Sectors UUID Type 1 16384 131072 e1f87b96-01 0c Boot 2 147456 30629888 e1f87b96-02 83 3 4341760 20480 e1f87b96-03 83 4 4362240 24997888 e1f87b96-04 05 Extd bad MBR sector signature 0x0000
u-boot=> mmc read ${loadaddr} 0x7fffffff 1
MMC read: dev # 2, block # 2147483647, count 1 ... MMC: block number 0x80000000 exceeds max(0x1d5a000) 0 blocks read: ERROR
u-boot=> mmc erase 0 0x1d5a000
MMC erase: dev # 2, block # 0, count 30777344 ... 30777344 blocks erased: OK
u-boot=> mmc dev 2 1
switch to partitions #1, OK mmc2(part 1) is current device
MMC read: dev # 2, block # 2147483647, count 1 ... MMC: block number 0x80000000 exceeds max(0x2000) 0 blocks read: ERROR
u-boot=> mmc erase 0 0x2000
MMC erase: dev # 2, block # 0, count 8192 ... 8192 blocks erased: OK
u-boot=> mmc dev 2 2
switch to partitions #2, OK mmc2(part 2) is current device
u-boot=> mmc part
Part Start Sector Num Sectors UUID Type bad MBR sector signature 0x0000 u-boot=>
