設置MX8MP LVDS clock
Calculate PLL_1443X_RATE()
Fout=((m + k/65536) × Fin) / (p × 2^s)
Fin is 24 MHz and Fout is LVDS clock MHz x 7, then calculate m,
FoutmSpkLVDS clockLVDS Resolution
2800000009322040000000800x600
2310000007722033000000
1890000006322027000000
1747500005822024964286
1710000005722024428571
2100000007022030000000
453000000151220647000001024x768
357000000119220510000001024x600
Contents
  • 1Comment out LVDS clock fix at 74.25MHz,
  • 2Add Fout clock into imx8mp.dtsi. Example to set LVDS clock to 30MHz.
  • 3Add PLL_1443X_RATE to driver.
  • 4Add LVDS timing clock into panel-simple.c.
  • 5Rebuild kernel image and dtb file.
  • 6Check the LVDS output clock:
diff --git a/drivers/gpu/drm/imx/imx8mp-ldb.c b/drivers/gpu/drm/imx/imx8mp-ldb.c index be969f453587..f1672f392122 100644 --- a/drivers/gpu/drm/imx/imx8mp-ldb.c +++ b/drivers/gpu/drm/imx/imx8mp-ldb.c @@ -198,11 +198,12 @@ imx8mp_ldb_encoder_atomic_check(struct drm_encoder *encoder, * Due to limited video PLL frequency points on i.MX8mp, * we do mode fixup here in case any mode is unsupported. / + / if (ldb->dual) mode->clock = mode->clock > 100000 ? 148500 : 74250; else mode->clock = 74250; - + */ return 0; } @@ -224,12 +225,13 @@ imx8mp_ldb_encoder_mode_valid(struct drm_encoder *encoder, * Due to limited video PLL frequency points on i.MX8mp, * we do mode valid check here. / + / if (ldb->dual && mode->clock != 74250 && mode->clock != 148500) return MODE_NOCLOCK; if (!ldb->dual && mode->clock != 74250) return MODE_NOCLOCK; - + */ return MODE_OK; }
</li> </ol>
Fout is 30MHzx7=210000000.
diff --git a/arch/arm64/boot/dts/freescale/imx8mp.dtsi b/arch/arm64/boot/dts/freescale/imx8mp.dtsi index 7e71a112c618..408ced2aa378 100644 --- a/arch/arm64/boot/dts/freescale/imx8mp.dtsi +++ b/arch/arm64/boot/dts/freescale/imx8mp.dtsi @@ -823,7 +823,8 @@ clk: clock-controller@30380000 { <800000000>, <393216000>, <361267200>, - <1039500000>; + //<1039500000>; + <210000000>; };
Yocto 3.0 path: imx8mp_videopll_tbl[] at drivers/clk/imx/clk-imx8mp.c
Yocto4.0 path: imx_p111443_tb1[] at drivers/clk/imx/clk-pll14xx.c
diff --git a/drivers/clk/imx/clk-pll14xx.c b/drivers/clk/imx/clk-pll14xx.c
index 1563a7bff422..0882aeb196bb 100644
--- a/drivers/clk/imx/clk-pll14xx.c
+++ b/drivers/clk/imx/clk-pll14xx.c
@@ -62,6 +62,7 @@ static const struct imx_pll14xx_rate_table imx_pll1443x_tbl[] = {
PLL_1443X_RATE(519750000U, 173, 2, 2, 16384),
PLL_1443X_RATE(393216000U, 262, 2, 3, 9437),
PLL_1443X_RATE(361267200U, 361, 3, 3, 17511),
+      PLL_1443X_RATE(210000000U, 70, 2, 2, 0),
struct imx_pll14xx_clk imx_1443x_pll = {
Example modify for g070vvn01.
diff --git a/drivers/gpu/drm/panel/panel-simple.c b/drivers/gpu/drm/panel/panel-simple.c
index 22840352fdcf..ce13868206ee 100644
--- a/drivers/gpu/drm/panel/panel-simple.c
+++ b/drivers/gpu/drm/panel/panel-simple.c
@@ -1363,15 +1363,15 @@ static const struct panel_desc auo_b140han06 = {
static const struct display_timing auo_g070vvn01_timings = {
-       .pixelclock = { 33300000, 34209000, 45000000 },
+      .pixelclock = { 30000000, 30000000, 30000000 },
.hactive = { 800, 800, 800 },
-       .hfront_porch = { 20, 40, 200 },
-       .hback_porch = { 87, 40, 1 },
-       .hsync_len = { 1, 48, 87 },
+      .hfront_porch = { 20, 20, 20 },
+      .hback_porch = { 100, 100, 100 },
+      .hsync_len = { 64, 64, 64 },
.vactive = { 480, 480, 480 },
-       .vfront_porch = { 5, 13, 200 },
-       .vback_porch = { 31, 31, 29 },
-       .vsync_len = { 1, 1, 3 },
+      .vfront_porch = { 3, 3, 3 },
+      .vback_porch = { 2, 2, 2 },
+      .vsync_len = { 4, 4, 4 },
static const struct panel_desc auo_g070vvn01 = {
@@ -1379,8 +1379,8 @@ static const struct panel_desc auo_g070vvn01 = {
.num_timings = 1,
.bpc = 8,
.size = {
-               .width = 152,
-               .height = 91,
+              .width = 261,
+              .height = 163,
.delay = {
.prepare = 200,
Load imx8mp-rom5722-a1-lvds0-auo.dtb file for checking the result.
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
  • Copyright 2019 NXP
  1. include "imx8mp-rom5722-a1.dts"
lvds_panel: lvds_panel {
compatible = "auo,g070vvn01";
backlight = <&lvds_backlight0>;
port {
panel_lvds_in: endpoint {
remote-endpoint = <&lvds_out>;
&ldb {
status = "okay";
lvds-channel@0 {
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
status = "okay";
port@1 {
reg = <1>;
lvds_out: endpoint {
remote-endpoint = <&panel_lvds_in>;
&ldb_phy {
status = "okay";
&lvds_backlight0 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_lvds_vcc_0 &pinctrl_bklt_vcc_0>;
lvds-vcc-enable = <&gpio1 6 GPIO_ACTIVE_LOW>;   /* LCD0_VDD_EN */
lvds-bkl-enable = <&gpio1 0 GPIO_ACTIVE_LOW>;   /* LCD0_BKLT_EN */
status = "okay";
"arch/arm64/boot/dts/freescale/imx8mp-rom5722-a1-lvds0-auo.dts" 48L, 813C
cat /sys/kernel/debug/clk/clk_summary | grep -C 5 video
