ROM-6881_Android14_User_Guide
產品特性(Features)
- Rockchip RK3588 Arm Quad Cortex-A76 2.4GHz and Quad Cortex-A55 1.8 GHz
- Onboard 4/8 GB LPDDR4 memory and 32/64 GB eMMC
- Supports 8K @ 60 fps H.265/VP9 video decoding and 8K @ 30 fps H.265/H.264 video encoding
- Supports HDMI, DP, eDP and LVDS/DSI
- 4 x PCIe 3.0, dual gigabit LAN, 2 x USB 3.0, USB2.0 OTG, SATA 3.0, 2 x CAN, 4 x MIPI-CSI, 3 x UART
- Supports Linux Debian11 and Android
產品官網鏈接(Product official website link)
ROM-6881 - 研华 (advantech.com.cn)
接口佈局和尺寸(Layout and Sizes)
ROM-6881接口佈局图 Board Dimension Layout
SOM-DB2510 A1 Board Dimension Layout
The figures below indicate the main chips on SOM-DB2510 Development Board for SMARC 2.1.
SOM-DB2510 Connectors and Jumper Settings(default state)
Connector Locations
Switch Locations
I/O Connctor Locations
Button Locations
LED Locations
| Label | Function | Label | Function |
| ATX1 | ATX Connector | FAN1 | Smart Fan Connector |
| SMARC_IN1 | Wide Range Input Power Connector (3V~5.25V) | FAN2 | System Fan Connector |
| DCIN1 | DCIN connector | CAN0_1 | CAN Bus Connector |
| DP0_HDMI | DP & HDMI Connector | USB0 | USB OTG Connector |
| USB12 | USB 2.0 port1~2 & USB 3.0 port0 Connector | COM1_3 | COM Port Port1,3 Connector |
| TYPEC_DP1 | Type-C Connector | COM2_4 | COM Port Port2,4 Connector |
| LAN0_LAN1 | LAN0 & LAN1 Connector | CN8 | I2C connector for I2C_PM |
| LOUT1 | Line Out Connector | CN7 | I2C Connector for I2C_GP |
| MIC1 | MIC1 Connector | CN10 | eSPI Pin Header |
| CN1_MXM1 | SMARC Connector | SATAP1 | SATA Power Connector |
| PCIEA-X4 | PCIe x4 Connector | CSI0_B2B | MIPI B2B Connector for 2M Camera |
| SATA1 | SATA Port0 Connector | CSI1_B2B | MIPI B2B Connector for 8M & 13M Camera |
| PCIED-X1 | PCIe x1 Connector | SPI_BIOS1 | Carrier Board BIOS Socket (SOIC) |
| M2 | M.2 Key-E Connector | BAT1 | Coin battery holder |
| MPCIE_C | Mini PCIe Connector | BAT2 | Smart battery Connector |
| SIM | SIM card Connector | LINEOUT_1 | I2S Headphone Connector |
| LVDS1 | LVDS1 Connector | MIC_1 | I2S MIC In Connector |
| LVDS0 | LVDS0 Connector | CSI1_FPC | MIPI FPC Connector for 8M & 13M Camera |
| LVDS1_INVERTER | LVDS1 Invertor Connector | CSI0_FPC | MIPI FPC Connector for 2M Camera |
| LVDS0_INVERTER | LVDS0 Invertor Connector | CN5 | I2S2 Connector |
| SPI_BIOS2 | Carrier Board BIOS Socket (QFN) | CN17 | I2S0 Connector |
| SD | SD Card Connector |
Jumper Locations
| Lable | Function | Lable | Function |
| BTN3 | Sleep Button | J14 | EDP1/LVDS1 Hot-Plug Detect Selection Header |
| BTN1 | Power Button | J56 | Standby Voltage Control Header |
| BTN2 | Reset Button | J44 | Module +3.3V/+5V Power Selection Header |
| SW4 | BOOT SELECT Switch | PSON1 | AT/ATX Selection Header |
| LID1 | LID Switch | SPI_CN1 | SPI Header |
| J30 | Enable Battery Low# Header | CN14 | For CAN Bus port0 Terminal Resistor |
| M2E_DISABLE_N1 | M.2 Wireless Disable | CN15 | For CAN Bus port1 Terminal Resistor |
| J29 | SMB Alert Enable Header | J3/J4 | DP0 EQ0 Selection |
| CN9 | Header For GPIO Test | J5/J6 | DP0 EQ1 Selection |
| J7/J8 | LVDS0 Power Selection Header | J58 | PCIE_B_CKREQ# Selection |
| J11/J12 | LVDS1 Power Selection Header | J59 | PCIE_A_CKREQ# Selection |
| J9 | LVDS0 Inverter Power Selection Heade | GPIO_0 | GPIO0/CAM0_PWR# Selection |
| J10 | EDP0/LVDS0 Hot-Plug Detect Selection Header | GPIO_1 | GPIO1/CAM1_PWR# Selection |
| J26 | HDA/I2S Selection Header | GPIO_2 | GPIO2/CAM0_RST# Selection |
| J1 | DP1/HDMI1 Select | GPIO_3 | GPIO3/CAM1_RST# Selection |
| J13 | LVDS1 Inverter Power Selection Header | GPIO_4 | GPIO4/HDA_RST# Selection |
| J31 | Clear CMOS Header | GPIO_5 | GPIO5/PWM_OUT Selection |
| J25 | SPI Power Header | GPIO_6 | GPIO6/TACHIN Selection |
| SW1 | COM1 mode Select | SATA_ACT_PH1 | SATA act# Header |
| SW2 | COM3 mode Select | PWRBTN_PH1 | Power button Header |
| J41 | Core Power Voltage Control Header | SYS_RESET_PH1 | Reset button Header |
| J2 | DDI1 AUX/DDC Selection |
LED Function List
| Location | Function |
| MODULE_VIN_LED1 | WDT_TIME_OUT# Indicate |
| MODULE_5V_LED | Module 5V Indicate |
| MODULE_VIN_LED | Module +V_MOD_IN Indicate |
| RESET_OUT_LED | RESET_OUT Indicate |
| RESET_OUT_LED | CARRIER_STBY Indicate |
| CARRIER_PWR_ON_LED | CARRIER_PWR_ON Indicate |
| MODULE_3P3V_LED | Module 3.3V Indicate |
| 3P3V_LED | Carrier Board +V3.3 Indicate |
| 5V_LED | Carrier Board +V5 Indicate |
| 5V_DUAL_LED | Carrier Board +V5SB Indicate |
| 3P3V_DUAL_LED | Carrier Board +V3.3SB Indicate |
| 5VA_LED | Carrier Board +V5D_MOD Indicate |
| SATA_LED | SATA Indicate |
| SOM_LED | SOM BOM Indicate |
| RISC_LED | RISC BOM Indicate |
Switch Settings
ROM-6881 Switch Settings
- [SW1](./ROM-6881_Android13_User_Guide_wiki_data/ROM-6881_SW1 "ROM-6881 SW1".md)(AT & ATX Mode Switch)
SOM-DB2510 Switch Settings
- [SW4](./ROM-6881_Android13_User_Guide_wiki_data/SW4 "SW4".md) (Boot Select/Force Recovery/Test Switches)
- [LID1](./ROM-6881_Android13_User_Guide_wiki_data/LID1 "LID1".md) (LID Button Enable/Disable Switches)
- [SW5](./ROM-6881_Android13_User_Guide_wiki_data/SW5 "SW5".md) (LAN CONN LED Pull High Switches)
- [SW1](./ROM-6881_Android13_User_Guide_wiki_data/COM0_Settings "COM0 Settings".md)(COM0 Settings)
- [SW2](./ROM-6881_Android13_User_Guide_wiki_data/SW2 "SW2".md)(COM2 Settings)
- [SW3](./ROM-6881_Android13_User_Guide_wiki_data/I2S_Clock_Settings "I2S Clock Settings".md)(I2S Clock Settings)
- [M2E_DISABLE_N1](./ROM-6881_Android13_User_Guide_wiki_data/M2E_DISABLE_N1 "M2E DISABLE N1".md)(M.2 Wireless Disable Switch)
接口引脚定義 (Connector Pin definitions)
ROM-6881 Pin Connector
- [CN1 MIPI-CSI2 Connector](./ROM-6881_Android13_User_Guide_wiki_data/ROM-6881_CN1_MIPI-CSI2_Connector "ROM-6881 CN1 MIPI-CSI2 Connector".md)
- [CN2 MIPI-CSI3 Connector](./ROM-6881_Android13_User_Guide_wiki_data/ROM-6881_CN2_MIPI-CSI3_Connector "ROM-6881 CN2 MIPI-CSI3 Connector".md)
SOM-DB2510 Pin Connector
- [ATX1 Pin Connector](./ROM-6881_Android13_User_Guide_wiki_data/ATX1_Pin_Connector "ATX1 Pin Connector".md)
- [SMARC_IN1 Pin Connectors](./ROM-6881_Android13_User_Guide_wiki_data/SMARC_IN1_Pin_Connectors "SMARC IN1 Pin Connectors".md)
- [BAT1 RTC Battery Connectors](./ROM-6881_Android13_User_Guide_wiki_data/BAT1_RTC_Battery_Connectors "BAT1 RTC Battery Connectors".md)
- [DCIN1 DC-IN Power Connectors](./ROM-6881_Android13_User_Guide_wiki_data/DCIN1_DC-IN_Power_Connectors "DCIN1 DC-IN Power Connectors".md)
- [CAN0_1 CAN Bus Connectors](./ROM-6881_Android13_User_Guide_wiki_data/CAN0_1_CAN_Bus_Connectors "CAN0 1 CAN Bus Connectors".md)
- [CN9 GPIO Headers](./ROM-6881_Android13_User_Guide_wiki_data/CN9_GPIO_Headers "CN9 GPIO Headers".md)
- [COM2_4 COM Port2&4 Connectors](./ROM-6881_Android13_User_Guide_wiki_data/COM2_4_COM_Port2&4_Connectors "COM2 4 COM Port2&4 Connectors".md)
- [COM1_3 COM Port1& 3 Connectors](./ROM-6881_Android13_User_Guide_wiki_data/COM1_3_COM_Port1&_3_Connectors "COM1 3 COM Port1& 3 Connectors".md)
- [CN10 ESPI Headers](./ROM-6881_Android13_User_Guide_wiki_data/CN10_ESPI_Headers "CN10 ESPI Headers".md)
- [LVDS0 LVDS Connectors](./ROM-6881_Android13_User_Guide_wiki_data/LVDS0_LVDS_Connectors "LVDS0 LVDS Connectors".md)
- [LVDS0_INVERTER LVDS INVERTER Connectors](./ROM-6881_Android13_User_Guide_wiki_data/LVDS0_INVERTER_LVDS_INVERTER_Connectors "LVDS0 INVERTER LVDS INVERTER Connectors".md)
- [LVDS1 LVDS Connectors](./ROM-6881_Android13_User_Guide_wiki_data/LVDS1_LVDS_Connectors "LVDS1 LVDS Connectors".md)
- [LVDS1_INVERTER LVDS INVERTER Connectors](./ROM-6881_Android13_User_Guide_wiki_data/LVDS1_INVERTER_LVDS_INVERTER_Connectors "LVDS1 INVERTER LVDS INVERTER Connectors".md)
- [CN7 I2C_GP Connectors](./ROM-6881_Android13_User_Guide_wiki_data/CN7_I2C_GP_Connectors "CN7 I2C GP Connectors".md)
- [SPI_CN1 SPI Connectors](./ROM-6881_Android13_User_Guide_wiki_data/SPI_CN1_SPI_Connectors "SPI CN1 SPI Connectors".md)
- [SATAP1 SATA PWR Connectors](./ROM-6881_Android13_User_Guide_wiki_data/SATAP1_SATA_PWR_Connectors "SATAP1 SATA PWR Connectors".md)
- [CSI0_FPC Connectors](./ROM-6881_Android13_User_Guide_wiki_data/CSI0_FPC_Connectors "CSI0 FPC Connectors".md)
- [CSI1_FPC Connectors](./ROM-6881_Android13_User_Guide_wiki_data/CSI1_FPC_Connectors "CSI1 FPC Connectors".md)
- [CN5 I2S2 Connectors](./ROM-6881_Android13_User_Guide_wiki_data/CN5_I2S2_Connectors "CN5 I2S2 Connectors".md)
- [CN17 I2S0 Connectors](./ROM-6881_Android13_User_Guide_wiki_data/CN17_I2S0_Connectors "CN17 I2S0 Connectors".md)
- [PWRBTN_PH1 PWRBTN Pin Headers](./ROM-6881_Android13_User_Guide_wiki_data/PWRBTN_PH1_PWRBTN_Pin_Headers "PWRBTN PH1 PWRBTN Pin Headers".md)
- [SYS_RESET_PH1 SYS RESET Pin Headers](./ROM-6881_Android13_User_Guide_wiki_data/SYS_RESET_PH1_SYS_RESET_Pin_Headers "SYS RESET PH1 SYS RESET Pin Headers".md)
- [SATA_ACT_PH1 SATA ACT# Pin Headers](./ROM-6881_Android13_User_Guide_wiki_data/SATA_ACT_PH1_SATA_ACT "SATA ACT PH1 SATA ACT".md)
- [J32 Power LED Pin Headers](./ROM-6881_Android13_User_Guide_wiki_data/J32_Power_LED_Pin_Headers "J32 Power LED Pin Headers".md)
- [J30 BATLOW Pin Headers](./ROM-6881_Android13_User_Guide_wiki_data/J30_BATLOW_Pin_Headers "J30 BATLOW Pin Headers".md)
- [J29 SMBUS Alert Pin Headers](./ROM-6881_Android13_User_Guide_wiki_data/J29_SMBUS_Alert_Pin_Headers "J29 SMBUS Alert Pin Headers".md)
- [J41 Core Power Controls](./ROM-6881_Android13_User_Guide_wiki_data/J41_Core_Power_Controls "J41 Core Power Controls".md)
- [PSON1 ATX/AT Mode Selection](./ROM-6881_Android13_User_Guide_wiki_data/PSON1_ATX/AT_Mode_Selection "PSON1 ATX/AT Mode Selection".md)
- [J56 Standby Power Controls](./ROM-6881_Android13_User_Guide_wiki_data/J56_Standby_Power_Controls "J56 Standby Power Controls".md)
- [J44 Module Power Settings](./ROM-6881_Android13_User_Guide_wiki_data/J44_Module_Power_Settings "J44 Module Power Settings".md)
- [J7,J8 LVDS0 Power Selection](./ROM-6881_Android13_User_Guide_wiki_data/J7,J8_LVDS0_Power_Selection "J7,J8 LVDS0 Power Selection".md)
- [J9 LVDS0 Inverter Power Selection](./ROM-6881_Android13_User_Guide_wiki_data/J9_LVDS0_Inverter_Power_Selection "J9 LVDS0 Inverter Power Selection".md)
- [J11,J12 LVDS1 Power Selection](./ROM-6881_Android13_User_Guide_wiki_data/J11,J12_LVDS1_Power_Selection "J11,J12 LVDS1 Power Selection".md)
- [LVDS1 Inverter Power Selection](./ROM-6881_Android13_User_Guide_wiki_data/LVDS1_Inverter_Power_Selection "LVDS1 Inverter Power Selection".md)
- [EDP0 /LVDS0 HPD Selection](./ROM-6881_Android13_User_Guide_wiki_data/EDP0_/LVDS0_HPD_Selection "EDP0 /LVDS0 HPD Selection".md)
- [J14 EDP1/LVDS1 HPD Selection](./ROM-6881_Android13_User_Guide_wiki_data/J14_EDP1/LVDS1_HPD_Selection "J14 EDP1/LVDS1 HPD Selection".md)
- [CN14 CAN0 Terminal Resistor Selection](./ROM-6881_Android13_User_Guide_wiki_data/CN14_CAN0_Terminal_Resistor_Selection "CN14 CAN0 Terminal Resistor Selection".md)
- [CN15 CAN1 Terminal Resistor Selection](./ROM-6881_Android13_User_Guide_wiki_data/CN15_CAN1_Terminal_Resistor_Selection "CN15 CAN1 Terminal Resistor Selection".md)
- [J2 DDI1 AUX/DDC Selection](./ROM-6881_Android13_User_Guide_wiki_data/J2_DDI1_AUX/DDC_Selection "J2 DDI1 AUX/DDC Selection".md)
- [J1 DP1/HDMI1 Selection](./ROM-6881_Android13_User_Guide_wiki_data/J1_DP1/HDMI1_Selection "J1 DP1/HDMI1 Selection".md)
- [J58 PCIE_B_CKREQ# Selection](./ROM-6881_Android13_User_Guide_wiki_data/J58_PCIE_B_CKREQ "J58 PCIE B CKREQ".md)
- [J59 PCIE_A_CKREQ# Selection](./ROM-6881_Android13_User_Guide_wiki_data/J59_PCIE_A_CKREQ "J59 PCIE A CKREQ".md)
- [J31 Clear CMOS](./ROM-6881_Android13_User_Guide_wiki_data/J31_Clear_CMOS "J31 Clear CMOS".md)
- [J25 +V1.8M_SPI Power Jumpers](./ROM-6881_Android13_User_Guide_wiki_data/J25_+V1.8M_SPI_Power_Jumpers "J25 +V1.8M SPI Power Jumpers".md)
- [GPIO_0 GPIO0 Settings](./ROM-6881_Android13_User_Guide_wiki_data/GPIO_0_GPIO0_Settings "GPIO 0 GPIO0 Settings".md)
- [GPIO_1 GPIO1 Settings](./ROM-6881_Android13_User_Guide_wiki_data/GPIO_1_GPIO1_Settings "GPIO 1 GPIO1 Settings".md)
- [GPIO_2 GPIO2 Settings](./ROM-6881_Android13_User_Guide_wiki_data/GPIO_2_GPIO2_Settings "GPIO 2 GPIO2 Settings".md)
- [GPIO_3 GPIO3 Settings](./ROM-6881_Android13_User_Guide_wiki_data/GPIO_3_GPIO3_Settings "GPIO 3 GPIO3 Settings".md)
- [GPIO_4 GPIO4 Settings](./ROM-6881_Android13_User_Guide_wiki_data/GPIO_4_GPIO4_Settings "GPIO 4 GPIO4 Settings".md)
- [GPIO_5 GPIO5 Settings](./ROM-6881_Android13_User_Guide_wiki_data/GPIO_5_GPIO5_Settings "GPIO 5 GPIO5 Settings".md)
- [GPIO_6 GPIO6 Settings](./ROM-6881_Android13_User_Guide_wiki_data/GPIO_6_GPIO6_Settings "GPIO 6 GPIO6 Settings".md)
- [J26 HDA/I2S Selection](./ROM-6881_Android13_User_Guide_wiki_data/J26_HDA/I2S_Selection "J26 HDA/I2S Selection".md)
ROM-6881 機械尺寸(Mechanical Characteristics)
- Dimension: SMARC form factor size: (D x W) 82 x 80 mm / 3.22 x 3.15 inch
- Height on Top: 2.4 mm
- Height on Bottom: 1.45 mm
**SOM-DB2510_A1 机械尺寸 (**Mechanical Characteristics)
For more details regarding our 2D/3D models, please visit the Advantech COM support service website at: <http://com.advantech.com.
Board Mechanical Diagram -Front
Board Mechanical Diagram -Side1
Board Mechanical Diagram -Side2
Assemblly Diagram
These figures demonstrate the order of assembly needed when attaching the thermal module and COM module to the carrier board.
快速入门 (Quick Start)
系统下载 (OS Download)
Note: LIV= Yocto Linux , UIV=Ubuntu , DIV = Debian , AIV = Android, LBV=BSP , LIV= Image
| Platform | Product | Image Version | Release Date | Release Version | Release note | Image Download | BSP Download Tag | Test Report | Comment |
| RK3588 | ROM-6881 | V13010 | 2024/05/20 | Beta | Release_notes | Baidu Password:a887 Dropbox | RK3588_T13_AIV13010.xml | Test Report |
- Alpha: Basic I/O function bring up by RD;
- Beta: Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
- GA: Beta version by QE verification;
- RTM: Beta version by SI/Power/QE verification and pre-loaded;
系统燒錄方法 ( System burning mode )
1. [Usering_RKTool.](./ROM-6881_Android13_User_Guide_wiki_data/ROM-6881_Usering_RKTool. "ROM-6881 Usering RKTool.".md)
2. [Usering bootup_sd_disk made_by SDDiskTool.](./ROM-6881_Android13_User_Guide_wiki_data/ROM-6881_Usering_bootup_sd_disk_made_by_SDDiskTool. "ROM-6881 Usering bootup sd disk made by SDDiskTool.".md)
Linux基本使用方法
- How to debug
- How to Config Multi-Display
- How to use GPIO
- RTC
Linux BSP编译方法(Linux BSP Compile Method)
- [Linux BSP User Guide for ROM-6881 series Android](./ROM-6881_Android13_User_Guide_wiki_data/Linux_BSP_User_Guide_for_ROM-6881_series_Android "Linux BSP User Guide for ROM-6881 series Android".md)
