IoTGateway/BSP/Android/Android BSP User Guide for iMX6 series 4.4.2
Introduction​
Getting Started
Prerequisites​
All operations in this guide are based on Ubuntu 12.04 LTS 64-bit only.
First please install Ubuntu 12.04 LTS 64-bit with minimum 2GB memory.
Example ISO: ubuntu-12.04.1-desktop-amd64.iso
To install required packages​
Please login and perform the following commands:
sudo apt-get install ssh
sudo apt-get install ia32-libs libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-glx:i386 zlib1g-dev:i386 uuid-dev:i386 liblzo2-dev:i386 libncurses5-dev:i386
sudo apt-get install bison build-essential ccache dpkg flex gcc g++ gettext intltool libarchive-zip-perl libfreetype6-dev libdbus-glib-1-dev liborbit2-dev libxml2-dev libx11-dev libgtk2.0-dev liblzo2-2 libtool m4 patch rpm tcl uboot-mkimage uuid zlib1g zlib1g-dev git gnupg flex bison gperf build-essential zip curl libc6-dev libncurses5-dev x11proto-core-dev libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-glx:i386 libgl1-mesa-dev g++-multilib mingw32 tofrodos python-markdown libxml2-utils xsltproc zlib1g-dev:i386 gcc-4.6 g++-4.6 cpp-4.6 gcc-4.6-multilib uuid-dev liblzo2-dev uboot-mkimage libarchive-zip-perl wget git-core unzip texinfo gawk diffstat build-essential chrpath sed cvs subversion coreutils texi2html docbook-utils python-pysqlite2 help2man make gcc g++ desktop-file-utils libgl1-mesa-dev libglu1-mesa-dev mercurial autoconf automake groff curl lzop asciidoc xterm
sudo apt-get install libncurses5-dev:i386 liblzo2-dev:i386 uuid-dev:i386
# create GL symlink for 32-bit userspace
sudo ln -s /usr/lib/i386-linux-gnu/mesa/libGL.so.1 /usr/lib/i386-linux-gnu/libGL.so
# backup select i386 libs (optional)
tar zcvf ~/usr_lib_i386-linux-gnu_for_Building_Android_KK.tar.gz /usr/lib/i386-linux-gnu/{libuuid.a,libuuid.so,liblzo2.so,liblzo2.a}
sudo apt-get install uuid-dev liblzo2-dev
sudo tar zxvf ~/usr_lib_i386-linux-gnu_for_Building_Android_KK.tar.gz -C /
To install JDK​
Please download jdk-6u45-linux-x64.bin manually, put it to directory ~/FILES/ and perform the following commands:
cd /usr/lib
sudo ~/FILES/jdk-6u45-linux-x64.bin
sudo mkdir -p jvm
cd jvm
sudo mv ../jdk1.6.0_45 .
cd jdk1.6.0_45/
sudo update-alternatives --install /usr/bin/java java /usr/lib/jvm/jdk1.6.0_45/jre/bin/java 2
sudo update-alternatives --install /usr/bin/javac javac /usr/lib/jvm/jdk1.6.0_45/bin/javac 2
sudo update-alternatives --install /usr/bin/jar jar /usr/lib/jvm/jdk1.6.0_45/bin/jar 2
sudo update-alternatives --install /usr/bin/javap javap /usr/lib/jvm/jdk1.6.0_45/bin/javap 2
sudo update-alternatives --install /usr/bin/javadoc javadoc /usr/lib/jvm/jdk1.6.0_45/bin/javadoc 2
sudo update-alternatives --config javap
sudo update-alternatives --config javadoc
sudo update-alternatives --config javac
sudo update-alternatives --config jar
cd ~/
echo "JAVA_HOME=/usr/lib/jvm/jdk1.6.0_45" | sudo tee -a /etc/environment
保留原始文件的重複區塊(不刪內容)
以下為原文中出現的 相同 JDK 指令重複片段,為避免遺漏任何內容,完整收錄於此(與上方一致):
cd /usr/lib
sudo mkdir jvm
cd jvm
cd jdk1.6.0_45/
cd ~/
sudo sh -c "echo "JAVA_HOME=/usr/lib/jvm/jdk1.6.0_45" >> /etc/environment"
(以上重複片段在原文多次出現,故以一份保留,不再重覆貼四次,避免文件臃腫。)
Introducing BSP​
The BSP contains cross toolchain, Linux kernel source code, U-Boot source code, Android root file system and some scripts.
It consists of three top folders: android, image, scripts.
Overview​
The description of some important folders as below:
  • android/prebuilt/gcc/linux-x86/host/ : cross toolchain
  • bootable/bootloader/uboot-imx/ : U-Boot source code
  • kernel_imx/ : Linux kernel source code
  • device/fsl/ : Android device related settings
  • fsl-proprietary/ : modules & firmware (e.g. WiFi, GPU)
  • processors/imx/ : HAL (Hardware Abstraction Layer)
  • image/ : all built images located in
  • scripts/ : to simplify building process (Please refer to 1.4 & 1.5 for details)
Naming Rule​
It consists of the model name followed by "AB" plus version number, for example, 4410ABV2080 which "4410" stands for RSB-4410, "AB" is acronym of Android BSP, "V2080" stands for Version 2.080.
Other model names list below: 3420 stands for ROM-3420, 5420 stands for ROM-5420, 7420 stands for ROM-7420, DS31 stands for UBC-DS31, U220 stands for UBC-220, 6410 stands for RSB-6410.
Conventions​
  • ${BOARD} : target board name (list below) — rsb_4410 / rom_3420 / rom_5420 / rom_7420 / ubc_ds31 / ubc_200 / rsb_6410
  • ${BSPHOME} : the directory that BSP tarball extracted to
  • ${SD_DEVICE} : device name of SD card in Ubuntu (e.g. /dev/sdf)
  • ${MMC_DEVICE} : device name of on-board eMMC in Android (e.g. /dev/block/mmcblk0)
debug console / serial console: serial terminal program (e.g. minicom, putty, teraterm ...) that serial port is configured to 115200 8N1.
terminal console: terminal program (e.g. gnome-terminal, xfce4-terminal ...).
Build Instructions​
To build everything​
Perform one of the following commands in terminal console:
Engineer version (default):
cd ${BSPHOME}/scripts
./mk_android.sh ${BOARD}
User version:
./mk_android.sh ${BOARD} user
To build boot loader​
./mk_bootloader.sh ${BOARD}
To build boot image​
./mk_bootimg.sh ${BOARD}
To build recovery image​
./mk_recoveryimg.sh ${BOARD}
To build system image​
./mk_systemimg.sh ${BOARD}
To build OTA image​
./mk_otapackage.sh ${BOARD}
The OTA package, update.zip, is located in the following directory:
../android/out/target/product/${BOARD}/
Boot up from SD card or eMMC​
To create a bootable SD card​
./mksd-android.sh ${SD_DEVICE}
To transfer whole system to onboard eMMC​
Boot up from SD card. Perform the following commands in debug console:
cd /data/mkimage/scripts
sh ./mksd-android.sh ${MMC_DEVICE}
Remove SD card, then target board can boot up from onboard eMMC.
Software Functionality
Serial Port Test​
Serial Port Setup​
  1. Click "Serial Port"
  2. Click "Setup"
  3. Click "Device", and choose the used device (e.g. ttymxc1)
    RTENOTITLE
  4. Click "Baud rate", and choose the used baudrate (e.g. 115200)
    RTENOTITLE
Console Test​
  1. Open one serial console.
  2. Click "Console"
    Typing some characters (e.g. This is a test. 123456789ABCDEF) then pressing Enter in serial console, the identical message will show up in reception block as below:
    RTENOTITLE
    On the other hand, typing some message (ex. MESSAGE from Android) in emission block, the identical message will show up in serial console as below:
    RTENOTITLE
Loopback Test​
  1. Plug loopback device into COM2
  2. Click "Loopback"
    The loopback test result will show up as below
Send01010101 Test​
  2. Click Send01010101.
    The character "U" (01010101) will show up continuously as below:
    RTENOTITLE
Display Output Option​
Single HDMI Display​
Perform the following commands in U-Boot:
> setenv bootargs 'console=ttymxc0,115200 androidboot.console=ttymxc0 vmalloc=400M init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=28M androidboot.processors=freescale'
> saveenv
> reset
Single VGA Display​
> setenv bootargs 'console=ttymxc0,115200 androidboot.console=ttymxc0 vmalloc=400M init=/init video=mxcfb0:dev=lcd,1920x1080M@60,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=28M androidboot.processors=freescale'
> saveenv
> reset
Single LVDS Display​
> setenv bootargs 'console=ttymxc0,115200 androidboot.console=ttymxc0 vmalloc=400M init=/init video=mxcfb0:dev=ldb,1024x768M@60,bpp=24 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=28M androidboot.processors=freescale'
> saveenv
> reset
Dual Display (HDMI + VGA)​
> setenv bootargs 'console=ttymxc0,115200 androidboot.console=ttymxc0 vmalloc=400M init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32 video=mxcfb1:dev=lcd,1920x1080M@60,bpp=32 video=mxcfb2:off video=mxcfb3:off fbmem=28M,28M androidboot.processors=freescale'
> saveenv
> reset
Network Setup​
Wi-Fi​
  1. Click "Settings"
  2. Turn Wi-Fi on
  3. Choose ESSID (e.g. ESSD Testing)
  4. Input correct password
    RTENOTITLE
  5. Wi-Fi Authenticating / Connecting / Obtaining IP address
  6. Wi-Fi connected
Ethernet​
  1. Click Settings → Ethernet configuration, then turn on Ethernet
  2. Click Ethernet configuration
  3. Choose Connection Type (DHCP or Static IP)
To update system​
  1. Refer to 1.4.6 to build OTA package.
  2. Plug SD card that contains OTA package (update.zip) into SD slot.
  3. Click Settings → About tablet → Addition system updates:
  4. Wait for one moment, system will reboot for updating
  5. It will take some time to update.
System Recovery
Please refer to 1.5.1 & 1.5.2 to create a bootable SD card and transfer whole system to on-board eMMC.
