IoTGateway/BSP/Android/Android BSP User Guide 6.0.1 2.1.0
Introduction​
Android BSP Version​
Android 6.0.1_2.1.0
Introduction​
This document describes how to work with the RISC and ELAA Android 6.0.1 Board Support Package (BSP) release. The BSP includes bootloaders; the Android Linux kernel and root file system; and tools and documentation to ease development, deployment, and execution of Android-based systems.
Setup Ubuntu Host Computer​
Required equipment and software​
  • Ubuntu 14.04 LTS 64bit for Android build host OS
  • 80G bytes free disk spaces for build image
Install Ubuntu​
  • IMPORTANT! You must be able to log in as root or use sudo to have root permissions during the installation.
Go to http://releases.ubuntu.com/14.04/ and download 64-bit PC (AMD64) desktop image: http://releases.ubuntu.com/14.04/ubuntu-14.04.3-desktop-amd64.iso for the installation.
Install docker and Use docker​
Please use docker environment to compiler Android 6.0.1_2.1.0
Android 6.0.1_2.1.0 Docker
Image Repository : advrisc/u14.04-imx6abv4
Image Tag : 20160825
Reference: http://ess-wiki.advantech.com.tw/view/IoTGateway/Docker
To pull ubuntu 12.04 image from Docker Hub​
$ docker run --name imx6ABV6011 -it advrisc/u14.04-imx6abv4:20160825 /bin/bash
or
$ docker run -it --name android_6 -v /home/bsp/myandroid:/home/adv/BSP:rw advrisc/u14.04-imx6abv4:20160825 /bin/bash
## Getting Android Source Code
### Related version information:
- Android 6.0.1_2.1.0
- kernel Yocto-2.0
- U-Boot Yocto-2.0
*`*Step1 : To pull down the Android source tree to your working directory from the repositories as specified in the default manifest*`*
```$ git config --global user.name "Your Name"
$ git config --global user.email you@example.com
``````$ git config --global user.name "Your Name"
```$ mkdir myandroid
$ mkdir bin
$ cd myandroid/
$ curl https://storage.googleapis.com/git-repo-downloads/repo > ../bin/repo
$ chmod a+x ../bin/repo
$ ../bin/repo init -u https://github.com/ADVANTECH-Corp/android-manifest.git -b m6.0.1_2.1.0-ga -m release_version.xml
$ ../bin/repo sync=== The release_version.xml --> example: imx6ABV6011.xml please refer : https://github.com/ADVANTECH-Corp/android-manifest/tree/m6.0.1_2.1.0-ga ====
*Step2 : Patch to Android M6.0.1_2.1.0*
$ patch -p1 <../../../patches_android_6.0.1/6001-Uboot_Yocto_4.1.15_1.2.0-to-Android_M6.0.1_2.1.0.patch
$ cd myandroid/kernel_imx/
$ patch -p1 <../patches_android_6.0.1/6001-Linux_Yocto_4.1.15_1.2.0-to-Android_M6.0.1_2.1.0.patch
$ cd myandroid
$ mkdir bin
$ cd myandroid/
$ cd myandroid
*`*Step2 : Patch to Android M6.0.1_2.1.0*`*
```$ cd myandroid/bootable/bootloader/uboot-imx/
$ cd myandroid
$ cd myandroid
$ mkdir bin
$ cd myandroid/
$ cd myandroid
$ mkdir bin
$ cd myandroid/
$ cd myandroid
$ cd myandroid
``````$ cd myandroid/bootable/bootloader/uboot-imx/
$ cd myandroid
$ cd myandroid
$ cd myandroid
$ cd myandroid
$ cd myandroid
$ cd myandroid
## Building Android 6.0.1_2.1.0 image for SD card
If your product is ROM-3420A1, the product name is rom_3420_a1
$PRODUCT = rom_3420_a1
If your product is ROM-7421A1, the product name is rom_7421_a1
$PRODUCT = rom_7421_a1
If your product is RSB-4411A1, the product name is rsb_4411_a1
$PRODUCT = rsb_4411_a1
If your product is RSB-4410A1, the product name is rsb_4410_a1
$PRODUCT = rsb_4410_a1
If your product is RSB-6410A2, the product name is rsb_6410_a2
$PRODUCT = rsb_6410_a2
If your product is ROM-5420 B1, the product name is rom_5420_b1
$PRODUCT = rom_5420_b1
If your product is UBC-220 A1, the product name is ubc_220_a1
$PRODUCT = ubc_220_a1
### Build Instructions
Set the $JAVA_HOME environment variable
```$ export JAVA_HOME=/usr/lib/jvm/java-7-openjdk-amd64/
Set up the environment for building. This only configures the current terminal.
Execute the Android lunch command. In this example, the setup is for the production image of Advantech RISC platfrom device with user type.  If you devices is RSB4411,  you will be send command " lunch rsb_4411_a1-user
*To build boot loader*
Perform the following command in terminal console
The two files, u-boot_crc.bin & u-boot_crc.bin.crc, will be located in directory, ./out/target/product/product_name
*To build boot image*
*To build system image*
simg2img is a tool that converts a sparse system image to a raw system image on a Linux host PC and is located in myandroid/out/host/linux-x86/bin/simg2img.   (Before the imx6ABV6004 version need to do )
$ mv out/target/product/$PRODUCT/system_raw.img out/target/product/$PRODUCT/system.img
Porting your device  reference: http://ess-wiki.advantech.com.tw/view/IoTGateway/BSP/Android/How_to_do_about_first_porting
# The script below can be used to partition a SD card  reference: https://github.com/ADVANTECH-Corp/android_mk_sd_emmc_script   (imx6ABV6004 version)
# The script below can be used to partition a SD card  reference: https://github.com/ADVANTECH-Corp/android_mksd_script.git   (imx6ABV6005 version and affter the version)
Flash SD card​
Flash EMMC​
*To EMMC*
When system boot up, please send command.
HDMI Display​
``````$ export JAVA_HOME=/usr/lib/jvm/java-7-openjdk-amd64/
```$ source build/envsetup.sh
```$ lunch $PRODUCT-user
*`*To build boot loader*`*
```$ make -j4 bootloader
*`*To build boot image*`*
```$ make -j4 bootimage
*`*To build system image*`*
```$ make -j4 systemimage
```$ out/host/linux-x86/bin/simg2img out/target/product/$PRODUCT/system.img out/target/product/$PRODUCT/system_raw.img
Flash SD card​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash SD card​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
HDMI Display​
HDMI Display​
Flash SD card​
Flash EMMC​
*To EMMC*
HDMI Display​
``````$ source build/envsetup.sh
``````$ lunch $PRODUCT-user
``````$ make -j4 bootloader
``````$ make -j4 bootimage
``````$ make -j4 systemimage
Flash SD card​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash SD card​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash SD card​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
HDMI Display​
HDMI Display​
Flash SD card​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash SD card​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
HDMI Display​
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
HDMI Display​
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
Flash EMMC​
*To EMMC*
HDMI Display​
HDMI Display​
HDMI Display​
HDMI Display​
HDMI Display​
HDMI Display​
HDMI Display​
HDMI Display​
HDMI Display​
### HDMI Display
```setenv bootargs console=ttymxc0,115200 init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=256M androidboot.console=ttymxc0 consoleblank=0 androidboot.processors=freescale cma=384M androidboot.selinux=disabled
VGA Display
```setenv bootargs console=ttymxc0,115200 init=/init video=mxcfb0:dev=lcd,1920x1080M@60,bpp=32video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=256M androidboot.console=ttymxc0 consoleblank=0 androidboot.processors=freescale cma=384M androidboot.selinux=disabled
lvds Display
```setenv bootargs console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,800x600@60,bpp=32video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=256M androidboot.console=ttymxc0 consoleblank=0 androidboot.processors=freescale cma=384M androidboot.selinux=disabled
