Android 7.0 - i.MX6
IoTGateway/BSP/Android​
Android BSP Version​
Android 7.1.1_1.0.0
Introduction​
This document describes how to work with the RISC Android 7.1.1 Board Support Package (BSP) release. The BSP includes bootloaders; the Android Linux kernel and root file system; and tools and documentation to ease development, deployment, and execution of Android-based systems.
Build Environment on Host​
Currently, we adopt Docker as build environment.
You can get the latest version of advrisc/u16.04-imx6abv5 Docker image for developing imx6 risc projects.
If you don't know much about Docker, please refer to IoTGateway/Docker for details.
Docker Setup Commands​
# Pull Docker image
docker pull advrisc/u16.04-imx6abv5:20170523
# Run Docker container
docker run --name imx6ABV7001 -it advrisc/u16.04-imx6abv5:20170523 /bin/bash
Getting Android Source Code​
Version Information​
  • Android: 7.1.1_1.0.0
  • U-boot: based on Yocto-2.0 (2005.04)
  • Kernel: based on Yocto-2.1
Step 1: Pull Android Source Tree​
First, configure git with your credentials:
git config --global user.name "Your Name"
git config --global user.email you@example.com
Then pull down the Android source tree:
mkdir myandroid
mkdir bin
cd myandroid/
curl https://storage.googleapis.com/git-repo-downloads/repo > ../bin/repo
chmod a+x ../bin/repo
../bin/repo init -u https://github.com/ADVANTECH-Corp/android-manifest.git -b n7.1.1_1.0.0-ga -m release_version.xml
../bin/repo sync
Note: The release_version.xml please refer to: https://github.com/ADVANTECH-Corp/android-manifest/tree/n7.1.1_1.0.0-ga
For ROM-7421, use ELAA_A7_ROM7421_20170630_001.xml in the release_version.xml.
Step 2: Apply Patches to Android N7.1.1_1.0.0​
Apply U-boot patches:
cd myandroid/bootable/bootloader/uboot-imx/
patch -p1 < ../../../patches_android_7.1.1/7001-Uboot_Yocto_4.1.15_1.2.0-to-Android_N7.1.1_1.0.0.patch
cd myandroid/bootable/bootloader/uboot-imx/board/freescale/mx6advantech/
patch -p1 < ../../../../../../patches_android_7.1.1/7002-Uboot_Yocto_4.1.15_1.2.0-to-Android_N7.1.1_1.0.0.patch
Apply kernel patch:
cd myandroid/kernel_imx/
patch -p1 < ../patches_android_7.1.1/7001-Linux_Yocto_4.1.15_2.0.0-to-Android_N7.1.1_1.0.0.patch
cd myandroid
Supported Products​
The following products are supported with their corresponding product names:
ProductProduct Name
ROM-3420A1rom_3420_a1
ROM-7421A1rom_7421_a1
RSB-4411A1rsb_4411_a1
UBC-220A1ubc_220_a1
Build Instructions​
Environment Setup​
export JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64/
source build/envsetup.sh
lunch $PRODUCT-user
Where $PRODUCT is one of the supported product names listed above.
Build Components​
Build individual components:
make -j4 bootloader
make -j4 bootimage
make -j4 systemimage
Build Complete Image​
Execute the make command to generate the complete image:
make 2>&1 | tee build-log.txt
Build Environment Memory Requirements​
Important: Building Android 7.1.1 requires more than 8GB of memory.
Common Build Failure​
If you encounter systemimage build failures due to insufficient memory, use one of the following solutions:
Solution 1: Basic Memory Configuration​
export JACK_SERVER_VM_ARGUMENTS="-Dfile.encoding=UTF-8 -XX:+TieredCompilation -Xmx4096m"
./prebuilts/sdk/tools/jack-admin kill-server
./prebuilts/sdk/tools/jack-admin start-server
Solution 2: Advanced Configuration​
# Edit ~/.jack-settings
vim ~/.jack-settings
# Modify jack.server.service.port=8076 to jack.server.service.port=8086
# Modify jack.server.admin.port=8077 to jack.server.admin.port=8087
# Edit ~/.jack-server/config.properties
vim ~/.jack-server/config.properties
# Modify jack.server.max-service=4 to jack.server.max-service=2
make systemimage
Flash SD Card / eMMC​
Download Flashing Script​
Reference: https://github.com/ADVANTECH-Corp/android_mksd_script/tree/n7.1.1_1.0.0-ga
git clone https://github.com/ADVANTECH-Corp/android_mksd_script.git -b n7.1.1_1.0.0-ga
Note: If your host PC is Ubuntu 18.04, please download the mksd-android7-ubuntu18.sh from the link above.
Boot Configuration on Advantech RISC Board​
Boot from MMC/SD Card​
To set the bootargs environment, use the following reference commands:
HDMI Display Configuration​
setenv bootargs console=ttymxc0,115200 init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 androidboot.processors=freescale cma=448M androidboot.selinux=permissive
VGA Display Configuration​
setenv bootargs console=ttymxc0,115200 init=/init video=mxcfb0:dev=lcd,1920x1080M@60,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 androidboot.processors=freescale cma=448M androidboot.selinux=permissive
Additional Resources​
Troubleshooting​
  1. Memory Issues: Ensure your build environment has more than 8GB of RAM
  2. Jack Server Issues: Use the memory configuration solutions provided above
  3. Docker Issues: Refer to IoTGateway/Docker documentation
