← Back to EPC-R7300
EPC-R7300 Ubuntu 22.04 User Guide
Introduction​
產品介紹 (Product Introduction)
RTENOTITLE
產品特性 (Product Features)​
  • NVIDIA Jetson Orin™ Nano and NX Module compatible Barebone PC
  • Industrial and Expandable Design
  • HDMI up to 3840 x 2160 at 60Hz resolution
  • Dual GbE LAN, 2 USB3.2 Gen 2
  • 1 Nano SIM Slot
  • 1 M.2 3042/52 Key B Slot, 1 M.2 2230 Key E Slot, 1 M.2 2280 Key M Slot
  • 4 Kinds of Rear I/O for Each Vertical Focus: IEM, Self Service, Automation and Networking
EPC-R7300
硬件接口說明 (Hardware Interface Introduction)
EPC-R7300 接口布局圖 Board Dimension Layout​
接口引脚定義 (Pin Definition)​
DC in
RTENOTITLE
USB Ports
RTENOTITLE
RTENOTITLE
LAN Ports
RTENOTITLE
HDMI
RTENOTITLE
LED Indicator
RTENOTITLE
Side Door
RTENOTITLE
OTG Port
RTENOTITLE
Nano SIM
RTENOTITLE
Bottom Door
RTENOTITLE
Debug Port
EPC-R7300 provides one Debug Port for development used. Debug cable P/N: 1700021565-01 4P-1.25 to D-SUB 9P (F) 60cm
RTENOTITLE
Recovery Key
RTENOTITLE
M.2 2230 Key E Slot
EPC-R7300 provides one M.2 2230 Key E Slot for WLAN card. P/N: EWM-W159M201E 802.11 ac/a/b/g/n + Bluetooth 5.0 M.2 2230 (A-E Key) Card
RTENOTITLE
RTENOTITLE
M.2 3042 Key B Slot
EPC-R7300 provides one M.2 3042 Key B Slot for WWAN card. P/N: AIW-355 DQ-E01 5G M.2 3052 (B Key) Card
RTENOTITLE
RTENOTITLE
M.2 2280 Key M Slot
EPC-R7300 provides one M.2 2280 Key M Slot for NVMe card. P/N: SQF-C8MV2-128G-EDE 128G M.2 2280 (M Key) Card
RTENOTITLE
RTENOTITLE
机械尺寸 (Mechanical Characteristics)​
RTENOTITLE
RTENOTITLE
快速入门 (Quick Start)
系统下载 (OS Download)​
Jetpack 6.2
Jetpack 5.1
Linux 燒錄方法 (Linux Flash eMMC Method)​
  1. Prepare a Linux host system Ubuntu x64 v18.04. Download the image file and unzip the image.tar.gz file on Linux host PC. Example use image version 7300A1AIM35UIV20026.tar.gz.
$ sudo tar zxvf 7300A1AIM35UIV20026_2023-07-03.tgz
$ cd Linux_for_Tegra
  1. Enter to recovery mode by holding the recover button (SW1) and plug power to boot. Release recover button around 3 seconds after plug in power.
RTENOTITLE
Or enter following command in the device.
$ sudo reboot --force forced-recovery
  1. Connect Micro USB cable from EPC-R7300 Micro USB port to Linux host PC USB TypeA port. Check the device is in recovery mode by command "lsusb". Will get NVidia Corp. with ID 0955:7623
[ubuntu@linux 11:55:43 ~]$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 072: ID 174c:2362 ASMedia Technology Inc. ASM236X series
Bus 001 Device 073: ID 05ac:12a8 Apple, Inc. iPhone5/5C/5S/6
Bus 001 Device 074: ID 0955:7623 NVIDIA Corp. APX
Bus 001 Device 003: ID 0bda:0169 Realtek Semiconductor Corp. Mass Storage Device
  1. Execute command to flash image:
For Jetpack 5.1.1:
(1) To flash QSPI + NVME SSD:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-epcr7300-a1 internal
(2) To flash only QSPI:
$ sudo ./flash.sh --no-system./img_EPC-R7300 -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-epcr7300-a1 mmcblk0p1
(3) To flash only NVMe SSD (Need to flash QSPI first):
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-only --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml --showlogs --network usb0 jetson-orin-epcr7300-a1 internal
For Jetpack 6.2:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit-super internal
(2) To flash QSPI + USB DISK:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device sda1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit-super internal
  1. Wait around 10~15 minute to flash image to device:
If you get the below "strings: command not found" error, please install "binutils"
$ sudo apt install binutils
RTENOTITLE
  1. Check the device login to system:
login user: ubuntu/ubuntu
  1. Check the eth1 can get the IP Addr:
  2. Lock nvidia-l4t packages (prevents black screen):
$ sudo apt-mark hold nvidia-l4t*
Flash image video:
Debug 串口調試 (Debug Port Setting)​
以 Tera Term 为例介绍如何使用串口调试功能
Baud Rate波特率:115200
Data 数据位:8
Parity 奇偶校验:无
Stop 停止位:1
Flow Control流控:无
Tera Term Tool
RTENOTITLE
RTENOTITLE
Check the Serial port in Device Manager (查看PC端的串口号):
If you can not identify the Serial device, please check your serial driver.
RTENOTITLE
Debug port connection (串口連接)
Log into Terminal Tool (进入串口调试终端):
Linux 基本使用方法 for Jetson Series (Linux System Basic Operating Method for Jetson Series)
  • Check module
$ jetson_release
$ cat /proc/device-tree/model
  • Check OS release version
$ cat /etc/os-release
  • Check tegra version
$ cat /etc/nv_tegra_release
  • Install stress-ng
$ sudo apt install stress-ng
  • Execute stress test
$ stress-ng --cpu 0 --cpu-method all -t 1h
  • Install jtop
$ sudo apt update
$ sudo apt install python3-pip
$ sudo pip3 install -U jetson-stats
$ jtop
  • Install chromium
$ sudo snap install chromium
If there is issue cannot launch chromium, please reference link below to download grade snap version:
chromium not working
  • Install nvidia-jetpack
$ sudo apt install nvidia-jetpack
RTENOTITLE
Modify defconfig: If an unknown symbol issue occurs after modifying the defconfig, please refer to the compiled information below.
It may fail with additional steps. Please simply follow the steps:
  1. And follow the steps to rebuild kernel, out-of-tree modules, and dtbs:
https://docs.nvidia.com/jetson/archives/r36.4.3/DeveloperGuide/SD/Kernel/KernelCustomization.html#building-the-jetson-linux-kernel
// ignore step 2 which is for RT kernel
https://docs.nvidia.com/jetson/archives/r36.4.3/DeveloperGuide/SD/Kernel/KernelCustomization.html#building-the-nvidia-out-of-tree-modules
https://docs.nvidia.com/jetson/archives/r36.4.3/DeveloperGuide/SD/Kernel/KernelCustomization.html#building-the-dtbs
  1. Manually copy the files: (quick fix for a known issue: https://forums.developer.nvidia.com/t/319667/)
$ cd /Linux_for_Tegra/rootfs/lib/modules/5.15.148-tegra/updates/
$ sudo cp nvidia.ko opensrc-disp/
$ sudo cp nvidia-modeset.ko opensrc-disp/
$ sudo cp nvidia-drm.ko opensrc-disp/
  1. Flash the system
$ sudo ./flash.sh jetson-agx-orin-devkit internal
NVIDIA 模塊安裝 (NVIDIA Jetson Module Installation)
How to Build BSP (BSP Compile)
NVIDIA Jetson Software:
◼ Jetson Support Resource
https://developer.nvidia.com/embedded/community/support-resources
◼ Jetson Wiki
https://elinux.org/Jetson
◼ Jetson Jetpack SDK
https://developer.nvidia.com/embedded/jetpack
◼ Jetson FAQ
https://developer.nvidia.com/embedded/faq
Software Forum:
◼ Jetson Developer Forum
https://forums.developer.nvidia.com/c/agx-autonomous-machines/jetson-embedded-systems/70
◼ AIM-Linux Developer Forum
https://forum.aim-linux.advantech.com/
◼ NVIDIA NVONLINE
https://partners.nvidia.com/
Personal Tools​
  • Log in
Namespaces​
  • Page
  • Discussion
Variants​
Views​
  • Read
  • View source
  • View history
More​
  • AIM-Linux
  • X86-Linux
  • ASR
  • SUSI
  • Windows Embedded
  • Advantech Power Suite
  • Edge AI SDK
  • Adv Robotic Suite
  • DeviceOn
  • DeviceOn/iEdge
  • DeviceOn/ePaper
  • AIW Module
  • Internal Use
Tools​
  • What links here
  • Related changes
  • Special pages
  • Printable version
  • Permanent link
  • Page information
  • Page values
This page was last modified on 10 December 2025, at 03:28.
  • Privacy policy
  • About ESS-WIKI
  • Disclaimers
