← Back to ROM-3620
ROM-3620 Yocto 2.5 User Guide
產品特性 (Product Features)​
  • NXP i.MX 8X processor with 2-4 x Arm Cortex-A35 cores
  • Onboard LPDDR4 memory and eMMC 16GB
  • Supports wide range power input 5V~24V
  • Supports Vivante GC7000 Lite processors accelerators
  • Supports Ultra HD 4K/ full HD 1080p video decode and HD 1080p video encode processors engine
  • Supports 1 PCIe, 1 USB 3.0, 1 USB 2.0, 1 USB OTG2.0, 5 I2C, 1 I2S, 1 Camera in, 2 CANbus, 10 GPIO
  • Low power consumption, fanless design
  • Supports Linux and Android BSP
ROM-3620
硬件接口說明 (Hardware interface introduction)
接口布局和尺寸 (Layout and Sizes)​
ROM-3620 接口布局圖 Board Dimension Layout​
Z51
PositionDescription
SW1(1)UART & Debug Port selection
SW1(2)AT & ATX mode selection
SW1(1): UART & Debug Port selection
SettingFunction
1-OnNormal UART
1-OffDebug Console (Default)
SW1(2): AT/ATX Mode Selection
SettingFunction
2-OnAT Mode (Default)
2-OffATX Mode
ROM-DB3900 接口布局圖 Board Dimension Layout​
Z54
Z53
主板内置插针式引脚排序方式 (Pin Header definition)​
Internal I/O​
Z55
PositionDescriptionConnector Type
DCINDC-inDC POWER JACK 2.5mm 90D(M) DIP 2DCG213B200
COM01COM PortD-SUB Conn. 18P 90D(M) DIP DM10151-H531-4F
HDMIHDMIHDMI Conn. 19P 0.5mm 90D(F) SMD QJ51191-LFB4-7F
VGAVGAD-SUB Conn. 15P 90D(F) DIP 070242FR015S200ZU
RJ45+USBLAN+USBPhoneJack RJ45+USB3.0*2 32P 90D(F) DIP 05-A00919
Phone JackPhone JackAudio Jack 9P 2.5mm 90D(F) DIP ABA-JAK-03
AudioAudioPIN HEADER 2x10P 2.54mm 180D(M) DIP 21N22564
LVDSLVDSB/B Conn. 40P 1.25mm 90D SMD DF13-40DP-1.25V(91)
FANFANWafer 2.54mm 3P 180D(M) DIP 22-27-2031
SATA_PWRSATA powerWAFER 4P 2.5mm 180D(M) DIP 24W1161-04S10-01T
PCIE_SLOT0PCIE_SLOT0PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF
PCIE_SLOT1PCIE_SLOT1PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF
SATASATASerial ATA 7P 1.27mm 180D(M) DIP WATM-07DBN4A3B8
GPIOGPIOPIN HEADER 10x2P 2.0mm 180D(M) DIP 21N22050
LVDS_BKLTLVDS BacklightWAFER BOX 2.0mm 5P 180D(M) DIP WO/Pb JIHVEI
SW3Reset buttonTACT SW STS-091 SMD 4P H=3.8mm
SW4Power buttonTACT SW STS-091 SMD 4P H=3.8mm
SW5Sleep buttonTACT SW STS-091 SMD 4P H=3.8mm
SW6Wake up buttonTACT SW STS-091 SMD 4P H=3.8mm
SPI0SPI0PIN HEADER 2x4P 2.54mm 180D(M) DIP 210-92-04GB02
SPI1SPI1PIN HEADER 2x4P 2.54mm 180D(M) DIP 210-92-04GB02
SW2Boot selectionDIP SW EDG104S DIP 6P Radial SPST
COM3COM3BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
COM2COM2BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
CAN1CAN1BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
CAN0CAN0BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
USB_OTGUSB OTGMINI USB 5P 180D(F) SMD UH51543-CS7-7F
SDSDSD CARD 9P 90D(F) SMD WK2192C-S3D-7H
System_BusSYSTEMBUSPCB SKT 30x4P 2.00mm 180D(F) DIP 264-40303-02
I2C0I2C0WAFER BOX 2.0mm 4P 180D(M) W/LOCKA2001WV2-4P
I2C1I2C1WAFER BOX 2.0mm 4P 180D(M) W/LOCKA2001WV2-4P
RTXA,RTXB, RTXC,RTXDRTX B2B ConnectorB/B Conn. 50x2P 0.5mm 180D(M) SMDAXK500137YG
Rear I/O​
Z56
PositionDescriptionName
DCINDC JackA
COM01AUART Port 1B
COM01BUART Port 2C
HDMIHDMI PortD
VGAVGA PortE
RJ45+USBGbE Ethernet ConnectorF
RJ45+USBUSB Port 1/ 2G
PHONE_JACKMIC Input/ Audio OutputH
接口引脚定義 (Pin definitions)​
Rear IO:
  • DCIN
  • 串口 (COM01A、UART1、4_WIRE(ttyLP1))
  • 串口 (COM01B、UART2、4_WIRE(ttyLP2))
  • 显示接口 (VGA、HDMI)
  • RJ45+USB接口 (RJ45、USB1-2)
  • PHONE_JACK接口 (Audio_output)
Internal IO:
  • Boot_selection_switch
  • 電池 (BAT1)
  • CAN (CAN0,CAN1)
  • LVDS接口 (LVDS、LVDS_BKLT)
  • 串口 (COM3(COM_DB(ttyLP0))、COM2(UART3)(ttyLP3))
  • USB_OTG接口 (USB_OTG)
  • I2S0接口 (I2S/Audio_Codec)
  • 电源及指示灯和开关机复位按钮 (Power、LED、Power Button、Reset Button、Sleep Button)
  • GPIO接口
  • PCIE接口_SATA接口_SPI、I2C_接口
机械尺寸 (Mechanical Characteristics)​
ROM-3620
ROM-3620-MS1 ROM-3620-MS2
快速入门 (Quick Start)
系统下载 (OS Download)​
Linux系统 (Linux OS)
VersionDateProductCPUOS VersionSDKTest ReportReleaseComment
V902102021-03-09ROM-36208XYocto 2.5SDKTest Report4.14.98 MPMP
VA02972021-07-21ROM-36208XYocto 3.0SDKTest Report5.4.70 AlphaQE test
Linux 燒錄方法 (Linux Flash eMMC Method)​
使用 Flash tool 燒錄鏡像到 eMMC (Flash image into eMMC by Flash Tools)
  1. Copy 3620A1AIM20LIV90210_iMX8X_flash_tool.tgz package to your desktop.
  2. Insert SD card to PC.
  3. Make a bootable sd card.
# tar zxvf 3620A1AIM20LIV90210_iMX8X_flash_tool.tgz
# cd 3620A1AIM20LIV90210_iMX8X_flash_tool/mk_inand/
# sudo ./mksd-linux.sh /dev/sdg
4. Insert SD card and copy 3620A1AIM20LIV90210\_iMX8X\_flash\_tool to USB disk.
5. Insert USB disk and SD card then Boot from SD.
6. Enter usb disk folder, make a bootable emmc.
# cd /run/media/sda1/
# cd 3620A1AIM20LIV90210\_iMX8X\_flash\_tool/mk\_inand/
# sudo ./mksd-linux.sh /dev/mmcblk0
**使用UUU工具燒錄鏡像到eMMC (Flash image into eMMC by UUU Tools)**
1. Download UUU tool from (<https://github.com/ADVANTECH-Corp/uuu/releases/download/v20191101/uuu>).
2. Create a folder with files as below:
 UUU
 imx-boot-imx8qxprom3620a1-sd.bin-flash
 fsl-image-qt5-validation-imx-imx8qxprom3620a1-20210309105548.rootfs.sdcard
3. Connect otg cable from PC to device.
4. Set the correct boot mode, then power on(4-on only).
**[![RTENOTITLE](img_ROM-3620/Recovery-mode.jpg)]**
5. Perform the following command:
$ sudo ./uuu -b emmc\_all\_adv imx-boot-imx8qxprom3620a1-sd.bin-flash fsl-image-qt5-validation-imx-imx8qxprom3620a1-20210309105548.rootfs.sdcard
6. UUU tool will start recovery image to eMMC.
7. For more usage:
<http://ess-wiki.advantech.com.tw/view/IoTGateway/BSP/Linux/iMX8/Yocto_LBV9_User_Guide#System_Recovery>
## **Debug 串口調試 (Debug port Setting)**
1. Connect debug port cable (1701100300) to debug port (COM3) on ROMDB3900.
2. Connect it to your PC with RS-232 Cable (1700019474).
**[![RTENOTITLE](img_ROM-3620/ROM-3620-Debug_cable.jpg)]**
ROM-3620 can communicate with a host server by using serial cables. Common serial communication programs such as HyperTerminal, Tera Term or PuTTY can be used in this case. The example below describes the serial terminal setup using HyperTerminal on a Windows host:
1. Connect ROM-3620 with your PC by using a serial cable.
2. Open HyperTerminal on your Windows PC, and select the settings as shown in below Photo.
以 Tera Term  为例介绍如何使用串口调试功能
Tera Term Tool
[![RTENOTITLE](../../NXP_i.MX_6/RSB-3430_wiki_data/img_RSB-3430/TeraTerm12021-09-10_141114n.jpg)]
Check the Sriel port in Device Manager (查看PC端的串口号):
if you can not identify the Serial device , please check your serial driver.
Debug port connection (串口連接)
Log into Terminal  Tool (进入串口调试终端):
# **Linux系统的基本使用(Linux System Basic Operating Method)**
## **Display Setting (ROM-3620)**
* Single Channel LVDS0 + Single Channel LVDS1 (Default):
LVDS0 - g070vw01v0(VDD:3.3V, Backlight Power:12V)
1. Connect LVDS VDD and Backlight Power cable.
2. Power on.
3. Weston UI will be displayed on the screen.
[![RTENOTITLE](img_ROM-3620/ROM-3620-LVDS0.jpg)]
LVDS1 - g070vw01v0(VDD:3.3V, Backlight Power:12V)
2. Power on.
[![RTENOTITLE](img_ROM-3620/ROM-3620-LVDS1.jpg)]
* Dual Channel LVDS:
Dual Channel LVDS - g215hvn0 (VDD:5V, Backlight Power:12V)
1. Connect two LVDS VDD and Backlight Power cable.
2. Power on.
3. Press enter after boot, system will stop at u-boot as below:
u-boot=>
u-boot=>run lvds\_dual
4. Weston UI will be displayed on the screen
[![RTENOTITLE](img_ROM-3620/ROM-3620-LVDS-dual.jpg)]
* MIPI to HDMI test:
1. Connect LVDS to HDMI cable to LVDS0 or LVDS1.
2. Power on.
u-boot=>
u-boot=>run hdmi\_bridge
4. Weston UI will be displayed on the screen.
[![RTENOTITLE](img_ROM-3620/ROM-3620-MIPI_to_HDMI.jpg)]
Test HDMI with different resolutions:
1. Disable weston UI.
# systemctl stop weston
2. Get “connect ID” and “support resolutions“.
# modetest -c
[![RTENOTITLE](img_ROM-3620/ROM-3620-modetest.jpg)]
3. Play colorbar of the specified resolution on HDMI.
# modetest -s 56:1920x1080-60
## **Audio測試方法(Audio Testing Method):**
1. Connect ROM-EG51 to I2S\_CN3, connect MIC and headphone.
2. Power on and check Audio Codec (SGTL5000)
# cat /proc/asound/cards
# amixer set Mic 100%
# amixer set Headphone 100%
[![RTENOTITLE](img_ROM-3620/ROM-3620-Audio.jpg)]
3. Record and playback.
# arecord -t wav -c 1 -r 44100 -d 5 /tmp/mic.wav
# aplay /tmp/mic.wav
## **4G使用方法(4G Testing Method)**
Test 4G: (EWM-C117FL06E - USB)
1. Connect EWM-C117FL06E to Mini PCIE slot on 9680015491 and connect the card to CN6 PCIe\_D slot on ROM-DB5901.
2. Connect the antenna 1750007990-01 to the SMA (F) connector on 9680015491 and connect the IPEX connector to MT1 on EWM-C117FL06E module.
3. Connect the Mini USB cable from 9680015491 to USB 2.0 Type A port on ROM-DB3900.
4. Power on and execute the pppd command to connect to the network.
# pppd connect 'chat -v -s -t 10 "" "AT" "" "ATDT\*99\*\*\*4#" "CONNECT" ""' user username pass�word password /dev/ttyACM2 460800 nodetach crtscts debug usepeerdns defaultroute &
[![RTENOTITLE](img_ROM-3620/ROM-3620-4G.jpg)]
## **WiFi使用方法(WIFI Testing Method)**
Test WiFi card (EWM-W189H02E PCIe signal)
# killall wpa\_supplicant
# ifconfig wlan0 up
# wpa\_passphrase “SSID” “PASSWORD” > /tmp/wpa.conf
# wpa\_supplicant -BDwext -iwlan0 -c/tmp/wpa.conf
# udhcpc -b -i wlan0
Ping network:
[![RTENOTITLE](img_ROM-3620/ROM-3620-WIFI_Ping.jpg)]
## **串口使用方法(Serial Port Operating Method)**
A. RS-232 Test:
Loopback test (eg. ttyLP1)
UART1(COM01\_UP)(ttyLP1):      Change SW1801 jumper to switch modes. (SW1801: 1-on, 2,3,4-off)
UART2(COM01\_Down)(ttyLP2):  Change SW1802 jumper to switch modes. (SW1802: 1-on, 2,3,4-off)
UART3(COM2)(ttyLP3):               Change SW1901 jumper to switch modes. (SW1901: 1-on, 2,3,4-off)
# stty -F /dev/ttyLP1 -echo -onlcr 115200
# cat /dev/ttyLP1 &
# echo test > /dev/ttyLP1
B. RS-485 Test:
UART1(COM01\_UP)(ttyLP1): Change SW1801 jumper to switch modes. (SW1801: 2-on, 1,3,4-off)
Test RS-485 with Adam-4520.
# ./enable485 /dev/ttyLP1
# stty -F /dev/ttyLP1 speed 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
# cat /dev/ttyLP1 &
## **I2C測試方法(I2C Testing Method)**
Check I2C Device (audio codec: 3-000a):
# i2cdetect -y 1
[![RTENOTITLE](img_ROM-3620/ROM-3620-I2C_detect.jpg)]
I2C set and get:
# i2cset -f -y 1 0x0a 0 0xff00 w
# i2cget -f -y 1 0x0a 0 w
[![RTENOTITLE](img_ROM-3620/ROM-3620-I2C_set.jpg)]
## **USB測試方法(USB Testing Method)**
USB (2.0/3.0) disk test
After inserting the USB disk into 2.0 or 3.0 port: (Please note that with ROM-3620, USB3.0 port on ROM-DB3900 coastline can only recognize USB 3.0 devices. It can not recognize USB 2.0 only devices.)
[![RTENOTITLE](img_ROM-3620/ROM-3620-USB.jpg)]
Test (eg. if USB disk is/dev/sda)
# dd if=/dev/urandom of=data bs=1 count=1024
# dd if=/dev/sda of=backup bs=1 count=1024 skip=4096
# dd if=data of=/dev/sda bs=1 seek=4096
# dd if=/dev/sda of=data1 bs=1 count=1024 skip=4096
# diff data data1
# dd if=backup of=/dev/sda bs=1 seek=4096
## **RTC測試方法(RTC Testing Method)**
Disable rtc sync service:
# systemctl stop systemd-timesyncd
# systemctl stop ntpdate.service
[![RTENOTITLE](img_ROM-3620/ROM-3620-RTC1.jpg)]
Set system time to current, then write to RTC:
# date 021710452022 && hwclock -w && date
[![RTENOTITLE](img_ROM-3620/ROM-3620-RTC2.jpg)]
Set one incorrect time, then read time from RTC to verify:
# date 010100002000 && hwclock -r && date
[![RTENOTITLE](img_ROM-3620/ROM-3620-RTC3.jpg)]
Restore the RTC time to system time.
# hwclock -s && date
[![RTENOTITLE](img_ROM-3620/ROM-3620-RTC4.jpg)]
## **eMMC/SD/SPI Flash測試方法(eMMC/SD/SPI Flash Testing Method)**
eMMC: /dev/mmcblk0
SD: /dev/mmcblk1
QSPI1: /dev/mtd0
SPI0\_0: /dev/mtd1
SPI0\_1: /dev/mtd2
SPI3\_0: /dev/mtd3
SPI3\_1: /dev/mtd4
Test command(eg. emmc):
# dd if=/dev/mmcblk0 of=backup bs=1 count=1024 skip=4096
# dd if=data of=/dev/mmcblk0 bs=1 seek=4096
# dd if=/dev/mmcblk0 of=data1 bs=1 count=1024 skip=4096
# diff data data1
# dd if=backup of=/dev/mmcblk0 bs=1 seek=4096
## **乙太網路使用方法(Ethernent Testing Method)**
Connect cable and use command : ifconfig
# ifconfig
[![RTENOTITLE](img_ROM-3620/ROM-3620-LAN1.jpg)]
Ping test (eg.eth1):
# ping - I eth1 8.8.8.8
[![RTENOTITLE](img_ROM-3620/ROM-3620-LAN2.jpg)]
## **GPIO使用方法(GPIO Operating Method)**
| CPU Ball Name | Pin# | Number |
| SC\_P\_QSPI0B\_DATA0\_LSIO\_GPIO3\_IO18 | GPIO0 | 402 |
| SC\_P\_QSPI0B\_DQS\_LSIO\_GPIO3\_IO22 | GPIO1 | 406 |
| SC\_P\_QSPI0B\_DATA1\_LSIO\_GPIO3\_IO19 | GPIO2 | 403 |
| SC\_P\_CSI\_PCLK\_LSIO\_GPIO3\_IO00 | GPIO3 | 384 |
| SC\_P\_SPI2\_SCK\_LSIO\_GPIO1\_IO03 | GPIO4 | 451 |
| SC\_P\_SPI2\_CS0\_LSIO\_GPIO1\_IO00 | GPIO5 | 448 |
| SC\_P\_SPI2\_SDO\_LSIO\_GPIO1\_IO01 | GPIO6 | 449 |
| SC\_P\_SPI2\_SDI\_LSIO\_GPIO1\_IO02 | GPIO7 | 450 |
| SC\_P\_MCLK\_IN0\_LSIO\_GPIO0\_IO19 | GPIO8 | 499 |
| SC\_P\_QSPI0B\_SCLK\_LSIO\_GPIO3\_IO17 | GPIO9 | 401 |
Loopback test (take GPIO0 and GPIO1 as an example)
1. Connect GPIO0 and GPIO1.
2. Export GPIO interface.
# echo 402 > /sys/class/gpio/export
# echo 406 > /sys/class/gpio/export
[![RTENOTITLE](img_ROM-3620/ROM-3620-GPIO1.jpg)]
3. Set direction.
# echo out > /sys/class/gpio/gpio1/direction
# echo in > /sys/class/gpio/gpio2/direction
[![RTENOTITLE](img_ROM-3620/ROM-3620-GPIO2.jpg)]
4. Read value and set output value than check.
# cat /sys/class/gpio/gpio2/value
# echo 1 > /sys/class/gpio/gpio1/value
[![RTENOTITLE](img_ROM-3620/ROM-3620-GPIO3.jpg)]
## **Watchdog測試方法(Watchdog Testing Method)**
System will reboot after 1 sec.
# /unit\_tests/Watchdog/wdt\_driver\_test.out 1 2 0
[![RTENOTITLE](img_ROM-3620/ROM-3620-WDog.jpg)]
## C**amer測試方法(Camera Testing Method)**
Please connect MIPI-CSI2 camera (OV5640) to CN39 FPC connector.
Preview:
# gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=640,height=480 ! waylandsink
Capture:
# gst-launch-1.0 v4l2src num-buffers=1 device=/dev/video0 ! video/x-raw,width=640,height=480 ! jpegenc ! filesink location=sample.jpeg
## **CANbus測試方法(CANbus Testing Method)**
**1. Connect CAN0\_D+ to CAN1\_D+ and CAN0\_D- to CAN1\_D-.
2. Set CAN0 and CAN1 up.**
**# ip link set can0 up type can bitrate 12500
# ifconfig can0 up
# ip link set can1 up type can bitrate 12500
# ifconfig can1 up**
[![RTENOTITLE](img_ROM-3620/ROM-3620-CAN1.jpg)]
3. candump can0.
# candump can0 &
[![RTENOTITLE](img_ROM-3620/ROM-3620-CAN2.jpg)]
4. cansend can1.
# cansend can1 1F334455#1122334455667788
[![RTENOTITLE](img_ROM-3620/ROM-3620-CAN3.jpg)]
## **TPM測試方法(TPM Testing Method)**
Using the “tpm\_test.bin” to test, please connect to your Advantech contact window for the test tool.
# ./tpm\_test.bin
[![ROM-3620-TPM1.jpg](img_ROM-3620/ROM-3620-TPM1.jpg)]
## **遠程訪問及文件傳輸(Remote Access and File Transimmion)**
**Windows下SSH访问及文件传输**
SSH Remote Log into Device
* SSH远程登录,以putty选择putty.exe(或者使用Xshell、SecureCRT等类似软件)
* 需要设置远程设备的IP、通讯端口(默认22)、通讯方式,登录后验证用户名密码
[![RTENOTITLE](../../../../formfactor/2-5-inch-sbc/img/SSHsettingdetail.jpg)]
[![RTENOTITLE](../../../../formfactor/2-5-inch-sbc/img/RSB-3720_user_guide_img042.jpg)]
[![RTENOTITLE](../../../../formfactor/2-5-inch-sbc/img/RSB-3720_user_guide_img043.jpg)]
# **通用方法(General Method)**
### **查看CPU温度(Check CPU Temperature)**
root@imx8qxprom5620a1:/# cat /sys/devices/virtual/thermal/thermal_zone0/temp 44600
或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 45°
### **查看CPU频率(Check CPU Frequency)**
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
900000 cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
1200000
### **查看内存容量(Check Memory Capacity)**
root@imx8qxprom5620a1:/# busybox free -m total used free shared buffers cached Mem: 1794920 516080 1278840 17252 9852 80292 -/+ buffers/cache: 425936 1368984 Swap: 0 0 0
### **查看存储容量(Check Storage Capacity)**
root@imx8qxprom5620a1:/# busybox df -h Filesystem Size Used Available Use% Mounted on /dev/root 13.4G 1.7G 11.1G 13% / devtmpfs 395.8M 4.0K 395.8M 0% /dev tmpfs 876.4M 0 876.4M 0% /dev/shm tmpfs 876.4M 16.5M 859.9M 2% /run tmpfs 876.4M 0 876.4M 0% /sys/fs/cgroup tmpfs 876.4M 4.0K 876.4M 0% /tmp tmpfs 876.4M 280.0K 876.2M 0% /var/volatile /dev/mmcblk0p2 13.6G 1.7G 11.3G 13% /run/media/mmcblk0p2 /dev/mmcblk0p1 63.9M 23.4M 40.5M 37% /run/media/mmcblk0p1 /dev/mmcblk1p1 63.9M 23.4M 40.5M 37% /run/media/mmcblk1p1 tmpfs 175.3M 88.0K 175.2M 0% /run/user/0 root@imx8qxprom5620a1:/#
### **網路Ping測試(Ping Network Testing)**
ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data. 64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms 64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
### **設置RTC (RTC Setting)**
root@imx8qxprom5620a1:/# systemctl stop ntpdate.service root@imx8qxprom5620a1:/# date 090816072021 && hwclock -w && date Wed Sep 8 16:07:00 UTC 2021 Wed Sep 8 16:07:00 UTC 2021 root@imx8qxprom5620a1:/# date Wed Sep 8 16:07:06 UTC 2021 root@imx8qxprom5620a1:/#'''
# **Linux BSP編譯方法(Linux BSP Compile Method)**
### **Yocto 2.5**
### **Yocto 3.0**
**如果有驗證上的錯誤 請使用以下的方法**
**### repo sync failed with Server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
`export GIT_SSL_NO_VERIFY=1`
#or
git config --global http.sslverify false
