← Back to ROM-2820
產品介紹
產品特性(Features)​
  • NXP i.MX 93 Cortex-A55 Dual-core (up to 1.7GHz)
  • 1 x Arm Cortex-M33 core
  • 1 x Ethos®-U65 microNPU
  • 1 x 2GB LPDDR4X up to 3733MT/s
  • 1 x 4 lane MIPI-DSI
  • 2 x USB 2.0, 5 x UART, 4 x I2C, 16 x GPIO, 2 x PWM, 2 x CAN-FD
  • Compact size form factor - OSM Size L (45 x 45 mm)
  • Support Ycoto Linux
ROM-2820
接口布局和尺寸(Layout and Sizes)
ROM-2820 接口布局圖 Board Dimension Layout​
RTENOTITLE
ROM-ED93 接口布局圖 Board Dimension Layout​
RTENOTITLE
主板内置插针式引脚排序方式 (Pin Header defination)​
Internal I/O, Jummper/Switch List:​
PositionDescription
[AT801]AT/ATX select header
[AUDIO1]Line Out Connector
[BAT601]Battery Connector
[CN1301]Camera FPC connector
[CN1801]CANA terminal resistor enable jumper
[CN1802]CANB terminal resistor enable jumper
[CANA]CAN Bus Connector
[CANB]CAN Bus Connector
[COMA]RS232/422/485
[COMB]RS232/422/485
[COMC]COM A port wafer
[COMD]COM D port wafer
[COME_DEBUG]Debug console wafer
[CN1601]RJ45 1x2
[DCIN701]12V DCIN connector
[DSI]DSI connector
[DSI_BKLT_PWR]DSI blacklight wafer
[DSI_BKLT_SLT]DSI blacklight power select
[DSI_VDD_SLT]DSI VDD power select
[GPIO]GPIO header
[I2S_CN]Audio expander pin header
[LVDS]LVDS connector
[LVDS_BKLT_PWR]LVDS blacklight wafer
[LVDS_BKLT_SLT]LVDS blacklight power select
[LVDS_VDD_SLT]LVDS VDD power select
[M2B_CN]M2 Key B connector
[M2E_CN]M2 Key E connector
[MIC]MIC Connector
[SD_CARD]Micro SD slot
[SD2001]SDIO device select jumper
[SD2002]SDIO device select jumper
[SD2003]SDIO device select jumper
[SD2005]SDIO device select jumper
[SD2004]SDIO device select jumper
[SD2006]SDIO device select jumper
[SIM]SIM card connector
[SPI]SPI pin header
[SW1001]Boot select switch
[SW1002]Reset button
[SW1003]Power button
[SW1104]COMA UART setting switch
[SW1103]COMB UART setting switch
[USB1201]USB2.0 2x1 Connector
[USB0_OTG1]Micro USB Connector
RTENOTITLE
RTENOTITLE
RTENOTITLE
快速入門 (Quick Start)
系统下载 (OS Download)​
  • 'Linux系统 (Linux OS)'
**Yocto 4.2:**IoTGateway/BSP/Linux/iMX8/OS Support List 4.2 release ROM-2820 - ESS-WIKI (advantech.com.tw)
Linux 燒錄方法 (Linux Flash eMMC Method)​
使用Flash tool 燒錄鏡像到eMMC (Flash image into eMMC by Flash Tools)
Step0: 檢查SD卡在Linux 環境的代號 (check SD card symbol in Linux system)
RTENOTITLE
Step1: 創造一張可開機的SD 卡 (Create a bootable SD card)
Command :
sudo dd if=2820A1AIM36LIVD0042_iMX93_2G_2024-05-26.img of=/dev/sdh bs=1M conv=fsync
RTENOTITLE
Step2: 將可開機的SD 卡插入底板SD卡卡槽(Plug the SD card into Carrier board 's SD card slot)
Step3: 確認開機選擇指撥開關
SD  boot:1 on , 2on
EMMC boot:1 off , 2 on
AT/ATX mode Jumper
AT mode2&3
ATX mode1&2
RTENOTITLE
System ID : root​
Password : 12345678​
Step4:打開電源 和 終端機 (Turn on the Power & Terminal)
RTENOTITLE
RTENOTITLE
Step 5:  按下Power 開關 (Turn on Power , open terminal , then press the Power Button )
SW1003 : PWR_Button , SW1002: Reset_Button
RTENOTITLE
RTENOTITLE
Step6: 複製flash tool到U盤中, 解壓縮flash tools檔案,(copy to USB Disk, then unzip the flash tools file)(Test with 32G SD card)
    複製檔案到U盤中 (Copy the flash file to USB Disk), 解壓縮flash tool到home目錄(Unzip the file to home)
  1. Format your USB Disk to ext2 format
            Command :  sudo mkfs.ext2 -F /dev/sdX
       2. Unzip the flash file in your linux system
RTENOTITLE
     3. Copy the flash file into USB DISK
RTENOTITLE
     4. 進入flsah tool下的mk_inand資歷夾, 執行指令./mksd-linux.sh /dev/mmcblk0燒錄image到eMMC(Connect USB Disk to ROM-2820 system, extract the flash tool and browser to mk_inand folder and execute flash shell script "./mksd-linux.sh /dev/mmcblk0"
解壓縮後如果沒有mksd-linux.sh檔案, 可以到以下連結下載並複製到mk_inand資料夾下(If there is no mksd-linux.sh file in mk_inand directory. Please download from the link below and place it in mk_inand directory:
下載 mksd-linux.sh​
ROM-2820Device node
SD card/dev/mmcblk1
eMMC/dev/mmcblk0
RTENOTITLE
Step 7 . 移除SD card , 切換開機switch來設定成從eMMC開機(Romve SD card and  Change boot switch to boot from eMMC. Reboot system).
SD  boot:1 on , 2on
RTENOTITLE
Debug 串口調試 (Debug port Setting)​
以 Tera Term  为例介绍如何使用串口调试功能
Tera Term Tool
RTENOTITLE
RTENOTITLE
Check the Sriel port in Device Manager (查看PC端的串口号):
if you can not identify the Serial device , please check your serial driver.
RTENOTITLE
Debug port connection (串口連接)
Log into Terminal  Tool (进入串口调试终端):
RTENOTITLE
Linux系统的基本使用(Linux System Basic Operating Method)
Recovery by UUU Tool  使用方法(Mirco USB Connection (OTG port))​
Connect Mirco USB cable to USB OTG port.
RTENOTITLE
Change boot switch to "SW1001 " to boot from force recovery mode.
RTENOTITLE
Serial download:1on , 2 off
Download uuu tool from link below:
Releases · nxp-imx/mfgtools (github.com)
The uuu verison we tested is 1.4.193: uuu
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.193-0-ge56424c
Perpare uboot and image files below:
  1. Download uuu
$ wget <https://github.com/nxp-imx/mfgtools/releases/download/uuu_1.4.193/uuu>
$ chmod a+x uuu
Connect OTG to Ubuntu System(x86 PC)  , make sure the device was identified
RTENOTITLE
Type command below to flash eMMC:
tar -xvzf 2820A1AIM36LIVD0042_iMX93_2G_flash_tool.tgz
cd 2820A1AIM36LIVD0042_iMX93_2G_flash_tool/image/
sudo ./uuu -b emmc_all imx-image-full-imx93rom2820a1-20240321094239.rootfs.wic
RTENOTITLE
Display Setting (ROM-2820)​
LVDS​
Single Channel LVDS: G070VW01 (VDD: 3.3V, Backlight Power: 12V)
Step 1: Connect G070VW01 LVDS panel with the LVDS cable. Connect this to the LVDS. Connect the Backlight cable to LVDS_BKLT_PWR.
Step 2: Connect another 12V adapter to the DC-Jack on the backlight cable.
Step 3: Power on RSB-2820 and the extra 12V adapter.
Step 4: Press enter after boot. The system will stop at u-boot as demonstrated below, enter the command in red and press enter.
RTENOTITLE
(LVDS_BPLT_SLT : 2&3 jumper short)
Normal Boot
Hit any key to stop autoboot:  0
=> setenv fdtfile imx93-rom2820-a1-lvds.dtb
=> saveenv
=> boot
MIPI HDMI​
Single Channel MIPI HDMI: (VDD: 3.3V, Backlight Power: 5V)
Step 1: Connect another 5V adapter to the DC-Jack on the backlight cable.
Step 2: Power on RSB-2820 and the extra 5V adapter.
Step 3: Press enter after boot. The system will stop at u-boot as demonstrated below, enter the command in red and press enter.
RTENOTITLE
Normal Boot
=> setenv fdtfile imx93-rom2820-a1.dtb
=> saveenv
=> boot
MIPI DSI​
Single Channel LVDS: G101UAN02.0 (VDD: 3.3V, Backlight Power: 12V)
Step 1: Connect G101UAN02.0 LVDS panel with the LVDS cable. Connect this to theLVDS. Connect the Backlight cable to DSI_BKLT_PWR.
RTENOTITLE
(DSI_BKLT_SLT: 2&3 jumper short)
Normal Boot
=> setenv fdtfile imx93-rom2820-a1-auog101uan02.dtb
=> saveenv
=> boot
Audio(Audio Testing Methid)​
Step 1: Check audio codec
cat /proc/asound/cards
0 [sgtl5000       ]: sgtl5000 - sgtl5000 sgtl5000
Step 2: Audio codec (sgtl5000):
  1. Set MIC and headphone:
amixer set Mic 100%
amixer set Headphone 100%
Record and playback:
Record
arecord -D plughw:0,0 -r 16000 -f S16_LE ./f-16000.wav
Playback
aplay -D plughw:0,0 f-16000.wav
M.2 WiFi/BT測試方法(M.2 WiFi/BT Testing Method)​
  • Test Wi-Fi with  NXP IW-612 Module (SDIO Interface)
Step 1: Switch jumper SD2001~SD2006(2&3 jumper short)
RTENOTITLE
Step 2: Press enter after boot. The system will stop at u-boot, and change dtb file by below command.
setenv fdtfile imx93-rom2820-a1-m2-sdio.dtb
saveenv
boot
RTENOTITLE
Step 3: Install driver by below command.
modprobe moal mod_para=nxp/wifi_mod_para.conf
RTENOTITLE
Step 4: WIFI test command.
#ifconfig mlan0 up
#wpa_passphrase ${SSID} ${PASSWORD} > /tmp/wpa.conf
#wpa_supplicant -BDwext -imlan0 -c/tmp/wpa.conf
#udhcpc -b -i mlan0
RTENOTITLE
RTENOTITLE
Test Bluetooth with NXP IW-612 Module (UART Interface):
Step 1: Please refer to the 3.3.1 step 1.
Step 2: Please refer to the 3.3.1 step 2.
Step 3: Please refer to the 3.3.1 step 3.
Step 4: Bluetooth test command.
modprobe btnxpuart
hciconfig hci0 up
bluetoothctl
discoverable on
pairable on
scan on
 [NEW] FC:18:3C:8D:75:F4 myphone
scan off
pair FC:18:3C:8D:75:F4
connect FC:18:3C:8D:75:F4
  • Test 4G with EWM-C401CQE01 Module (UART Interface)
Step1 :You need to connect two antennas.
Step2 : Uboot command
  1. setenv fdtfile imx93-rom2820-a1-m2-sdio.dtb
  2. saveenv
  3. reset
Step 2: Install driver by below command.
#modprobe moal mod_para=nxp/wifi_mod_para.conf
 Step3: 4G test command.
# stty -F /dev/ttyUSB1 speed 115200 -echo
# cat /dev/ttyUSB1 &
# echo "AT+CSQ" > /dev/ttyUSB1
Console message:
AT+CSQ
+CSQ: 25,99
OK
# pppd connect 'chat -v -s -t 10 "" "AT" "" "ATDT*99#" "CONNECT" ""' user username password password /dev/ttyUSB2 460800 nodetach crtscts debug usepeerdns defaultroute &
# ping 8.8.8.8
64 bytes from 8.8.8.8: icmp_seq=1 ttl=56 time=222 ms
Serial Port測試方法(Serial Testing Method)(COM A/C)​
RS-232​
  • RS-232 Loopback Test (eg. COMA: ttyLP0):
Step 1:. Connect loopback with COMA(ttyLP4)&COMB(ttyLP5)
Step 2: Run test command.
stty -F /dev/ttyLP4 -echo -onlcr 115200
cat /dev/ttyLP4 &
echo "Serial Port Test" > /dev/ttyLP4
RS-485​
RS-485 Test:
Step 1: Test RS-485 with Adam-4520. Connect Adam-4520 with COMA with DB9 as the following(COMA(ttyLP4)&COMB(ttyLP5))
Adam-4520 RX- ROM-2820 COMA DB9 Pin  1,
Adam-4520 RX+ ROM-2820 COMA DB9 Pin  2,
Adam-4520 TX- ROM-2820 COMB DB9 Pin   1,
Adam-4520 TX+ ROM-2820 COMB DB9 Pin  2
RTENOTITLE
Step 3: Run below command:
stty -F /dev/ttyLP0 speed 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
cat /dev/ttyLP0 &
echo "Serial Test" > /dev/ttyLP0
Step 2 :Create the following file and save it as rs485.sh
#!/bin/sh
i2cset -y -f 4 0x21 0x00 0x10
i2cset -y -f 4 0x21 0x01 0x01
i2cset -y -f 4 0x21 0x02 0xdf
i2cset -y -f 4 0x21 0x03 0xfd
i2cset -y -f 4 0x21 0x04 0x00
i2cset -y -f 4 0x21 0x05 0x00
i2cset -y -f 4 0x21 0x06 0xcf
i2cset -y -f 4 0x21 0x07 0xfc
# sudo chmod 775 rs485.sh
# ./rs485.sh
# stty -F /dev/ttyLP4 -echo -onlcr 115200
# cat /dev/ttyLP4 &
# echo "Serial Port Test" > /dev/ttyLP4
Step 4: You need to open two terminals: one to connect to the debug port of the ROM2820, and the other to connect to the Adam-4520.
Step 5:You can send data from the ROM2820's debug port to the Adam-4520, and you can also input text from the Adam-4520's terminal using the keyboard so that the ROM2820's debug port can receive it.
RTENOTITLE
I2C測試方法(I2C Testing Method)
 Step 1: Test command
i2cdetect -l
i2c-0   i2c             44340000.i2c                            I2C adapter
i2c-1   i2c             44350000.i2c                            I2C adapter
i2c-2   i2c             42530000.i2c                            I2C adapter
i2c-4   i2c             426b0000.i2c                            I2C adapter
i2c-7   i2c             426e0000.i2c                            I2C adapter
RS-422​
RS-422 Test
#!/bin/sh
i2cset -y -f 4 0x21 0x02 0xff
USB測試方法(USB Testing Method)​
USB disk test (USB 2.0)
Step 1:Issue the following command (lsusb -t) after inserting a USB disk into the USB 2.0 port to check if the USB device is listed.
Step 2: Test (eg. if usb disk is /dev/sda)
# dd if=/dev/urandom of=data bs=1 count=1024
# dd if=/dev/sda of=backup bs=1 count=1024 skip=4096 # dd if=data of=/dev/sda bs=1 seek=4096
# dd if=/dev/sda of=data1 bs=1 count=1024 skip=4096 # diff data data1
# dd if=backup of=/dev/sda bs=1 seek=4096
RTC測試方法(RTC Testing Method)​
Step 1: Set system time to current, then write to RTC
root@imx93rom2820a1:~# date 010100002025 && hwclock -w && date
Step 2: Set one incorrect time, then read time from RTC to verify
root@imx93rom2820a1:~# hwclock -r && date
Step 3:  Restore the RTC time to system time
eMMC/SD測使方法(eMMC/SD Testing Method)​
Device Routes
eMMC: /dev/mmcblk0
SD: /dev/mmcblk2
Test (eg. emmc)
Step 1: Test command:
dd if=/dev/mmcblk0 of=backup bs=1 count=1024 skip=4096
dd if=data of=/dev/mmcblk0 bs=1 seek=4096
dd if=/dev/mmcblk0 of=data1 bs=1 count=1024 skip=4096
diff data data1
dd if=backup of=/dev/mmcblk0 bs=1 seek=4096
乙太網路使用方法(Ethernent Testing Method)​
Command : ifconfig
RTENOTITLE
Command: Ping - I eth1 8.8.8.8  or Ping - I eth0 8.8.8.8
RTENOTITLE
GPIO使用方法(GPIO Operating Method)​
GPIO pin:
CPU pin to GPIOGPIO 1101Number
GPIO1(shared pin)1496
GPIO22497
GPIO33498
GPIO44499
GPIO55500
GPIO66501
GPIO77502
GPIO88503
GPIO99504
GPIO1010505
GPIO1111506
GPIO1212507
GPIO loop test:
Connect GPIO pin#3 and GPIO pin#4
root@imx93rom2820a1:/# echo 498 > /sys/class/gpio/export
root@imx93rom2820a1:/# echo 499 > /sys/class/gpio/export
root@imx93rom2820a1:/# echo out > /sys/class/gpio/gpio498/direction
root@imx93rom2820a1:/# echo in > /sys/class/gpio/gpio499/direction
root@imx93rom2820a1:/#cat /sys/class/gpio/gpio498/value
0
root@imx93rom2820a1:/# echo 1 > /sys/class/gpio/gpio498/value
root@imx93rom2820a1:/# cat /sys/class/gpio/gpio498/value
1
RTENOTITLE
Connect GPIO pin#5 and GPIO pin #6
root@imx93rom2820a1:/# echo 500 > /sys/class/gpio/export
root@imx93rom2820a1:/# echo 501 > /sys/class/gpio/export
root@imx93rom2820a1:/# echo out > /sys/class/gpio/gpio500/direction
root@imx93rom2820a1:/# echo in > /sys/class/gpio/gpio501/direction
root@imx93rom2820a1:/# cat /sys/class/gpio/gpio500/value
0
root@imx93rom2820a1:/# echo 1 > /sys/class/gpio/gpio500/value
root@imx93rom2820a1:/# cat /sys/class/gpio/gpio501/value
1
RTENOTITLE
Connect GPIO pin#7 and GPIO pin#8
root@imx93rom2820a1:/# echo 502 > /sys/class/gpio/export
root@imx93rom2820a1:/# echo 503 > /sys/class/gpio/export
root@imx93rom2820a1:/# echo out > /sys/class/gpio/gpio502/direction
root@imx93rom2820a1:/# echo in > /sys/class/gpio/gpio503/direction
root@imx93rom2820a1:/# cat /sys/class/gpio/gpio502/value
0
root@imx93rom2820a1:/# echo 1 > /sys/class/gpio/gpio502/value
root@imx93rom2820a1:/# cat /sys/class/gpio/gpio503/value
1
RTENOTITLE
Connect GPIO pin#9 and GPIO pin#10
root@imx93rom2820a1:/# echo 504 > /sys/class/gpio/export
root@imx93rom2820a1:/# echo 505 > /sys/class/gpio/export
root@imx93rom2820a1:/# echo out > /sys/class/gpio/gpio504/direction
root@imx93rom2820a1:/# echo in > /sys/class/gpio/gpio505/direction
root@imx93rom2820a1:/# cat /sys/class/gpio/gpio504/value
0
root@imx93rom2820a1:/# echo 1 > /sys/class/gpio/gpio504/value
root@imx93rom2820a1:/# cat /sys/class/gpio/gpio505/value
1
RTENOTITLE
Connect GPIO pin#11 and GPIO pin#12
root@imx93rom2820a1:/# echo 506 > /sys/class/gpio/export
root@imx93rom2820a1:/# echo 507 > /sys/class/gpio/export
root@imx93rom2820a1:/# echo out > /sys/class/gpio/gpio506/direction
root@imx93rom2820a1:/# echo in > /sys/class/gpio/gpio507/direction
root@imx93rom2820a1:/# cat /sys/class/gpio/gpio507/value
0
root@imx93rom2820a1:/# echo 1 > /sys/class/gpio/gpio506/value
1
RTENOTITLE
Camera使用方法(Camera Testing Method)​
MIPI-CSI0 (Tested with OV5640 + mini-SAS to MIPI-CSI Cable): OV5640 CSI (CN701): Connect OV5640 camera to EG-55 CAM3
Step 1: Take pictures
gst-launch-1.0 v4l2src num-buffers=1 device=/dev/video0 ! video/x-raw,width=640,height=480 ! jpegenc ! filesink location=sample.jpeg
Step 2: View on panel
PWM測試方法(PWM Testing Method)​
TBD
CAN Bus​
Step 1: Connect can1 and can2
Step 2 Test command
ip link set can0 up type can bitrate 125000
ip link set can1 up type can bitrate 125000
candump can1 &
cansend can0 12345678#123412341234
The following shows the result
can1  12345678   [6]  12 34 12 34 12 34
RTENOTITLE
通用方法(General Method)
查看CPU温度(Check CPU Temperature)​
root@imx93rom2820a1:/home# cat /sys/devices/virtual/thermal/thermal_zone0/temp
39850
查看内存容量(Check Memory Capacity)​
root@imx93rom2820a1:/home# free -h
               total        used        free      shared  buff/cache   available
Mem:           1.9Gi       197Mi       1.6Gi       9.6Mi       215Mi       1.7Gi
Swap:             0B          0B          0B
查看存储容量(Check Storage Capacity)​
root@imx93rom2820a1:/home# df -hT
Filesystem     Type      Size  Used Avail Use% Mounted on
/dev/root      ext4      6.1G  3.5G  2.4G  60% /
devtmpfs       devtmpfs  716M  4.0K  716M   1% /dev
tmpfs          tmpfs     973M     0  973M   0% /dev/shm
tmpfs          tmpfs     390M  9.5M  380M   3% /run
tmpfs          tmpfs     4.0M     0  4.0M   0% /sys/fs/cgroup
tmpfs          tmpfs     973M  4.0K  973M   1% /tmp
tmpfs          tmpfs     973M  196K  973M   1% /var/volatile
/dev/mmcblk0p1 vfat       84M   33M   51M  39% /run/media/boot-mmcblk0p1
tmpfs          tmpfs     195M     0  195M   0% /run/user/0
設置RTC (RTC Setting)
查看系統時間 (Check the system)
root@imx8ulprom2820a1:/# timedatectl
[   41.402592] kauditd_printk_skb: 6 callbacks suppressed
[   41.402611] audit: type=1334 audit(45.332:16): prog-id=15 op=LOAD
[   41.417884] audit: type=1334 audit(45.344:17): prog-id=16 op=LOAD
               Local time: Thu 1970-01-01 00:00:46 UTC
           Universal time: Thu 1970-01-01 00:00:46 UTC
                 RTC time: Thu 1970-01-01 00:00:45            Real-Time Clock,RTC                 Time zone: Universal (UTC, +0000)              Time zone 目前
System clock synchronized: no
              NTP service: active
              RTC in local TZ: no
Note :
Change Time Zone
Local time: Fri 2024-05-03 09:07:42 CST            Universal time: Fri 2024-05-03 01:07:42 UTC                 RTC time: Fri 2024-05-03 09:07:42                 Time zone: Asia/Taipei (CST, +0800) System clock synchronized: yes               NTP service: active               RTC in local TZ: yes
Time Zone List
$ sudo timedatectl list-timezones
Africa/Abidjan
Africa/Accra
Africa/Addis_Ababa
Africa/Algiers
Africa/Asmara
Africa/Bamako
Africa/Bangui
Africa/Banjul
Africa/Bissau
Africa/Blantyre
Africa/Brazzaville
Africa/Bujumbura
Africa/Cairo
Africa/Casablanca
Linux BSP編譯方法(Linux BSP Compile Method)
Yocto 4.2​
Linux BSP編譯方法(Linux BSP Compile Method)​
tip
完整的 BSP 編譯步驟請參考對應 OS 版本的 README:NXP Yocto 4.2 BSP
