← Back to AOM-5521
產品介紹
產品特性(Features)​
NXP i.MX95 Cortex®-A55 AOM-5521 AI-on-Module Nano
  • NXP Arm® Cortex®-A55 i.MX95 Six Cores up to 2.0 GHz
  • 1 x Arm Cortex-M7 core & 1 x Cortex-M33 core
  • Onboard LPDDR5 8 GB, 6400MT/s memory
  • 1 x 4 lane MIPI-DSI (Optional), 1 x Dual channel LVDS, 1 x HDMI
  • 1 x USB3.2 Gen1By1, 4 x USB2.0, 1 x USB 2.0 OTG, 4 x UART,
  • 5 x I2C, 14 x GPIO, 1 x PCIe3.0, 1x10GbE +2x Gb Ethernet (w/TSN), 2 x CAN-FD
  • Neural network accelerator built-in
AOM-5521
接口布局和尺寸(Layout and Sizes)
AOM-5521 接口布局圖 Board Dimension Layout​
AOM-5521_01_
AOM-5521_SW1
SOM-DB2510 接口布局圖 Board Dimension Layout​
SOM-DB2510
SOM-DB2510_IO
主板内置插针式引脚排序方式 (Pin Header defination)​
Internal I/O​
SOM-DB2510_connect1
SOM-DB2510_connect2
LabelFunctionLabelFunction
ATX1ATX ConnectorFAN1Smart Fan Connector
SMARC_IN1Wide Range Input Power Connector (3V~5.25V)FAN2System Fan Connector
DCIN1DCIN connectorCAN0_1CAN Bus Connector
DP0_HDMIDP & HDMI ConnectorUSB0USB OTG Connector
USB12USB 2.0 port1~2 & USB 3.0 port0 ConnectorCOM1_3COM Port Port1,3 Connector
TYPEC_DP1Type-C ConnectorCOM2_4COM Port Port2,4 Connector
LAN0_LAN1LAN0 & LAN1 ConnectorCN8I2C connector for I2C_PM
LOUT1Line Out ConnectorCN7I2C Connector for I2C_GP
MIC1MIC1 ConnectorCN10eSPI Pin Header
CN1_MXM1SMARC ConnectorSATAP1SATA Power Connector
PCIEA-X4PCIe x4 ConnectorCSI0_B2BMIPI B2B Connector for 2M Camera
SATA1SATA Port0 ConnectorCSI1_B2BMIPI B2B Connector for 8M & 13M Camera
PCIED-X1PCIe x1 ConnectorSPI_BIOS1Carrier Board BIOS Socket (SOIC)
M2M.2 Key-E ConnectorBAT1Coin battery holder
MPCIE_CMini PCIe ConnectorBAT2Smart battery Connector
SIMSIM card ConnectorLINEOUT_1I2S Headphone Connector
LVDS1LVDS1 ConnectorMIC_1I2S MIC In Connector
LVDS0LVDS0 ConnectorCSI1_FPCMIPI FPC Connector for 8M & 13M Camera
LVDS1_INVERTERLVDS1 Invertor ConnectorCSI0_FPCMIPI FPC Connector for 2M Camera
LVDS0_INVERTERLVDS0 Invertor ConnectorCN5I2S2 Connector
SPI_BIOS2Carrier Board BIOS Socket (QFN)CN17I2S0 Connector
SDSD Card Connector
Rear I/O​
SOM-DB2510_IO
Jumper 位置( Jumper Locations)​
DB-2510_JumperLocations1
DB-2510_JumperLocations2
LableFunctionLableFunction
BTN3Sleep ButtonJ14EDP1/LVDS1 Hot-Plug Detect Selection Header
BTN1Power ButtonJ56Standby Voltage Control Header
BTN2Reset ButtonJ44Module +3.3V/+5V Power Selection Header
SW4BOOT SELECT SwitchPSON1AT/ATX Selection Header
LID1LID SwitchSPI_CN1SPI Header
J30Enable Battery Low# HeaderCN14For CAN Bus port0 Terminal Resistor
M2E_DISABLE_N1M.2 Wireless DisableCN15For CAN Bus port1 Terminal Resistor
J29SMB Alert Enable HeaderJ3/J4DP0 EQ0 Selection
CN9Header For GPIO TestJ5/J6DP0 EQ1 Selection
J7/J8LVDS0 Power Selection HeaderJ58PCIE_B_CKREQ# Selection
J11/J12LVDS1 Power Selection HeaderJ59PCIE_A_CKREQ# Selection
J9LVDS0 Inverter Power Selection HeadeGPIO_0GPIO0/CAM0_PWR# Selection
J10EDP0/LVDS0 Hot-Plug Detect Selection HeaderGPIO_1GPIO1/CAM1_PWR# Selection
J26HDA/I2S Selection HeaderGPIO_2GPIO2/CAM0_RST# Selection
J1DP1/HDMI1 SelectGPIO_3GPIO3/CAM1_RST# Selection
J13LVDS1 Inverter Power Selection HeaderGPIO_4GPIO4/HDA_RST# Selection
J31Clear CMOS HeaderGPIO_5GPIO5/PWM_OUT Selection
J25SPI Power HeaderGPIO_6GPIO6/TACHIN Selection
SW1COM1 mode SelectSATA_ACT_PH1SATA act# Header
SW2COM3 mode SelectPWRBTN_PH1Power button Header
J41Core Power Voltage Control HeaderSYS_RESET_PH1Reset button Header
J2DDI1 AUX/DDC Selection
LED Function List​
LocationFunction
MODULE_VIN_LED1WDT_TIME_OUT# Indicate
MODULE_5V_LEDModule 5V Indicate
MODULE_VIN_LEDModule +V_MOD_IN Indicate
RESET_OUT_LEDRESET_OUT Indicate
RESET_OUT_LEDCARRIER_STBY Indicate
CARRIER_PWR_ON_LEDCARRIER_PWR_ON Indicate
MODULE_3P3V_LEDModule 3.3V Indicate
3P3V_LEDCarrier Board +V3.3 Indicate
5V_LEDCarrier Board +V5 Indicate
5V_DUAL_LEDCarrier Board +V5SB Indicate
3P3V_DUAL_LEDCarrier Board +V3.3SB Indicate
5VA_LEDCarrier Board +V5D_MOD Indicate
SATA_LEDSATA Indicate
SOM_LEDSOM BOM Indicate
RISC_LEDRISC BOM Indicate
Switch Settings​
  • SW4 (Boot Select / Force Recovery / Test Switches)
  • LID1 (LID Button Enable/Disable Switches)
  • SW5 (LAN CONN LED Pull High Switches)
  • SW1 (COM0 Settings)
  • SW2 (COM2 Settings)
  • SW3 (I2S Clock Settings)
  • M2E_DISABLE_N1 (M.2 Wireless Disable Switch)
接口引脚定義 (Connector Pin definitions)​
  • ATX1 Pin Connector
  • SMARC_IN1 Pin Connectors
  • BAT1 RTC Battery Connectors
  • DCIN1 DC-IN Power Connectors
  • CAN0_1 CAN Bus Connectors
  • CN9 GPIO Headers
  • COM2_4 COM Port2&4 Connectors
  • COM1_3 COM Port1&3 Connectors
  • CN10 ESPI Headers
  • LVDS0 LVDS Connectors
  • LVDS0_INVERTER LVDS INVERTER Connectors
  • LVDS1 LVDS Connectors
  • LVDS1_INVERTER LVDS INVERTER Connectors
  • CN7 I2C_GP Connectors
  • SPI_CN1 SPI Connectors
  • SATAP1 SATA PWR Connectors
  • CSI0_FPC Connectors
  • CSI1_FPC Connectors
  • CN5 I2S2 Connectors
  • CN17 I2S0 Connectors
  • PWRBTN_PH1 PWRBTN Pin Headers
  • SYS_RESET_PH1 SYS RESET Pin Headers
  • SATA_ACT_PH1 SATA ACT# Pin Headers
  • J32 Power LED Pin Headers
  • J30 BATLOW Pin Headers
  • J29 SMBUS Alert Pin Headers
  • J41 Core Power Controls
  • PSON1 ATX/AT Mode Selection
  • J56 Standby Power Controls
  • J44 Module Power Settings
  • J7, J8 LVDS0 Power Selection
  • J9 LVDS0 Inverter Power Selection
  • J11, J12 LVDS1 Power Selection
  • LVDS1 Inverter Power Selection
  • EDP0 / LVDS0 HPD Selection
  • J14 EDP1/LVDS1 HPD Selection
  • CN14 CAN0 Terminal Resistor Selection
  • CN15 CAN1 Terminal Resistor Selection
  • J2 DDI1 AUX/DDC Selection
  • J1 DP1/HDMI1 Selection
  • J58 PCIE_B_CKREQ# Selection
  • J59 PCIE_A_CKREQ# Selection
  • J31 Clear CMOS
  • J25 +V1.8M_SPI Power Jumpers
  • GPIO_0 GPIO0 Settings
  • GPIO_1 GPIO1 Settings
  • GPIO_2 GPIO2 Settings
  • GPIO_3 GPIO3 Settings
  • GPIO_4 GPIO4 Settings
  • GPIO_5 GPIO5 Settings
  • GPIO_6 GPIO6 Settings
  • J26 HDA/I2S Selection
机械尺寸 (Mechanical Characteristics)​
AOM-5521
快速入门 (Quick Start)
系統下載 (OS Download)​
Linux系統 (Linux OS)
Linux 燒錄方法 (Linux Flash eMMC Method)​
使用Flash tool 燒錄鏡像到eMMC (Flash image into eMMC by Flash Tools)
Step0: 檢查SD卡在Linux 環境的代號 (check SD card symbol in Linux system)
AOM-5521_SD_number1
Step1: 創造一張可開機的SD 卡 (Create a bootable SD card)
Command :
$ sudo dd if=5521A1AIM38LIVG0009_iMX95_8G_2025-03-06.img of=/dev/sdf bs=1M conv=fsync status=progress
AOM-5521_SD_dd_image1
Step2: 將可開機的SD 卡插入底板SD卡卡槽(Plug the SD card into Carrier board 's SD card slot)
Step4: 確認開機選擇指撥開關
           SD 卡開機模式: (2, 3:on, others off)
           eMMC 開機模式: (1: on, others off)
SOM-DB2510_SD_switch_setting
Step3:打開電源 和 終端機 (Turn on the Power & Terminal)
AOM-5521_SD_boot1
Step4: 下載flash tools image檔案,並複製到U盤中(Download and copy the flash tool image file, then copy to USB Disk), USB Disk use the exFAT file system for an example.
Step5: 將U盤連接到AOM-5521系統, 解壓縮image檔(Connect USB Disk to the AOM-5521 system, then unzip the flash tool image file)
    解壓縮(Unzip/tar the file), 先設定系統時間(setup system time first), tar解壓縮加入--no-same-owner參數(tar + --no-sam-owner)
# date -s "2025-05-21 16:21:00"
# tar zxf 5521A1AIM38LIVG0009_iMX95_8G_flash_tool.tgz --no-same-owner
AOM-5521_SD_boot2
  1. 將U盤連接到AOM-5521系統, 進入flsah tool下的mk_inand資歷夾, 執行指令./mksd-linux.sh /dev/mmcblk0燒錄image到eMMC(Connect USB Disk to AOM-5521 system, browser to mk_inand folder and execute flash shell script "./mksd-linux.sh /dev/mmcblk0"
如果mk_inand資料夾下沒有mksd-linux.sh檔案, 請到以下連結下載並複製到mk_inand下(Please download the mksd-linux.sh file from the link below if there is no script file in mk_inand deiectory)
Download mksd-linux.sh in <https://github.com/ADVANTECH-Corp/RISC_tools_scripts/blob/mickledore/imx8/mksd-linux.sh>
AOM-5521
SD card/dev/mmcblk1
eMMC/dev/mmcblk0
# ./mksd-linux.sh /dev/mmcblk0
RTENOTITLE
  1. 切換開機switch 1:on 2,3,4,5,6:off來設定成從eMMC開機(Change boot switch to "1:on 2,3,4,5,6:off" to boot from eMMC. Reboot system).
Debug 串口調試 (Debug port Setting)​
Debug port output:
AOM-5521 CPULinux device nodeAOM-5521 golden fingerDB5901DB2510
UART5/dev/ttyLP4SER2CN15B downCOM3
UART1: A core/dev/ttyLP0SER3COM3COM4
UART6/dev/ttyLP5SER0CN15A upCOM1
UART2: M coreSER1COM1COM2
以 Tera Term  为例介绍如何使用串口调试功能
   Baud Rate波特率:115200
Data 数据位:8
Parity 奇偶校验:无
  Stop 停止位:1
Flow Control流控:无
Tera Term Tool
Check the Serial port in Device Manager (查看PC端的串口号):
if you can not identify the Serial device, please check your serial driver.
Debug port connection (串口連接)
SOM-DB2510_Debug_port
Log into Terminal  Tool (进入串口调试终端):
AOM-5521_Login
Linux系统的基本使用(Linux System Basic Operating Method)
UUU 使用方法(USB Connection (OTG port))​
Download uuu tool: Releases · nxp-imx/mfgtools
Inofrmation for uuu: Home · nxp-imx/mfgtools Wiki
Version for tested:
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.182-0-gda3cd53
AOM-5521_uuu1
The “imx-boot-imx95aom5521a1-8G.bin-flash_all” file is included in 5521A1AIM38LIVG0XXX_iMX95_8G_imx-boot.tgz. XXX is the version.
The "imx-image-full-imx95aom5521a1.rootfs.wic" file included in 5521A1AIM38LIVG0XXX_iMX95_8G_flash_tool/tgz.
U-Boot image: imx-boot-imx95aom5521a1-8G.bin-flash_all
Complete Image: imx-image-full-imx95aom5521a1.rootfs.wic
AOM-5521_uuu2
Connect USB cable to USB OTG port.
Change the boot switch to "4:on 1,2,3,5,6:off" to boot from force recovery mode.
Type the command below to flash eMMC:
$ sudo ./uuu_aom5521 -b emmc_all 5521A1AIM38LIVG0009_iMX95_8G_imx-boot/imx-boot-imx95aom5521a1-8G.bin-flash_all 5521A1AIM38LIVG0009_iMX95_8G_flash_tool/image/imx-image-full-imx95aom5521a1.rootfs.wic
AOM-5521_uuu3
Display Setting (ROM-5722)​
Ex:
list dtb files in u-boot:
=> fatls mmc 0
RTENOTITLE
=> setenv fdtfile imx95-aom5521-a1-lvds0-auo.dtb
U-boot Command :
  • Display
    • HDMI (default)
      • imx95-aom5521-a1.dtb
    • LVDS
      • g070vw01(LVDS0)
        • imx95-aom5521-a1-lvds0-auo.dtb
      • g070vw01(LVDS1)
        • imx95-aom5521-a1-lvds1-auo.dtb
      • g215hvn01(DUAL LVDS)
        • imx95-aom5521-a1-lvds-dual.dtb
    • DSI
      • auog101uan02(DSI)
        • imx95-aom5521-a1-auog101uan02.dtb
  • Camera
    • OV5640 (default)
Audio使用方法(Audio Test Method)​
Audio codec (sgtl5000): Connect ROM-EG51 to AUDIO pin header
DB-2520 has two I2S pin heaters CN5 and CN17.
Test on DB2510: CN17
J26: no jumper
SW3: 1:off, 2-on
J50~J53: pin13
Check audio codec:
# cat /proc/asound/cards
AOM-5521_AUDIO1
Set MIC and headphones: The sgtl5000 is card 1:
# amixer -c 1 set Mic 50%
# amixer -c 1 set Headphone 80%
# amixer -c 1 set Lineout unmute
# amixer -c 1 set Lineout 80%
# amixer -c 1 set PCM 100%
AOM-5521_AUDIO2
Record and playback:
# arecord –D plughw:1,0 -t wav -c 2 -r 44100 -d 10 /tmp/mic.wav
AOM-5521_AUDIO3
# aplay -D plughw:1,0 /tmp/mic.wav
AOM-5521_AUDIO4
乙太網路使用方法(Ethernent Testing Method)​
Command: ifconfig
Command: Ping - I eth1 8.8.8.8  or Ping - I eth0 8.8.8.8
AOM-5521_eth0
AOM-5521_eth1
10 G:
AOM-5521_10G
AOM-5521_10G1
WiFi使用方法(WIFI Testing Method)​
Test with AIW-167(M.2): Switch SOM-DB2510 J15~J21 to 1 and 2.
AOM-5521_WiFi
Load dtb file in u-boot:
=> setenv fdtfile imx95-aom5521-a1-m2-sdio.dtb; boot
Install Driver:
# modprobe moal mod_para=nxp/wifi_mod_para.conf
# modprobe btnxpuart
AOM-5521_WiFi3
AOM-5521_WiFi4
WiFi Test:
AP PW: xxxxxxxx
# ifconfig mlan0 up
# wpa_passphrase ASUS_RISC_SOM_ESBC_2.4 xxxxxxxx > /tmp/wpa.conf && wpa_supplicant -d -B -i mlan0 -c /tmp/wpa.conf
# udhcpc -b -i mlan0
# ping 8.8.8.8
AOM-5521_WiFi5
AOM-5521_WiFi6
AOM-5521_WiFi7
AOM-5521_WiFi8
AOM-5521_WiFi9
藍芽使用方法(Bluetooth Operating Method)​
Test AIW-167 BT: Follow the above WiFi test to install the driver and run the BT test.
BT Test:
# hciconfig hci0 up
# bluetoothctl
# discoverable on
# pairable on
# scan on
AOM-5521_BT1
AOM-5521_BT2
AOM-5521_BT3
Device 84:C5:A6:D3:AF:E4 NB090726
scan off
pair 84:C5:A6:D3:AF:E4
AOM-5521_BT4
# connect 84:C5:A6:D3:AF:E4
AOM-5521_BT5
4G使用方法(4G Testing Method)​
Test with AIW-344(Full-size mPCIe USB interface): Connect to PCIe x4 slot and mini USB to TypeA
Test by MBIM mode:
Enable AIW-344 module MBIM mode:
# echo -e "AT+GTUSBMODE=29\r" > /dev/ttyUSB1
# systemctl stop connman
# systemctl disable connman
(System Reboot)
AOM-5521_4G1
Install driver and confige mbim network:
# modprobe cdc_mbim
# vi /etc/mbim-network.conf
# 'APN' can config for different telecommunication providers
APN=internet
APN_USER
APN_PASS
APN_AUTH
PROXY=yes
AOM-5521_4G2
# mbimcli -d /dev/cdc-wdm0 -p --query-connection-state
# mbimcli -d /dev/cdc-wdm0 -p --query-subscriber-ready-status
# mbimcli -d /dev/cdc-wdm0 -p --set-radio-state=on
AOM-5521_4G3
If you need to auth by PIN (If necessary): This step is not necessary
# mbimcli -d /dev/cdc-wdm0 -p --enter-pin=0000
# mbim-network /dev/cdc-wdm0 start
AOM-5521_4G4
Query the IP addr information:
# mbimcli -d /dev/cdc-wdm0 -p --query-ip-configuration
AOM-5521_4G5
Reference the above query result for IP configuration to set up:
# ifconfig wwan0 up
# sudo ip addr add 10.75.191.149/30 dev wwan0
# sudo ip route add default via 10.75.191.150
# sudo sh -c 'echo "nameserver 168.95.1.1" > /etc/resolv.conf'
# sudo sh -c 'echo "nameserver 168.95.192.1" >> /etc/resolv.conf'
$ sudo ip link set dev wwan0 mtu 1500
Test Ping:
# ping 8.8.8.8 -I wwan0
AOM-5521_4G7
GPIO使用方法(GPIO Operating Method)​
GPIO pin:
SMARC Pin#SMARC Pin NameCPU Ball NameKernel GPIODefault Direction
p108GPIO0GPIO_IO12__GPIO2_IO_BIT12524
p109GPIO1SD3_CLK__GPIO3_IO_BIT20GPIO1_CAM1_PWR#
p110GPIO2SD3_CMD__GPIO3_IO_BIT21565
p111GPIO3SD3_DATA0__GPIO3_IO_BIT22GPIO3_CAM1_RST#
p112GPIO4SD3_DATA1__GPIO3_IO_BIT23567
p113GPIO5GPIO_IO16__GPIO2_IO_BIT16528
p114GPIO6SD3_DATA2__GPIO3_IO_BIT24568
p115GPIO7SD3_DATA3__GPIO3_IO_BIT25569
p116GPIO8PCA6416_P0_5653
p117GPIO9PCA6416_P0_4652
p118GPIO10PCA6416_P0_3651
p119GPIO11PCA6416_P0_2650
s142GPIO12PCA6416_P0_1649
s123GPIO13PCA6416_P0_0648
Loop-back Test (Take GPIO0 and GPIO2 as examples)
Step 1: Connect GPIO0 and GPIO2, change GPIO_0 and GPIO_2 to pin 12
Step 2: Export GPIO interface
root@imx95aom5521a1: ~# echo 524 > /sys/class/gpio/export
root@imx95aom5521a1: ~# echo 565 > /sys/class/gpio/export
Step 3: Set direction
root@imx95aom5521a1: ~# echo out > /sys/class/gpio/gpio1/direction
root@imx95aom5521a1: ~# echo in > /sys/class/gpio/gpio2/direction
Step 4: Read value and set output value then check
root@imx95aom5521a1: ~# cat /sys/class/gpio/gpio2/value
0
root@imx95aom5521a1: ~# echo 1 > /sys/class/gpio/gpio1/value
1
Watch Dog測試方法(Watch Dog Test Method)​
System will reboot after 3 sec:
# /unit_tests/Watchdog/wdt_driver_test.out 1 2 0
AOM-5521_WDT1
Timeout 10s:
System will not reboot. Watchdog can be refreshed when feed dog before it timeout.
# /unit_tests/Watchdog/wdt_driver_test.out 10 1 0
  1. Ctrl + C ==> System will reboot after 10 sec. Watchdog does not refresh after it timeout.
AOM-5521_WDT2
Timeout 60s:
# /unit_tests/Watchdog/wdt_driver_test.out 60 1 0
AOM-5521_WDT3
串口使用方法(Serial Port Operating Method)​
RS-232 Test
CN15上(SER0/UART6): /dev/ttyLP5
CN15下(SER2/UART5): /dev/ttyLP4
DB2510 COM4  (A core debug/SER3/UART1): /dev/ttyLP0
DB2510 COM1 (M core debug/SER1/UART2):
SW7 Setting (SW7設置)
MODE1  MODE0
    0            0            LOOPBACK
    0            1            RS232
    1            0            RS485
    1            1            RS422
Loopback test (eg. ttymxc0)
Connect loopback test tool
  1. stty ‐F /dev/ttyLP4 115200
    stty ‐F /dev/ttyLP4 ‐echo
    cat /dev/ttyLP4 &
    echo test > /dev/ttyLP4
I2C測試方法(I2C Test Method)​
I2C test: Check I2C device
(0x50 EEPROM on module)
# i2cdetect -y 1
AOM-5521_I2C1
Write/Read/Verify eeprom Hi/Low byte
# modprobe at24
# echo "ADVANTECH" > test
# dd if=test of=/sys/bus/i2c/devices/1-0050/eeprom
# hexdump -C /sys/bus/i2c/devices/1-0050/eeprom -n 64
AOM-5521_I2C2
RTC測試方法(RTC Test Method)​
Disable RTC sync service:
# systemctl stop systemd-timesyncd
# systemctl disable systemd-timesyncd
AOM-5521_RTC1
Set system time to current, then write to RTC:
# date 021710452022 && hwclock -w && date
AOM-5521_RTC2
Set one incorrect time, then read time from RTC to verify:
# date 010100002000 && hwclock -r && date
AOM-5521_RTC3
Set the system time from the RTC:
# hwclock -s && date
AOM-5521_RTC4
Store into RTC and check RTC current status:
# hwclock -w -f /dev/rtc0
# hwclock -v -f /dev/rtc0
AOM-5521_RTC5
Enable RTC sync service:
# systemctl enable systemd-timesyncd
# systemctl start systemd-timesyncd
AOM-5521_RTC6
TPM使用方法(TPM Test Method)​
Generate Random code
# tpm2_getrandom --hex 20
AOM-5521_TPM1
Crypt msg.dat file
# tpm2_createprimary -C p -c platform_primary.ctx
# tpm2_create -C platform_primary.ctx -G rsa2048 -u key.pub -r key.priv
# tpm2_load -C platform_primary.ctx -u key.pub -r key.priv -c key.ctx
# echo "my test" >msg.dat
# tpm2_rsaencrypt -c key.ctx -o msg.enc msg.dat
# tpm2_rsadecrypt -c key.ctx -o msg.ptext msg.enc
AOM-5521_TPM2
AOM-5521_TPM3
AOM-5521_TPM4
AOM-5521_TPM5
AOM-5521_TPM6
AOM-5521_TPM7
# cat msg.ptext
# cat msg.dat
AOM-5521_TPM8
Store data to TPM
# nv_test_index=0x1500031
# tpm2_nvdefine -Q 0x1500031 -C o -s 32 -a "ownerread|policywrite|ownerwrite"
# echo "write_tpm_adv" > adv.data
# tpm2_nvwrite -Q 0x1500031 -C o -i adv.data
# tpm2_nvread -Q 0x1500031 -C o -s 32 -o read.data
# cat read.data
AOM-5521_TPM9
AOM-5521_TPM10
Check TPM store area
# tpm2_nvreadpublic > nv.out
# cat nv.out
AOM-5521_TPM11
AOM-5521_TPM12
SPI BUS功能測試(SPI BUS Function Test)​
Storage information:
eMMC:    /dev/mmcblk0
SD:        /dev/mmcblk1
QSPI1:    /dev/mtd0
SPI0_0:  /dev/mtd1
SPI0_1:  /dev/mtd2
SPI1_0:  /dev/mtd3
SPI1_1:  /dev/mtd4
QSPIA (On the SMARC module)
# echo -n $'\x06\x05\x04\x03\x02\x01' > test
# dd if=test of=/dev/mtd0
# hexdump -C /dev/mtd0 -n 64
AOM-5521_SPI1
SPI0 test: flash (Winboan 25q64) function:
Place SPI flash to SPI_BIOS1:
J46, J47, J48: pin12
J24: pin 12
(/dev/mtd1)
AOM-5521_SPI2
Dump SPI content:
# dd if=test of=/dev/mtd1
# hexdump -C /dev/mtd1 -n 64
AOM-5521_SPI3
SPI1(ESPI)(CN10) test: flash (Winboan 25q64) function:
(/dev/mtd2)
AOM-5521_SPI4
Dump SPI content:
# dd if=test of=/dev/mtd2
# hexdump -C /dev/mtd2 -n 64
or
# dd if=/dev/mtdblock2 bs=1 count=100 | hexdump -C
AOM-5521_SPI5
SPI_CN1: Test with ROM-EG70
(Need to rework U62 +V_SPI to +V3.3 for ROM-EG70)
(There are two SPI NOR flash on ROM-EG70)
AOM-5521_SPI6
Dump SPI content:
# echo -n $'\x03\x03\x10\x10\x20\x25' > test
# dd if=test of=/dev/mtdblock1
or
# dd if=/dev/mtdblock1 bs=1 count=100 | hexdump –C
mtdblock1:
AOM-5521_SPI7
mtdblock2:
AOM-5521_SPI8
CANBUS功能測試(CABBUS Test Method)​
Connect: CAN0_R_D- to CAN1_R_D- and CAN0_R_D+ to CAN1_R_D+
CAN0_R_D-: pin3
CAN0_R_D+: pin4
CAN1_R_D-: ping13
CAN1_R_D+: ping14
Set can0 and can1 up:
Check CAN driver
# zcat /proc/config.gz | grep FLEXCAN
AOM-5521_CANBUS1
# ip link set can0 up type can bitrate 12500
# ifconfig can0 up
# ip link set can1 up type can bitrate 12500
# ifconfig can1 up
(candump can0/1)(cansend can0/1)
# candump can0 & candump can1 &
# cansend can0 1F334455#1122334455667788
# cansend can1 1F334455#1122334455667788
AOM-5521_CANBUS2
CAN FD:
# ip link set can0 up type can bitrate 1000000 dbitrate 8000000 fd on
# ip link set can1 up type can bitrate 1000000 dbitrate 8000000 fd on
# ifconfig can0 up
# ifconfig can1 up
# cansend can0 123##300112233445566778899aabbccddeeff
# cansend can1 123##300112233445566778899aabbccddeeff
AOM-5521_CANBUS3
MIPI CS功能測試(MIPI CSI Test Method)​
AOM-5521 to DB-2510
CSI1: CSI1_FPC(4 lane)
CSI2: CSI0_FPC(2 lane): Not support
Preview(CSI1_FPC):
Connect OV5640 camera to EG-55 CAM2
Connect EG-55 to DB-2510 CSI1_FPC(video0)
OV5640 setup:
# media-ctl -l "'ov5640 2-003c':0 ->'csidev-4ad30000.csi':0 [1]"
# media-ctl -V "'ov5640 2-003c':0 [fmt: UYVY8_1X16/1920x1080 field:none]"
# media-ctl -V "'csidev-4ad30000.csi':0 [fmt: UYVY8_1X16/1920x1080 field:none]"
# media-ctl -V "'crossbar':2 [fmt: UYVY8_1X16/1920x1080 field:none]"
# media-ctl -V "'mxc_isi.0':0 [fmt: UYVY8_1X16/1920x1080 field:none]"
# media-ctl -V "'mxc_isi.2':0 [fmt: UYVY8_1X16/1920x1080 field:none]"
# media-ctl -V "'mxc_isi.3':0 [fmt: UYVY8_1X16/1920x1080 field:none]"
# media-ctl -V "'mxc_isi.4':0 [fmt: UYVY8_1X16/1920x1080 field:none]"
# media-ctl -V "'mxc_isi.5':0 [fmt: UYVY8_1X16/1920x1080 field:none]"
# media-ctl -V "'mxc_isi.6':0 [fmt: UYVY8_1X16/1920x1080 field:none]"
# media-ctl -V "'mxc_isi.7':0 [fmt: UYVY8_1X16/1920x1080 field:none]"
OV5640 Preview:
# gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1920,height=1080' ! autovideosink
(Check the HDMI can preview the image)
遠程訪問及文件傳輸(Remote Access and File Transimmion)
**查看主板IP位址 ( Chech IP Address ):**​
        Command: ifconfig
Windows下SSH访问及文件传输​
SSH Remote Log into Device
  • SSH远程登录,以putty选择putty.exe(或者使用Xshell、SecureCRT等类似软件)
  • 需要设置远程设备的IP、通讯端口(默认22)、通讯方式,登录后验证用户名密码
RTENOTITLE
通用方法(General Method)
查看CPU温度(Check CPU Temperature)​
    # cat /sys/devices/virtual/thermal/thermal_zone*/temp
# 或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 45°
查看CPU频率(Check CPU Frequency)​
           # cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq
>> 500000
# cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_max_freq
>> 1800000
查看内存容量(Check Memory Capacity)​
root@imx95aom5521a1:~# free -h
               total        used        free      shared  buff/cache   available
Mem:           7.5Gi       431Mi       7.1Gi        13Mi       151Mi       7.1Gi
Swap:             0B          0B          0B
查看存储容量(Check Storage Capacity)​
root@imx95aom5521a1:~# df -hT
Filesystem     Type      Size  Used Avail Use% Mounted on
/dev/root      ext4       15G  5.4G  8.0G  41% /
devtmpfs       devtmpfs  3.3G  4.0K  3.3G   1% /dev
tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
tmpfs          tmpfs     1.6G   11M  1.5G   1% /run
tmpfs          tmpfs     3.8G   12K  3.8G   1% /tmp
tmpfs          tmpfs     3.8G  260K  3.8G   1% /var/volatile
/dev/mmcblk0p1 vfat       84M   37M   47M  45% /run/media/boot-mmcblk0p1
/dev/mmcblk1p1 vfat       84M   37M   47M  45% /run/media/boot-mmcblk1p1
tmpfs          tmpfs     769M  8.0K  769M   1% /run/user/0
/dev/mmcblk1p2 ext4       15G  5.4G  8.1G  41% /run/media/root-mmcblk1p2
網路Ping測試(Ping Network Testing)​
     ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
設置RTC (RTC Setting)​
root@imx8mprom5722a1:~# systemctl stop ntpdate.service
root@imx8mprom5722a1:~# date 090816072021 && hwclock -w && date
Wed Sep  8 16:07:00 UTC 2021
Tue Nov 23 07:38:50 UTC 2021
Tue Nov 23 07:38:56 UTC 2021
Add Patch in linux-imx_6.1.bb file
SRC_URI:append:imx8qmrom5722a1 += " file://panel_gpi4.patch"
Linux BSP編譯方法(Linux BSP Compile Method)
tip
完整的 BSP 編譯步驟請參考對應 OS 版本的 README:
Build known issue​
如果有驗證上的錯誤 請使用以下的方法
### repo sync failed with Server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none ERROR: gstreamer1.0-1.14.4.imx-r0 do_unpack: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/hom e/adv/adv-release-bsp/build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/usr/bin/py thon3-native:/home/adv/adv-release-bsp/sources/poky/scripts:/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-poky-l inux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/usr/bin/aarch64-poky-linux:/home/adv/adv-release-bsp/build_x11/tm p/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot/usr/bin/crossscripts:/home/adv/adv-release-bsp/buil d_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/usr/sbin:/home/adv/adv-release-bsp/b uild_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/usr/bin:/home/adv/adv-release-bsp /build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/sbin:/home/adv/adv-release-bsp/ build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/recipe-sysroot-native/bin:/home/adv/adv-release-bsp/so urces/poky/bitbake/bin:/home/adv/adv-release-bsp/build_x11/tmp/hosttools"; export HOME="/home/adv"; git -c core.fsyncob jectfiles=0 submodule update --init --recursive failed with exit code 1, output:
Submodule 'common' (
<https://anongit.freedesktop.org/git/gstreamer/common.git)> registered for path 'common'
Cloning into '/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/git/common'...
fatal: unable to access '
<https://anongit.freedesktop.org/git/gstreamer/common.git/':> server certificate verification fa iled. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
fatal: clone of '
<https://anongit.freedesktop.org/git/gstreamer/common.git'> into submodule path '/home/adv/adv-release-b sp/build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14.4.imx-r0/git/common' failed
Failed to clone 'common'. Retry scheduled
fatal: clone of '
Failed to clone 'common' a second time, aborting
ERROR: gstreamer1.0-1.14.4.imx-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-poky-linux/gstreamer1.0/1.14. 4.imx-r0/temp/log.do_unpack.42631
ERROR: Task (/home/adv/adv-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer 1.0_1.14.imx.bb:do_unpack) failed with exit code '1'
ERROR: gstreamer1.0-plugins-base-1.14.4.imx-r0 do_unpack: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; expo rt PATH="/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/ recipe-sysroot-native/usr/bin/python3-native:/home/adv/adv-release-bsp/sources/poky/scripts:/home/adv/adv-release-bsp/b uild_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/recipe-sysroot-native/usr/bin/aarch6 4-poky-linux:/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx -r0/recipe-sysroot/usr/bin/crossscripts:/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer 1.0-plugins-base/1.14.4.imx-r0/recipe-sysroot-native/usr/sbin:/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8m m-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/recipe-sysroot-native/usr/bin:/home/adv/adv-release-bsp/build_x11/ tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/recipe-sysroot-native/sbin:/home/adv/adv-rele ase-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/recipe-sysroot-native/bin:/ home/adv/adv-release-bsp/sources/poky/bitbake/bin:/home/adv/adv-release-bsp/build_x11/tmp/hosttools"; export HOME="/hom e/adv"; git -c core.fsyncobjectfiles=0 submodule update --init --recursive failed with exit code 1, output:
Cloning into '/home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.im x-r0/git/common'...
fatal: clone of '
<https://anongit.freedesktop.org/git/gstreamer/common.git'> into submodule path '/home/adv/adv-release-b sp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0-plugins-base/1.14.4.imx-r0/git/common' failed
fatal: clone of '
ERROR: gstreamer1.0-plugins-base-1.14.4.imx-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/adv/adv-release-bsp/build_x11/tmp/work/aarch64-mx8mm-poky-linux/gstreamer1.0 -plugins-base/1.14.4.imx-r0/temp/log.do_unpack.51633
ERROR: Task (/home/adv/adv-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/gstreamer/gstreamer 1.0-plugins-base_1.14.imx.bb:do_unpack) failed with exit code '1'
nnshark error
<https://community.nxp.com/t5/i-MX-Processors/Yocto-3-3-5-10-72-BSP-Build-Fail/m-p/1487902>
