ROM-5780 Debian9 User Guide
← Back to ROM-5780
產品介紹(Product introduction )​
產品特性(Product Features)​
  • Rockchip RK3399 Arm dual Cortex-A72 and quad Cortex-A53 1.8 GHz
  • Onboard 2GB LPDDR4 memory and 16GB eMMC
  • Support HDMI2.0 4K 60fps, 1x DP, 1x eDP, 1 x LVDS
  • Support 4K H.264/H.265 Video decoder
  • 2 x USB3.0, 3 x USB2.0,1 x USB2,0 OTG, 3 x UART, 12 x GPIO
  • 1 x PCIe2.0, 1 x SATA, 1 x 4-lane MIPI CSI, Gigabit LAN
  • Support Debian Linux and Android
ROM-5780
接口布局和尺寸(Layout and Sizes)​
ROM-5780 接口布局圖 Board Dimension Layout​
RTENOTITLE
Board Connectors​
The board has one switch that allows you to configure your system.
RTENOTITLE
Connector List​
Switch
PositionDescription
SW1UART & Debug Port selection
SW2AT& ATX mode selection
SW1: UART & Debug Port Selection
SettingFunction
SW1(2-3)Normal UART
SW1(2-1)Debug Console (Default)
SW2: AT/ATX Mode Selection
SettingFunction
SW2(2-3)AT Mode (Default)
SW2(2-1)ATX Mode
ROM-DB5901 接口布局圖 Board Dimension Layout​
RTENOTITLE
RTENOTITLE
主板内置插针式引脚排序方式 (Pin Header defination)​
Internal I/O​
RTENOTITLE
PositionDescriptionConnector Type
BAT1PIN Header for BatteryWAFER 8P 2.54mm 180D(M) DIP A2543WV2-8P
BH1RTC Battery HolderBATTERY HOLDER 24.9*23.4*8.9 CR2032 BH800.4GG
CAN1CANBus Port 1BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
CAN2CANBus Port 2BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
COM1COM Port 1BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
COM3COM Port 3 (Debug Port)BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10
CN4PCIex1 Connector 1PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF
CN5PCIex1 Connector 2PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF
CN6PCIex1 Connector 3PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF
CN11SATA ConnectorSerial ATA 7P 1.27mm 180D(M) DIP WATM-07DBN4A3B8
CN12SATA Power ConnectorWAFER 4P 2.5mm 180D(M) DIP 24W1161-04S10-01T
CN22GPIOx8 setsPIN HEADER 10x2P 2.0mm 180D(M) DIP 21N22050
CN25MXM 3.0 ConnectorMXM Conn. 314P 90D(F) SMD AS0B821-S78B-7H
CN26M.2 Key E SlotsNGFF 75P 0.5mm 90D(F) H=4.2mm SMD AS0BC21-S40BE
CN38FAN (Reserved)WTB Con. 3P 2.54mm 180D(M) DIP A2543WV0-3P-6T-5e
CN39MIPI-CSI1 (FPC, 4-LaneFPC 39P, 0.6mm, H0.9mm
CN40MIPI-CSI0 (FPC, 2-Lane)FPC 39P, 0.6mm, H0.9mm
CN41MIPI-CSI0 (Mini-SAS, 2-Lane)Mini SAS 36P/0.8mm/(M)/LCP/VA/G15u/ S/BK/W
CN42MIPI-CSI1 (Mini-SAS, 4-Lane)Mini SAS 36P/0.8mm/(M)/LCP/VA/G15u/ S/BK/W
ESPI_CN1ESPIPIN HEADER 6x2P 2.0mm180D(M) SMD 21N22050-12M00B
I2C_GP_1I2C Pin HeaderWAFER BOX 4P 2.00mm 180D(M) DIP 721-81-04TW00
I2C_CN3Audio Codec BoardPIN HEADER 2x10P 2.54mm 180D(M) DIP 21N22564
LVDS0LVDS0Wafer 2x20P/1.25mm/(M)/NY9T/VA/GFL/ S/WH/W
LVDS_BK_PWRLVDS0 Back LightWAFER BOX 5P 2.0mm 180D(M) DIP A2001WV2-5P
LVDS1LVDS1Wafer 2x20P/1.25mm/(M)/NY9T/VA/GFL/ S/WH/W
LVDS1_BK_PWRLVDS1 Back LightWAFER BOX 5P 2.0mm 180D(M) DIP A2001WV2-5P
SD1SD Card SlotSD CARD 9P 90D(F) SMD WK2192CS3D- 7H
SPI_CN1SPI Pin HeaderPIN HEADER 4x2P 2.54mm 180D(M) SMD 21N22564
SW2Reset ButtonTACT SW STS-091 SMD 4P H=3.8mm
SW4SLP ButtonTACT SW STS-091 SMD 4P H=3.8mm
SW5Power ButtonTACT SW STS-091 SMD 4P H=3.8mm
USB0_OTG1USB OTGMicro USB 5P/0.65mm/(F)/NY9T/GFL/ RA/S/BK/B
USB-4-5USB Port 4, Port 5PIN HEADER 2x5P 2.0mm 180D(M) SMD 21N22050
Rear I/O​
RTENOTITLE
PositionDescriptionName
DCINDC JackA
CN15AUART Port 0B
CN15BUART Port 2C
CN1ADP PortD
CN1BHDMI PortE
CN33Type C Controller Programming Header (Reserved Only)F
CN34USB Type CG
CN8GbE Ethernet Connector PortH
CN3USB Port 1/ 2I
Audio1MIC Input/ Audio OutputJ
**机械尺寸 (**Mechanical Characteristics)​
  • Dimensions: SMARC form factor size: (D x W) 82 x 50 mm/ 3.22 x 1.9 in
  • Height on Top: Under 3.0 mm base on SPEC definition (without heat sink)
  • Height on Bottom: Under 1.3 mm base on SPEC definition
RTENOTITLE
RTENOTITLE
快速入门 (Quick Start)​
系统下载 (OS Download)​
Note:  LIV=Yocto Linux, UIV=Ubuntu, DIV=Debian, AIV=Android
             LBV=BSP, LIV=Image
PlatformProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagComment
RK3399ROM-5780DIV100342021/01/22RTMRelease_noteBaidu      Password:a887 DropboxRK3399_RISC_DIV10034.xml
  • Alpha:  Basic I/O function bring up by RD;
  • Beta:  Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
  • GA:  Beta version by QE verification;
  • RTM:  Beta version by SI/Power/QE verification and pre-loaded;
DS-100
  • Linux BSP User Guide for rk3399 series Debian9
  • Linux BSP User Guide for rk3399 series DeviceOn
  • Linux BSP User Guide for SGI [DMS-SA53]
Linux 燒錄方法 (Linux Flash eMMC Method)​
  • Linux BSP User Guide for rk3399 series Debian9/Debian10
  • Getting Start
  • MAC_Address
  • Qt5Creator
  • Qt5Creator_toolchain_Qt_5.11.3
Debug 串口調試 (Debug port Setting)​
以 Tera Term 为例介绍如何使用串口调试功能
   Baud Rate波特率:115200
Data 数据位:8
Parity 奇偶校验:无
  Stop 停止位:1
Flow Control流控:无
Tera Term Tool
RTENOTITLE
RTENOTITLE
Check the Sriel port in Device Manager (查看PC端的串口号):
if you can not identify the Serial device , please check your serial driver.
RTENOTITLE
Debug port connection (串口連接)
RTENOTITLE
Log into Terminal Tool (进入串口调试终端):
Linux系统的基本使用(Linux System Basic Operating Method)​
Display Setting (ROM-5780)​
乙太網路使用方法(Ethernent Testing Method)​
Command : ifconfig
Command: Ping - I eth1 8.8.8.8 or Ping - I eth0 8.8.8.8
WiFi使用方法(WIFI Testing Method)​
Command :
# killall wpa_supplicant
# ifconfig wlan0 up
# wpa_passphrase "SSID" "PASSWORD" > /tmp/wpa.conf
# wpa_supplicant -BDwext -iwlan0 -c/tmp/wpa.conf
# udhcpc -b -i wlan0'''
ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
RTENOTITLE
4G使用方法(4G Testing Method)​
Command:
Test 4G: (EWM-C117FL06E - USB)
Step 1: Connect EWM-C117FL06E to Mini PCIE slot on 9680015491 and connect
the card to CN6 PCIe_D slot on ROM-DB5901.
Step 2: Connect the antenna 1750007990-01 to the SMA (F) connector on
9680015491
and connect the IPEX connector to MT1 on EWM-C117FL06E module.
Step 3: Connect the Mini USB cable from 9680015491 to USB 2.0 Type A port on
ROM-DB5901.
Step 4: Power on and execute the pppd command to connect to the network.
RTENOTITLE
RTENOTITLE
串口使用方法(Serial Port Operating Method)​
RS-232 Test
SER1_UART2: /dev/ttyLP2: COM1
SER3_UART0: /dev/ttyLP0: COM3
SW6/7 Setting (SW6/7設置)
RS232: 1:on 2:off
RS422: 1:on 2:on
RS485: 1:off 2:on
RTENOTITLE
COM0 (CN15A): UART1 test
Loopback Test (eg. ttyLP1)
UART 1: Change SW7 jumper to switch modes. (1ON 2OFF: RS-232)
UART 1: Change CN27~CN30 jumper to (1-2 short)
# stty -F /dev/ttyLP1 -echo -onlcr 115200
# cat /dev/ttyLP1 &
# echo test > /dev/ttyLP1
蓝牙使用方法(BlueTooth Operating Method)​
Command :
$ hciconfig hci0 up
$ bluetoothctl
$ discoverable on
$ pairable on
$ scan on
[NEW] FC:18:3C:8D:75:F4 myphone
$ scan off
$ pair FC:18:3C:8D:75:F4
$ connect FC:18:3C:8D:75:F4
RTENOTITLE
遠程訪問及文件傳輸(Remote Access and File Transimmion)​
**查看主板IP位址 ( Chech IP Address ):**​
        Command : ifconfig
Windows下SSH访问及文件传输​
SSH Remote Log into Device
  • SSH远程登录,以putty选择putty.exe(或者使用Xshell、SecureCRT等类似软件)
  • 需要设置远程设备的IP、通讯端口(默认22)、通讯方式,登录后验证用户名密码
RTENOTITLE
RTENOTITLE
RTENOTITLE
通用方法(General Method)​
查看CPU温度(Check CPU Temperature)​
     /# cat /sys/devices/virtual/thermal/thermal_zone0/temp 44600
# 或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 45°
查看CPU频率(Check CPU Frequency)​
           cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
>> 900000
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
>> 1200000
读取DDR频率(Read DDR frequency)​
# cat /sys/class/devfreq/dmc/cur_freq
856000000
查看存储容量(Check Storage Capacity)​
網路Ping測試(Ping Network Testing)​
     ping 8.8.8.8
設置RTC (RTC Setting)​
Linux BSP編譯方法(Linux BSP Compile Method)​
Debian 9​
如果有驗證上的錯誤 請使用以下的方法​
**### repo sync failed with Server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
export GIT_SSL_NO_VERIFY=1
#or
git config --global http.sslverify false
