AOM-2721 Windows on Arm Release Note
Contents
- 1Release Version
- 2Known Issue 2.11.0.1 2.20.9.0
Release Version
| Product | Release Version | Windows Edition & Version | Image Version | Release Date |
| AOM-2721 | RTM | Windows 11 IoT Enterprise LTSC 24H2 | 1.0.1 | 2025/08/21 |
| AOM-2721 | Beta | Windows 11 IoT Enterprise LTSC 24H2 | 0.9.0 | 2025/05/08 |
Note: Due to licensing restrictions, we are unable to provide the Windows image for direct download. Please contact our representative for further assistance.
Known Issue
1.0.1
- [AOM-2721][Win 11] The audio select dialog may flicker sometimes.
- [AOM-2721][Win 11] Camera enable may fail sometime and need to reflash to recover.
- [AOM-2721][Win 11] After inserting the 5G card, some monitors may need to replug HDMI to display.
- [AOM-2721][Win 11] TPM is not enabled. TPM is one-time programmable, so it is not recommended to enable it casually.
- [AOM-2721][Win 11] The LAN LED light behavior is different from usual.
- [AOM-2721][Win 11] UART stress test shows few transmission errors.
- [AOM-2721][Win 11] Three kernel-PnP warning messages appear in the System section of Windows Logs in Event Viewer.
- [AOM-2721][Win 11] Two error messages related to luafv and l1vhlwf services appear in the System section of Windows Logs in Event Viewer.
- [AOM-2721][Win 11] A warning message for DistributedCOM appears in the System section of Windows Logs in Event Viewer.
- [AOM-2721][Win 11] A warning message for Disk 1 appears in the System section of Windows Logs in Event Viewer.
- [AOM-2721][Win 11] When clicking the system's Hibernate option and then waking it up, the system performs a full reboot instead of resuming from hibernation.
- [AOM-2721][Win 11] The hardware has only one physical SIM card slot, but the OS displays two SIM cards available for use
- [AOM-2721][Win 11] Click 'Create a system repair disc' within Backup and Restore (Windows 7), after which the system shows no response
- [AOM-2721][Win 11] After S0 low-power idle wake-up, DHCP fails with IP 169.254.15.179. Network cable reconnection required to restore normal configuration
0.9.0
- [AOM-2721][win 11] HDMI output is being used for the display, but no HDMI Audio output option appears in the Audio menu
- [AOM-2721][win 11] TPM drivers show yellow exclamation marks in Device Manager
- [AOM-2721][win 11] There are only two selectable HDMI resolution settings, too few options available.
- [AOM-2721][win 11] Click 'Create a system repair disc' within Backup and Restore (Windows 7), after which the system shows no response
- [AOM-2721][win 11] HDMI monitor shows no display output, while DP monitor continues to display normally
- [AOM-2721][win 11] When operating in dual-monitor mode, disconnecting the HDMI cable causes the system to experience lag/stuttering
- [AOM-2721][win 11] The hardware has only one physical SIM card slot, but the OS displays two SIM cards available for use
- [AOM-2721][win 11] When clicking the system's Hibernate option and then waking it up, the system performs a full reboot instead of resuming from hibernation.
- [AOM-2721][win 11] A warning message for Disk 1 appears in the System section of Windows Logs in Event Viewer
- [AOM-2721][win 11] The Bluetooth driver for AIW-170BQ-001 displays a yellow exclamation mark
- [AOM-2721][win 11] When running the LAN-related test in BurnInTest for approximately 3 minutes, the LAN icon disappears and the test fails.
- [AOM-2721][win 11] Wi-Fi cannot connect to any of the scanned devices
- [AOM-2721][win 11] After adding the "SleepClockSelect "key to the registry, you need to refresh the Device Manager following a restart OS for the WiFi device to remain consistently present
- [AOM-2721][win 11] The BaseBoard Product & Version needs to be modified to AOM-2721 and the current Release version.
- [AOM-2721][win 11] When AIW-170BQ-001 is inserted during the first boot into Windows OOBE process, there is a probability that the system will experience a BSOD
- [AOM-2721][win 11] Two error messages related to luafv and l1vhlwf services appear in the System section of Windows Logs in Event Viewer.
