This document describes how to work with the RISC and Qualcomm LE GA1.1 (QLI 1.1) Board Support Package (BSP) release.
Yocto Version​
Yocto 4.0.18
Kernel Version​
Kernel 6.6.28
Meta Build ID​
QCM6490.LE.1.0-00218-STD.PROD-1
Host machine requirements
OS​
Ubuntu 20.04 or Ubuntu 22.04
CPU​
Intel Core-i7 Processor (>= 8 cores)
RAM​
16+ GB RAM
Disk​
350 GB free disk space?(more is recommended and SSD is suggested for better performance)
Docker Install and BSP Download
Install Docker Engine on your platform​
Please refer to Docker Installation Guide for details
Pull docker images​
$ sudo docker pull advrisc/u20.04-qcslbv2:latest
Run docker example​
$ mkdir -p /home/bsp/myLinux
$ sudo docker run --privileged -it --name qclinux -v /home/bsp/myLinux:/home/adv/BSP:rw advrisc/u20.04-qcslbv2 /bin/bash
adv@7cc0fa834366:~$ sudo chown adv:adv -R BSP
Download BSP​
You need to get the ADV_GIT_TOKEN by contacting the PM or AE of AOM-2721.
$ cd /home/adv/BSP
$ git config --global credential.helper 'store --file ~/.my-credentials'
$ echo "https://AIM-Linux:${ADV_GIT_TOKEN}@dev.azure.com" > ~/.my-credentials
$ repo init -u https://dev.azure.com/AIM-Linux/risc_qcs_linux_le_1.1/_git/manifest -b main -m aom2721a1_yl01101_k0606028_q6490_08g.xml
$ repo sync -c -j${YOUR_CPU_CORE_NUM}
$ cp layers/meta-advantech/conf/machine/qcm6490.conf layers/meta-qcom-hwe/conf/machine/qcm6490.conf
$ cp layers/meta-advantech/recipes-sdk/files/content_config.json layers/meta-qcom-robotics-sdk/recipes-sdk/files/content_config.json
$ cp layers/meta-advantech/recipes-core/base-files/base-files/fstab layers/poky/meta/recipes-core/base-files/base-files/fstab
If you want to get latest bsp
$ repo init -u https://dev.azure.com/AIM-Linux/risc_qcs_linux_le_1.1/_git/manifest -b main -m adv-6.6.28-QLI.1.1-Ver.1.1_robotics-product-sdk-1.1.xml
You can check the download BSP as the following.
Get and Unzip the Downloads Files (Must to do)​
Yocto downloads file:[ downloads.qcs6490.le.1.1.r00041.0.tar.gz ]
The size of downloads.qcs6490.le.1.1.r00041.0.tar.gz is 32064460216byte (31,312,950 KB)
The md5sum of downloads.qcs6490.le.1.1.r00041.0.tar.gz is 02a2d44d728cd8cabf4a9c25752f0606
You need to get the PASSWORD by contacting the PM or AE of AOM-2721.
$ cd /home/adv/BSP
$ openssl des3 -d -k ${PASSWORD} -salt -pbkdf2 -in downloads.qcs6490.le.1.1.r00041.0.tar.gz -out downloads.qcs6490.le.1.1.r00041.0.decrypt.tar.gz
$ tar -zxvf downloads.qcs6490.le.1.1.r00041.0.decrypt.tar.gz
Build Instructions
Source env​
For the "Build All images", "Build All Images individually" and "Build yocto images", you need to do the "Source env".
$ source scripts/env.sh
Build All Images​
$ scripts/build_release.sh -all
  • Output ufs images: build-qcom-robotics-ros2-humble/tmp-glibc/deploy/images/qcm6490/qcom-robotics-full-image
  • Output emmc images: build-qcom-robotics-ros2-humble/tmp-glibc/deploy/images/qcm6490/qcom-robotics-full-image-emmc
Build All Images individually​
1. Build ADSP Image​
After building the ADSP, you need to build the "6. Generate Firmware Prebuilds" to package new firmware prebuild files.
$ scripts/build_release.sh -adsp
2. Build AOP Image​
After building the AOP, you need to build the "6. Generate Firmware Prebuilds" to package new firmware prebuild files.
$ scripts/build_release.sh -aop
3. Build CDSP Image​
After building the CDSP, you need to build the "6. Generate Firmware Prebuilds" to package new firmware prebuild files.
$ scripts/build_release.sh -cdsp
4. Build BOOT(XBL) Image​
After building the BOOT(XBL), you need to build the "6. Generate Firmware Prebuilds" to package new firmware prebuild files.
$ scripts/build_release.sh -boot
5. Build TZ Image​
After building the TZ, you need to build the "6. Generate Firmware Prebuilds" to package new firmware prebuild files.
$ scripts/build_release.sh -tz
6. Generate Firmware Prebuilds​
$ scripts/build_release.sh -common
Output firmware prebuild files:
amss/QCM6490.LE.1.0/common/build/ufs/bin/QCM6490_bootbinaries.zip
amss/QCM6490.LE.1.0/common/build/ufs/bin/QCM6490_dspso.zip
amss/QCM6490.LE.1.0/common/build/ufs/bin/QCM6490_fw.zip
7. Build YOCTO Image​
$ scripts/build_release.sh -yocto
Build yocto images​
$ cd /home/adv/BSP
$ MACHINE=qcm6490 DISTRO=qcom-robotics-ros2-humble source setup-robotics-environment
$ ../qirp-build qcom-robotics-full-image
For the qcsLBV11026 version:
$ cd /home/adv/BSP
$ MACHINE=qcm6490 DISTRO=qcom-wayland source setup-environment
$ devtool modify qps615
$ bitbake qcom-multimedia-image
Recovery & Rescue
Using windows PCAT or Qualcomm Download (QDL) tool to flash software images to the device.
Get the official images and unzip​
Unzip command example:
$ sudo tar -zxvf aom2721a1_yl01101_k0606028_q6490_08g_ufs4_2025-02-10.tgz
Enter EDL download mode​
  • Connect the?Micro USB (EDL)?to your host computer.
  • Forced Recovery: The SW2 switch to 1-on.
  • Flash EMMC: the SW1 switch to 1-off, 2-on
  • Flash UFS: the SW1 switch to 1-on, 2-on
  • Connect the adapter and power on the device
Use the windows PCAT to flash images​
Install​
You can choose one of the following methods to install the flash tool.
Install via CLI​
1. Download and install the Qualcomm Software Center
Qualcomm® Software Center
2. Open CMD or PowerShell
3. Login your ?Qualcomm ID
qsc-cli login -u <USER> -p <PASSWORD>
4. Install
Use -rv to specify the version you want to install.
The tool has only been tested with the version mentioned below.
Using other versions may result in unexpected behavior or inconsistent outcomes.
qsc-cli tool install --name pcat --activate-default-license -rv 2.40.2.83
qsc-cli tool install --name quts --activate-default-license -rv 1.82.2.7
qsc-cli tool install --name qud --activate-default-license -rv 1.00.90.9
If you see the message "Accept and continue with installation [y/n]?:", type y and press Enter to proceed.
Install via GUI​
This wiki page was created based on version 1.16.0. GUIs in other versions may differ.
2. Open the?Qualcomm Software Center
Login in your Qualcomm ID and Click "Catalog -> Tools -> Search Tools"
3. Search "PCAT" in the search bar
RTENOTITLE
4. Click?Qualcomm® Product Configuration Assistant Tool
5. Select Qualcomm® Product Configuration Assistant Tool version
Version: 2.33.2.119 or 2.40.2.83
RTENOTITLE
6. Install?Qualcomm® Product Configuration Assistant Tool
7.?Search "QUTS" in the search bar
RTENOTITLE
8. Click the??Qualcomm® Unified Tools Services
9. Select?Qualcomm® Unified Tools Services version
Version?: 1.75.2.9 or 1.82.2.7
10. Install?Qualcomm® Unified Tools Services
RTENOTITLE
11.?Search "QUD" in the search bar
12. Click the?Qualcomm® USB Drivers and click the?Qualcomm® USB Driver
13. Select?Qualcomm® USB Driver version
Version:?1.00.90.9
14. Install the Qualcomm® USB Driver
Flash​
1. Unzip the UFS File and eMMC File
For example?:
aom2721a1_yl01101_k0606028_q6490_08g_emmc_2025-02-10.tgz
2. After completing the installation of PCAT and QUTS, you will find the new applications in your Windows system. To begin, open PCAT.
RTENOTITLE
3. Connect your device via Micro USB.
UFS​
USF Provision
1. Select? provision button???RTENOTITLE
RTENOTITLE
2. Add the?prog_firehose_ddr.elf and?provision_ufs31.xml in UFS??folder.
RTENOTITLE
3. Then press "OK" , it will start to do USF Provision.
RTENOTITLE
4. When the Provision finished , you can see the result in message window.
RTENOTITLE
Connect to device and Flash
1. Change the SW1 and SW2
Flash UFS:? the SW1 switch to 1-on, 2-on
Forced Recovery?:??The SW2 switch to 1-on? ,2 - on .
2. Turn on the power
3. Open " PCATApp" Tool
4. Click " Connect A Device"
RTENOTITLE
5. Select? "Qualcomm HS-USB QDLoader 9008 (COM6)
RTENOTITLE
6. Click " Connect "? device
RTENOTITLE
7. When you connected successfully , it will show? "green word" - Qualcomm HS-USB QDLoader 9008 (COM 6)
RTENOTITLE
8. Select UFS Folder in PCAT Tool , the Tool will help load Files automatically and Select "MEMORY_TYPE_UFS"
9. Click " Download"
10. UFS Download Status
RTENOTITLE11. UFS Donwload compeleted
RTENOTITLE
12. When the UFS installation finished . Close the PCAT tool ,
13. pleaes remove the mirco usb cable, turn off the power
14.?UFS boot up?:
The SW1 switch to 1-on, 2-on
The SW2 switch to 1-off, 2-on
15. Connect debug cable and open the terminal ,??turn on the power .
16.? When the systme boot up , you need to type ?" qcm6490 login: root "? , " Password: oelinux123"
17.? After type the long in and password , and you also can chek the image information about date , kernel version etc..
eMMC​
1.? Turn off the Power
2.?Change the SW1 and SW2
Flash eMMC:? The SW1 switch to 1-off, 2-on
Forced Recovery?:??The SW2 switch to 1-on, 2-on
3. Turn on the power
4. Make sure the device connection status.
5.?If the device disconnect with PCAT Tool , please connect it again.
RTENOTITLE
6. Select eMMC Folder.
RTENOTITLE7. Make sure the setting ,then press " Download " button.
RTENOTITLE
8. eMMC downlaoad status
RTENOTITLE
'*9. eMMC D'*onwload compeleted
RTENOTITLE
10. When the eMMC installation finished . Close the PCAT tool ,
11. pleaes remove the mirco usb cable, turn off the power
12.?eMMC boot up?:
13. Connect debug cable and open the terminal ,??turn on the power .
14.? When the systme boot up , you need to type ?" qcm6490 login: root "? , " Password: oelinux123"
15.? After type the long in and password , and you also can chek the image information about date , kernel version etc..
Qualcomm Download (QDL) Tool​
One-time Prerequisite​
To set the udev USB rule with the Qualcomm manufacturing vendor ID 05c6:
$ cd /etc/udev/rules.d
$ sudo vi 51-qcom-usb.rules
# add the following
SUBSYSTEMS=="usb", ATTRS{idVendor}=="05c6", ATTRS{idProduct}=="9008", MODE="0666", GROUP="plugdev"
$ sudo systemctl restart udev
Use the QDL to flash images (UFS only now)​
  1. Ensure the QDL mode
$ lsusb
Bus 001 Device 028: ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode)
  1. Ensure ModemManager is not running It is identified as a Qualcomm modem for some Linux distributions when the device is connected in USB mode. Check the status of ModemManager:
$ sudo systemctl status ModemManager
If the ModemManager is enabling, please help to stop it by:
$ sudo systemctl stop ModemManager
  1. Go to the location of images in the workspace to flash the images:
$ cd build-qcom-robotics-ros2-humble/tmp-glibc/deploy/images/qcm6490/qcom-robotics-full-image
$ ./qdl prog_firehose_ddr.elf rawprogram*.xml patch*.xml
HELLO version: 0x2 compatible: 0x1 max_len: 1024 mode: 0
READ64 image: 13 offset: 0x0 length: 0x40
READ64 image: 13 offset: 0x40 length: 0x3f0
READ64 image: 13 offset: 0x1000 length: 0x1000
READ64 image: 13 offset: 0x2000 length: 0x260
READ64 image: 13 offset: 0x3000 length: 0x1000
READ64 image: 13 offset: 0x4000 length: 0x1000
Update Primary Header with CRC of Primary Header.
LOG: INFO: Calling handler for patch
Zero Out Header CRC in Backup Header.
Update Backup Header with CRC of Backup Header.
LOG: INFO: Calling handler for setbootablestoragedrive
LOG: INFO: Using scheme of value= 1
partition 1 is now bootable
LOG: INFO: Calling handler for power
LOG: INFO: Will issue reset/power off 100 useconds, if this hangs check if watchdog is enabled
LOG: INFO: bsp_target_reset() 1
If you see the "partition 1 is now bootable" in your terminal window, the flash is successful.
Note: If you get the following issue, please help to download the qdl file or to build the standalone QDL.
-bash: ./qdl: No such file or directory
How to build the standalone QDL?
$ sudo apt-get install libxml2-dev libudev-dev
$ git clone https://git.codelinaro.org/linaro/qcomlt/qdl.git
$ cd qdl
$ make
Customization
Setting up SDK​
You can download the sdk from [ sdk.qcs6490.le.1.1.r00041.0.tar.gz ] or perform the following command in terminal console
The size of sdk.qcs6490.le.1.1.r00041.0.tar.gz is 4160567372?byte (4,063,055?KB)
The md5sum of sdk.qcs6490.le.1.1.r00041.0.tar.gz is f4184521f8d2c71a8a2953ac1b143242
$ cd build-qcom-robotics-ros2-humble/tmp-glibc/deploy/sdk
$ sudo ./qcom-robotics-ros2-humble-x86_64-qcom-robotics-full-image-armv8-2a-qcm6490-toolchain-1.0.sh
Enter new installed directory or just press Enter to use default directory. While Proceed[Y/n]? shows up, please enter the correct one.
Waiting for the SDK installed (while the following messages show up completely)
Setting up cross compiling environment​
SDK has been set up (ref.Setting_up_SDK) Perform the following command in terminal console
$ source ${TOOLCHAIN}/environment-setup-armv8-2a-qcom-linux
Set the AI execution environment of QIRP images on AOM-2721 device board
Set the AI execution environment of QIRP images on your board:
$ source /opt/qcom/qirp-sdk/qirp-setup.sh
