AOM-DB3500 M.2 E1 Key——PCIE/SATA
Contents
  • 1AOM-3821 supports three PCIE ports.
  • 2M2_E1 Key Pin define
  • 3J8 M2_E1 Power Setting
  • 4J9 M.2_B Power Setting
  • 5WIFI/BT Support Modle:
  • 6BT(For example:“Mate 50 Pro”)
  • 7SATA(model:IM2S3334-512GCTB4
Using the PCIE disk (SQF-C8BV2-128G-EDE) to test the M.2_B-Key PCIE interface. Using the WIFI module (EWM-W179M201E) to test the M.2_E-Key PCIE interface. Using NVMe (UGREEN KB-SA0093-A1 + JZ-SSD256G-5) to test PCIEX4 interface.
M2_E1 M2_E1 Connector Pin Definition
Pin
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24-31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
PinFunction
J8(1-2)M2_E1 power 3.3V (Default)
J8(2-3)M2_E1 power 3.8V
PinFunction
J9(1-2)(B2B pin B76-B79) to M2_E1 (Default)
J9(2-3)UART1 (B2B pin B76-B79) to M2_E2
EWM-W179M201E RTL8852BE,Wifi6: PCIe + BT5.2: USB
AIW-162BS-GI1 Broadcom AP6275P, - 40°C~85°C PCIE+UART
1、Click the network icon in the top right corner of the screen and click the line of “Available networks” to select a Wi-Fi connection (for example: Advantech for guest)
2、Enter the Wi-Fi password to connect to the device.
3、If the password is correct, the device will connect quickly.
After connection, Wi-Fi will create a net point “wlan0”.
# ping -I wlan0 www.advantech.com
Step1 :Click “Applications” -> “Settings”-> “Bluetooth manager”. Click the “Search” button to search for Bluetooth devices.
Step2 :Right-click to select a device, such as “Mate 50 Pro”, and Connect Bluetooth.
Step3 :AOM-3821 will start sending files when the receiver device, such as “Mate 50 Pro ”, confirms bluetooth reception.
Step4:View the location and information of the sent file.
M.2_E-KEY PCIE TEST:
# fw_setenv combphy1 sata
# reboot
# fdisk -l /dev/sda
