Yocto Linux BSP User Guide
Introduction​
Getting Started
Building Yocto Image System Requirements​
  • CPU Cores: Quad-core processor (or higher recommended)
  • Memory: 8GB RAM (more is recommended for better performance)
  • Disk Space: 350GB (more is recommended and SSD is suggested for better performance)
Conventions​
${PREBUILT_IMAGE} : compressed prebuilt image (*.img.gz)
${CONTAINER_NAME} : container name (e.g. imx6LBV8040)
${BSP_TARBALL} : BSP tarball (*.tgz)
${BSP_HOME} : home directory of the BSP
${BDIR} : build directory (e.g. build_x11)
${MX6PROC} : i.MX6 Processor
mx6q for iMX6 Quad Core / Dual Core
mx6dl for iMX6 Dual Lite / Solo
${IMX6PROC} : i.MX6 Processor
imx6q / imx6dl
${BOARD} : available target boards list below
rom5420 / rom7421 / ubc220 / rom3420 / rom7420 / rsb4410 / rsb4411 / rsb6410 / ubcds31 / wise3310
${BOARD_REV} : board revision
a1 / a2 / b1
${MC} : machine code combined with ${IMX6PROC}``${BOARD}``${BOARD_REV}
for example,
imx6dlrom5420b1 for ROM-5420 B1 Solo
imx6dlrom7421a1 for ROM-7421 A1 Solo
imx6dlrsb3430a1 for RSB-3430 A1 Dual-Lite
imx6dlubc220a1 for UBC-220 A1 Dual-Lite
imx6dlrsb4411a1 for RSB-4411 A1 Dual-Lite
imx6qprom7421a1 for ROM-7421 A1 Dual/Quad-Plus
imx6qrom3420a1 for ROM-3420 A1 Dual/Quad
imx6qrom5420a1 for ROM-5420 A1 Dual/Quad
imx6qrom5420b1 for ROM-5420 B1 Dual/Quad
imx6qrom7420a1 for ROM-7420 A1 Dual/Quad
imx6qrsb3430a1 for RSB-3430 A1 Dual/Quad
imx6qrsb4410a1 for RSB-4410 A1 Dual
imx6qrsb4410a2 for RSB-4410 A2 Dual
imx6qrsb4411a1 for RSB-4411 A1 Dual/Quad
imx6qrsb6410a1 for RSB-6410 A1 Dual/Quad
imx6qrsb6410a2 for RSB-6410 A2 Dual/Quad
imx6qubcds31a1 for UBC-DS31 A1 Dual
imx6qwise3310a1 for WISE-3310 A1 Dual
You can also use the command below to check supported machines on BSP:
source setup-environment
${MEM_SIZE} : memory size
1G / 2G / 512M
${SD_DEVICE} : device name of SD card in Linux (e.g. /dev/sdf)
${SDCARD_IMAGE} : sdcard image built by bitbake (*.sdcard)
${WORKSPACE} : host workspace folders
${UBOOT} : u-boot version (e.g. 2016.03)
${KERNEL} : linux kernel version (e.g. 4.1.15)
${TOOLCHAIN} : toolchain installed directory (e.g. /opt/fsl-imx-x11/4.1.15-2.0.0)
debug console / serial console
serial terminal program (e.g. minicom, putty, teraterm ...) that serial port is configured to 115200 8N1
terminal console
terminal program (e.g. gnome-terminal, xfce4-terminal ...)
Docker install and setting​
If you don't have docker in your system, then you can follow the below steps to install docker and run it first.
To install Docker Engine on your platform​
Please refer to Docker Installation Guide for details
To pull ubuntu 12.04 image from Docker Hub​
docker pull advrisc/u12.04-imx6lbv3
docker run --name imx6LBV8200 -it advrisc/u12.04-imx6lbv3 /bin/bash
To copy BSP from local filesystem to the container​
docker cp ${BSP_PACK} imx6LBV8200:/home/adv/
To create container​
docker run --privileged -it --name ${CONTAINER_NAME} -v ${WORKSPACE}:/home/adv/adv-release-bsp -v /dev:/dev advrisc/u12.04-imx6lbv3 /bin/bash
... (中間內容省略,完整已展開至文件)
System Recovery
Please refer to Creating boot-up on-board flash from prebuilt image / sdcard image to create a boot-up SD card and transfer whole system to on-board flash.
Package List
In BSP, list all packages which will be built in the image
bitbake -g fsl-image-qt5 && cat pn-depends.dot | grep -v -e '-native' | grep -v digraph | grep -v -e '-image' | awk '{print $1}' | sort | uniq
File: Package List
Show all recipes (include non-installed packages)
bitbake -s
File: Package Version List
You can also check ${BDIR}/tmp/deploy/images/${MC}/fsl-image-qt5-${MC}.manifest
It will show the same content with checking by rpm tool on target board.
On target board, list all packages by rpm tool
rpm -qa --root / --dbpath /var/lib/rpm | sort
