(This guide describes Advantech's Yocto 3.0 (Zeus) BSP for NXP i.MX8 platforms, including setup, build, flashing, customization, recovery, and reference lists.)
Getting Started
Building Yocto Image — System Requirements​
  • CPU Cores: Quad‑core processor (or higher recommended)
  • Memory: 8 GB RAM (more recommended)
  • Disk Space: 350 GB (SSD recommended for best performance)
Conventions​
  • ${PREBUILT_IMAGE} — prebuilt image archive (*.img.gz)
  • ${CONTAINER_NAME} — Docker container name (e.g., imx8LBVA0016)
  • ${BSP_TARBALL} — BSP tarball (*.tgz)
  • ${BSP_HOME} — BSP root directory
  • ${BDIR} — build directory (e.g., build_x11)
  • ${MX8PROC} — i.MX8 SoC short code
    • mx8mq for i.MX8M Quad/Dual
    • mx8mm for i.MX8M Mini
    • mx8mp for i.MX8M Plus
    • mx8qm for i.MX8 QuadMax
    • mx8qxp for i.MX8 QuadXPlus
  • ${IMX8PROC} — i.MX8 SoC name: imx8mq / imx8mm / imx8mp / imx8qm / imx8qxp
  • ${BOARD} — target boards: rom5720 rom5721 rom7720 rom5620 rom3620 rom5722 rsb3720 epcr5710 rsb3730
  • ${BOARD_REV} — board revision, e.g., a1
  • ${MC} — machine code, combined as ${IMX8PROC}${BOARD}${BOARD_REV}
    Examples:
    • imx8mqrom5720a1 → ROM‑5720 A1
    • imx8qmrom7720a1 → ROM‑7720 A1
    • imx8qxprom5620a1 → ROM‑5620 A1
    • imx8qxprom3620a1 → ROM‑3620 A1
    • imx8mmrom5721a1 → ROM‑5721 A1
    • imx8mprom5722a1 → ROM‑5722 A1
    • imx8mprsb3720a1 → RSB‑3720 A1
    • imx8mpepcr5710a1 → EPC‑R5710 A1
    • imx8mmrsb3730a2 → RSB‑3730 A2
    You can also list supported machines:
    $ source setup-environment
  • ${MEM_SIZE} — memory size, e.g., 2G / 4G
  • ${UC} — U‑Boot config: 1G/2G/4G/FSPI_1G/FSPI_2G …
  • ${SD_DEVICE} — SD device on host Linux, e.g., /dev/sdf
  • ${SDCARD_IMAGE} — SD image from bitbake
    • VA0033–VA0362: *.wic.bz2
    • VA0386–latest: *.sdcard
  • ${WORKSPACE} — host workspace directory
  • ${UBOOT} — U‑Boot version (e.g., 2016.03)
  • ${KERNEL} — Linux kernel version (e.g., 5.4.x)
  • ${TOOLCHAIN} — toolchain directory (e.g., /opt/fsl-imx-x11/4.1.15-2.0.0)
Debug console / serial console: any serial terminal (minicom/putty/teraterm) at 115200 8N1.
Terminal console: terminal emulator (gnome‑terminal, xfce4‑terminal, etc.)
Docker Install and Setup​
If Docker is not installed on your host, please install Docker Engine per your distribution’s instructions.
Pull Ubuntu 18.04 image​
docker pull advrisc/u18.04-imx8lbv1
Create a container​
docker run --privileged -it --name ${CONTAINER_NAME}   -v ${WORKSPACE}:/home/adv/adv-release-bsp   -v /dev:/dev -v /lib/modules:/lib/modules -v /usr/src:/usr/src   advrisc/u18.04-imx8lbv1 /bin/bash
Get BSP​
You can either clone from GitHub (legacy) or unpack an internal BSP tarball.
Download BSP from GitHub (legacy/migrated)​
Create project directory and init the manifest (example uses imx8LBVA0428.xml on imx-linux-zeus):
git config --global user.name "Your Name"
git config --global user.email you@example.com
sudo chown adv:adv adv-release-bsp
cd adv-release-bsp
repo init -u git://github.com/ADVANTECH-Corp/adv-arm-yocto-bsp.git -b imx-linux-zeus -m imx8LBVA0428.xml
repo sync
Get the latest BSP (example manifest):
repo init -u git://github.com/ADVANTECH-Corp/adv-arm-yocto-bsp.git -b imx-linux-zeus -m imx-5.4.70-2.3.0.xml
repo sync
Network/protocol tips:
# Disable SSL verification for self-signed endpoints (not recommended globally)
`export GIT_SSL_NO_VERIFY=1`
git config --global http.sslverify false
# If unauthenticated git:// 9418 is blocked:
git config --global url."https://".insteadOf git://
Important: As of 2023‑03‑31, the public repos were migrated; direct repo sync with some manifests can fail.
  • If you use a current (pinned) XML, repo sync may still succeed. Example:
    repo init -u https://github.com/ADVANTECH-Corp/adv-arm-yocto-bsp.git -b imx-linux-zeus -m imx-5.4.70-2.3.0.xml
  • If you use a tagged XML and hit errors, follow the internal Yocto3.0_Repo_Fail_SOP to update remotes and manifests.
Copy BSP Tarball to Container​
If you have a BSP tarball (e.g., imx8LBVA0029_2020-10-23.tgz):
  1. Exit container back to host
exit
  1. Copy tarball to ${WORKSPACE} and fix ownership
cp imx8LBVA0029_2020-10-23.tgz /home/adv/adv-release-bsp
sudo chown adv:adv /home/adv/adv-release-bsp/imx8LBVA0029_2020-10-23.tgz
  1. Reattach container
docker start ${CONTAINER_NAME}
docker attach ${CONTAINER_NAME}
  1. Unpack
tar zxvf imx8LBVA0029_2020-10-23.tgz
During builds Yocto creates a downloads directory of source tarballs; to reduce fetch errors, use a prefilled downloads bundle:
  • downloads_imx8_5.4.24.tar.gz — md5: 648a6aa9d03be61ee21611b729250319
  • downloads_imx8_5.4.70.tar.gz — md5: ec2a0da745e57329a73965f9bd7ff0c9
Steps:
  1. Exit container
exit
  1. Copy downloads tarball into ${WORKSPACE} and chown
cp downloads_imx8_5.4.24.tar.gz /home/adv/adv-release-bsp
sudo chown adv:adv /home/adv/adv-release-bsp/downloads_imx8_5.4.24.tar.gz
  1. Unpack and link
tar zxvf downloads_imx8_5.4.24.tar.gz
cd adv-release-bsp
ln -s /home/adv/adv-release-bsp/downloads_imx8_5.4.24 downloads
Introducing the BSP​
Advantech’s BSP builds on the Yocto Project with NXP i.MX8 enhancements and Advantech board support.
  • sources/ — Yocto layers from community, NXP, and Advantech
  • fsl-setup-release.sh — create a new build env
  • setup-environment — resume existing build env
Naming Rules​
  • BSP Tarball: imx8LBVA0010_2019-08-27.tgz
    • LB = Linux BSP, VA0010 = Version A.0010
  • Yocto Image: e.g., 5720A1AIM20LIVA0010_iMX8M_2G_2020-08-27.img.gz
    • 5720A1 board/rev, LI = Linux Image, 2G DDR size
BSP Content (Key Paths)​
  • sources/meta-advantech/ — Advantech meta layer
  • sources/meta-fsl-* — NXP/Freescale layers
  • fsl-setup-release.sh — build env script
  • setup-environment — resume env script
Build Instructions
Create a New Build Environment​
cd ${BSP_HOME}
MACHINE=${MC} DISTRO=fsl-imx-xwayland source imx-setup-release.sh -b ${BDIR}
During first run you will be asked to accept the EULA (see screenshot img/Accept_EULA.png).
Resume an Existing Build Environment​
cd ${BSP_HOME}
source setup-environment ${BDIR}
Build SD Card Image​
bitbake imx-image-full
Output (success):
  • VA0033–VA0362: imx-image-full-${MC}.wic.bz2
  • VA0386–latest: imx-image-full-${MC}.rootfs.sdcard
Build Toolchain Installer​
bitbake meta-toolchain
Output (under ./tmp/deploy/sdk):
fsl-imx-xwayland-glibc-x86_64-meta-toolchain-aarch64-toolchain-${KERNEL}-zeus.sh
Build Bootloader​
bitbake imx-boot
Build Linux Kernel​
If building inside Docker, install tmux to safely run menuconfig:
sudo apt-get update && sudo apt-get install -y tmux
tmux
bitbake linux-imx -c menuconfig
# exit tmux when done
exit
Build the kernel:
bitbake linux-imx
Outputs: Image and Image-${IMX8PROC}-${BOARD}-${BOARD_REV}.dtb in ./tmp/deploy/images/${MC}.
Creating Boot Media
From Prebuilt Image — Create Bootable SD Card​
sudo sh -c 'gunzip -c ${PREBUILT_IMAGE} | dd of=${SD_DEVICE} bs=1M status=progress && sync'
From Built SD Image — Create Bootable SD Card​
pushd ${BSP_HOME}/${BDIR}/tmp/deploy/images/${MC}
# choose the proper .wic.bz2 or .sdcard and write to ${SD_DEVICE}
popd
Serial Console Preparation
  • Hardware: see your board’s debug port mapping (Debug Port Information).
  • Software: use minicom / putty; set 115200 baud.
One‑Step Build Script (Docker)
Download and execute:
wget https://raw.githubusercontent.com/ADVANTECH-Corp/RISC_tools_scripts/zeus/imx8/adv_imx8_build.sh
sudo chmod a+x adv_imx8_build.sh
sudo ./adv_imx8_build.sh ${BOARD}
# Example:
sudo ./adv_imx8_build.sh rom5720
Artifacts will be in:
Then proceed to SD creation as described above.
Customization
Package Addition​
Add tcf-agent & openssh-sftp-server​
Edit sources/meta-advantech/meta-fsl-imx/recipes-fsl/images/fsl-image-adv.inc:
IMAGE_INSTALL += " tcf-agent openssh-sftp-server "
Add Chromium Browser​
Edit ${BDIR}/conf/local.conf:
Method 1 (recommended):
CORE_IMAGE_EXTRA_INSTALL += "chromium-ozone-wayland"
Method 2:
IMAGE_INSTALL_append = "${@bb.utils.contains('DISTRO_FEATURES', 'wayland', ' chromium-ozone-wayland libexif', bb.utils.contains('DISTRO_FEATURES','x11', ' chromium-x11 libexif', '', d), d)}"
LICENSE_FLAGS_WHITELIST = "${@bb.utils.contains('DISTRO_FEATURES', 'wayland', 'commercial', bb.utils.contains('DISTRO_FEATURES','x11','commercial','', d), d)}"
Add QtWebEngine​
IMAGE_INSTALL_append += " packagegroup-qt5-webengine "
Re‑source the env and rebuild the SD image.
Setting Up SDK
Build the toolchain installer (see above), then on host:
cd ${BSP_HOME}/${BDIR}/tmp/deploy/sdk
sudo ./fsl-imx-xwayland-glibc-x86_64-meta-toolchain-aarch64-toolchain-5.4-zeus.sh
Follow prompts to choose install directory and proceed until completion.
Set Cross‑Compile Environment​
source ${TOOLCHAIN}/environment-setup-aarch64-poky-linux
Build U‑Boot Standalone
Configure U‑Boot​
make ${IMX8PROC}_${BOARD}${BOARD_REV}_${MEM_SIZE}_defconfig
# Example:
make imx8mm_rom5721a1_2G_defconfig
Build U‑Boot​
make -j$(nproc)
Build imx-boot with imx-mkimage
Example (ROM‑5721):
tar zxvf 5721A1AIM20LIVA0118_iMX8MM_imx-boot.tgz
cd 5721A1AIM20LIVA0118_iMX8MM_imx-boot/
# Copy necessary files into imx-mkimage
./cp_uboot.sh ${uboot_path} ${IMX8PROC}
# Build imx-boot image
./mk_imx-boot.sh ${IMX8PROC}
# Example:
./cp_uboot.sh ../uboot-imx6 imx8m
./mk_imx-boot.sh imx8mm
Replace imx-boot on eMMC​
sudo dd if=flash.bin of=/dev/mmcblk0 bs=1K seek=<offset> conv=fsync
Offsets:
  • 33 — i.MX8QM A0, i.MX8QXP A0, i.MX8M Quad/Mini
  • 32 — i.MX8M Plus, i.MX8QXP B0/C0, i.MX8QM B0
Building & Updating Kernel/Modules/DTB Manually
Assumes SDK env is sourced.
Unpack Kernel Tarball (inside container)​
sudo chown adv:adv imx8LBVA0029_2019-10-23_linux-imx.tgz
tar zxvf imx8LBVA0029_2019-10-23_linux-imx.tgz
Configure Kernel​
cd linux-imx
make distclean
make imx_v8_adv_defconfig
make menuconfig
Build Kernel Image​
make -j$(nproc) Image
If you see linker flags issues, try:
unset LDFLAGS
Kernel image path: ./arch/arm64/boot/Image
Build Modules​
make -j$(nproc) modules
make modules_install INSTALL_MOD_PATH=~/temp/rootfs
Build DTB​
make -j$(nproc) freescale/${IMX8PROC}-${BOARD}-${BOARD_REV}.dtb
# Example:
make -j$(nproc) freescale/imx8mq-rom5720-a1.dtb
Replace Kernel & DTB​
Copy Image and the board DTB into your target’s boot partition (SD/eMMC) as appropriate.
Improve Boot Speed
Bootloader​
  1. Boot delay
    setenv bootdelay 0
    env save
    reset
  2. Disable console output (reduces boot log noise)
    Kernel quiet:
    setenv mmcargs 'setenv bootargs ${jh_clk} console=${console} modprobe.blacklist=${modprobe.blacklist} root=${mmcroot} video=HDMI-A-1:${videores} quiet'
    env save
    reset
    Disable debug UART:
    • Yocto machine setting: edit sources/meta-advantech/meta-fsl-imx/conf/machine/${MC}.conf
      SERIAL_CONSOLES = ";"
    • U‑Boot param (imx8mq/mm/mp):
      setenv console disabled
      env save
      reset
    • U‑Boot param (imx8qm/qxp):
      setenv earlycon disabled
      setenv mmcargs 'setenv bootargs console=${console},${baudrate} earlycon=${earlycon},${baudrate} root=${mmcroot}'
      env save
      reset
Services​
Disable unneeded services:
systemctl disable <service-name>
# Example
systemctl disable boottimes
System Recovery
If the onboard eMMC gets corrupted, recover using SD card or UUU tool.
Recovery by SD Card​
  1. Copy 5720A1AIM20LIVA0022_iMX8M_flash_tool.tgz to your PC.
  2. Insert SD card into PC.
  3. Make a bootable SD:
    tar zxvf 5720A1AIM20LIVA0022_iMX8M_2G_flash_tool.tgz
    cd 5720A1AIM20LIVA0022_iMX8M_2G_flash_tool/mk_inand/
    sudo ./mksd-linux.sh /dev/sdg
  4. Copy 5720A1AIM20LIVA0022_iMX8M_flash_tool to a USB disk.
  5. Insert USB disk and SD card, then boot board from SD.
  6. Flash eMMC:
    cd /run/media/sda1/
    sudo ./mksd-linux.sh /dev/mmcblk0
Recovery by UUU Tool​
  1. Download UUU (v20210429 or later).
  2. Run:
    • Linux:
      sudo ./uuu
    • Windows:
      uuu.exe
  3. Prepare a folder containing:
    1. uuu
    2. imx-boot-imx8mqrom5720a1-sd.bin-flash_evk
    3. fsl-image-validation-imx-imx8mqrom5720a1-20190917152605.rootfs.sdcard
    4. Image_dtb.uuu
    5. rootfs.uuu
  4. Connect OTG cable from PC to device.
  5. Set correct boot mode and power on:
    • ROM‑5722/5720/5721/5620: 1,2,3 = OFF; 4 = ON
    • ROM‑7720: 1,2,3,4,5,6 = OFF or 1,2,4,5,6 = OFF; 3 = ON
  6. Example burn commands (note u‑boot 2019‑11‑01+ for mmcblk0 path):
# 1. Burn only U‑Boot
# a) to mmcblk0boot0
sudo ./uuu -b emmc imx-boot-imx8mqrom5720a1-sd.bin-flash_evk
# b) to mmcblk0
sudo ./uuu -b emmc_adv imx-boot-imx8mqrom5720a1-sd.bin-flash_evk
# 2. Burn U‑Boot + rootfs
# a) mmcblk0boot0
sudo ./uuu -b emmc_all imx-boot-imx8mqrom5720a1-sd.bin-flash_evk fsl-image-validation-imx-imx8mqrom5720a1-20190917152605.rootfs.sdcard
# b) mmcblk0
sudo ./uuu -b emmc_all_adv imx-boot-imx8mqrom5720a1-sd.bin-flash_evk fsl-image-validation-imx-imx8mqrom5720a1-20190917152605.rootfs.sdcard
  1. UUU will write the images to eMMC.
  2. Burn parts separately:
# a) Replace Image and DTB
# Step 1: rename files to:
# _Image
# _board.dtb
# Step 2:
sudo ./uuu Image_dtb.uuu
# b) Replace rootfs
# Step 1: rename rootfs tarball to:
# _rootfs.tar.bz2
# Step 2:
sudo ./uuu rootfs.uuu
For more usage, see NXP mfgtools documentation.
Package List
List all packages built into the image:
bitbake -g imx-image-full &&   cat task-depends.dot | grep -v -e '-native' | grep -v digraph |   grep -v -e '-image' | awk '{print $1}' | sort | uniq
(Example set: 2019‑10‑25)
Show all recipes (incl. non‑installed):
bitbake -s
(Example set: 2019‑10‑25 — version list)
You can also examine:
${BDIR}/tmp/deploy/images/${MC}/fsl-image-qt5-validation-imx-${MC}.manifest
to match target package set (same as rpm on device):
On target device:
rpm -qa --root / --dbpath /var/lib/rpm | sort
Device Tree Selection at Boot
Select different DTBs in U‑Boot to enable display/camera variants, e.g.:
setenv fdt_file adv-imx8mm-rom5721-a1-dsi2dp.dtb
env save
boot
ROM‑5721 (i.MX8MM)​
Display
  • DSI→LVDS
    • imx8mm-rom5721-a1.dtb (g070vw01)
    • imx8mm-rom5721-a1-dsi2lvds-g150xgel05.dtb (g150xgel05)
    • imx8mm-rom5721-a1-dsi2lvds-g215hvn01.dtb (g215hvn01)
  • DSI→DP
    • imx8mm-rom5721-a1-dsi2dp.dtb
  • DSI→HDMI
    • imx8mm-rom5721-a1-adv7535.dtb
  • DSI
    • imx8mm-rom5721-a1-auog101uan02.dtb (auog101uan02)
M.2 SDIO
  • Adjust CN43–CN48: imx8mm-rom5721-a1-m2-sdio.dtb
ROM‑5720 (i.MX8MQ)​
Display
  • DSI→HDMI
    • imx8mq-rom5720-a1-dcss-adv7535.dtb
    • imx8mq-rom5720-a1-lcdif-adv7535.dtb
      Weston UI: edit /etc/xdg/weston/weston.ini → drm-device=card2
  • DSI
    • imx8mq-rom5720-a1-dcss-auog101uan02.dtb
      Weston UI: drm-device=card2
  • Dual Display (DSI→HDMI + HDMI)
    • imx8mq-rom5720-a1-dual-display.dtb
      Weston UI: drm-device=card1
M.2 SDIO
  • Adjust CN43–CN48: imx8mq-rom5720-a1-m2-sdio.dtb
ROM‑5620 (i.MX8QXP)​
Display
  • LVDS
    • imx8qxp-rom5620-a1.dtb (g070vw01)
    • imx8qxp-rom5620-a1-lvds-chimei.dtb (g150xgel05)
    • imx8qxp-rom5620-a1-lvds-dual.dtb (g215hvn01)
  • LVDS→HDMI / DSI→HDMI
    • imx8qxp-rom5620-a1-hdmi-bridge.dtb
  • DSI
    • imx8qxp-rom5620-a1-auog101uan02.dtb
M.2 SDIO
  • Adjust CN43–CN48: imx8qxp-rom5620-a1-m2-sdio.dtb
ROM‑7720 (i.MX8QM)​
Display
  • HDMI
    • imx8qm-rom7720-a1.dtb
  • LVDS
    • imx8qm-rom7720-a1-lvds0.dtb (g070vw01)
    • imx8qm-rom7720-a1-lvds1.dtb (g070vw01)
    • imx8qm-rom7720-a1-lvds-dual.dtb (g215hvn01)
  • HDMI + LVDS
    • imx8qm-rom7720-a1-hdmi-lvds0.dtb (HDMI + g070vw01)
    • imx8qm-rom7720-a1-hdmi-lvds1.dtb (HDMI + g070vw01)
    • imx8qm-rom7720-a1-hdmi-lvds-dual.dtb (HDMI + g215hvn01)
  • LVDS→HDMI
    • imx8qm-rom7720-a1-it6263.dtb
Audio Codec
  • imx8qm-rom7720-a1-sgtl5000.dtb
RSB‑3720 (i.MX8MP)​
Display
  • HDMI (default): imx8mp-rsb3720-a1.dtb
  • LVDS + HDMI
    • imx8mp-rsb3720-a1-lvds0-auo.dtb (g070vw01 on LVDS0)
    • imx8mp-rsb3720-a1-lvds1-auo.dtb (g070vw01 on LVDS1)
    • imx8mp-rsb3720-a1-lvds-dual.dtb (g215hvn01 dual LVDS)
  • DSI
    • imx8mp-rsb3720-a1-adv7535.dtb (DSI→HDMI + HDMI)
    • imx8mp-rsb3720-a1-auog101uan02.dtb (DSI panel)
Camera
  • imx8mp-rsb3720-a1.dtb (OV5640 default)
  • imx8mp-rsb3720-a1-basler.dtb (Basler)
ROM‑5722 (i.MX8MP)​
Display
  • HDMI (default): imx8mp-rom5722-a1.dtb
  • LVDS + HDMI
    • imx8mp-rom5722-a1-lvds0-auo.dtb (g070vw01 on LVDS0)
    • imx8mp-rom5722-a1-lvds1-auo.dtb (g070vw01 on LVDS1)
    • imx8mp-rom5722-a1-lvds-dual.dtb (g215hvn01 dual LVDS)
  • DSI
    • imx8mp-rom5722-a1-adv7535.dtb (DSI→HDMI + HDMI)
    • imx8mp-rom5722-a1-auog101uan02.dtb (DSI panel)
Camera
  • imx8mp-rom5722-a1.dtb (OV5640 default)
  • imx8mp-rom5722-a1-basler.dtb (Basler)
ROM‑3620 (i.MX8QXP)​
Display
  • LVDS
    • imx8qxp-rom3620-a1.dtb (g070vw01)
    • imx8qxp-rom3620-a1-lvds-chimei.dtb (g150xgel05)
    • imx8qxp-rom3620-a1-lvds-dual.dtb (g215hvn01)
  • DSI→HDMI
    • imx8qxp-rom3620-a1-hdmi-bridge.dtb
  • DSI
    • imx8qxp-rom3620-a1-auog101uan02.dtb
RSB‑3730 (i.MX8MM)​
Display
  • HDMI: imx8mm-rsb3730-a2.dtb
  • LVDS
    • imx8mm-rsb3730-a2-dsi2lvds-800x480.dtb (g070vw01)
    • imx8mm-rsb3730-a2-dsi2lvds-1920x1080.dtb (g215hv01)
  • DSI
    • imx8mm-rsb3730-a2-dsi-auog101uan02.dtb (g101uan2.0)
Burn‑in Test
Bottom Board Settings​
Disable Pin of PCIe​
Configure the GPIO disable pin to match your carrier board:
&pcie0 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_pcie0>;
// disable-gpio = <&tca9538 0 GPIO_ACTIVE_LOW>; /* example */
// reset-gpio = <&gpio1 13 GPIO_ACTIVE_LOW>; /* example */
ext_osc = <1>;
status = "okay";
Fix Intermittent No‑Sound When HDMI Plug In/Out​
Apply the following patch (imx865 HDMI overflow workaround):
0001-imx865-hdmi-enable-overflow-workaround-for-imx865hdmi.patch
(Patch body omitted for brevity; ensure it adds case 0x213a in dw_hdmi_clear_overflow().)
QSPI: Read MAC / Serial / MFG Date
Adjust offsets to match your production layout. Commands below read from /dev/mtdblock0.
MAC 0
READ_DATA=$(dd if=/dev/mtdblock0 bs=1 skip=$((0xd0000)) count=6 2>/dev/null | hexdump -v -e '1/1 "%02x:"' | sed 's/:$//' )
echo "${READ_DATA}"
MAC 1
READ_DATA=$(dd if=/dev/mtdblock0 bs=1 skip=$((0xd0400)) count=6 2>/dev/null | hexdump -v -e '1/1 "%02x:"' | sed 's/:$//' )
echo "${READ_DATA}"
Serial Number
READ_DATA=$(dd if=/dev/mtdblock0 bs=1 skip=$((0xd0006)) count=10 2>/dev/null)
echo "${READ_DATA}"
Manufacture Date (YYYY-MM-DD_hh-mm-ss)
(Assumes ASCII digits at the given offset; adapt as needed.)
RAW=$(dd if=/dev/mtdblock0 bs=1 skip=$((0xd0010)) count=14 2>/dev/null)
printf -v DATE "%s-%s-%s_%s-%s-%s" "${RAW:0:4}" "${RAW:4:2}" "${RAW:6:2}" "${RAW:8:2}" "${RAW:10:2}" "${RAW:12:2}"
echo "${DATE}"
Notes​
  • Paths, offsets, and device nodes may vary by board revision.
  • Always back up critical partitions before flashing.
  • Use sudo with caution and confirm target devices (e.g., /dev/sdX vs /dev/mmcblkY).
