Yocto Linux BSP Ver.E User Guide for i.MX9 Series — Yocto 4.3 (Nanbield)
Introduction​
This document explains how to set up the build environment, obtain the BSP, build images, create bootable media, and customize software for Advantech boards based on NXP i.MX9 (e.g., i.MX95, AOM-3511). It targets BSP Version E aligned with NXP release L6.6.3-1.0.0 (Yocto 4.3 nanbield).
Getting Started
System Requirements​
  • CPU Cores: Intel® Core™ i7 (≥ 8 cores)
  • Memory: ≥ 16 GB
  • Disk Space: ≥ 500 GB (SSD strongly recommended)
Conventions​
  • ${PREBUILT_IMAGE} — compressed prebuilt image (*.img.gz)
  • ${CONTAINER_NAME} — container name (e.g., imx9LBVE0017)
  • ${BSP_TARBALL} — BSP tarball (*.tgz)
  • ${BSP_HOME} — BSP root directory inside the container
  • ${BDIR} — build directory (e.g., build_xwayland)
  • ${IMX9PROC} — i.MX9 processor code (e.g., imx95 for i.MX95)
  • ${BOARD} — target board (e.g., aom3511)
  • ${BOARD_REV} — board revision (e.g., a1)
  • ${MC} — machine code = ${IMX9PROC}${BOARD}${BOARD_REV}
Example: imx95aom3511a1 for AOM-3511 A1
You can list supported machines after sourcing the environment:
$ source setup-environment
  • ${MEM_SIZE} — memory size (1G / 2G / 4G / 6G / 8G)
  • ${UC} — U-Boot config (1G / 2G / 4G / 6G / 8G / FSPI_1G / FSPI_2G / FSPI_4G / FSPI_6G / FSPI_8G ...)
  • ${SD_DEVICE} — SD device path on host Linux (e.g., /dev/sdf)
  • ${SDCARD_IMAGE} — SD card image built by bitbake (*.wic.zst)
  • ${WORKSPACE} — host workspace folder mapped into the container
  • ${UBOOT} — U-Boot version (e.g., v2023.04_6.6.3-1.0.0)
  • ${KERNEL} — Linux kernel version (e.g., 6.6.3-1.0.0)
  • ${TOOLCHAIN} — toolchain install base (e.g., /opt/fsl-imx-xwayland/6.6-nanbield)
Debug/Serial console: use a terminal tool (minicom/putty/teraterm) configured to 115200 8N1. Terminal console: any terminal emulator (gnome-terminal, xfce4-terminal, etc.).
Docker Install and Settings​
If Docker is not available on your system, please install it first.
Install Docker Engine​
Refer to the official Docker installation guide for your platform.
Pull base image (example)​
$ docker pull advrisc/u20.04-imx8lbv1
The example image is Ubuntu 20.04 and works as a base for i.MX9 builds as well.
Create a container​
$ docker run --privileged -it \
--name ${CONTAINER_NAME} \
-v ${WORKSPACE}:/home/adv/adv-release-bsp \
-v /dev:/dev \
advrisc/u20.04-imx8lbv1 /bin/bash
Get BSP​
You can obtain the BSP in two ways.
Method A — Download BSP from GitHub​
The following example downloads the Advantech Yocto BSP into the adv-release-bsp directory and checks out nanbield / 6.6.3-1.0.0:
$ git config --global user.name "Your Name"
$ git config --global user.email you@example.com
$ sudo chown adv:adv adv-release-bsp
$ cd adv-release-bsp
$ repo init -u https://github.com/ADVANTECH-Corp/adv-arm-yocto-bsp.git \
-b imx-linux-nanbield \
-m adv-6.6.3-1.0.0.xml
$ repo sync
Troubleshooting:​
  • "server certificate verification failed" (self-signed certs):
`export GIT_SSL_NO_VERIFY=1`
# or
git config --global http.sslverify false
  • "The unauthenticated git protocol on port 9418 is no longer supported.":
git config --global url."https://".insteadOf git://
Method B — Copy BSP tarball into the container​
If you have a BSP tarball (e.g., imx9LBVE0017_2024-08-21.tgz), copy it into the container workspace.
  1. Exit to host:
exit
  1. Copy into ${WORKSPACE} and fix ownership:
cp imx9LBVE0017_2024-08-21.tgz ${WORKSPACE}
sudo chown adv:adv ${WORKSPACE}/imx9LBVE0017_2024-08-21.tgz
  1. Re-attach to the container:
docker start ${CONTAINER_NAME}
docker attach ${CONTAINER_NAME}
  1. Unpack inside the container:
tar zxvf imx9LBVE0017_2024-08-21.tgz
During Yocto builds, a downloads/ folder caches sources. To reduce fetch failures, reuse a prepared tarball (e.g., downloads_6.6.3_1.1.0.tar).
  1. Exit to host:
exit
  1. Copy the downloads tarball into ${WORKSPACE}:
cp downloads_6.6.3_1.1.0.tar ${WORKSPACE}
sudo chown adv:adv ${WORKSPACE}/downloads_6.6.3_1.1.0.tar
  1. Unpack:
tar zxvf downloads_6.6.3_1.1.0.tar
  1. Link into the BSP tree:
cd adv-release-bsp
ln -s ${WORKSPACE}/downloads_6.6.3_1.1.0 downloads
Introducing BSP​
The BSP is based on the Yocto Project with NXP (Freescale) enhancements for i.MX95, plus Advantech board support. The release directory contains:
  • sources/ — Yocto layers (community + NXP + Advantech)
  • one or more build directories
  • scripts to set up the build environment
Naming Rule​
  • BSP file name: imx9LBVE0017_YYYY-MM-DD.tgz
    • LB = Linux BSP
    • VE0017 = Version E, build 0017
  • Prebuilt image name: 3511A1AIM37LIVE0017_iMX95_8G_YYYY-MM-DD.img.gz
    • 3511A1 = AOM-3511 A1
    • LI = prebuilt Linux Image
    • 8G = DDR size
BSP Content (key items)​
  • sources/meta-advantech/ — Advantech meta-layer
  • sources/meta-fsl-* — NXP (Freescale) meta-layers
  • fsl-setup-release.sh — create a new build environment
  • setup-environment — continue an existing build environment
Build Instructions
Create a New Build Environment​
cd ${BSP_HOME}
MACHINE=${MC} DISTRO=fsl-imx-xwayland source imx-setup-release.sh -b ${BDIR}
To set a default U-Boot config during creation:
MACHINE=${MC} UBOOT_CONFIG=${UC} DISTRO=fsl-imx-xwayland source imx-setup-release.sh -b ${BDIR}
You need to read and accept the EULA.
Accept EULA
Continue an Existing Build Environment​
cd ${BSP_HOME}
source setup-environment ${BDIR}
Build SD Card Image​
bitbake imx-image-full
Results (upon success) in ./tmp/deploy/images/${MC}:
  • imx-image-full-${MC}.wic.zst
  • imx-image-full-${MC}.wic.bmap
Build Toolchain Installer (SDK)​
bitbake meta-toolchain
The installer appears in ./tmp/deploy/sdk/, e.g.:
fsl-imx-xwayland-glibc-x86_64-meta-toolchain-armv8a-imx95-19x19-lpddr5-evk-toolchain-6.6-nanbield.sh
Build Bootloader​
bitbake imx-boot
Build Linux Kernel​
If you are in Docker, install tmux before running menuconfig:
sudo apt-get update
sudo apt-get install -y tmux
tmux
bitbake linux-imx -c menuconfig
# After editing, exit the tmux window:
exit
Build the kernel:
bitbake linux-imx
Resulting files under ./tmp/deploy/images/${MC}:
  • Image
  • Image-${IMX9PROC}-${BOARD}-${BOARD_REV}.dtb
Creating Boot Media
From a Prebuilt Image​
Warning: Double-check ${SD_DEVICE} before running dd.
sudo sh -c 'gunzip -c ${PREBUILT_IMAGE} | dd of=${SD_DEVICE} bs=1M status=progress'
sync
From a Built SD Card Image​
pushd ${BSP_HOME}/${BDIR}/tmp/deploy/images/${MC}
zstd -cd ${SDCARD_IMAGE} | sudo dd of=${SD_DEVICE} bs=1M status=progress
# Or use bmaptool (faster, sparse aware):
sudo bmaptool copy --bmap ${SDCARD_IMAGE/.zst/.bmap} ${SDCARD_IMAGE} ${SD_DEVICE}
sync
popd
Debug Console Information
If you want to see bootloader/kernel messages, prepare:
Hardware​
  • Refer to your product's Debug Port Information for the connector location and pinout (AOM-3511).
Software​
  • Use a serial terminal such as minicom or putty.
  • Baud rate: 115200
Customization
Setting up SDK​
Build the SDK as described above, then run the installer:
cd ${BSP_HOME}/${BDIR}/tmp/deploy/sdk
sudo ./fsl-imx-xwayland-glibc-x86_64-meta-toolchain-armv8a-imx95-19x19-lpddr5-evk-toolchain-6.6-nanbield.sh
Follow prompts: choose install path or press Enter for default, then confirm Proceed [y/n]?.
(Reference download link for SDK if provided: [downloads_SDK])
Setting up SDK
Setting up Cross-Compiling Environment​
After SDK installation, source the toolchain environment:
source ${TOOLCHAIN}/environment-setup-aarch64-poky-linux
Build U-Boot in a Standalone Environment​
Configure U-Boot​
make ${IMX9PROC}_${BOARD}${BOARD_REV}_${MEM_SIZE}_defconfig
# e.g.
make imx95_aom3511a1_8G_defconfig
Build U-Boot​
make -j$(nproc)
Build imx-boot Image using imx-mkimage (i.MX95)​
  1. Obtain the imx-boot tarball for your product (example for AOM-3511):
tar zxvf 3511A1AIM37LIVE0017_iMX95_8G_imx-boot.tgz
cd 3511A1AIM37LIVE0017_iMX95_8G_imx-boot/
  1. Copy necessary artifacts into the imx-mkimage folder:
cp u-boot.bin spl/u-boot-spl.bin arch/arm/dts/imx95-aom3511-a1.dtb tools/mkimage \
/path/to/imx-mkimage/iMX9/
  1. Build flash.bin:
cd /path/to/imx-mkimage
make SOC=iMX95 OEI=YES flash_all
Flash imx-boot​
  • Using uuu to eMMC:
cp flash.bin ~/mfgtools/uuu/
cd ~/mfgtools/uuu
sudo ./uuu -b emmc flash.bin
  • Or write raw to device (example /dev/sdd, adjust as needed):
sudo dd if=flash.bin of=/dev/sdd bs=1K seek=32 conv=fsync
sync
Building & Updating Kernel / Modules / DTB Manually​
Ensure your cross-compile environment is sourced (see Setting up Cross-Compiling Environment).
Get Linux-imx Sources​
If not already available, obtain the sources per your workflow. (Reference: [adv_6.6.3_1.0.0])
Configure the Kernel​
cd linux-imx
make distclean
make imx_v8_adv_defconfig
make menuconfig
Build Kernel Image​
make -j$(nproc) Image
If you encounter link-flags issues, try:
unset LDFLAGS
The kernel Image is at: ./arch/arm64/boot/
Build Kernel Modules​
make -j$(nproc) modules
make modules_install INSTALL_MOD_PATH=~/temp/rootfs
Build Device Tree Blob​
make -j$(nproc) freescale/${IMX9PROC}-${BOARD}-${BOARD_REV}.dtb
# e.g.
make -j$(nproc) freescale/imx95-aom3511-a1.dtb
DTBs are at: ./arch/arm64/boot/dts/freescale/
Replace Kernel & DTB on Target Media​
  • Copy Image to the appropriate /boot (or partition) on SD/eMMC.
  • Copy ${IMX9PROC}-${BOARD}-${BOARD_REV}.dtb to the device's DTB directory on SD/eMMC. (Exact paths depend on your image layout and bootloader configuration.)
Improve Boot Speed
Bootloader​
  1. Boot delay
Disable boot delay in U-Boot:
setenv bootdelay 0
saveenv
reset
  1. Disable console output
Reducing console messages accelerates boot.
  • Kernel quiet mode in bootargs (example):
setenv mmcargs 'setenv bootargs ${jh_clk} console=${console} modprobe.blacklist=${modprobe_blacklist} root=${mmcroot} video=HDMI-A-1:${videores} quiet'
saveenv
reset
  • Or disable console entirely:
setenv console
saveenv
reset
Rootfs​
Optimize services and startup scripts based on your application.
Services​
Disable unneeded services:
sudo systemctl disable <service-name>
# e.g.
sudo systemctl disable boottimes
System Recovery
This section provides procedures to restore the eMMC image.
For more information, refer to the NXP mfgtools (UUU) wiki.
Reflash eMMC from Boot SD Card​
  1. Download mksd-linux.sh: https://github.com/ADVANTECH-Corp/RISC_tools_scripts/blob/mickledore/imx8/mksd-linux.sh
  2. Download "Product_AIM_Release_version"_flash_tool.tgz and unzip it.
  3. Copy mksd-linux.sh into the mk_inand folder.
  4. Run mksd-linux.sh and follow on-screen prompts to reflash from SD to eMMC.
Document version: Ver.E (Yocto 4.3 — nanbield, kernel 6.6.3-1.0.0, i.MX95 / AOM-3511).
