ROM-7720 Yocto 3.0 User Guide
Contents
- 產品介紹(Product introduction )
- 1.1 產品特性(Product Features)
- 1.2 產品官網連結(Product official website link)
- 硬件接口說明(Hardware interface introduction)
- 2.1接口布局和尺寸(Layout and Sizes)
- 2.2 ROM-7720 接口布局圖 Board Dimension Layout
- 2.3 ROM-DB7503 接口布局圖 Board Dimension Layout
- 2.4 主板内置插针式引脚排序方式 (Pin Header defination)
- 2.5 Internal I/O
- 2.6 Rear I/O
- 2.7 接口引脚定義 (Pin definitions)
- 2.8 机械尺寸 (Mechanical Characteristics)
- 快速入门 (Quick Start)
- 3.1 系统下载 (OS Download)
- 3.2 Linux 燒錄方法 (Linux Flash eMMC Method)
- Linux系统的基本使用(Linux System Basic Operating Method)
- 4.1 UUU 使用方法(USB Connection (OTG port))
- 4.2 Display Setting (ROM-7720)
- 4.3 乙太網路使用方法(Ethernent Testing Method)
- 4.4 WiFi使用方法(WIFI Testing Method)
- 4.5 4G使用方法(4G Testing Method)
- 4.6 GPIO使用方法(GPIO Operating Method)
- 4.7 串口使用方法(Serial Port Operating Method)
- 4.8 蓝牙使用方法(BlueTooth Operating Method)
- 4.9 Audio Test:
- 4.10 Audio - SGTL5000
- 4.11 通用方法(General Method)
- 4.12 查看CPU温度(Check CPU Temperature)
- 4.13 查看CPU频率(Check CPU Frequency)
- 4.14 查看内存容量(Check Memory Capacity)
- 4.15 查看存储容量(Check Storage Capacity)
- 4.16 網路Ping測試(Ping Network Testing)
- 4.17 設置RTC (RTC Setting)
- 5Linux BSP編譯方法(Linux BSP Compile Method) 5.1Yocto 3.0 5.2Yocto2.5
- NXP i.MX8 QuadMax 8-Core Processor with 2 Cortex-A72, 4 Cortex-A53 and 2 Cortex-M4F
- Multi OS support in Ubuntu/Debian/Yocto Linux and Android
- 64-bit LPDDR4 4GB
- 4K h.265 decoder, HD h.264 encoder
- Onboard eMMC Flash 16GB, boot selection from SPI/MMC/SD or SATA
- 3 USB 3.0 with OTG, Dual lane MIPI Camera
- Yocto, Android, QNX OS support
Internal I/O
| Position | Description | Connector Type |
| BAT1 | PIN Header for Battery | WAFER 8P 2.54mm 180D(M) DIP A2543WV2-8P |
| BH1 | RTC Battery Holder | BATTERY HOLDER 24.923.48.9 CR2032 BH800.4GG |
| CAN1 | CANBus Port 1 | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| CAN2 | CANBus Port 2 | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| COM1 | COM Port 1 | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| COM3 | COM Port 3 (Debug Port) | BOX HEADER 5x2P 2.54mm 180D(M) DIP 23N6960-10S10 |
| CN4 | PCIex1 Connector 1 | PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF |
| CN5 | PCIex1 Connector 2 | PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF |
| CN6 | PCIex1 Connector 3 | PCIEXPRESS 36P 180D(F) DIP 2EG01817-D2D-DF |
| CN11 | SATA Connector | Serial ATA 7P 1.27mm 180D(M) DIP WATM-07DBN4A3B8 |
| CN12 | SATA Power Connector | WAFER 4P 2.5mm 180D(M) DIP 24W1161-04S10-01T |
| CN22 | GPIOx8 sets | PIN HEADER 10x2P 2.0mm 180D(M) DIP 21N22050 |
| CN25 | MXM 3.0 Connector | MXM Conn. 314P 90D(F) SMD AS0B821-S78B-7H |
| CN26 | M.2 Key E Slots | NGFF 75P 0.5mm 90D(F) H=4.2mm SMD AS0BC21-S40BE |
| CN38 | FAN (Reserved) | WTB Con. 3P 2.54mm 180D(M) DIP A2543WV0-3P-6T-5e |
| CN39 | MIPI-CSI1 (FPC, 4-Lane | FPC 39P, 0.6mm, H0.9mm |
| CN40 | MIPI-CSI0 (FPC, 2-Lane) | FPC 39P, 0.6mm, H0.9mm |
| CN41 | MIPI-CSI0 (Mini-SAS, 2-Lane) | Mini SAS 36P/0.8mm/(M)/LCP/VA/G15u/ S/BK/W |
| CN42 | MIPI-CSI1 (Mini-SAS, 4-Lane) | Mini SAS 36P/0.8mm/(M)/LCP/VA/G15u/ S/BK/W |
| ESPI_CN1 | ESPI | PIN HEADER 6x2P 2.0mm180D(M) SMD 21N22050-12M00B |
| I2C_GP_1 | I2C Pin Header | WAFER BOX 4P 2.00mm 180D(M) DIP 721-81-04TW00 |
| I2C_CN3 | Audio Codec Board | PIN HEADER 2x10P 2.54mm 180D(M) DIP 21N22564 |
| LVDS0 | LVDS0 | Wafer 2x20P/1.25mm/(M)/NY9T/VA/GFL/ S/WH/W |
| LVDS_BK_PWR | LVDS0 Back Light | WAFER BOX 5P 2.0mm 180D(M) DIP A2001WV2-5P |
| LVDS1 | LVDS1 | Wafer 2x20P/1.25mm/(M)/NY9T/VA/GFL/ S/WH/W |
| LVDS1_BK_PWR | LVDS1 Back Light | WAFER BOX 5P 2.0mm 180D(M) DIP A2001WV2-5P |
| SD1 | SD Card Slot | SD CARD 9P 90D(F) SMD WK2192CS3D- 7H |
| SPI_CN1 | SPI Pin Header | PIN HEADER 4x2P 2.54mm 180D(M) SMD 21N22564 |
| SW2 | Reset Button | TACT SW STS-091 SMD 4P H=3.8mm |
| SW4 | SLP Button | TACT SW STS-091 SMD 4P H=3.8mm |
| SW5 | Power Button | TACT SW STS-091 SMD 4P H=3.8mm |
| USB0_OTG1 | USB OTG | Micro USB 5P/0.65mm/(F)/NY9T/GFL/ RA/S/BK/B |
| USB-4-5 | USB Port 4, Port 5 | PIN HEADER 2x5P 2.0mm 180D(M) SMD 21N22050 |
Rear I/O
| Position | Description | Name |
| DCIN | DC Jack | A |
| CN15A | UART Port 0 | B |
| CN15B | UART Port 2 | C |
| CN1A | DP Port | D |
| CN1B | HDMI Port | E |
| CN33 | Type C Controller Programming Header (Reserved Only) | F |
| CN34 | USB Type C | G |
| CN8 | GbE Ethernet Connector Port | H |
| CN3 | USB Port 1/ 2 | I |
| Audio1 | MIC Input/ Audio Output | J |
- 電池(BAT1) & 電池扣(BH1)
- CAN(CAN1,CAN2)
- 串口(COM_DB(COM3)、COM1、UART0 、UART2)
- 显示接口(LVDS、LVDS Backlight、HDMI、DP)
- LAN接口(LAN)
- USB接口(USB1-2、USB-4-5、USB Type C、USB OTG)
- 音频接口(Audio Output &Audio Codec)
- 电源及指示灯和开关机复位按钮(Power 、LED、Power Button、Reset Button、Sleep Button)
- GPIO接口
- MINI_PCIE接口_M.2接口_SPI、I2C_接口
机械尺寸 ( Mechanical Characteristics)
ROM-7720
快速入门 (Quick Start)
系统下载 (OS Download)
- Linux系统 (Linux OS)
使用Flash tool 燒錄鏡像到eMMC (Flash image into eMMC by Flash Tools)
Step0: 檢查SD卡在Linux 環境的代號 (check SD card symbol in Linux system)
Step1: 創造一張可開機的SD 卡 (Create a bootable SD card)
Step2: 將可開機的SD 卡插入底板SD卡卡槽(Plug the SD card into Carrier board 's SD card slot)
Step3: 設定SD卡開機模式SW1 on module(Set boot swtich SW1 on module for SD card boot):
2-3-4 is "ON" for SD
eMMC 開機模式(Boot switch for eMMC) :
4 is "ON" for eMMC
Step4: 打開電源 和 終端機 (Turn on the Power & Terminal)
Step5: 複製Flash iamge tools檔案到系統(Copy Flash image tool to system)
插入U盤到你的Ubuntu電腦上 (Plug the USB Disk into your device)
檢視U盤在Ubuntu系統代號(Check the USB Disk's symbol in Ubuntu System)
掛載U盤在Ubuntu系統中
複製檔案到U盤中(Copy the flash file to USB Disk)
移除U盤並將U盤拆入到ROM7720系統(Remove USB Disk and plug the USB Disk to the ROM-7720 system)
- 複製flash_tool檔案到系統(Copy flash_tool to the system)
- 解壓縮(Extract the image file)
- Execute the flash image tool
移除 SD Card ( Unplug the SD card )
測試 eMMC 開機
Note : eMMC 開機模式(Boot switch for eMMC) :
4 is "ON" for eMMC
U-boot Command :
setenv fdt_file xxxx.dtb
env save
boot
- Display HDMI adv-imx8qm-rom7720-a1.dtb LVDS g070vw01 adv-imx8qm-rom7720-a1_lvds0.dtb adv-imx8qm-rom7720-a1_lvds1.dtb g215hvn01 adv-imx8qm-rom7720-a1_lvds_dual.dtb HDMI + LVDS HDMI + g070vw01 adv-imx8qm-rom7720-a1_hdmi_lvds0.dtb adv-imx8qm-rom7720-a1_hdmi_lvds1.dtb HDMI + g215hvn01 adv-imx8qm-rom7720-a1_hdmi_lvds_dual.dtb LVDS to HDMI adv-imx8qm-rom7720-a1-it6263.dtb
- Audio Codec adv-imx8qm-rom7720-a1-sgtl5000.dtb
Command :
ifconfig
Command:
ping - I eth1 8.8.8.8 or Ping - I eth0 8.8.8.8
Command :
# killall wpa_supplicant
# ifconfig wlan0 up
# wpa_passphrase "SSID" "PASSWORD" > /tmp/wpa.conf
# wpa_supplicant -BDwext -iwlan0 -c/tmp/wpa.conf
# udhcpc -b -i wlan0'''
ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=54 time=2.10 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=54 time=2.10 ms
Command :
Test 4G: (EWM-C117FL06E - USB)
Step 1: Connect EWM-C117FL06E to Mini PCIE slot on 9680015491 and connect
the card to CN6 PCIe_D slot on ROM-DB5901.
Step 2: Connect the antenna 1750007990-01 to the SMA (F) connector on
9680015491
and connect the IPEX connector to MT1 on EWM-C117FL06E module.
Step 3: Connect the Mini USB cable from 9680015491 to USB 2.0 Type A port on
ROM-DB5901.
Step 4: Power on and execute the pppd command to connect to the network.
| GPIO | command |
| 1/2 | 488/489 |
| 3/4 | 353/354 |
| 5/6 | 298/299 |
| 7/8 | 300/301 |
GPIO:
$ function test_gpio_pair(){
cd /sys/class/gpio
local GO=$1 GI=$2
echo gpio$GO output to gpio$GI
echo $GI > export; echo $GO > export
echo out > gpio$GO/direction; echo in > gpio$GI/direction
echo 1 > gpio$GO/value; echo "$GO:$(<gpio$GO/value) ==> $GI:$(<gpio$GI/value)"
echo 0 > gpio$GO/value; echo "$GO:$(<gpio$GO/value) ==> $GI:$(<gpio$GI/value)"
echo $GI > unexport; echo $GO > unexport
cd - > /dev/null
上表的GPIO1-GPIO8 對應到下圖的 GPIO0-GPIO7,注意: 並非插槽針腳的編號(The GPIO1-GPIO8 in the table above correspond to GPIO0-GPIO7 in the diagram below. Note: These are not the slot pin numbers.)
| ROM-DB7503-SCA1E w/ ROM-7720 | i.MX8 | Pinmux | Linux GPIO Number |
| GPIO0 | M40_GPIO0_00 | IMX8QM_M40_GPIO0_00_LSIO_GPIO0_IO08 | 488 |
| GPIO1 | M40_GPIO0_01 | IMX8QM_M40_GPIO0_01_LSIO_GPIO0_IO09 | 489 |
| GPIO2 | FLEXCAN2_RX | IMX8QM_FLEXCAN2_RX_LSIO_GPIO4_IO01 | 353 |
| GPIO3 | FLEXCAN2_TX | IMX8QM_FLEXCAN2_TX_LSIO_GPIO4_IO02 | 354 |
| GPIO4 | ENET1_RGMII_TXC | IMX8QM_ENET1_RGMII_TXC_LSIO_GPIO6_IO10 | 298 |
| GPIO5 | ENET1_RGMII_TX_CTL | IMX8QM_ENET1_RGMII_TX_CTL_LSIO_GPIO6_IO11 | 299 |
| GPIO6 | ENET1_RGMII_TXD0 | IMX8QM_ENET1_RGMII_TXD0_LSIO_GPIO6_IO12 | 300 |
| GPIO7 | ENET1_RGMII_TXD1 | IMX8QM_ENET1_RGMII_TXD1_LSIO_GPIO6_IO13 | 301 |
GPIO number calculation: 480 - (bank * 32) + (pin & 0x1f)
GPIOCHIP info(Yocto3.0):
RS-232 Test
Command :
$ hciconfig hci0 up
$ bluetoothctl
$ discoverable on
$ pairable on
$ scan on
[NEW] FC:18:3C:8D:75:F4 myphone
$ scan off
$ pair FC:18:3C:8D:75:F4
$ connect FC:18:3C:8D:75:F4
Audio Test:
Audio - SGTL5000
Get sgtl5000 device
$ HW=$(aplay -l | grep "^card.*sgtl5000" | sed "s/^card //;s/:.*//"); echo HW=$HW
Use amixer ,and set sgtl5000 headphone / PCM volume
$ amixer -c $HW sset 'Headphone' 90%
$ amixer -c $HW sset 'PCM' 90%
Voice Testing:
$ VA=~/video_audio.mp4 # video file
$ gst-launch-1.0 filesrc location=$VA ! decodebin ! audioconvert ! audioresample ! alsasink device=hw:$HW
root@imx8qmrom7720a1:/# cat /sys/devices/virtual/thermal/thermal_zone0/temp
65400
或者直接以度爲單位顯示
echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 45°
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
>> 900000
cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
>> 1200000
root@imx8qmrom7720a1:/# busybox free -m
total used free shared buffers cached
Mem: 1792540 563488 1229052 17504 18460 139496
-/+ buffers/cache: 405532 1387008
Swap: 0 0 0
root@imx8qmrom7720a1:/# busybox df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 12.8G 2.3G 9.9G 19% /
devtmpfs 394.6M 4.0K 394.6M 0% /dev
tmpfs 875.3M 0 875.3M 0% /dev/shm
tmpfs 875.3M 16.5M 858.8M 2% /run
tmpfs 875.3M 0 875.3M 0% /sys/fs/cgroup
tmpfs 875.3M 4.0K 875.3M 0% /tmp
tmpfs 875.3M 500.0K 874.8M 0% /var/volatile
/dev/mmcblk0p5 7.7M 45.0K 7.3M 1% /run/media/mmcblk0p5
/dev/mmcblk0p1 127.7M 23.9M 103.8M 19% /run/media/mmcblk0p1
/dev/sda1 58.1G 9.5G 48.6G 16% /run/media/sda1
/dev/mmcblk0p6 739.9M 776.0K 685.4M 0% /cache
tmpfs 175.1M 88.0K 175.0M 0% /run/user/0
ping 8.8.8.8
設置RTC (RTC Setting)
root@imx8qmrom7720a1:/# systemctl stop ntpdate.service
root@imx8qmrom7720a1:/# date 031516072023 && hwclock -w && date
Wed Mar 15 16:07:00 UTC 2023
Wed Mar 15 03:46:31 UTC 2023
Wed Mar 15 03:46:39 UTC 2023
完整的 BSP 編譯步驟請參考對應 OS 版本的 README:NXP Yocto 3.0 BSP
