← Back to RSB-3720
Erase eMMC
RSB-3720 16G eMMC:
u-boot=> mmc list
FSL_SDHC: 1 (SD) FSL_SDHC: 2
u-boot=> mmc dev 2 0
switch to partitions #0, OK mmc2(part 0) is current device
u-boot=> mmc part
Partition Map for MMC device 2  --   Partition Type: DOS
Part    Start Sector    Num Sectors     UUID            Type
1     16384           131072          e1f87b96-01     0c Boot
2     147456          30629888        e1f87b96-02     83
3     4341760         20480           e1f87b96-03     83
4     4362240         24997888        e1f87b96-04     05
Extd bad MBR sector signature 0x0000
u-boot=> mmc read ${loadaddr} 0x7fffffff 1
MMC read: dev # 2, block # 2147483647, count 1 ... MMC: block number 0x80000000 exceeds max(0x1d5a000) 0 blocks read: ERROR
u-boot=> mmc erase 0 0x1d5a000
MMC erase: dev # 2, block # 0, count 30777344 ... 30777344 blocks erased: OK
u-boot=> mmc dev 2 1
switch to partitions #1, OK mmc2(part 1) is current device
MMC read: dev # 2, block # 2147483647, count 1 ... MMC: block number 0x80000000 exceeds max(0x2000) 0 blocks read: ERROR
u-boot=> mmc erase 0 0x2000
MMC erase: dev # 2, block # 0, count 8192 ... 8192 blocks erased: OK
u-boot=> mmc dev 2 2
switch to partitions #2, OK mmc2(part 2) is current device
u-boot=> mmc read $loadaddr} 0x7fffffff 1
u-boot=> mmc part
u-boot=>
