IoTGateway/BSP/Android/Android BSP User Guide 6.0.1 for rk
Contents
- 1Android BSP Version
- 2Introduction
- 3Setup Docker 3.1Install Docker 3.2Get base image
- 4Getting Android Source Code 4.1Related version information:
- 5Building Android 6.0.1 image 5.1Start Docker Container 5.2Build Instructions
- 6Flash SD Card /EMMC
- 7Bootimg from MMC/SD on the Advantech RISC board
Android BSP Version
Android 6.0.1
This document describes how to work with the RISC and ELAA Android 6.0.1 Board Support Package (BSP) release. The BSP includes bootloaders; the Android Linux kernel and root file system; and tools and documentation to ease development, deployment, and execution of Android-based systems.
Setup Docker
Install Docker
- Before you use Docker to develop, you have to install Docker on your platform. Please refer to Docker Installation Guide . You are able to install Docker on Linux, Cloud, Windows, and OS X. In general, you may choose to install on Ubuntu . [1]
Get base image
To get the images we provided, you can use docker pull <IMAGE REPOSITORY> to get the images in the image list .
$ docker pull advrisc/u14.04-imx6abv4
$ docker run --name rkABV2500 -it advrisc/u14.04-imx6abv4 /bin/bash
- Android 6.0.1
- kernel 3.10.0
- U-Boot 2014-10
Step1 : To pull down the Android source tree to your working directory from the repositories as specified in the default manifest
$ mkdir myandroid
$ mkdir bin
$ cd myandroid/
$ curl https://storage.googleapis.com/git-repo-downloads/repo > ../bin/repo
$ chmod a+x ../bin/repo
$ ../bin/repo init -u https://github.com/ADVANTECH-Rockchip/android-rk-manifest.git -b android-6.0.1 -m [ release_version.xml ]
$ ../bin/repo sync
=== The release_version.xml is an option, the default value is default.xml please refer : https://github.com/ADVANTECH-Rockchip/android-rk-manifest/tree/android-6.0.1 ====
$ docker run -it --name android6.0-build -v /home/adv/myandroid:/home/adv/android6.0:rw advrisc/u14.04-imx6abv4 /bin/bash
Build Instructions
Set the $JAVA_HOME environment variable
$ export JAVA_HOME=/usr/lib/jvm/java-7-openjdk-amd64/
Set up the environment for building. This only configures the current terminal.
$ source build/envsetup.sh
Execute the Android lunch command. In this example, the setup is for the production image of Advantech RISC platfrom device with userdebug type. If you devices is RSB4680, you will be send command " lunch rsb4680-userdebug
$ lunch $PRODUCT-userdebug
To build boot loader
Perform the following command in terminal console
$ cd u-boot/
$ make rk3288_rsb4680a3_2G_defconfig
$ make -j4
The one file, RK3288UbootLoader_V2.30.10.bin, will be located in directory
To build kernel image
$ cd kernel/
$ make rk3288_adv_defconfig
$ make -j4 rk3288-rsb4680-a3.img
To build system image
$ make -j4
$./mkimage.sh
all android image will be generated in rockdev/Image-rsb4680/ folder.
Problems and Solutions
Compiled kernel
/bin/sh: 1: /home/zengwei/android_rk3288_androi6.0/kernel/scripts/gcc-wrapper.py: Permission denied
make[1]: *** [kernel/bounds.s] Error 126
make: *** [prepare0] Error 2
make: *** Waiting for unfinished jobs....
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTLD scripts/dtc/dtc
make: *** [scripts] Error 2
Solution
$ chmod 555 kernel/scripts/gcc-wrapper.py
Compiled android,Please copy this file before compiling
$ cp .repo/manifests/default.xml manifest.xml
Flash SD Card /EMMC
reference: https://github.com/ADVANTECH-Rockchip/rk3288_tools
SD_Firmware_Tool.v1.46 ;AndroidTool_Release_v2.33 ; DriverAssitant_v4.2
reference:{android_source}/RKDocs/ and {android_source}/RKTools/
