This document describes how to work with the RISC and Qualcomm QLI 2.0 Board Support Package (BSP) release.
Yocto Version​
Yocto 6.0.1
Kernel Version​
Kernel 6.18.30
Host Machine Requirements
OS​
Ubuntu 22.04 or Ubuntu 24.04
CPU​
Intel Core-i7 Processor (>= 8 cores)
RAM​
16+ GB RAM
Disk​
350 GB free disk space (more is recommended and SSD is suggested for better performance)
Docker Install and BSP Download
Install Docker Engine on Your Platform​
Please refer to Docker Installation Guide for details
Pull Docker Images​
sudo docker pull advrisc/u22.04-qcslbv1:20260908
Run Docker Example​
mkdir -p /home/bsp/myLinux
sudo docker run --privileged -it --name qclinux -v /home/bsp/myLinux:/home/adv/BSP:rw advrisc/u22.04-qcslbv1:20260908 /bin/bash
adv@7cc0fa834366:~$ sudo chown adv:adv -R BSP
Download BSP​
cd BSP
repo init -u https://AIM-Linux@dev.azure.com/AIM-Linux/adv-arm-yocto-bsp/_git/adv-arm-yocto-bsp -b qcom-linux-wrynose -m ${OFFICIAL_MANIFEST}
repo sync -c -j${YOUR_CPU_CORE_NUM}
kas_ci="meta-advantech-qualcomm/ci"
kas_list="${kas_ci}/base.yml" # Base source
kas_list="${kas_list}:${kas_ci}/addons/capsule.yml" # Option: Capsule related meta layer
kas checkout ${kas_list}
PlatformMachineOFFICIAL_MANIFEST
QCS6490AOM-2721aom2721a1_yocto6.0.1-qli2.0_v0.0.1_kernel-6.18.30_qcs6490.xml
IQ9075AIR-055air055a1_yocto6.0.1-qli2.0_v0.0.1_kernel-6.18.30_iq9075.xml
If you want to get latest bsp
cd BSP
repo init -u https://AIM-Linux@dev.azure.com/AIM-Linux/adv-arm-yocto-bsp/_git/adv-arm-yocto-bsp -b qcom-linux-wrynose -m adv-6.18.30-qli.2.0.xml
Get and Unzip the Downloads Files​
Yocto downloads file:[ downloads.qualcomm.qli.2.0.tar ]
The size of the compressed file is 58.13 GB
The md5sum of the compressed file is 3601cdea7f0869eb8bacb0b42625d3d1
Build Instructions
Build Yocto Images in the Docker Container​
cd /home/adv/BSP
kas_list="${kas_ci}/machines/${YOCTO_MACHINE_NAME}.yml"
kas_list="${kas_list}:${kas_ci}/feature/performance.yml" # Optional: Fast boot & minimal initramfs settings
kas_list="${kas_list}:${kas_ci}/distro/sota.yml" # Optional: OSTree OTA Updates
kas_list="${kas_list}:${kas_ci}/addons/capsule.yml" # Optional: NHLOS OTA Updates
kas build ${kas_list}
MachineYOCTO_MACHINE_NAME
AOM-2721aom2721a1
AIR-055air055a1
Output images: build/tmp/deploy/images/${YOCTO_MACHINE_NAME}/qcom-multimedia-proprietary-image-${YOCTO_MACHINE_NAME}.rootfs.qcomflash
UFS and eMMC Flash Images
The output image folder supports UFS flashing by default. You may need to prepare the flash folder manually depending on your target storage type (UFS or eMMC). The partition_ufs/ and partition_emmc/ directories contain partition layout files specific to each storage type. You can use the following method to prepare for UFS or eMMC flashing.
UFS Flash Images​
1. Remove all gpt*.bin and *.xml files from the image root folder.
cd <image_folder>
rm -f gpt*.bin *.xml
2. Copy the following files from partition_ufs/ to the image root folder.
for f in partition_ufs/gpt_backup{0..5}.bin; do [ -f "$f" ] && cp "$f" .; done
for f in partition_ufs/gpt_main{0..5}.bin; do [ -f "$f" ] && cp "$f" .; done
for f in partition_ufs/rawprogram{0..5}.xml; do [ -f "$f" ] && cp "$f" .; done
for f in partition_ufs/patch{0..5}.xml; do [ -f "$f" ] && cp "$f" .; done
cp partition_ufs/provision*.xml .
eMMC Flash Images​
cd <image_folder>
2. Copy the following files from partition_emmc/ to the image root folder.
for f in partition_emmc/gpt_backup{0..1}.bin; do [ -f "$f" ] && cp "$f" .; done
for f in partition_emmc/gpt_main{0..1}.bin; do [ -f "$f" ] && cp "$f" .; done
for f in partition_emmc/rawprogram{0..1}.xml; do [ -f "$f" ] && cp "$f" .; done
for f in partition_emmc/patch{0..1}.xml; do [ -f "$f" ] && cp "$f" .; done
The folder is now ready for eMMC flashing.
Device Guides
QCS6490 Device Guides​
SW112
UFSONON
eMMCOFFON
SW212
USB EDL ModeON
Normal ModeOFF
ATON
ATXOFF
IQ9075 Device Guides​
SW1 1
ON   AT
OFF ATX
SW3           1   2
USB EDL Mode ON   ON
Normal  Mode OFF OFF
Recovery & Rescue
Using BSP Launcher or QDL (Qualcomm Device Download) tool to flash software images to the device.
Prepare images​
Get the Official Images and Unzip​
EX:
sudo tar -zxvf aom2721a1_yocto6.0.1-qli2.0_v0.0.1_kernel-6.18.30_qcs6490_8g_ufs+emmc_2026-10-06.tgz
Build Folder Images​
cd ${workspace}/build/tmp/deploy/images/${YOCTO_MACHINE_NAME}/qcom-multimedia-proprietary-image-${YOCTO_MACHINE_NAME}.rootfs.qcomflash
Use BSP Launcher to Flash image on x86 Ubuntu Host​
Please use BSP Launcher
Use QDL Tool to Flash Image​
Windows x86 QDL User and Installation Guide
Overview
Qualcomm Device Loader (QDL ) is a software tool that communicates with Qualcomm USB devices to upload a flash loader and flash software images.
Installation Guide
  1. Download Qualcomm Device Loader from below link https://softwarecenter.qualcomm.com/catalog/item/Qualcomm_Device_Loader
  2. According your host mach to select OS type and which version you want qdl_downalod_page.png
  3. Unzip download file in any path
  4. Serach Edit the system environment variables (環境變數) to open Advanced system settings
    Also you can open Settings app → System → About → Advanced system settings → Advanced qdl_open_system_environment.png
  7. Select New (新增) and type the Qualcomm Device Loader path then select OK (確定) qdl_add_environment_path.png
  8. Search cmd to open Windows Terminal
winUSB Installation Guide
  1. Let board enter EDL mode
Please check Device Guides for more details
  1. Connect the EDL USB port to PC
  2. Search device manager (裝置管理員)
  4. Open install_driver.bat in QDL path to install winUSB driver qdl_install_usb_driver_bat.png
Linux x86 QDL User and Installation Guide
Overview
Installation Guide
  1. Add Qualcomm USB udev rules (one-time prerequisite)
    Add below line in /etc/udev/rules.d/51-qcom-usb.rules
    SUBSYSTEMS=="usb", ATTRS{idVendor}=="05c6", ATTRS{idProduct}=="9008", MODE="0666", GROUP="plugdev"
  2. Restart udev service
    sudo systemctl restart udev
  3. Download Qualcomm Device Loader from below link https://softwarecenter.qualcomm.com/catalog/item/Qualcomm_Device_Loader
  4. According your host mach to select OS type and which version you want qdl_linux_download_page.png
  5. Unzip download file in any pah
    unzip QDL_2.7.1_Linux_x64.zip
  6. Change the qdl tools permission
    sudo chmod 755 QDL_2.7.1_Linux_x64/qdl*
  7. Install dependency packages
    sudo apt-get install libxml2 libzip-dev
    You can see the QDL_User_Guide.pdf for more details
  9. Move qdl tools to global path
    sudo mv QDL_2.7.1_Linux_x64/qdl* /usr/local/bin/
Let device in EDL mode and connect the EDL USB Port to HOST.
Open terminal and enter the image folder:
EX:
cd ${workspace}/build/tmp/deploy/images/aom2721a1/qcom-multimedia-proprietary-image-aom2721a1.rootfs.qcomflash
Choosing the platform to flashing image.
QCS6490​
QCS6490 Platform Flashing Guide
Flash UFS provision (Once only)
qdl prog_firehose_ddr.elf provision_ufs31.xml
Flash UFS All Images
qdl prog_firehose_ddr.elf rawprogram*.xml patch*.xml
Flash EMMC All Images
qdl --storage emmc prog_firehose_ddr.elf rawprogram*.xml patch*.xml
IQ9075​
IQ9075 Platform Flashing Guide
qdl prog_firehose_ddr.elf provision_1_2.xml
Flash Safety Island
  1. Enter sail_nor folder
cd sail_nor
  1. Flash sail_nor
qdl --storage spinor prog_firehose_ddr.elf rawprogram0.xml patch0.xml
  1. Back to the root path
cd ..
Switch device to Normal Mode and power on device
Customization
Setting up SDK​
Not support now
Setting up cross compiling environment​
Not support now
