← Back to RSB-4810
RSB-4810 Debian10 user guide
Contents​
  • 1产品介绍(product presentation) 1.1产品特性(product feature) 1.2产品官网链接(Product official website link)
  • 2硬件接口说明 2.1接口布局圖 Board Layout 2.2接口尺寸 Board Dimension 2.3接口引脚定義 (Pin definitions) 2.4List
  • 4Linux系统的基本使用(Linux System Basic Operating Method) 4.1乙太網路使用方法(Ethernent Testing Method) 4.2WiFi使用方法(WIFI Testing Method) 4.34G使用方法(4G Testing Method) 4.4蓝牙使用方法(BlueTooth Operating Method) 4.5音訊使用方法(BlueTooth Operating Method) 4.6CAN2.0 測試( CAN Test method) 4.7I2C 測試( I2C Test method) 4.8看門狗測試 (Watch Dog Test method) 4.9UART測試 (UART Test method) 4.10GPIO測試(GPIO Test method) 4.11Display測試(Display Test method) 4.11.1How_to_Config_Multi-Display 4.12遠程訪問及文件傳輸(Remote Access and File Transimmion)
  • 5通用方法(General Method)
  • 6How to build Debian BSP (Debian BSP 編譯) 6.1Linux BSP User Guide for RSB-4810 series Debian11
产品介绍(product presentation)​
产品特性(product feature)​
  • Rockchip RK3568 Arm Quad Cortex-A55, up to 2.0GHz
  • Built-in NPU with processing performance of up to 0.8 TOPS
  • Onboard 2/4GB LPDDR4 memory and 16/32GB eMMC
  • Supports 1 x HDMI 2.0 4K, 1 x LVDS/MIPI-DSI, and 1 x eDP
  • Supports 4K H.264/H.265 video decoder
  • Provides 2 x GbE, 1 x SATA 3.0, 6 x UART, 2 x USB 3.0, 2 x USB 2.0, 1 x USB OTG, and 2 x CAN FD
  • Provides a M.2 E Key with PCIE 3.0/USB 2.0/SDIO/UART signal for Wi-Fi 5/6 Modules, and a MINI-PCIE with PCIE 3.0/USB 2.0 signal for LTE/5G Modules
  • Supports Linux and Android OS
RSB-4810 - Rockchip Arm Cortex-A55 RK3568 3.5" SBC - Advantech
硬件接口说明​
接口布局圖 Board Layout​
接口尺寸 Board Dimension​
接口引脚定義 (Pin definitions)​
Jumper List
J1MASKROM mode select Short pin 12 and power on the RSB-4810 to enter MASKROM mode. Change back to pin 23 before click "Run" to flash image
J2CAN impedance matching
J3CAN impedance matching
J4OTG Mode selection, default USB3.0 host
SW1AT & ATX Mode Switch, default AT mode
BLP1LVDS BKL PWR 3.3V&5V level select, default 5V
BLP2LVDS BKL PWR 12V select
VDD1EDP VDD 3.3V &5V level select, default 3.3V
VDD2LVDS VDD 3.3V & 5V level select, default 3.3V
J5COM5,COM6 power 12/5V level select, default 5V
List​
AUDIOAudio pin header (Headphone, Mic in, Speaker)
EDPeDP CONN
LVDSLVDS CONN
BLLVDS Back light Control
SATASATA3.0
MINIPCIEMINI PCIe 52P
SIMNano SIM card
M2M.2 E-Key CONN
SDMicro SD slot
PWRBTNPower button and LED
DCIN112V DC jack
COM1RS-232 pin header
COM2RS-232 DB9
HDMIHDMI CONN
CAN1/2CAN FD CONN
USB1/2USB pin header
USB3/4USB Type A ((2 x USB3.0, the lower Type A connector can be configured to OTG by jumper setting))
SATAPSATA Power
LAN1LAN1
LAN2LAN2
BATRTC CONN
COM3/4COM3 and COM4 with RS-232 or RS-485
COM5/6COM5 and COM6 with RS-232
RSTReset button
CN1GPIO CONN
I2C1I2C pin header
Debug portDebug connector
快速入门 (Quick Start)​
系统下载 (OS Download)​
Note:  LIV=Yocto Linux, UIV=Ubuntu, DIV=Debian, AIV=Android
LBV=BSP, LIV=Image
PlatformProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagSDKCommentCAN2.0 Patch
RK3568RSB-4810DIV1300062022/11/01RTM(old)Release noteBaidu Password:a887 DropboxRK3568_RISC_DIV130006.xmlMP versionCAN2.0 Errata 提取码:a887 Patch:Baidu Password:a887
  • Alpha:  Basic I/O function bring up by RD;
  • Beta:  Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
  • GA:  Beta version by QE verification;
  • RTM:  Beta version by SI/Power/QE verification and pre-loaded;
How to update images .​
There are three ways to update images:
Usering_RKTool.​
SD_update image.​
Linux系统的基本使用(Linux System Basic Operating Method)​
乙太網路使用方法(Ethernent Testing Method)​
Command : ifconfig
WiFi使用方法(WIFI Testing Method)​
4G使用方法(4G Testing Method)​
蓝牙使用方法(BlueTooth Operating Method)​
音訊使用方法(BlueTooth Operating Method)​
CAN2.0 測試( CAN Test method)​
Note:RK3568 CAN2.0 Errata;
CAN2.0 Errata: CAN2.0 Errata 提取码:a887
CAN2.0 Patch: Baidu Password:a887
Short CAN1/2 Pin header ,Loopback test for example:
CAN0_D+->CAN1_D+
CAN0_D-->CAN1_D-
输入指令:
# ip link set can0 down
# ip link set can0 type can bitrate 1000000
# ip link set can0 up
# ip -details link show can0
# candump can0 &
# ip link set can1 down
# ip link set can1 type can bitrate 1000000
# ip link set can1 up
# ip -details link show can1
# cansend can1 123#55
can0  123   [1]  55
I2C 測試( I2C Test method)​
看門狗測試 (Watch Dog Test method)​
UART測試 (UART Test method)​
How to Configure RS-232/485 Mode Enter U-boot interrupt mode. Connect the device to the debug port and open the debug console. Press “ctrl + c” before powering on the device.
The following information should be displayed on the debug console:
Hit any key to stop autoboot: 0
Then input the following command to configure the UART mode.
RS-485 Mode:
setenv uart_mode 0x0c
saveenv
reset
RS-232 Mode:
setenv uart_mode 0x00
saveenv
reset
Note: The default value is RS-232. Cp210x supports four ports, but for RSB-4810 only ttyUSB2 and ttyUSB3 support RS-485 mode.
In the above command “setenv uart_mode 0x0c”, 0x0c means set bit2(ttyUSB2) and bit3(ttyUSB3) to 1 (0 means to RS-232; 1 means to RS-485). To configure just ttyUSB2 (or ttyUSB3) to RS-485 mode, change 0x0c to 0x04 (or 0x08).
GPIO測試(GPIO Test method)​
Display測試(Display Test method)​
How_to_Config_Multi-Display​
遠程訪問及文件傳輸(Remote Access and File Transimmion)​
查看主板IP位址 ( Chech IP Address ):
ID: root password:123456
通用方法(General Method)​
QT Toolchain
查看CPU温度(Check CPU Temperature) # cat /sys/devices/virtual/thermal/thermal_zone0/temp   40000
或者直接以度爲單位顯示 echo $[$(cat /sys/class/thermal/thermal_zone0/temp)/1000]° >>> 40°
查看CPU频率(Check CPU Frequency) cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq >> 1200000 cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq >> 1800000
查看内存容量(Check Memory Capacity) # busybox free -m
查看存储容量(Check Storage Capacity) # busybox df -h
調整亮度(Change the backlight)
Note: connect with LVDS Panel  , default value is 200
root@linaro-alip:# echo 100 > /sys/class/backlight/backlight/brightness root@linaro-alip:# echo 200 > /sys/class/backlight/backlight/brightness root@linaro-alip:~#
root@linaro-alip:# cat /sys/class/backlight/backlight/max_brightness 255 root@linaro-alip:# cat /sys/class/backlight/backlight/brightness 200
How to build Debian BSP (Debian BSP 編譯)​
Linux BSP User Guide for RSB-4810 series Debian10​
