← Back to RSB-4680
RSB-4680 Android 8 User Guide
Contents​
  • 1產品介紹(Product Presentation) 1.1產品特性(Product Features) 1.2产品官网链接(Product official website link)
  • 2接口布局和尺寸(Layout and Sizes) 2.1接口布局圖 Board Dimension Layout 2.2Connector List 2.3接口引脚定義 (Pin definitions) 2.4机械尺寸  (Mechanical Characteristics)
  • 3快速入门 (Quick Start) 3.1系統下载 (OS Download) 3.2Debian 燒錄方法 (Debiand Flash eMMC Method)
  • 4Linux系统的基本使用(Linux System Basic Operating Method) 4.1User Guide
  • 5通用方法(General Method) 5.1查看CPU温度(Check CPU Temperature) 5.2查看CPU频率(Check CPU Frequency) 5.3查看GPU温度(Check GPU Temperature) 5.4查看GPU频率(Check GPU Frequency) 5.5查看DDR频率(Check DDR Frequency) 5.6查看存储容量(Check Storage Capacity) 5.7网路Ping測試(Ping Network Testing) 5.8設置RTC (RTC Setting)
  • 6Debian BSP編譯方法(Debian BSP Compile Method) 6.1Linux BSP build and update image
產品介紹(Product Presentation)​
產品特性(Product Features)​
  • Rockchip ARM Cortex-A17 RK3288 Quad Core, up to 1.6GHz
  • Onboard 2GB DDR3L memory and 8GB eMMC
  • HDMI 3840x2160 at 60Hz, VGA 1920x1200 at 60Hz, Dual Channel 18/24/30 bit LVDS
  • Support 4K H.264/H.265 Video decoder
  • 6 UART, 6 USB2.0, 1 GbE, 8 GPIO, 1 MIPI CSI, 1 SPI
  • M.2 for WIFI/BT support, mini-PCIe for 3G/4G support
  • Support Linux and Android
RSB-4680 - 研华 (advantech.com.cn)
接口布局和尺寸(Layout and Sizes)​
接口布局圖 Board Dimension Layout​
Connector List​
BATRTC Battery Connector
CN2Audio
CN3GPIO
CN418/24/30 bit Dual-Channel LVDS
LVDS_BLLVDS Backlight Control
CN5Power Button & LED
CN7Recover
CN1612V DC Jack
CN20Internal USB Pin Header
USB34Dual Type A USB Connector
OTGMicro USB Connector
CN21SPI
CN22I2C
COMInternal RS232 (COM6 & COM7 with 12V/5V Power)
COM13Internal RS232 (COM1 & COM3)
COM4External COM (With RS232 &RS-485)
DEBUGCOM2 or Console
HDMIHDMI
LANLAN
M.2M.2
MINIPCIEMINIPCIE
SDMicro SD
SIM1Standard SIM
SW2Reset Button
VGAVGA
接口引脚定義 (Pin definitions)​
机械尺寸  ( Mechanical Characteristics)​
快速入门 (Quick Start)​
系統下载 (OS Download)​
Debian 9.8
PlatformProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagComment
RK3288RSB-4680DIV210452021/08/10AlphaRelease_NoteBaidu Password:a887 DropboxRK3288DIV21045.xml
DIV210412020-04-21BetaRelease NoteBaidu Password:a887RK3288DIV21041.xml
Debian 10
Image VersionProductDateReleaseRelease NoteBinary OS Image Name
DIV230009RSB-46802021-04-13BetaRelease Note4680A3AIM20DIV230009_2021-04-13.img.tgz
Debian 燒錄方法 (Debiand Flash eMMC Method)​
1. Update through Android Tool
2. Usering bootup_sd_disk made_by SDDiskTool
NOTE :
This way only support Linux(Debian9) upgrade to Linux(Debian9) 、 Android6.0 upgrade to Android6.0 or Android8.1 upgrade to Android8.1.
If the device is in Android, you want to upgrade to Linux(Debian9), please use Android Tool.
Linux系统的基本使用(Linux System Basic Operating Method)​
User Guide​
通用方法(General Method)​
查看CPU温度(Check CPU Temperature)​
root@linaro-alip:/# cat /sys/class/thermal/thermal_zone0/temp
42769
查看CPU频率(Check CPU Frequency)​
cat /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq
600000
cat /sys/devices/system/cpu/cpufreq/policy4/scaling_cur_freq
900000
查看GPU温度(Check GPU Temperature)​
root@linaro-alip:/# cat /sys/class/thermal/thermal_zone1/temp
43042
查看GPU频率(Check GPU Frequency)​
root@linaro-alip:/# cat /sys/class/devfreq/ffa30000.gpu/cur_freq
200000000
查看DDR频率(Check DDR Frequency)​
root@linaro-alip:/# cat /sys/class/devfreq/dmc/cur_freq
0
查看存储容量(Check Storage Capacity)​
root@linaro-alip:/# df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       3.9G  2.5G  1.3G  67% /
devtmpfs        991M  8.0K  991M   1% /dev
tmpfs          1000M     0 1000M   0% /dev/shm
tmpfs          1000M  8.9M  991M   1% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs          1000M     0 1000M   0% /sys/fs/cgroup
/dev/mmcblk1p9  3.1G  3.3M  3.1G   1% /userdata
/dev/mmcblk1p7   63M   13M   48M  21% /oem
tmpfs           200M  8.0K  200M   1% /run/user/1000
tmpfs           200M     0  200M   0% /run/user/0
网路Ping測試(Ping Network Testing)​
Command:ifconfig
root@linaro-alip:~# ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:9d:3a:25:6f  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.127.100  netmask 255.255.255.0  broadcast 192.168.127.255
        inet6 fe80::3269:bcb5:eaa7:b6b7  prefixlen 64  scopeid 0x20<link>
        ether c4:00:ad:41:6d:fb  txqueuelen 1000  (Ethernet)
        RX packets 175  bytes 16715 (16.3 KiB)
        TX packets 109  bytes 7172 (7.0 KiB)
        device interrupt 44
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 980  bytes 66000 (64.4 KiB)
        TX packets 980  bytes 66000 (64.4 KiB)
Command:Ping 192.168.127.100
root@linaro-alip:~# ping 192.168.127.100
PING <span style="color:#FF0000;">192.168.127.100</span> (192.168.127.100) 56(84) bytes of data.
64 bytes from 192.168.127.100: icmp_seq=1 ttl=64 time=0.200 ms
64 bytes from 192.168.127.100: icmp_seq=2 ttl=64 time=0.161 ms
64 bytes from 192.168.127.100: icmp_seq=3 ttl=64 time=0.147 ms
^C
--- <span style="color:#FF0000;">192.168.127.100</span> ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2ms
rtt min/avg/max/mdev = 0.147/0.169/0.200/0.024 ms
設置RTC (RTC Setting)​
root@linaro-alip:~# sudo su
root@linaro-alip:~# date
Tue Oct 26 08:16:04 UTC 2021
root@linaro-alip:~# date -s "2022-9-1 13:00:00"
Thu Sep  1 13:00:00 UTC 2022
Thu Sep  1 13:00:10 UTC 2022
root@linaro-alip:~#hwclock -w
root@linaro-alip:~# hwclock
Thu Sep  1 13:01:07 2022  0.000000 seconds
Debian BSP編譯方法(Debian BSP Compile Method)​
Linux BSP build and update image​
