← Back to RSB-4680
RSB-4680 How to use GPIO.
Configuration/Test​
Configuration​
The RK3288 bank/bit notation for GPIOs must be formed as "GPIO<GPIO_bank>_<gpio_bit>"
The numeric value of GPIO is calculated as follows:
32 x (gpio_bank) + gpio_bit - 8
Group GPIO0 only 24 gpios,So each GPIO Num subtracts 8.
gpio_bit : A0~A7 0-7 B0~B7 8-15 C0~C7 16-23 D0~D7 24-31
E.g. GPIO2_A4 becomes 60
RSB-4680
GPIO NumberGPIO formedNumeric Representation
GPIO0GPIO7_A3219
GPIO1GPIO7_A4220
GPIO2GPIO7_A5221
GPIO3GPIO7_C5237
GPIO4GPIO8_A2250
GPIO5GPIO8_A3251
GPIO6GPIO8_A0248
GPIO7GPIO8_A1249
Test
Export GPIO then you can use control GPIO from userr space through sysfs
Export GPIO0
# echo 219 > /sys/class/gpio/export
Set GPIO direction to in/out
# echo "out" > /sys/class/gpio/gpio219/direction
Set GPIO value 0/1 if GPIO pin define is output
#  echo 1 > /sys/class/gpio/gpio219/value
Used as IRQ signal
Note:You have to configure GPIO to input
#  echo "rising" > /sys/class/gpio/gpio219/edge
  • rising: Trigger on rising edge
  • falling: Trigger on falling edge
  • both: Trigger on both edges
  • none: Disable interrupt on both edges
Unexport GPIO0
# echo 219 > /sys/class/gpio/unexport
Test​
GPIO 219 and GPIO 220 are taken as an example:
  • Connect GPIO 219 and GPIO 220
  • Export GPIO 219 and GPIO 220
# echo 220 > /sys/class/gpio/export
  • Set GPIO 219 to output
  • Set GPIO 220 to input
# echo "in" > /sys/class/gpio/gpio220/direction
  • Change GPIO 219 to 1 and read GPIO 220 value
# cat /sys/class/gpio/gpio220/value
1
  • Change GPIO 219 to 0 and read GPIO 220 value
# echo 0 > /sys/class/gpio/gpio219/value
0
