← Back to RSB-4680
RSB-4680 How to Config Multi-Display.
RSB-4680 surport 3 display ports : eDP、LVDS、HDMI . Only two ports work at the same time .
You can config Multi-Display to eDP + HDMI 、eDP + LVDS、LVDS + HDMI .
Contents​
  • 1Enter U-boot interrupt mode
  • 2eDP + HDMI
  • 3eDP + LVDS
  • 4LVDS + HDMI
  • 5Default Support Display
Enter U-boot interrupt mode​
Connect device to debug port, and open debug console. See more : .
Press "ctrl + c" key before power up the device, until get the following information on debug console :
Hit any key to stop autoboot: 0
=> <INTERRUPT>
Then you can input the following cammand to config Multi-Display.
eDP + HDMI​
setenv prmry_screen edp-1920x1080
setenv extend_screen hdmi-default
saveenv
reset
eDP + LVDS​
setenv extend_screen lvds-g070vw01
saveenv
reset
LVDS + HDMI​
setenv prmry_screen hdmi-default
saveenv
reset
Default Support Display​
PortRSB4680USM110
edpedp-1920x1200 edp-1920x1080 edp-1024x768edp-1920x1080 edp-1280x720 edp-1024x768 edp-720x480 edp-640x480
lvdslvds-g070vw01 lvds-idk1110wp lvds-g150xgel05 lvds-g215hvn01 lvds-p460hvn02NA
hdmihdmi-defaulthdmi-default
NOTE :
  1. The name of the panel must begin with "edp-"、"lvds-" or "hdmi-" .
And it can be found in "kernel/include/dt-bindings/display/screen-timing/{LCDNAME}.dtsi" like :
lvds_g070vw01: lvds-g070vw01
  1. If there is no configuration, you will get default setting :
edp-default (edp-1920x1080) and hdmi-default as default setting.
  1. Check your configuration in Terminal or debug console.
cat /proc/cmdline
... prmry_screen=edp-1920x1080 extend_screen=hdmi-default
