← Back to RSB-4680
RSB-4680 How to use UART.
Contents​
  • 1Overview 1.1RS-485
  • 2Boards 2.1RSB4680 Borad
Overview
The Android/Linux UART/serial port access from user is through the tty-devices. The tty-devices have different names depending on UART driver on different board.
RS-485​
RS-485 uses half-duplex communication, which means that one medium is shared for transmitting and receiving data. Therefore the system needs to control the RS-485 transceiver's transmit mode. Usually the UART RTS signal is used to switch the transmitter on and off.
Boards
RSB4680 Borad​
COM NameDevice NodeRemark
COM0/dev/ttyS0for BT Data
COM1/dev/ttyS1
COM2/dev/ttyS2Debug Port
COM3/dev/ttyS3
COM4/dev/ttyS4Supprot RSB485
COM5/dev/ttyUSB0Usb to Uart
COM6/dev/ttyUSB1Usb to Uart
Note :
  1. Only COM1、COM2、COM3、COM4、COM5 and COM6 are designed for custom using.
  2. Only COM4 support RSB485.
  3. COM2 is designed as debug port default.
