← Back to AOM-3821
AOM-3821 Android 14 user guide
Contents
  • 1產品特性(Features) 1.1產品官網鏈接(Product official website link)
  • 2接口布局和尺寸(Layout and Sizes) 2.1AOM-3821 Board Dimension Layout 2.2AOM-3821 Mechanical Specifications 2.3Electrocal Specifications 2.4Environmental Specifications
  • 3AOM-DB3500  Board Dimension Layout 3.1Connector Locations 3.2I/O Connector Locations 3.3Mechanical Diagram 3.4Assembly Diagram
  • 4AOM-3821 on AOM-DB3500 Connector,Jumper,Switch Settings 4.1Connector List 4.2Jumper Locations 4.3Switch Locations 4.4Button Locations 4.5LED Function List
  • 5快速入门(Quick Start) 5.1系统下载(OS Download) 5.2Debian 烧录方法(Debian flash eMMC Method)
  • 6Linux 基本使用方式(Basic usage of Linux)
  • 7Linux BSP 编译方法(Linux BSP Compile Method) 7.1Linux_BSP_User_Guide_for AOM-3821_Series-Debian12
產品特性(Features)
  • Rockchip RK3588 Arm Quad Cortex-A76 2.4GHz and Quad Cortex-A55 1.8 GHz
  • Onboard 4/8 GB LPDDR4 memory and 32/64 GB eMMC
  • Supports 8K @ 60 fps H.265/VP9 video decoding and 8K @ 30 fps H.265/H.264 video encoding
  • Supports HDMI, DP, eDP and LVDS/DSI
  • 4 x PCIe 3.0, dual gigabit LAN, 2 x USB 3.0, USB2.0 OTG, SATA 3.0, 2 x CAN, 4 x MIPI-CSI, 3 x UART
  • Supports Linux Debian11 and Android
AOM-3821 - 研华
  • Dimension:RTXe form factor size:(D X W)77 x 65 mm
  • Height on Top:2mm
  • Height on Bottonm:1.5mm
  • Power Supply Voltage:DC-in 5V+-5%
  • Power Supply Current:
ModelMaximum modeKernel idleSleep mode
AOM-38217.61W1.40W0.07W
Test Conditions: 1. Test loading: - Maximum load mode: Running programs* - Idle mode: DUT power management off and no running any program 2. OS: Debian12 *Programs software: Burnin.sh (full loading for CPU+NPU+GPU+VPU)
  • Operating Temperature:0~70 °C / -40 ~ 85 °C
  • Operating Humidity: 40°C @ 95% relative humidity, non-condensing
  • Storage Temperature: -40 ~ 85 °C
  • Storage Humidity: 95% @ 60 °C
Connector Locations
Mechanical Diagram
For more details regarding our 2D/3D models, please visit the Advantech support service website at: http://www.advantech.com .
Board Mechanical Diagram - Front
Board Mechanical Diagram – Side1
Board Mechanical Diagram - Side2
Assembly Diagram
These figures demonstrate the order of assembly needed when attaching the thermal module and COM module to the carrier board.
Connector List
LableFunctionLableFunction
DC IN4Pin Terminal Connector for DC IN(Input)CN3GPIO Pin Header
ROM-AB1RTXe connectorHDMI RXHDMI RX Connector(Input)
ROM-CD1RTXe connectorCAN0_1CAN Bus Connector
PWRBTN PHPower Button Pin HeaderHDM A TYPEHDMI Connector
RSTBTN_PHReset Button Pin HeaderTYPEC_DPDP&USB2.0+USB 3.0 Typec Connector
DEBUGDebug PortSDSD Card Connector
MIC1MIC-IN Connector(Input)MICRO USBMicro USB Connector(USB2.0 only)
LOUT1Headphones Connector(Output)USB1/2TypeA USB Connector(2xUSB2.0+USB3.0)
MIC2MIC-IN Connector(Input)SPI_CN2SPI0 Pin Header
LOUT2Headphones Connector(Output)SPI_CN1SPI1 Pin Header
PCIEA-X4PCIe x4 ConnectorGMAC0GMAC0 Connector
EDPEDP ConnectorGMAC1GMAC1 Connector
EDP BLEDP Backlight ConnectorERP DEBUGEPR MCU FW Update Connector
I2S0I2S0 ConnectorRTC BATRTC Coin Battery Connector
I2S1I2S1 ConnectorCN1Watchdog Connector
SIMSIM card ConnectorM.2_BM.2 Key-B Connector
CN2I2C Connector for I2C0M.2_E1M.2 Key-E Connector
CM1_2COM Port Port1,2 Con-nectorM.2_E2M.2 Key-B Connector(for SDIO)
CN4I2C Connector for I2C1CN6Resvered Signal Connector
CSI0_FPCMIPI FPC Connector for CSI0CN5SDIO Connector(for SD1)
CSI1_FPCMIPI FPC Connector for CSI1CN7Supply +5V Connector
CSI2_FPCMIPI FPC Connector for CSI2
Jumper Locations
Switch Locations
Button Locations
LableFunctionLableFunctiion
PWR BTNPower ButtonJ8M2_E1 Power Select
RST BTNReset ButtonJ10M.2_B Power Selsct
SW1BOOT SELECT SwitchJ9UART1 to M2_E2 or M2_E1 Connector Select
SW2USB0 PWE_EN Select SwitchJ2AT/ATX Select Header
SW3USB0 OC# Select SwitchJ37GPIO4_Z_G Selection
J12EDP0/LVDS0/DSI Hot-Plug   Detect Selection HeaderJ26GPIO0_Z_G Selection
J15EDP VDD Power SelectJ28GPIO0 Selection
J16EDP Backlight Power SelectJ31GPIO4 Selection
J17Header For SD1 SelectionJ20GPIO7 Selection
J18Header For SD1_CD# SelecttionJ24GPIO7A Selection
J30Header For  EDP0_BKLT_EN and EDP0_BKLT_PWMJ25GPIO1 Selection
J22CAN0 BUS Terminal ResistorJ27GPIO1_Z_G Selection
J23CAN1 BUS Terminal ResistorJ29GPIO6 Selection
J14Header For WDT_OUT#  Link SelectionJ32GPIO5 Selection
J13Header For WDT_OUT# SelectionJ1SD0_WP Select Header
J11TYPEC_OTG_ID Selection HeaderJ5SPI1_CS#  Select Header
J6SPI0_CS#  Select HeaderJ7USB3 2.0 OTG and Host Select  Header
J35U7 mode SelectJ36U58 mode Select
LED Function List
LocationFunction
+V12 LEDCarrier Board +V12 Indicate
+V12 SB LEDCarrier Board +V12_SB Indicate
+V3.3 LEDCarrier Board +V3.3 Indicate
+V3.3 SB LEDCarrier Board +V3.3_SB Indicate
+V5 LEDCarrier Board +V5 Indicate
+V5 SB LEDCarrier Board +V5_SB Indicate
MOD_PWR_LEDModule Power Indicate
LED1M2_E1-Key LED1 Indicate
LED2M2_E1-Key LED2 Indicate
LED3M2_B-Key LED3 Indicate
LED4M2_E2-Key LED4 Indicate
LED5M2_E2-Key LED5 Indicate
快速入门(Quick Start)
系统下载(OS Download)
Note:LIV=Yocto Linux , UIV=Ubuntu,DIV=Debain,AIV=Android
LBV=BSP,LIV=Image
ProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagSDKCommentTest Report
AOM-3821DIV1100672025/06/16RTMRelease_NoteBaidu Password:a887 DropboxRK3588_RISC_DIV110067.xmlAsk PM for Help[Test Report]
  • Alpha:  Basic I/O function bring up by RD;
  • Beta:  Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
  • GA:  Beta version by QE verification;
  • RTM:  Beta version by SI/Power/QE verification and pre-loaded;
1、 AOM-3821 on AOM-DB3500 Usering_RKTool.
2、 AOM-3821 on AOM-DB3500 Usering bootup_sd_disk made_by SDDiskTool.
AOM-3821 (Develop Board AOM-DB3500)Support List Desocroption
DC_IN
UART_RS232(DEBUG、COM1)
Button(RST、PWR)
AUDIO_MIC1/OUT1
AUDIO_MIC2/OUT2
Display
M.2_B Key——4G/5G
[M2_E1 Key——WIFI/BT/SATA]
SPI_CN1&SPI_CN2&CN2_I2C&CN4_I2C——I2C/SPI
GMAC0/1
Video In(MIPI CSI0/CSI1)——Camera
PCIE X4
GPIO_CN3
ADC_Pin Header
Watchdog
RTC
