← Back to AOM-3821
AOM-DB3500 GMAC0/1
Contents​
  • 1Ethernet
  • 2Configure to Static IP
  • 3Configure to DHCP
  • 4Ethernet Test
Ethernet​
AOM-3821 supports two Ethernet ports (via 9696EG6A000): eth0/eth1. All ports are using the “DHCP” mode by default. The following configurations and tests are taking eth0 as an example.
Configure to Static IP​
  1. Click “Applications” -> “Settings” -> “Advanced Network Configration”.
2. Double-click “Wired Connection 1” to configure it.
Configure to DHCP​
1. Click “Applications” -> “Settings -> “Advanced Network Configration”.
Ethernet Test​
After connection, Ethernet will create a net point “eth0” and “eth1”.
# #---- Test eth0 ----# #
# ping –I eth0 www.advantech.com
# #---- Test eth1 ----# #
# ping –I eth1 www.advantech.com
