← Back to ROM-6881
ROM-6881 How to use GPIO
Contents​
  • 1Configuration
  • 2ROM-6881
  • 3SOM-DB2510 Setting GPIO
  • 4Test
  • 5GPIO Test
Configuration​
The RK3588 bank/bit notation for GPIOs must be formed as "GPIO<GPIO_bank>_<gpio_bit>"
The numeric value of GPIO is calculated as follows:
32 x (gpio_bank) + gpio_bit
gpio_bit : A0~A7 0-7 B0~B7 8-15 C0~C7 16-23 D0~D7 24-31
E.g. GPIO3_A0 becomes 96
ROM-6881​
GPIO NumberGPIO formedNumeric Representation
GPIO0Ext-GPIO0 P00493
GPIO1Ext-GPIO0 P01494
GPIO2Ext-GPIO0 P02495
GPIO3Ext-GPIO0 P03496
GPIO4Ext-GPIO0 P04497
GPIO5GPIO4_B5141
GPIO6Ext-GPIO0 P05498
GPIO7Ext-GPIO0 P06499
GPIO8Ext-GPIO0 P07500
GPIO9GPIO4_A0128
GPIO10GPIO3_C0112
GPIO11GPIO3_C1113
SOM-DB2510 Setting GPIO​
  1. Before the test, jump the GPIO0_0-GPIO0_6 and GPIO0_10 Jumper on the baseplate to 1-2.
  2. Short-circuit GPIO signals on CN9 with cable
Test​
Here we take GPIO0 of ROM-6881 as an example.
Export GPIO then you can use control GPIO from userr space through sysfs.
Export GPIO0
# echo 493 > /sys/class/gpio/export
Set GPIO direction to in/out
# echo "out" > /sys/class/gpio/gpio493/direction
Set GPIO value 0/1 if GPIO pin define is output
#  echo 1 > /sys/class/gpio/gpio493/value
Unexport GPIO0
# echo 493 > /sys/class/gpio/unexport
Used as IRQ signal
Note:You have to configure GPIO to input
#  echo "rising" > /sys/class/gpio/gpio493/edge
  • rising: Trigger on rising edge
  • falling: Trigger on falling edge
  • both: Trigger on both edges
  • none: Disable interrupt on both edges
GPIO Test​
  1. GPIO0 and GPIO1 are taken as an example: Connect GPIO0 and GPIO1
  • Export GPIO0 and GPIO1
# echo 494 > /sys/class/gpio/export
  • Set GPIO0 to output and GPIO1 to input
# echo "in" > /sys/class/gpio/gpio494/direction
  • Change GPIO0 to 1 and read GPIO1 value
# cat /sys/class/gpio/gpio494/value
1
  • Change GPIO0 to 0 and read GPIO1 value
# echo 0 > /sys/class/gpio/gpio493/value
0
2. Test GPIO mode 2
# /tools/test/adv/gpio/gpio_autotest.sh
