← Back to AOM-3841
AOM-3841 CAN FD(CAN0/1)
Contents​
  • 1CAN FD
  • 2AOM-DB3500 CAN0_1 HW Pindefine
  • 3Check Network Ports 3.1Configure
  • 4Send and Reveive Data
CAN FD​
AOM-3841 has two CAN ports. Use the “candump” and “cansend” tools directly to send and receive messages. The tools have been embedded into the system.
AOM-DB3500 CAN0_1 HW Pindefine​
PinSignalI/ODescription
1CAN0_D+I/OCAN0 Data+
2CAN0_D-I/OCAN0 Data-
3CAN1_D+I/OCAN1 Data+
4CAN1_D-I/OCAN1 Data-
5GNDGround
6GNDGround
7N/ANot Applicable
8N/ANot Applicable
Check Network Ports​
Check network ports of can0 and can1:
# ifconfig -a
can0: flags=193<UP,RUNNING,NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
can1: flags=193<UP,RUNNING,NOARP> mtu 16
Configure​
Use “ip” command to configure can port. See details of the usage of “ip link”:
# ip link help
ip link set { DEVICE | dev DEVICE | group DEVGROUP }
[ { up | down } ]
[ type TYPE ARGS ]
# ip link help can
ip link set DEVICE type can
[ bitrate BITRATE [ sample-point SAMPLE-POINT] ] |
[ dbitrate BITRATE [ dsample-point SAMPLE-POINT] ] |
[ fd { on | off } ]
For example, set can0 "birate rate” to 1000000 “dbitrate rate” to 2000000 “fd” to on
# #---- For can0 ----# #
# ip link set can0 down
# ip link set can0 type can bitrate 1000000 dbitrate 2000000 fd on
# ip link set can0 up
Send and Reveive Data​
  • As receiver
# #---- As receiver ----# #
# candump can0 &
  • As sender
# #---- As sender ----# #
# ip link set can1 down
# ip link set can1 type can bitrate 1000000 dbitrate 2000000 fd on
# ip link set can1 up
# cansend can1 123##155
# #----If no error, the receiver will receive the following data----# #
Can0 123 [01] 55
