← Back to AOM-3841
AOM-3841 Debian12 user guide
Contents​
  • 1產品特性(Features) 1.1產品官網鏈接(Product official website link)
  • 2接口布局和尺寸(Layout and Sizes) 2.1AOM-3841 Board Dimension Layout 2.2AOM-3841 Mechanical Specifications 2.3Electrocal Specifications 2.4Environmental Specifications
  • 3AOM-DB3500  Board Dimension Layout 3.1Connector Locations 3.2I/O Connector Locations 3.3Mechanical Diagram 3.4Assembly Diagram
  • 4AOM-3841 on AOM-DB3500 Connector,Jumper,Switch Settings 4.1Connector List 4.2Jumper Locations 4.3Switch Locations 4.4Button Locations 4.5LED Function List
  • 5快速入门(Quick Start) 5.1系统下载(OS Download) 5.2Debian 烧录方法(Debian flash eMMC Method)
  • 6Linux 基本使用方式(Basic usage of Linux)
  • 7Linux BSP 编译方法(Linux BSP Compile Method) 7.1Linux_BSP_User_Guide_for AOM-3841 Series-Debian12
產品特性(Features)​
  • 2.0 GHzRockchip RK3576 Arm Quad Cortex-A72 2.2GHz and Quad Cortex-A53
  • Onboard 4/8 GB LPDDR4 memory and eMMC / UFS
  • Supports HDMI, DP and 1 x 4 lane MIPI-DSI
  • Gen1, SDIO, 3 x MIPI-CSI, 3 x UART2 x GMAC, Type C, 1 x PCIe 2.1/SATA 3.1, 1 x PCIe 2.1/SATA 3.1/USB3.2
  • Supports Linux Debian12 and Android14
AOM-3841 - Advantech
接口布局和尺寸(Layout and Sizes)​
AOM-3841 Board Dimension Layout​
AOM-3841 Mechanical Specifications​
  • Dimension:RTXe form factor size:(D X W)77 x 65 mm
  • Height on Top:2mm
  • Height on Bottonm:1.5mm
Electrocal Specifications​
  • Power Supply Voltage:DC-in 5V±5%
  • Power Supply Current:
ModelMaximum modeKernel idleSleep mode
AOM-38414.92W0.76W0.08W
Test Conditions: 1. Test loading: - Maximum load mode: Running programs* - Idle mode: DUT power management off and no running any program 2. OS: Debian12 *Programs software: Burnin.sh (full loading for CPU+NPU+GPU+VPU)
Environmental Specifications​
  • Operating Temperature:0~70 °C / -40 ~ 85 °C
  • Operating Humidity: 40°C @ 95% relative humidity, non-condensing
  • Storage Temperature: -40 ~ 85 °C
  • Storage Humidity: 95% @ 60 °C
AOM-DB3500  Board Dimension Layout​
Connector Locations​
I/O Connector Locations​
Mechanical Diagram​
For more details regarding our 2D/3D models, please visit the Advantech support service website at: http://www.advantech.com .
Board Mechanical Diagram - Front
Board Mechanical Diagram – Side1
Board Mechanical Diagram - Side2
Assembly Diagram​
These figures demonstrate the order of assembly needed when attaching the thermal module and COM module to the carrier board.
AOM-3841 on AOM-DB3500 Connector,Jumper,Switch Settings​
Connector List​
LableFunctionLableFunction
DC IN4Pin Terminal Connector for DC IN(Input)CN3GPIO Pin Header
ROM-AB1RTXe connectorHDMI RXHDMI RX Connector(Input)
ROM-CD1RTXe connectorCAN0_1CAN Bus Connector
PWRBTN PHPower Button Pin HeaderHDM A TYPEHDMI Connector
RSTBTN_PHReset Button Pin HeaderTYPEC_DPDP&USB2.0+USB 3.0 Typec Connector
DEBUGDebug PortSDSD Card Connector
MIC1MIC-IN Connector(Input)MICRO USBMicro USB Connector(USB2.0 only)
LOUT1Headphones Connector(Output)USB1/2TypeA USB Connector(2xUSB2.0+USB3.0)
MIC2MIC-IN Connector(Input)SPI_CN2SPI0 Pin Header
LOUT2Headphones Connector(Output)SPI_CN1SPI1 Pin Header
PCIEA-X4PCIe x4 ConnectorGMAC0GMAC0 Connector
EDPEDP ConnectorGMAC1GMAC1 Connector
EDP BLEDP Backlight ConnectorERP DEBUGEPR MCU FW Update Connector
I2S0I2S0 ConnectorRTC BATRTC Coin Battery Connector
I2S1I2S1 ConnectorCN1Watchdog Connector
SIMSIM card ConnectorM.2_BM.2 Key-B Connector
CN2I2C Connector for I2C0M.2_E1M.2 Key-E Connector
CM1_2COM Port Port1,2 Con-nectorM.2_E2M.2 Key-B Connector(for SDIO)
CN4I2C Connector for I2C1CN6Resvered Signal Connector
CSI0_FPCMIPI FPC Connector for CSI0CN5SDIO Connector(for SD1)
CSI1_FPCMIPI FPC Connector for CSI1CN7Supply +5V Connector
CSI2_FPCMIPI FPC Connector for CSI2
Jumper Locations​
Switch Locations​
Button Locations​
LableFunctionLableFunctiion
PWR BTNPower ButtonJ8M2_E1 Power Select
RST BTNReset ButtonJ10M.2_B Power Selsct
SW1BOOT SELECT SwitchJ9UART1 to M2_E2 or M2_E1 Connector Select
SW2USB0 PWE_EN Select SwitchJ2AT/ATX Select Header
SW3USB0 OC# Select SwitchJ37GPIO4_Z_G Selection
J12EDP0/LVDS0/DSI Hot-Plug   Detect Selection HeaderJ26GPIO0_Z_G Selection
J15EDP VDD Power SelectJ28GPIO0 Selection
J16EDP Backlight Power SelectJ31GPIO4 Selection
J17Header For SD1 SelectionJ20GPIO7 Selection
J18Header For SD1_CD# SelecttionJ24GPIO7A Selection
J30Header For  EDP0_BKLT_EN and EDP0_BKLT_PWMJ25GPIO1 Selection
J22CAN0 BUS Terminal ResistorJ27GPIO1_Z_G Selection
J23CAN1 BUS Terminal ResistorJ29GPIO6 Selection
J14Header For WDT_OUT#  Link SelectionJ32GPIO5 Selection
J13Header For WDT_OUT# SelectionJ1SD0_WP Select Header
J11TYPEC_OTG_ID Selection HeaderJ5SPI1_CS#  Select Header
J6SPI0_CS#  Select HeaderJ7USB3 2.0 OTG and Host Select  Header
J35U7 mode SelectJ36U58 mode Select
LED Function List​
LocationFunction
+V12 LEDCarrier Board +V12 Indicate
+V12 SB LEDCarrier Board +V12_SB Indicate
+V3.3 LEDCarrier Board +V3.3 Indicate
+V3.3 SB LEDCarrier Board +V3.3_SB Indicate
+V5 LEDCarrier Board +V5 Indicate
+V5 SB LEDCarrier Board +V5_SB Indicate
MOD_PWR_LEDModule Power Indicate
LED1M2_E1-Key LED1 Indicate
LED2M2_E1-Key LED2 Indicate
LED3M2_B-Key LED3 Indicate
LED4M2_E2-Key LED4 Indicate
LED5M2_E2-Key LED5 Indicate
快速入门(Quick Start)​
系统下载(OS Download)​
Note:LIV=Yocto Linux , UIV=Ubuntu,DIV=Debain,AIV=Android
LBV=BSP,LIV=Image
ProductImage VersionRelease DateRelease VersionRelease notesImage DownloadBSP Download TagSDKCommentTest Report
AOM-3841DIV1100252025/09/24RTMRelease_noteBaidu Password:a887 DropboxRK3576_RISC_DIV110025.xmlAsk PM for HelpTest Report
  • Alpha:  Basic I/O function bring up by RD;
  • Beta:  Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
  • GA:  Beta version by QE verification;
  • RTM:  Beta version by SI/Power/QE verification and pre-loaded;
Debian 烧录方法(Debian flash eMMC Method)​
1、 AOM-3841 on AOM-DB3500 Usering_RKTool.
2、 AOM-3841 on AOM-DB3500 Usering bootup_sd_disk made_by SDDiskTool.
Linux 基本使用方式(Basic usage of Linux)​
AOM-3841 (Develop Board AOM-DB3500)Support List Desocroption
DC_IN
UART_RS232(DEBUG、COM1、COM2、M.2 E1)
Button(RST、PWR)
AUDIO_MIC1/OUT1 & MIC2/OUT2
Display(HDMI、DP、EDP)
M.2_B Key——5G(PCIE型)
M2_E1 Key——WIFI/BT/SATA
SPI_CN1/SPI_CN2 & CN2_I2C/CN4_I2C——I2C/SPI
GMAC0/1
CAN FD(CAN0/1)
Video In (MIPI CSI0/CSI1) Camera
GPIO CN3
ADC Pin Header
Watchdog
RTC
Linux BSP 编译方法(Linux BSP Compile Method)​
Linux_BSP_User_Guide_for AOM-3841 Series-Debian12​
