← Back to AOM-3841
AOM-3841 on AOM-DB3500 Usering RKTool.
Contents​
  • 1For example, the PC used is a laptop. The specifications are as follows:
  • 2List
  • 3The setup environment is as follows.
  • 4PC Install the driver
  • 5Enter into MASKROM mode
  • 6Go to the RKDevTool_Release folder and run the RKDevTool.exe program.
For example, the PC used is a laptop. The specifications are as follows:​
Decompress the downloaded image on the PC.
List​
1、Prepare a TYPE_C to USB cable.
2、Prepare a DC_IN 24V 60W Adapter.(Advantech Part Number:96PSA-A60W24T2-3)
3、Prepare a USB to UART console cable.
4、Prepare an HDMI monitor and plug the HDMI cable into the HDMI port on the base plate.
The setup environment is as follows.​
PC Install the driver​
1、Extract Driver Assitant_v5.13.zip and follow these steps: Mounting driver.
2、Run the installer and wait for the installation to succeed.
3、Change Tool language in config.ini, please change "Selected: to "2"
选择工具语言:Selected=1(中文)<--Chinese ;Selected=2(英文)<-- English [Language] Kinds=2 Selected=2 LangPath=Language\
Enter into MASKROM mode​
When the device boot up to android or debian, you can use ADB or Debug console, send command "reboot loader" .
Or Press "ctrl + c" key when booting into uboot, until get the following information on debug console :
Android :
Hit any key to stop autoboot: 0
rkboot # <INTERRUPT>
rkboot # loader
Debian :
rkboot # rbrom
Next:
SW1 setting: Switch all positions 1 to 6 to ON to force the device into "MASKROM" mode. After entering the MASKROM mode, switch positions 4 and 5 back to OFF.
Go to the RKDevTool_Release folder and run the RKDevTool.exe program.​
1、Ensure that the path to the burned file is correct.
2、After entering the "MASKROM" mode, click to execute and start the burning process.
Note:Suspend or shut down the virtual machine during this process; otherwise, the pop-up information may affect the burning results.
3、Please be patient. After the burning process is completed, the board will automatically restart once the burning is successful.
4、Check the system version.
