← Back to AFE-R761
AFE-R761 UART(COM1/2/3/4)
Contents​
  • 1HW Pin define:
  • 2SW Function:
  • 3Configure RS232 or RS485
  • 4Configure Parameters
  • 5Send and Receive Data
HW Pin define:​
SW Function:​
Configure RS232 or RS485​
ttyS3 and ttyS5 support only RS485 mode, whereas ttyS6 and ttyS9 support configuration for both RS232 and RS485 modes. The default mode is RS232.
Set RS232 or RS485 separately(0 means RS232;1 means RS485):
Set ttyS6 to RS232 mode and ttyS9 to RS232 mode.
# fw_setenv uart_mode_cpu 6:0,9:0
# reboot
Set ttyS6 to RS232 mode and ttyS9 to RS485 mode.
# fw_setenv uart_mode_cpu 6:0,9:1
# reboot
Set ttyS6 to RS485 mode and ttyS9 to RS232 mode.
# fw_setenv uart_mode_cpu 6:1,9:0
# reboot
Set ttyS6 to RS485 mode and ttyS9 to RS485 mode.
# fw_setenv uart_mode_cpu 6:1,9:1
# reboot
Configure Parameters​
Use “stty” command to configure serial port parameters. The commonly used parameters include “Baud rate”, “Data bits”, “Stop bits”, “Parity”, “Flow control”. See details of the usage of “stty”:
# stty --help
csN set character size to N bits, N in [5..8]
[-]cstopb use two stop bits per character (one with '-')
[-]parenb generate parity bit in output and expect parity bit in input
[-]crtscts enable RTS/CTS handshaking
For example,
set COM4 "Baud rate" to 115200 “Data bits” to 8 “Stop bits” to 1 “Parity” to None “Flow control” to None.
# stty -F /dev/ttyS3 115200 cs8 -parenb -cstopb -crtscts
Send and Receive Data​
Taking COM4 as receiver and COM2 as sender:
# #---- COM4 as receiver ----# #
# stty -F /dev/ttyS3 115200 cs8 -cstopb -parenb -crtscts
# stty -F /dev/ttyS5 115200 cs8 -cstopb -parenb -crtscts
# echo pass > /dev/ttyS5
# #----If no error, the receiver will receive “pass”----# #
pass
