AFE-R761 Debian 12 user guide
Contents
- 1产品特性(Features) 1.1产品官网链接(Product official website link)
- 2接口布局和尺寸(Layout and Sizes) 2.1AFE-R761接口布局图 Board Dimension Layout 2.2接口尺寸 Board Dimension 2.3接口引脚定义 (Connector Pin definitions)
- 3安装(Installation) 3.1Exploded View 3.2Remove the Bottom Cover 3.3M.2 Module Installation 3.4GMSL/AHD board Installation 3.5DIN RAIL Kit Installation 3.6Wall Mount Kit Installation
- 4快速入门 (Quick Start) 4.1系统下载 (OS Download) 4.2Debian 燒錄方法 (Debiand Flash eMMC Method)
- 5Linux基本使用方法 5.1AFE-R761 Function:
- 6Linux BSP编译方法(Linux BSP Compile Method) 6.1Linux_BSP_User_Guide_for_ASR-A501_series-Debian12
产品特性(Features)
- Rockchip RK3588 Arm Quad Cortex-A76 2.4GHz and Quad Cortex-A55 1.8 GHz
- Built-in NPU with processing performance of up to 6 TOPS
- Onboard 8/16GB LPDDR4 memory and 64/128GB eMMC
- Supports 8K @ 60 fps H.265/VP9 video decoding and 8K @ 30 fps H.265/H.264 video encoding
- Dedicate I/Os for AMR : 1 x 2.5GbE, 3 x GbE, 2x USB3.2, 4 x USB2.0, 2 x CAN FD, 4 x RS-485, 8bit isolated DIO
- 12-24V DC In, contact: 8KV, air: 15KV, ESD protection
- Provides a M.2 E Key with PCIE 2.1, USB 2.0 signal and a M.2 B Key with PCIE 2.1/SATA, USB 2.0 signal
- Supports Linux Debian12, Android14
Jumper & Switches
The AFE-R761 has a number of jumpers that allow you to configure your system to suit your application. The table below lists the functions of the various jumpers.
Miscellaneous Selection Jumper: SW1
Unscrew the 4 screws on the rear cover, and remove the rear cover. Please refer to the picture to find J1, J2 location.
| Jumper List | |
| Position | Description |
| SW1 | COM2/4 485 Terminal |
| SW2 | CAN FD Terminal |
| J1 | USB0 OTG Mode selection,default USB3.0 host |
| J2 | ATX/AT Mode Selection,defa |
安装(Installation)
Exploded View
快速入门 (Quick Start)
系统下载 (OS Download)
Note:LIV=Yocto Linux , UIV=Ubuntu,DIV=Debain,AIV=Android
LBV=BSP,LIV=Image
| Prduct | Image Version | Release Date | Release Version | Release notes | Image Download | BSP Download Tag | SDK | Comment | Test Report |
| AFE-R761-UxA1 AFE-R761-UxD1 | DIV110057 | 2025/04/08 | RTM | Release_note | Baidu Password:a887 Dropbox | RK3588_RISC_DIV110057.xml | Ask PM for Help | Test Report | |
| AFE-R761-UxB1 | DIV110077 | 2025/09/19 | RTM | Release_note | Baidu Password:a887 Dropbox | RK3588_RISC_DIV110077.xml | Ask PM for Help | Test Report | |
| AFE-R761-UxC1 | DIV110079 | 2025/09/25 | RTM | Release_note | Baidu Password:a887 Dropbox | RK3588_RISC_DIV110079.xml | Ask PM for Help | Test Report |
- Alpha: Basic I/O function bring up by RD;
- Beta: Basic I/O function、performance and middleware verified by RD. Peripherals integrated;
- GA: Beta version by QE verification;
- RTM: Beta version by SI/Power/QE verification and pre-loaded;
For BSP files, Please contact us.
Using bootup sd disk made_by SDDiskTool for ASR-A501.
Linux基本使用方法
AFE-R761 Function:
- DC-IN
- HDMI
- USB1/2
- ETH
- Audio
- Power Button
- CAN/DEBUG
- UART(COM1/2/3/4)
- PCIE_M.2_E KEY
- PCIE_M.2_B KEY
- 4G/5G
- RST
- SD
- RTC_BAT
- Watchdog
- TPM
- RECOVERY
- USB3/4/5/6
- DI/DO
- GMSL & AHD
